New here , not sure what I'm doing but would like to learn.
Chumstick
C?ID=85038
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 75 77
VIN: 1VWCN7A36EC068175   Mileage: 148130km-92043miles
   Component: R4 2.0l TDI   H24 9981
   Revision: 71H24---    Serial number:
   Coding: 001D0012042400008000
   Shop #: WSC 04906 444 00000
   ASAM Dataset: EV_ECM20TDI01103L997009J 004004
   ROD: EV_ECM20TDI01103L997009H.rod
   VCID: 3B7EC454B283955E06-806E
5948 - EGR Valve 2 (N213)
          P045F 00 [237] - Stuck Closed
                    Mileage: 148097 km
                    Date: 2020.11.09
                    Time: 22:02:44
                    Engine speed: 1563.00 /min
                    Normed load value: 49.0 %
                    Vehicle speed: 82 km/h
                    Coolant temperature: 87 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 14.460 V
                    Air mass: actual value (mg/stroke): 581.1 mg/stroke
                    Specified value of low pressure EGR valve: 100.00 %
                    Actual value of low pressure EGR valve: 83.96 %
                    Low-pressure EGR valve: offset closed: 0.06 %
                    Low-pressure EGR valve: status-Bits 0-7: 0
                    Low-pressure EGR valve: status-Bits 0-7: 55
                    Low-pressure EGR valve: status-Bits 0-7: 7
                    Low-pressure EGR valve: uncond voltage: 1479.6 mV
5947 - EGR Valve 2 (N213)
          P045E 00 [237] - Stuck Open
                    Mileage: 148097 km
                    Date: 2020.11.09
                    Time: 22:02:44
                    Engine speed: 1562.50 /min
                    Normed load value: 64.3 %
                    Voltage terminal 30: 14.420 V
                    Air mass: actual value (mg/stroke): 257.5 mg/stroke
                    Specified value of low pressure EGR valve: 16.00 %
                    Actual value of low pressure EGR valve: 27.44 %
                    Low-pressure EGR valve: status-Bits 0-7: 71
                    Low-pressure EGR valve: status-Bits 0-7: 4
                    Low-pressure EGR valve: uncond voltage: 3175.6 mV
Readiness: 1 2 0 0 1
First time I have posted was wondering what I need or where to start to sort this problem out. Not even sure this is where I should have started if this is the wrong place on this site to start I apologize now. Looked around the web and haven't seen anything relating the codes on this car other then generic things relating to egr system. I believe this is the egr on the back side of the motor, car seems to run fine and would like to understand the system better before I just start replacing parts, plus it looks like I have to tell this car when I put new parts on it.
Thanks for any help .
2014 US model car with 92,000 miles on it, with Dieselgate fixes. Emissions-related things like EGR should be under the extended Dieselgate warranty, I think.
Chumstick
C?ID=85038
Thank you and you. Checked this out with dealer and the car is covered. Have made an appointment and we'll see what happens.
