2017 Audi S8 - Changed tires/wheels this morning, factory sizing. Used the "lift" setting correctly. Getting a "tpms malfunction" and no option on MMI to use "tire pressure monitoring" to reset.
Screen says "The selected system is currently not available"
Friday,13,November,2020,14:09:40:54171
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
VIN: WUAJ5AFD5HN900402 License Plate:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C
42 44 46 47 52 53 55 56 5F 62 65 6C 6D 6F 72 81 82 85 88 89
8B 8E 8F 90 A9 BA
VIN: WUAJ5AFD5HN900402 Mileage: 44015km-27349miles
Address 01: Engine (------DDTA) Labels: None
Part No SW: 4H0 907 557 H HW: 4H0 906 014
Component: 4.0l V8TFSI / H63 0001
Revision: NCH63---
Coding: 022A00326546000E3000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM40TFS0114H0907557H 001002
ROD: EV_ECM40TFS011_AU64.rod
VCID: 35372AC1E5CC4F13B15-8060
7636 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
P2096 00 [096] - Too Lean
Mileage: 42868 km
Date: 2020.10.12
Time: 16:06:52
Engine speed: 1777.00 /min
Normed load value: 13.3 %
Vehicle speed: 71 km/h
Coolant temperature: 101 °C
Intake air temperature: 45 °C
Voltage terminal 30: 13.876 V
Unlearning counter according OBD: 36
Engine status: COENG_RUNNING
Part No SW: 4H1 927 158 FF HW: 0BK 927 156 AD
Component: 0BK 40TFSIUSA H19 1006
Revision: --H19---
ASAM Dataset: EV_TCMALX51011 002022
ROD: EV_TCMALX51011_002_AU64.rod
VCID: 79AFE6F189546B7315D-802C
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 AC HW: 4H0 907 379 AC
Component: ESP PREMIUM H10 0930
Coding: D2FD82004BBF4100E200
ASAM Dataset: EV_ESPPremi 005025
ROD: EV_ESPPremi_005_AU64.rod
VCID: 73B3D4D9AB3811235F1-8026
Part No SW: 4H0 907 064 JD HW: 4H0 907 064 JD
Component: BCM2 2.0 H43 0582
Coding: 0D876F4E000000000000
VCID: 74B1D7C5AEB6161B46B-8020
Serial number: 3216000137991010
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H08 0156
Revision: AA000000 Serial number: 00000208474421
Coding: C018320085043201010001010101112131313333283333
VCID: 35372AC1E54C4F13B15-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 P HW: 4H0 820 043 P
Component: Klima 4 Zonen H20 0210
Coding: 680120785C0000
ASAM Dataset: EV_AirCondiFront 003001
ROD: EV_AirCondiFront_002.rod
VCID: 2D0702A10D9C07D3C95-8078
0245 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 56
Mileage: 38954 km
Date: 2020.06.05
Time: 16:48:19
Part No SW: 4H0 907 063 GB HW: 4H0 907 063 AB
Component: BCM1 2.0 H20 0368
Revision: 19020001 Serial number: 00001421339202
Coding: 01050011043C9FF2F90048C4A0003800009CD308AA08022180000894710017000060002D0B0000
VCID: 6E85C5ADC09A3CCBB0F-803A
Subsystem 1 - Part No SW: 4H1 955 119 D HW: 4H1 955 119 A
Component: WWS641 160605 H38 0100
Serial number: 160620203616
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 62066972
Coding: 02004E
Subsystem 3 - Part No SW: 4H0 941 531 F HW: 4H0 941 531 F
Component: E1 - LDS H01 0044
Serial number: 14 07 2016 00002199
Component: USHL4.2 H30 0030
Serial number: 00000000095Z02591D4C
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA124397000022592944
Coding: 020300
Subsystem 6 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0005
Serial number: 26B84A3800PAG0MUFU03
01229 - A/C Humidity Sensor (G260)
014 - Defective
Fault Status: 01101110
Reset counter: 56
Mileage: 38954 km
Date: 2020.06.05
Time: 16:48:25
Part No SW: 4H0 907 561 C HW: 4H0 907 561
Component: ACC3 H21 0055
Coding: 7601010101
ASAM Dataset: EV_AdaptCruisContrAU64X 002026
