1.9Tdi fuel filter check valve?
Orchid70
Sweden
C?ID=354348
Hi
Im trying to get a Golf V 2007 1.9Tdi to start. It died intermittent during drive - but now it wont even start.
There are no fault codes.
Suspecting it could perhaps be the check valve in the lid on the fuel filter holder.
They are not easy to find - so Id like to find a picture on a working check valve. Any one have one, they could take a picture of (the inside of the filter holder)?
It has this number: 1K0127400K
And it is the type A.
Picture from Amazon: https://www.amazon.com/Genuine-OE-Volkswagen-Housing-1K0127400K/dp/B00BIPTFKC
Orchid70
Sweden
C?ID=354348
I have ordered a used fuel filter holder.
I can fill the fuel filter cup with fuel, with 12V directly on pump. Still couldnt start the engine yesterday.
Today I wanted to be sure the timing was correct and was ready to read measuring blocks during crank - when the bloody engine started!
Pump in tank went on when I turned ignition on, then engine started.
So I run inside to get low amp probe and SnapOn - the tank pump was not running!
I took off the electric connector on tank pump and the engine continued to run.
I turned off the engine. Started it again, without tank pump connected.
The fuel filter holder will be run empty by the tandem pump.
Am I thinking correct here:
There must be a pressure switch in the fuel pump in the tank - that switches off when the fuel pressure is up in the fuel filter holder.
If a check valve in the filter holder lid is stuck closed - the pump in the tank will not turn on (its brand new).
But I cannot find ANY information on the check valve on a fuel filter holder modell A, where the valve is placed within the lid construction (and not the separate type placed above the lid, that can be changed separately).
Here is a Autoscan - with a fault code from me disconnecting the electric connector:
Monday,16,November,2020,14:00:32:18201
Dealer/Shop Name: Firma Johannes Bruun
Workshop Code: 000 02013 000000
VIN: WVWZZZ1KZ7W264681   License Plate: BWH469
Mileage: 263050km-163451mi   Repair Order:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ7W264681   Mileage: 263050km-163451miles
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 KG    HW: 03G 906 021 AN
   Component: R4 1,9L EDC  000SG  9244
   Revision: --H07---    Serial number: VWZ7Z0G8112637
   Coding: 0000071
   Shop #: WSC 01392 785 00200
   VCID: 6E85CCE2FC9374EBB0F-803A
   Part No: 1K0 907 379 P
   Coding: 0017025
   VCID: 3FDB41A6EB79CD636B9-806A
   Part No SW: 1K0 820 047 FT    HW: 1K0 820 047 FT
   Component: Climatic PQ35   141 0909
   Revision: 00141027    Serial number: 00000000000000
   VCID: 7BA3F5B6BFE11143071-802E
   Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006938468
   Coding: 08890F2700041500471400001400000000097B075C0001
   Shop #: WSC 00000 785 00200
   VCID: 6B83C5F6CF8181C3971-803E
   Component: Wischer 180407 021  0501
   Coding: 00038805
   Component: 37 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD15ZV80
   Coding: 0013111
   Shop #: WSC 01373 785 00200
   VCID: 3D273BAEE175DF73795-8068
   Subsystem 1 - Serial number: 6332MSME177E4B65Q
   Subsystem 2 - Serial number: 6342MSME17101C600
   Subsystem 3 - Serial number: 6352QSME246D2369M
   Subsystem 4 - Serial number: 6362QSME26724D7FY
   Part No SW: 1K0 953 549 BB    HW: 1K0 953 549 BB
   Component: Lenksäulenmodul 036 0070
   Coding: 0000002
   Shop #: WSC 00011 768 00200
   VCID: 73B3DD9697B159035F1-8026
   Part No SW: 1K0 920 853 Q    HW: 1K0 920 853 Q
   Revision: V0003000    Serial number: VWZ7Z0G8112637
   Coding: 0003103
   Shop #: WSC 02013 222 99650
   VCID: 38292ABACE57FA5BAA3-806C
00771 - Fuel Level Sensor (G)
                    Fault Status: 00101010
                    Reset counter: 75
                    Mileage: 263053 km
                    Time: 13:47:05
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 080407F1001349
   Coding: 3D0F034007000002
   VCID: 2F3B11E63B193DE3FB9-807A
   Component: IMMO            VDD 1610
   Component: Tuer-SG         005 0987
   Coding: 0000180
