hi everyone i m new to the site
i need some help whit the retrofitting i have have follow all the steps what i found on the forums done the following change headlights from halogen to bi xenon get the kufatec connector hares connect all the pins on the brown plug and red plug change a new BCM from 8K907063K TO 8K907063DH remove the component protectin from the new BCM all the lights works DRL LED LOW BEAM DEEP BEAM ..
But i have lose power steering .. and i have the following codes if i change back the old BCM power steering works but no lights only low beam .. i don't know were to go next i try coding whit ODIS but no luck fixing the power steering..
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000789478902
Coding: 260000118034AF000281408000001D0D0F1D470803010201000008004400030100000024000000
Shop #: WSC 00046 123 12345
VCID: 78FFE88FCB88234633-802C
Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 111220 H11 0050
Serial number: 90243015111129133013
Coding: 01DD13
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 20023848
Coding: 024D25
Component: E1 - LDS H03 0031
Serial number: 00000000001201123039
8 Faults Found:
01312 - Powertrain Data Bus
Reset counter: 49
Mileage: 219286 km
Date: 2020.11.16
Time: 13:30:31
01229 - A/C Humidity Sensor (G260)
Reset counter: 49
Mileage: 219286 km
Date: 2020.11.16
Time: 13:30:31
03608 - Humidity Sensor in Fresh Air Intake Duct
Reset counter: 49
Mileage: 219286 km
Date: 2020.11.16
Time: 13:30:31
03124 - Terminal 30 - 3
Reset counter: 49
Mileage: 219286 km
Date: 2020.11.16
Time: 13:30:32
00497 - Sensor for Vehicle Leveling; Rear
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 49
Mileage: 219286 km
Date: 2020.11.16
Time: 13:30:32
01543 - Parking Aid Warning Chime (H15)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 49
Mileage: 219286 km
Date: 2020.11.16
Time: 13:30:32
01625 - Front Parking Aid Warning Chime (H22)
Reset counter: 49
Mileage: 219286 km
Date: 2020.11.16
Time: 13:30:32
Reset counter: 49
Mileage: 219286 km
Date: 2020.11.16
Time: 13:57:24