ROD: EV_AdaptCruisContrAU64X_002.rod
VCID: 2B030CB9338809E3D71-807E
Part No SW: 4H0 959 655 G HW: 4H0 959 655 G
Component: Airbag10.43 H63 0093
Revision: -------- Serial number: 003KC001DZ97
Coding: 303331323130303231384A55304C34483053
VCID: 3A2D39FDCCD2A06B5C7-806E
Subsystem 1 - Part No SW: 4H0 959 339 A HW: 4H0 959 339 A
Component: BF-Gewichtss. H03 0040
Serial number: 5850000R166140BKR5
Serial number: 3575HRB400K55BUCBP7X
Serial number: 3585HRB400O55CGC924/
Serial number: 3515JRB400C571NC88S7
Serial number: 3525JRB400Q571NCQPOA
Serial number: 3554VRB40145761QL12Z
Serial number: 3564VRB40145761QB12Q
Revision: -------- Serial number: 01335PGB0008O
Coding: 0000FC
VCID: 372B20C9FF40BD03A39-8062
Subsystem 1 - Part No SW: 4H0 951 528 A HW: 4H0 951 528 A
Serial number: 24 03 2016 B0071660
Part No SW: 4H0 920 881 B HW: 4H0 920 881 B
Component: TBenUSAACCNV- H55 0902
Revision: 41081213 Serial number: 658150716592033
Coding: 0B470803BF51D705020100
ASAM Dataset: EV_RBD4K 004050
ROD: EV_RBD4K_AU64.rod
VCID: 2A0D09BD3C7210EB2C7-807E
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 P HW: 4H0 919 204 P
Component: Analoguhr D4 H05 0225
Serial number: 2160607001156
Part No SW: 4H0 907 468 AH HW: 4H0 907 468 AC
Component: J533--Gateway H15 0096
Revision: -------- Serial number: 00000002319554
Coding: 80E1034804
ASAM Dataset: EV_GatewPkoUDS 002000
VCID: 77ABE0C9BF407D03639-8022
Subsystem 1 - Part No SW: 4H0 915 181 G HW: 4H0 915 181 G
Component: J367-BDM H08 0270
Serial number: 53188B07531481346599
0267 - Optical data bus
U1049 00 [008] - Open circuit
Reset counter: 22
Mileage: 43318 km
Date: 2020.10.22
Time: 16:17:29
Voltage terminal 30: 11.7 V
Voltage terminal 15: 0.0 V
Control Module temperature: 36 °C
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 0
12290 - Quiescent Current
U1406 00 [008] - Too High
Fault Frequency: 8
Reset counter: 21
Mileage: 43329 km
Date: 2020.10.22
Time: 22:00:12
Voltage terminal 30: 12.1 V
Control Module temperature: 26 °C
System status: LIN_active
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 0
U140B 00 [008] - -
[Powermanagement active]
Fault Frequency: 6
Reset counter: 21
Mileage: 42820 km
Date: 2020.10.01
Time: 22:22:10
Voltage terminal 30: 11.2 V
Voltage terminal 15: 11.3 V
Control Module temperature: 25 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 1
Part No SW: 8K0 907 144 N HW: 8K0 907 144 N
Component: DYNAMIKLENK. H06 0740
Revision: 52001005 Serial number: --------------
Coding: 090000
VCID: 3A2D39FDCC52A06B5C7-806E
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 4H0 857 511 A HW: 4H0 857 511 A
Component: FLA H04 0021
Revision: AB001001
Coding: 04018B6B74745D545420363E00
VCID: 2809F3B522FE22FB3A3-807C
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H19 0200
Serial number: 001007160001022
ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
VCID: 2809F3B5227E22FB3A3-807C
Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb
Part No SW: 4H0 919 158 J HW: 4H0 919 158 J
Component: Klima Fond H17 0200
Coding: 2000000000
ASAM Dataset: EV_AirCondiHeck 002001
ROD: EV_AirCondiHeck.rod
VCID: 372B20C9FFC0BD03A39-8062
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Coding: 008006
ROD: EV_AirSuspe_VW51.rod
VCID: 2F3B18A9079075C3FB9-807A
403200 - Function Shut-Off Active
C10C8 00 [008] - -
Reset counter: 55
Mileage: 44000 km
Date: 2020.11.13
Time: 08:52:48
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000208473991
Coding: C0183B0085053201010001010101112131313333203333
