Hi all.
I’m having problems with my (wife’s) 2009 TTS Roadster with CDLB engine and I hope someone can help me.
Bit of history - We’ve had the car about a year, but not done many miles this last year! Done full service and other things in the months after buying it. Rear diff oil, Haldex oil and filter, gearbox oil, engine oil and filter, fuel filter, air filter, spark plugs. Engine was all fine, but then recently I became aware of a very slight hunting at idle. So I replaced the PCV valve (turned out the replaced one was the originally factory fitted one) and replaced the fuel pump cam follower which I had not been aware of before.
This is when things started going wrong. Straight away I got error codes 012599 (basic setting missing) and 004248 (Position Sensor open or short). Didn’t know what to do about them at that point. My first assumption was that I must have dislodged something so having worked out where G336 and V471 (Intake Manifold Flap Control Motor and Valve combined unit) is located I took it out, cleaned the contacts, moved the rod to the manifold up and down, even took the unit apart – everything seemed ok. Put it all back together again and refitted. Now I was getting error codes 012691 (Open Stop outside of Valid Range) and 004248 (Position Sensor open or short).
The only instructions for Basic Setting I found are here –
Basic Setting 2.0 TFSI
Although CDLB is not mentioned, the engine is very similar and I guess process should be similar and in fact the Documented Basic Setting when I went into Module 1, Basic Settings is using the same Group (142). I tried the Basic Setting and it would not work. Kept coming up with ERROR in Box 4.
Driving around with these Intake Runner errors I started to get Misfire errors 0768 (Multiple) and 0769 (No. 1). Tried clearing multiple times in vain hope they would go away!
I now assumed I needed to replace the Intake Manifold Flap Control Motor and Valve 06F133482E so I bought a new one and fitted it. On completion I performed the Basic Setting and it worked. I got ‘ADP OK’.
Took it for a test drive and I still have the misfire. So back on the VCDS and I have errors 012691 (Open Stop outside of Valid Range) and 004248 (Position Sensor open or short) back again and the usual misfire codes (multiple and No.1)
So now I switch Coil Packs on No.1 and No.3, clear codes and take for another test drive to see if misfire stays on No.1 or moves to No.3. Lo and behold now it’s No.4!
So what next?? Any ideas gratefully received. Thanks.
Latest scan attached.
Saturday,14,November,2020,16:26:08:40778
VCDS Version: 20.4.2.0 (x64)
VIN: TRUZZZ8J19101xxxx License Plate:
Mileage: 115020km-71470mi Repair Order:
Chassis Type: 8J (1K0)
Scan: 01 03 08 09 10 14 15 16 17 19 22 25 26 37 42 44 46 47 52 55
56 77
VIN: TRUZZZ8J19101xxxx Mileage: 115020km-71470miles
Address 01: Engine (CDL) Labels:. 06F-907-115-CDL.clb
Part No SW: 8J0 907 115 Q HW: 8J0 907 115
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0H7FNS04W
Coding: 0113000C180F0060
Shop #: WSC 41059 344 603265
VCID: 3A7B087275C0D3561D-806E
012691 - Intake Manifold Runner Control
P3193 - 002 - Open Stop outside of Valid Range
Fault Status: 01100010
Mileage: 115020 km
Date: 2020.11.14
Time: 16:05:08
Temperature: 77.0∞C
Temperature: 30.0∞C
Absolute Pres.: 980.0 mbar
Voltage: 12.319 V
004248 - Intake Manifold Tuning Valve Position Sensor (G336)
P1098 - 001 - Open or Short to Plus
Fault Status: 01100001
Mileage: 115020 km
Date: 2020.11.14
Time: 16:05:08
Temperature: 77.0∞C
Temperature: 30.0∞C
Voltage: 12.319 V
P0300 - 001 -
Mileage: 115021 km
Date: 2020.11.14
Time: 16:15:50
RPM: 2667 /min
Load: 100.0 %
Speed: 112.0 km/h
Temperature: 84.0∞C
Temperature: 20.0∞C
Voltage: 13.843 V
000772 - Cylinder 4
P0304 - 001 - Misfire Detected
Mileage: 115021 km
Date: 2020.11.14
Time: 16:15:50
RPM: 2667 /min
Load: 100.0 %
Speed: 112.0 km/h
Temperature: 84.0∞C
Temperature: 20.0∞C
Voltage: 13.843 V
Readiness: 0010 0101
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 614 517 A HW: 8J0 614 517 A
Component: ESP MK60E1 0020
Revision: 00H60001
Coding: 0091958
Shop #: WSC 01236 785 00200
VCID: 2B553D368A9A7ADE96-807E
Address 08: Auto HVAC Labels: None
Part No SW: 8J0 820 043 AG HW: 8J0 820 043 AG
