2004 A6 C5 Allroad - Suspension issues, had this car for 14 years - moving to DIY to keep her going....😬
Bigbarper
West Sussex, UK
C?ID=421579
OK I'm new to all this VCDS stuff so go easy on me pls.
I've changed the piston ring in the compressor and replaced the front right air spring but......in the process the ride height calibration is now all over the place.
Tried the suspension recalibration process - followed the video - but when I go to do the adaptation after login (program crashes sometimes) I get an error along the lines of control channel not found? soz I don't recall the exact message.
Anyway I can 'see' the individual spring heights under measured blocks and I can run the step test program although the lowering steps doesn't appear to be doing much.
Many thanks for looking.
I've also got a 2015 A6 C7 BiTurbo .... seem to have a bit of a soft spot for the Allroad 😁
Here are the scan files.
Friday,13,November,2020,14:21:32:28801
VIN: WAUZZZ4B94N042167   License Plate: YE04XSR
Mileage: 1551567   Repair Order:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
          75 76 77
Address 01: Engine        Labels: 059-907-401-AKE.clb
   Part No: 8E0 907 401 J
   Component:  2.5l/4VTEDC G000AG  0005
   Coding: 06006
   Shop #: WSC 02334
   VCID: 2C010FA2EF1C3F7BDEB-4B1E
   Subsystem 1 - Part No: 00006059
   Component: 130 106LC150_1.V79730927389
   WAUZZZ4B94N042167     AUZ7Z0C2474335
00542 - Needle lift Sensor (G80)
Readiness: 0 0 X X X
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 4Z7 927 156 N
   Component: AG5 01V 2.5lTDI RdW 2222
   Coding: 00001
   VCID: 51FF7E56A8FE32938DD-5184
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 4Z7 907 389 A
   Component: ABS/ESP allrad      D56
   Coding: 06457
   Shop #: WSC 02334
   VCID: 4ACD693A45A8014BCC7-5160
Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
   Part No: 4B0 820 043 AR
   Component: A6-Klimavollautomat 0208
   Coding: 00104
   VCID: 6A8DC9BA2558E14BEC7-2580
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4Z7 959 655 H
   Component: Airbag 8.4EP        3000
   Coding: 0001106
   Shop #: WSC 02334 785 00200
   VCID: 54F1774292EC47BBA6B-5184
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4B0 920 981 J
   Component: KOMBI+WEGFAHRS. VDO D14
   Coding: 04460
   Shop #: WSC 01294
   VCID: 2D0702A6D4063673C95-5160
Address 34: Level Control        Labels: 4Z7-907-553.lbl
   Part No: 4Z7 907 553 F
   Component:  - 2C1A1          D060
   Coding: 25500
   Shop #: WSC 02334
   VCID: 48C953325BA4F35BDA3-513C
01400 - Suspension Level Control
            11-10 - Control Limit Not Reached - Intermittent
Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
   Part No: 4B0 962 258 N
   Component: Zentralverrieg.,DWA D38
   Coding: 07947
   Shop #: WSC 00673
   VCID: 343117C2371C67BB86B-4EEA
01572 - Alarm triggered by Door Contact Switch; Passenger Side
            35-00 - -
01374 - Alarm triggered by Terminal 15
            35-00 - -
01370 - Alarm triggered by Interior Monitoring
            35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
            35-00 - -
00955 - Key 1
            09-00 - Adaptation Limit Surpassed
            76-10 - Terminal 30 missing - Intermittent
Address 45: Inter. Monitor        Labels: 4B0-951-178.lbl
   Part No: 4B0 951 178 A
   Component: Innenraumueberw.    D04
   Coding: 00102
   Shop #: WSC 02334
   VCID: 2615FD8AF1C0052B08F-50D0
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00030
   Shop #: WSC 02334
   VCID: 04518702273C173B76B-4AE0
   Part No: 4B0 035 195 Q
   Component: symphony II PM6    0410
   Coding: 02601
   Shop #: WSC 00045
   VCID: 2E0505AAD9304D6BF0F-5020
Address 76: Park Assist        Labels: 8E0-919-283-8E2.lbl
   Part No: 8E0 919 283
   Component: Parkingsyst. A6 RDW D09
   Coding: 01186
   Shop #: WSC 02334
   VCID: 6D87C2A614B6F673895-513C
End----(Elapsed Time: 04:43, VBatt start/end: 11.9V/11.7V. VIgn 11.6V)-----
Friday,13,November,2020,16:54:27:28801
Adaptation Channel 001:
Stored value
  ERROR:
  Channel 01
  Not
  Available
                Address 34: Level Control  (4Z7 907 553 F)
16:55:46
  21.0 mm   Height Front1
  25.0 mm   Height Front2
  12.0 mm   Height Rear1
  35.0 mm   Height Rear2
  35.0∞C   Pump temp (5-95C)
  6.84 bar   Reservoir pressure (3.58-15.96 bar)
  OFF   Reservoir valve OFF=Closed
  OFF   Pump ON|OFF
16:55:50
  OFF   Pump ON|OFF
Control Module Part Number: 4Z7 907 553 F
  Component and/or Version:  - 2C1A1          D060
           Software Coding: 25500
            Work Shop Code: WSC 02334
            08-10 - Control Limit Surpassed - Intermittent
Address 34: DTCs cleared
Is the large discrepancy between the rear heights real?