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 L HW: 4H0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7100UYWC
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 382923F5F2DEB27BAA3-806C
Part No SW: 4H0 907 566 F HW: 4H0 907 566 F
Component: SWA Master H08 0040
Serial number: 0408648191
Coding: 040211
VCID: 333314D9EBB851239F1-8066
Subsystem 1 - Part No SW: 4H0 907 568 F HW: 4H0 907 568 F
Component: SWA Slave H08 0040
Serial number: 0403714515
Coding: 040211
Part No SW: 4H0 959 793 R HW: 4H0 959 793 G
Component: TSG FA H08 0280
Revision: -------- Serial number: 0000208530552
Coding: 011F1F005E0062C202003017
VCID: 48C9533582BEC2FBDA3-801C
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000001 Serial number: 0000092666
Coding: 011001010000
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
Revision: 00002001 Serial number: 0410177922
Coding: 0106023A00FA7185B0B0C7C0020316000000000000000000000000000000
Subsystem 1 - Part No SW: 4H0 959 719 HW: 4H0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000358116
Subsystem 3 - Part No SW: 4H0 959 591 B HW: 8V3 959 591 A
Component: J245 PS50.402 H03 0004
Serial number: 0000FST0012C4VE00000
Coding: 101F00
Subsystem 4 - Part No SW: 4H0 947 135 BK HW: 4H0 947 135 BK
Component: Dachelektroni H13 0080
Serial number: A2016000000000126854
Subsystem 5 - Part No SW: 4H0 959 591 A HW: 4H0 959 591 A
Component: V252 PS014 H06 0005
Serial number: WOO1000HN1G
Subsystem 6 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Serial number: 93827563
Part No SW: 4G1 035 223 A HW: 4G1 035 223 A
Component: BOSE-G3C7-ANC H02 0540
Revision: CJ002700 Serial number: 00000000019701
Coding: 030000
VCID: 1C61DF6566A6FE5BAEB-8048
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H08 0280
Revision: -------- Serial number: 0000208580625
Coding: 011F1F005E0062C202003006
VCID: 3C213FE5C6669E5B4EB-8068
Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
Component: EPB-4 H05 0017
Revision: -------- Serial number: 00000001921828
ASAM Dataset: EV_ParkiBrake 001029
ROD: EV_ParkiBrake_VW51.rod
VCID: 313F1ED111A46333EDD-8064
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 E HW: 7P6 907 357 B
Component: MxB-ECU 001 0100
Coding: 02720A1122600400
VCID: 343117C5EEB6561B86B-8060
Subsystem 1 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7570
Coding: E00200
Subsystem 2 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7570
Coding: E00200
Address 56: Radio (R) Labels: None
Part No SW: 4GD 035 082 H HW: 4GD 035 082
Component: Radio U SIRIU H66 0138
Revision: AB001007 Serial number: 315GX0G2510917
Coding: 020007010000000001
VCID: 392F26F1C954AB7355D-806C
Part No SW: 4H0 035 746 M HW: 4H0 035 746 J
Component: H-BNT-NA H44 1038
Revision: -------- Serial number: 503GY0G7525521
Coding: 03020000020BFDEF7D12CB1E00000003140001000000000000
VCID: 323D11DD1422582B947-8066
Subsystem 1 - Part No: 8R0 060 884 DQ
Component: NAR 2016/2017 1402
Subsystem 2 - Part No SW: 4H0 919 604 H HW: 4H0 919 604 H
Component: DU8 D4 SV NB H63 0060
Serial number: AUZ8ZDGY900YGZH
Subsystem 3 - Part No SW: 4H1 919 600 M HW: 4H1 919 600
Component: E380 BDT D4 H11 0110
Serial number: 00000000222236
Component: CD-Database 6890
02244 - Button in Control Head is Stuck
Fault Frequency: 7
Reset counter: 55
Mileage: 43862 km
Date: 2020.11.08
Time: 14:30:10
Voltage: 11.90 V
Hex Value: 0x0005
not available
03389 - Data Set Implausible
Reset counter: 237
Mileage: 43379 km
Date: 2020.10.25