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   Shop #: WSC 00000 028 00001
   VCID: 34311E8AD23F1E3B86B-8060
   Part No: 1K0 959 433 CP
   Coding: 81C802087F2D8405484BC6F010CC
   Shop #: WSC 40950 222 21286
   VCID: 0059825AD607729B523-8054
   Subsystem 2 - Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Subsystem 3 - Part No: 1K0 951 178 A
   Component: Innenraumueberw.003 0203
   Coding: 0000180
   VCID: 392F2FBEF55DE35355D-806C
   Part No SW: 1K0 035 186 T    HW: 1K0 035 186 T
   Component: Radio BVX       034 0046
   Revision: 00034000    Serial number: VWZ1Z2G4739028
   Coding: 0020200
   VCID: 372B2986C349F523A39-8062
End----------(Elapsed Time: 01:03, VBatt start/end: 12.6V/12.4V)-----------
Fred's Imports
Vermont, USA
C?ID=16454
In tank pump is a common failure. Use a scope to see the commutator/brushes wear.
Normally the engine will continue to run if the in tank pump fails but the engine will not restart.
Orchid70
Sweden
C?ID=354348
I failed to mention that the in-tank pump is changed.
I have even taken an other tandem pump - with same result.
This is why:
The fuel filter was changed shortly before this intermmitent engine stalling started. I checked inside the fuel filter holder some days ago (when a friend mentioned the valve stucking for him, once he had changed filter, and could not start the car what ever he did - with the new filter house, he could see that the valve looked different, had different position) - and could find that there was only diesel inside the filter when I lifted it up, no diesel inside the return hose or feed hose to tandem pump. When detatching the return hose, I felt there was vacuum.
So thats when I filled the filter cup with 12V directly on the tank pump. I put filter holder together and started the electric pump with computer - and checked if fuel came out at tandem pump. It did. Thats when I changed tandem pump.
Activating the in-tank pump with computer only works if I have had the system open. But Im guessing that it has a pressure switch somewhere. Something is stopping the in-tank pump from running.
Orchid70
Sweden
C?ID=354348
My theory on some pressure valve in the filter housing was not correct. The filter house is changed.
I have been able to measure the pressure at the tandem pump now: 5 bar (72 psi) at 1500 rpm. Around 1 bar at idle.
BUT: the only time I can activate the in tank pump is, if I have had the system open (change parts) or the car has been standing for a day or two.
The I can activate the pump with VCDS and I can start the car - again I run inside and took the SnapOn and tried to measure current on supply wire on in tank pump -> NOTHING!
Now I have to wait couple of days again to be able to activate it with the computer to see that there really is some amps from the pump....
The relay is clicking (I have tested it also) - and I have changed places with the other identical relay. So relay is not the problem.
The tank pump just wont run when the engine is on.
In VCDS, I can see that there is between 12,29-12,44V in the field "Fuel pump status" when the engine is running. Where is that voltage taken/measured from? Battery?
But the pump doesnt produce any current.
Its a brand new pump.
Any ideas?
Orchid70
Sweden
C?ID=354348
Solved the mystery.
The 12V feed pin on the connector was damaged. When I wasremoving the connector from the new pump, the locking tab broke. When I was trying to remove the pins from the connector - the plus feed wire broke on me.
It was corroded as hell!! It was just not possible to see when buried inside the connector housing.....
This is what the pin looked like on the old pump:
When the wire was not used for some time - it did pass the voltage - but when the engine was on, it didnt.
I did also connect an extra ground wire to the pump due to it having over 1 ohm resistance. And it was the same, attatched on the corroded 12 V and on chassi - there was voltage. Attatched on the corroded 12 V and ground on the connector - there was not much of voltage. But if that had to do with the corroded feed wire - I do not know.