Bigbarper
West Sussex, UK
C?ID=421579
Hi Uwe many thanks for looking, I am measuring (top of rim to underside of arch trim) a real difference of 25mm between the rears.
Currently with car at level 2 I have rim to trim distances as follows.
FL 160 FR 170
RL 180 RR 205
Bigbarper
West Sussex, UK
C?ID=421579
Had another go at the suspension calibration, got to commence a read of channel 01 but before a value was displayed I got the 'channel not available error' I was receiving yesterday.
Also a couple of new error codes one of which I could not erase.
Here are the scans.
Eh Noobie Question, Do I need to delete the old logs to get the correct date stamp on todays logs??
Friday,13,November,2020,16:47:40:28801
                      VCID: 48C953325BA4F35BDA3-5160
Friday,13,November,2020,17:13:16:28801
17:13:10
  -4.0 mm   Height Front1
  6.0 mm   Height Front2
  -2.0 mm   Height Rear1
  12.0 mm   Height Rear2
  19.0∞C   Pump temp (5-95C)
  OFF   Pump ON|OFF
Friday,13,November,2020,17:24:44:28801
17:24:40
  37.0∞C   Pump temp (5-95C)
  7.81 bar   Reservoir pressure (3.58-15.96 bar)
  OFF   Pump ON|OFF
Friday,13,November,2020,17:26:23:28801
Stored value
  ERROR:
  Channel 01
  Not
  Available
          75 76 77
   Coding: 06006
   Shop #: WSC 02334
   Coding: 00001
   Coding: 06457
   Shop #: WSC 02334
   Coding: 00104
   Coding: 0001106
   Coding: 04460
   Shop #: WSC 01294
   Coding: 25500
   Shop #: WSC 02334
   Coding: 07947
   Shop #: WSC 00673
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
00955 - Key 1
   Coding: 00102
   Shop #: WSC 02334
   Coding: 00030
   Shop #: WSC 02334
   Coding: 02601
   Shop #: WSC 00045
   Coding: 01186
   Shop #: WSC 02334
End----------(Elapsed Time: 04:38, VBatt start/end: 12.7V/12.6V)-----------
17:38:00 Group 005: Suspension unit extension
  134.0  Front1 no units
  140.0  Front2 no units
  140.0  Rear1 no units
  159.0  Rear2 no units
17:38:03 Group 005: Suspension unit extension
17:38:23 Group 004: Level control sensors
  -11.0 mm  Height Front1
  -1.0 mm  Height Front2
  -6.0 mm  Height Rear1
  4.0 mm  Height Rear2
17:38:34 Group 003
  Not Oper.  Status UpButton Not Oper.|Activated
  -  Duplicate UpButton?