Component: J255 Klima 1 Zone 0080
Revision: 00H08006 Serial number: 00000001109807
Coding: 1574148
VCID: 6BD5FD364A1ABADED6-803E
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008938139
Coding: 15060E8280141C80CF18000A1800000000084E075B260802800000000000
VCID: 489F62BA3B2CB1C69B-801C
Subsystem 1 - Part No: 8J2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer AU354 H08 0070
Coding: 00064784
Shop #: WSC 01236
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0140
Revision: 11001001 Serial number: 36861125700145
Coding: 00000B
Shop #: WSC 06314 000 00000
VCID: 489F62BAFB2CB1C69B-801C
Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
Part No SW: 8J0 910 376 B HW: 8J0 907 376 B
Component: J250 Raddaempfung 0050
Revision: --H18--- Serial number: 190DPH 8218095
Coding: 0000034
VCID: 2E533422B9880FF6B1-807A
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -t Airbag 9.43 H02 0020
Revision: 93H02002 Serial number: 0036K0036E4D
Coding: 0011636
VCID: 79F9D77E3046184E54-802C
Subsystem 1 - Serial number: 6332DRB407AA4B2D/
Subsystem 2 - Serial number: 6342DRB407CC04A1U
Subsystem 3 - Serial number: 63747RB4041BD857W
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0003011
VCID: 41897F9E1816808E5C-8014
Component: E0221 H06 0030
Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb
Part No SW: 8J0 920 980 A HW: 8J0 920 980 A
Component: KOMBIINSTR. VDO H14 0330
Revision: D0H14006 Serial number: 2247H006002211
Coding: 0069408
Shop #: WSC 14557 067 57207
VCID: 2F6D2926BE8206FEBA-807A
00003 - Control Module
014 - Defective
Fault Status: 01101110
Mileage: 110750 km
Date: 2017.10.27
Time: 00:00:26
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K087228361
Coding: E9AB1F265006025101
VCID: 35611B4E5CDE3C2EF0-8060
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
Component: Haldex 4Motion 3016
Coding: 0000005
VCID: 43857596020A929E4E-8016
Revision: D0H14006 Serial number: AUX7Z0H7FNS04W
Address 26: Auto Roof Labels: 8J7-959-255.lbl
Part No: 8J7 959 255 B
Component: 256 VSG TT H14 0110
VCID: 3E73046269E8FF7621-806A
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8J0 035 193 D HW: 8J0 035 193 D
Component: RNS-E PU EU H07 0260
Revision: 0000013S Serial number: AUZBZ7ND403133
Coding: 0619717
Shop #: WSC 07728 004 104857
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
007 - Short to Ground
Fault Status: 01100111
Reset counter: 102
Mileage: 115014 km
Date: 2020.11.13
Time: 19:00:55
Mileage: 115010 km
Count: 1311
Clock: 19:00
02444 - Disk Drive Load / Eject Malfunction
Reset counter: 142
Mileage: 115014 km
Date: 2020.11.14
Time: 10:54:53
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8J7 959 801 E HW: 8J7 959 801 E
Component: Tuer-SG H02 0070
Coding: 0000637
Part No: 8J0 909 144 C
Component: EPS_ZFLS Kl. 237 2302
Revision: 00H15000
VCID: 306F2A5AA3BC1906A3-8064
Address 46: Central Conv. Labels:. 8J0-959-433.lbl
Part No: 8J0 959 433 B
Component: KSG H11 0080
Coding: 1890300241182D098505489AD633
Subsystem 1 - Part No: 1K0 951 605 F
Component: LIN BACKUP HORN H01 0008
Subsystem 2 - Part No: 8J0 951 177
Component: DWA-Sensor H03 0020
Address 47: Sound System Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 D HW: 8J0 035 223 D
Component: J525 Amp High H04 0150
Revision: PROD_01 Serial number: 00000000006525
Coding: 0136115
Shop #: WSC 19378 444 84935
VCID: 2541CB0EEC7E4CAE40-8070
16349 - Control Module - Error in Output Stage
Fault Status: 00101110
Fault Frequency: 29
Reset counter: 228
Mileage: 37160 km
Date: 2011.09.09
Time: 01:48:58
00871 - Bass Speaker Front Right (R23)
Fault Status: 00111011
Reset counter: 141
Part No SW: 8J7 959 802 E HW: 8J7 959 802 E
Coding: 0000636
VCID: 3F8D79666EE2F67E2A-806A
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H02 0010
Coding: 0000011
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0619717
Reset counter: 102
Mileage: 115014 km
Date: 2020.11.13
Time: 19:00:55
Mileage: 115010 km
Count: 1311
Clock: 19:00
Reset counter: 142
Mileage: 115014 km
Date: 2020.11.14
Time: 10:54:53
Part No SW: 8P0 862 335 S HW: 8P0 862 335 S
Component: FSE_256x BT H34 0550
Revision: 00000000 Serial number: 00000005036919
Coding: 0011402
VCID: 46836C823138A7B669-8012
End-------------------------(Elapsed Time: 02:18)--------------------------