Time: 16:00:43
Voltage: 14.30 V
Bin. Bits: 010
04142 - LVDS Line for Display Module
Fault Status: 00101011
Reset counter: 50
Mileage: 43862 km
Date: 2020.11.08
Time: 14:24:00
Voltage: 11.50 V
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H08 0280
Revision: -------- Serial number: 0000209959191
Coding: 010F1F00400062C202003006
Address 65: Tire Pressure (-----) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 B HW: 4H0 907 273 B
Component: RDKBERU25 H10 0820
Serial number: 10000000030160
ROD: EV_RDKBERU25_AU57.rod
8397058 - Front Left TPMS Sensor
C1050 31 [009] - No Signal
Reset counter: 16
Mileage: 44002 km
Date: 2020.11.13
Time: 09:45:29
8397314 - Front Right TPMS Sensor
C1051 31 [009] - No Signal
Reset counter: 16
Mileage: 44002 km
Date: 2020.11.13
Time: 09:45:29
8397570 - Rear Left TPMS Sensor
C1052 31 [009] - No Signal
Reset counter: 16
Mileage: 44002 km
Date: 2020.11.13
Time: 09:45:29
8397826 - Rear Right TPMS Sensor
C1053 31 [009] - No Signal
Reset counter: 16
Mileage: 44002 km
Date: 2020.11.13
Time: 09:45:29
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4H0 907 428 E HW: 7P6 907 441 G
Component: TopView H09 0361
Revision: 11001001 Serial number: 82330JG0187279
Coding: 020F000101010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
ROD: EV_CamerSysteTopViewAUDI.rod
9617697 - Function Restricted due to Insufficient Voltage
U1400 00 [024] - -
[Functional limitation by undervoltage]
Reset counter: 56
Mileage: 43862 km
Date: 2020.11.08
Time: 14:41:52
Voltage terminal 30: 8.0 V
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 AC HW: 4H0 959 107 AC
Component: HDSG-Modul H12 0049
Revision: 10012001 Serial number: 184600954
Coding: 021004C120
ASAM Dataset: EV_DeckLidContrUnit 001032
ROD: EV_DeckLidContrUnit.rod
VCID: 6FBBD8A9C71035C3BB9-803A
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000213220
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 6393A4991BD881A32F1-8036
Component: TSG HR H08 0280
Revision: -------- Serial number: 0000209959192
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H09 0083
Revision: 0L0D5015 Serial number: SN160624 0167
ROD: EV_GSM2x3Mono_AU64.rod
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4H0 919 617 HW: 4H0 919 617
Component: HeadUpDisplay H20 0023
Coding: C20000
ASAM Dataset: EV_HUDContiC7 001025
ROD: EV_HUDContiC7.rod
VCID: 6D87C2A1CD1CC7D3895-8038
Address 85: On Board Cam.
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00027384071801
Coding: 764FF2
ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00027384073101
Coding: 364FF2
Part No SW: 4H0 907 541 C HW: 4H0 907 541
Coding: 7601010101
ASAM Dataset: EV_AdaptCruisContr2AU64X 002023
ROD: EV_AdaptCruisContr2AU64X_002.rod
VCID: 290FF6B139741BF325D-807C
Part No SW: 4H0 907 107 H HW: 4H0 907 107
Component: BV-SG H34 0090
Serial number: 005002450807167
Coding: 01C19A030111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 2C010FA536860EDBDEB-8078
Component: RGS-VL H16 0080
Coding: 0066F609031F0376070308014240C0010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
Component: RGS-VR H16 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
VCID: 323D11DD14A2582B947-8066
Part No SW: 4H0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0003
Serial number: 160423200056
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H10 0008
Revision: 00001001 Serial number: 97813007107401
ROD: EV_AEMLearAU64X.rod
End----(Elapsed Time: 03:27, VBatt start/end: 11.7V/11.5V. VIgn 11.5V)-----