  Not Oper.  Status DnButton Not Oper.|Activated
  Relay OFF  Pump relay OFF|ON
17:38:44 Group 002
  Door Closed  Door status Open|Closed
  Trailer: No  Trailer status No
  4.95 V  Voltage3 (4.95V)
  -  [Text 000 089]
17:38:55 Group 001
  11.77 V  Voltage1 (varies)
  12.36 V  Voltage2 (varies)
  0.0 km/h  Speed Km/h
  Term 50 Off  (Term. 50 OFF)
17:42:20 Group 004: Level control sensors
  22.0 mm  Height Front1
  23.0 mm  Height Front2
  15.0 mm  Height Rear1
17:42:20 Group 005: Suspension unit extension
  166.0  Front1 no units
  163.0  Front2 no units
  159.0  Rear1 no units
  186.0  Rear2 no units
17:42:20 Group 006
  62.0∞C  Pump temp (5-95C)
  6.18 bar  Reservoir pressure (3.58-15.96 bar)
  OFF  Pump ON|OFF
17:44:17 Group 004: Level control sensors
  10.0 mm  Height Front1
  19.0 mm  Height Front2
  13.0 mm  Height Rear1
  37.0 mm  Height Rear2
17:44:17 Group 005: Suspension unit extension
  155.0  Front1 no units
  158.0  Front2 no units
  158.0  Rear1 no units
  188.0  Rear2 no units
17:44:17 Group 006
  45.0∞C  Pump temp (5-95C)
  8.14 bar  Reservoir pressure (3.58-15.96 bar)
  OFF  Pump ON|OFF
17:46:54 Group 004: Level control sensors
  15.0 mm  Height Front2
  11.0 mm  Height Rear1
  39.0 mm  Height Rear2
17:46:54 Group 005: Suspension unit extension
  146.0  Front1 no units
  155.0  Front2 no units
  155.0  Rear1 no units
  189.0  Rear2 no units
17:46:54 Group 007: Shock valve status (ON=OPEN)
  OFF  Front valve1 ON|OFF
  OFF  Front valve2 ON|OFF
  OFF  Rear valve1 ON|OFF
  OFF  Rear valve2 ON|OFF
Saturday,14,November,2020,13:23:41:28801
Stored value
  ERROR:
  Channel 01
  Not
  Available
Adaptation Channel 002:
Stored value
  ERROR:
  Channel 02
  Not
  Available
Stored value
  ERROR:
  Channel 02
  Not
  Available
Adaptation Channel 003:
Stored value
  ERROR:
  Channel 03
  Not
  Available
Adaptation Channel 004:
Stored value
  ERROR:
  Channel 04
  Not
  Available
OK, then the readings you previously posted are plausible.
But why are you measuring from "top of rim"? You're supposed to measure from the axle centerline, like this:
Bigbarper
West Sussex, UK
C?ID=421579
It's "six of one and half a dozen of the other" as we say over here in the UK.
Thought this technique works well.....
Originally Posted by Mr. Timewise
In my case with the allroad's double spoke wheels, the rim diameter is 470mm. Half that is 235mm. So the distance from the top edge of the wheel rim to the fender edge should be 167mm to get the standard 402mm setting. (IN LEVEL 2)
I place the end of my tape measure on the top edge of the wheel rim and note the distance to the highest point on the fender arch edge. For example, if the distance from the wheel rim to the fender is 160 mm, I add that number to the radius of the wheel rim (235 mm) and get a height of 395 mm. It is the 395 mm which would be programmed in the "402 Mod" to get the car back to the standard specs.
Bigbarper
West Sussex, UK
C?ID=421579
Whats your take on the 'Adaptation channel not available' error message?
Well, the values you need to enter into the Adaptation channels in order to calibrate the suspension must be measured in the manner I described. Measuring them that way would also tell us how far out of whack things actually are.
Not sure. That's the module itself refusing for some reason.
Bigbarper
West Sussex, UK
C?ID=421579
OK by way of a wrap-up, I left the car for a couple of days and then went back for another go at the suspension calibration.
Wasn't expecting much but my perseverance payed off as this time when I went to read the channel values instead of the previous error message channel not available the module returned a value and I was able to read all 4 channels ( and the 5th ) and enter the miscalibrated actual measured values.
So job done, went for a test drive, rescanned and got a clean scan of the level control channel.
Happy days 👍
