TPMS malfunction
MTHines
SC, USA
2017 Audi S8 - Changed tires/wheels this morning, factory sizing. Used the "lift" setting correctly. Getting a "tpms malfunction" and no option on MMI to use "tire pressure monitoring" to reset.
Screen says "The selected system is currently not available"
Friday,13,November,2020,14:09:40:54171
VIN: WUAJ5AFD5HN900402   License Plate:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C
          42 44 46 47 52 53 55 56 5F 62 65 6C 6D 6F 72 81 82 85 88 89
          8B 8E 8F 90 A9 BA
VIN: WUAJ5AFD5HN900402   Mileage: 44015km-27349miles
Address 01: Engine (------DDTA)       Labels: None
   Part No SW: 4H0 907 557 H    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H63 0001
   Revision: NCH63---
   Coding: 022A00326546000E3000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM40TFS0114H0907557H 001002
   ROD: EV_ECM40TFS011_AU64.rod
   VCID: 35372AC1E5CC4F13B15-8060
7636 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
          P2096 00 [096] - Too Lean
                    Mileage: 42868 km
                    Date: 2020.10.12
                    Time: 16:06:52
                    Engine speed: 1777.00 /min
                    Normed load value: 13.3 %
                    Vehicle speed: 71 km/h
                    Coolant temperature: 101 °C
                    Intake air temperature: 45 °C
                    Voltage terminal 30: 13.876 V
                    Unlearning counter according OBD: 36
                    Engine status: COENG_RUNNING
   Part No SW: 4H1 927 158 FF    HW: 0BK 927 156 AD
   Component: 0BK 40TFSIUSA H19 1006
   Revision: --H19---
   VCID: 79AFE6F189546B7315D-802C
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 AC    HW: 4H0 907 379 AC
   Component: ESP PREMIUM   H10 0930
   Coding: D2FD82004BBF4100E200
   ASAM Dataset: EV_ESPPremi 005025
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 73B3D4D9AB3811235F1-8026
   Part No SW: 4H0 907 064 JD    HW: 4H0 907 064 JD
   Component: BCM2 2.0      H43 0582
   Coding: 0D876F4E000000000000
   VCID: 74B1D7C5AEB6161B46B-8020
   Serial number: 3216000137991010
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000208474421
   Coding: C018320085043201010001010101112131313333283333
   VCID: 35372AC1E54C4F13B15-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 P    HW: 4H0 820 043 P
   Component: Klima 4 Zonen H20 0210
   Coding: 680120785C0000
   ASAM Dataset: EV_AirCondiFront 003001
   ROD: EV_AirCondiFront_002.rod
   VCID: 2D0702A10D9C07D3C95-8078
0245 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 56
                    Mileage: 38954 km
                    Date: 2020.06.05
                    Time: 16:48:19
   Part No SW: 4H0 907 063 GB    HW: 4H0 907 063 AB
   Component: BCM1 2.0      H20 0368
   Revision: 19020001    Serial number: 00001421339202
   Coding: 01050011043C9FF2F90048C4A0003800009CD308AA08022180000894710017000060002D0B0000
   VCID: 6E85C5ADC09A3CCBB0F-803A
   Subsystem 1 - Part No SW: 4H1 955 119 D    HW: 4H1 955 119 A
   Component: WWS641 160605  H38 0100
   Serial number:         160620203616
   Coding: 0045F7
   Serial number: 62066972
   Coding: 02004E
   Subsystem 3 - Part No SW: 4H0 941 531 F    HW: 4H0 941 531 F
   Component: E1 - LDS  H01 0044
   Serial number: 14 07 2016  00002199
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z02591D4C
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA124397000022592944
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: 26B84A3800PAG0MUFU03
01229 - A/C Humidity Sensor (G260)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 56
                    Mileage: 38954 km
                    Date: 2020.06.05
                    Time: 16:48:25
   Part No SW: 4H0 907 561 C    HW: 4H0 907 561
   Component: ACC3          H21 0055
   Coding: 7601010101
   ASAM Dataset: EV_AdaptCruisContrAU64X 002026
   ROD: EV_AdaptCruisContrAU64X_002.rod
   VCID: 2B030CB9338809E3D71-807E
   Part No SW: 4H0 959 655 G    HW: 4H0 959 655 G
   Component: Airbag10.43   H63 0093
   Revision: --------    Serial number: 003KC001DZ97
   Coding: 303331323130303231384A55304C34483053
   VCID: 3A2D39FDCCD2A06B5C7-806E
   Subsystem 1 - Part No SW: 4H0 959 339 A    HW: 4H0 959 339 A
   Component: BF-Gewichtss.  H03 0040
   Serial number: 5850000R166140BKR5
   Serial number: 3575HRB400K55BUCBP7X
   Serial number: 3585HRB400O55CGC924/
   Serial number: 3515JRB400C571NC88S7
   Serial number: 3525JRB400Q571NCQPOA
   Serial number: 3554VRB40145761QL12Z
   Serial number: 3564VRB40145761QB12Q
   Revision: --------    Serial number: 01335PGB0008O
   Coding: 0000FC
   VCID: 372B20C9FF40BD03A39-8062
   Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
   Serial number: 24 03 2016  B0071660
   Part No SW: 4H0 920 881 B    HW: 4H0 920 881 B
   Component: TBenUSAACCNV- H55 0902
   Revision: 41081213    Serial number: 658150716592033
   Coding: 0B470803BF51D705020100
   ASAM Dataset: EV_RBD4K 004050
   ROD: EV_RBD4K_AU64.rod
   VCID: 2A0D09BD3C7210EB2C7-807E
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 P    HW: 4H0 919 204 P
   Component: Analoguhr D4  H05 0225
   Serial number: 2160607001156
   Part No SW: 4H0 907 468 AH    HW: 4H0 907 468 AC
   Revision: --------    Serial number: 00000002319554
   Coding: 80E1034804
   VCID: 77ABE0C9BF407D03639-8022
   Subsystem 1 - Part No SW: 4H0 915 181 G    HW: 4H0 915 181 G
   Component: J367-BDM  H08 0270
   Serial number: 53188B07531481346599
0267 - Optical data bus
          U1049 00 [008] - Open circuit
                    Reset counter: 22
                    Mileage: 43318 km
                    Date: 2020.10.22
                    Time: 16:17:29
                    Voltage terminal 30: 11.7 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 36 °C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Fault Frequency: 8
                    Reset counter: 21
                    Mileage: 43329 km
                    Date: 2020.10.22
                    Time: 22:00:12
                    Voltage terminal 30: 12.1 V
                    Control Module temperature: 26 °C
                    System status: LIN_active
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Reset counter: 21
                    Mileage: 42820 km
                    Date: 2020.10.01
                    Time: 22:22:10
                    Voltage terminal 30: 11.2 V
                    Voltage terminal 15: 11.3 V
                    Control Module temperature: 25 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 1
   Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
   Component: DYNAMIKLENK.  H06 0740
   Revision: 52001005    Serial number: --------------
   Coding: 090000
   VCID: 3A2D39FDCC52A06B5C7-806E
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511 A    HW: 4H0 857 511 A
   Component: FLA           H04 0021
   Revision: AB001001
   Coding: 04018B6B74745D545420363E00
   VCID: 2809F3B522FE22FB3A3-807C
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H19 0200
   Serial number: 001007160001022
   VCID: 2809F3B5227E22FB3A3-807C
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 J    HW: 4H0 919 158 J
   Component: Klima Fond    H17 0200
   Coding: 2000000000
   ASAM Dataset: EV_AirCondiHeck 002001
   ROD: EV_AirCondiHeck.rod
   VCID: 372B20C9FFC0BD03A39-8062
   Coding: 008006
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F3B18A9079075C3FB9-807A
          C10C8 00 [008] - -
                    Reset counter: 55
                    Mileage: 44000 km
                    Date: 2020.11.13
                    Time: 08:52:48
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000208473991
   Coding: C0183B0085053201010001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637 L    HW: 4H0 907 637 G
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7100UYWC
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 382923F5F2DEB27BAA3-806C
   Part No SW: 4H0 907 566 F    HW: 4H0 907 566 F
   Component: SWA Master    H08 0040
   Serial number: 0408648191
   Coding: 040211
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 333314D9EBB851239F1-8066
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4H0 907 568 F    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0040
   Serial number: 0403714515
   Coding: 040211
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H08 0280
   Revision: --------    Serial number: 0000208530552
   Coding: 011F1F005E0062C202003017
   VCID: 48C9533582BEC2FBDA3-801C
   Component: RCevo         H54 0202
   Revision: 00000001    Serial number: 0000092666
   Coding: 011001010000
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   Revision: 00002001    Serial number: 0410177922
   Coding: 0106023A00FA7185B0B0C7C0020316000000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0081
   Serial number: 00000000000000358116
   Subsystem 3 - Part No SW: 4H0 959 591 B    HW: 8V3 959 591 A
   Component: J245 PS50.402  H03 0004
   Serial number: 0000FST0012C4VE00000
   Coding: 101F00
   Subsystem 4 - Part No SW: 4H0 947 135 BK    HW: 4H0 947 135 BK
   Component: Dachelektroni  H13 0080
   Serial number: A2016000000000126854
   Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS014  H06 0005
   Serial number:     WOO1000HN1G
   Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93827563
   Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
   Component: BOSE-G3C7-ANC H02 0540
   Revision: CJ002700    Serial number: 00000000019701
   Coding: 030000
   VCID: 1C61DF6566A6FE5BAEB-8048
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H08 0280
   Revision: --------    Serial number: 0000208580625
   Coding: 011F1F005E0062C202003006
   VCID: 3C213FE5C6669E5B4EB-8068
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000001921828
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 313F1ED111A46333EDD-8064
   Coding: 02720A1122600400
   VCID: 343117C5EEB6561B86B-8060
   Subsystem 1 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7570
   Coding: E00200
   Subsystem 2 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7570
   Coding: E00200
Address 56: Radio (R)       Labels: None
   Part No SW: 4GD 035 082 H    HW: 4GD 035 082
   Component: Radio U SIRIU H66 0138
   Revision: AB001007    Serial number: 315GX0G2510917
   Coding: 020007010000000001
   VCID: 392F26F1C954AB7355D-806C
   Part No SW: 4H0 035 746 M    HW: 4H0 035 746 J
   Component: H-BNT-NA      H44 1038
   Revision: --------    Serial number: 503GY0G7525521
   Coding: 03020000020BFDEF7D12CB1E00000003140001000000000000
   VCID: 323D11DD1422582B947-8066
   Subsystem 1 - Part No: 8R0 060 884 DQ
   Component: NAR 2016/2017  1402
   Subsystem 2 - Part No SW: 4H0 919 604 H    HW: 4H0 919 604 H
   Component: DU8 D4 SV NB  H63 0060
   Serial number: AUZ8ZDGY900YGZH
   Subsystem 3 - Part No SW: 4H1 919 600 M    HW: 4H1 919 600
   Component: E380 BDT D4  H11 0110
   Serial number: 00000000222236
   Component: CD-Database  6890
02244 - Button in Control Head is Stuck
                    Reset counter: 55
                    Mileage: 43862 km
                    Date: 2020.11.08
                    Time: 14:30:10
                    Voltage: 11.90 V
                    Hex Value: 0x0005
                        not available
03389 - Data Set Implausible
                    Reset counter: 237
                    Mileage: 43379 km
                    Date: 2020.10.25
                    Time: 16:00:43
                    Voltage: 14.30 V
                    Bin. Bits:      010
04142 - LVDS Line for Display Module
                    Fault Status: 00101011
                    Reset counter: 50
                    Mileage: 43862 km
                    Date: 2020.11.08
                    Time: 14:24:00
                    Voltage: 11.50 V
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H08 0280
   Revision: --------    Serial number: 0000209959191
   Coding: 010F1F00400062C202003006
Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273 B    HW: 4H0 907 273 B
   Component: RDKBERU25     H10 0820
   Serial number: 10000000030160
   ASAM Dataset: EV_RDKBERU25 003014
   ROD: EV_RDKBERU25_AU57.rod
8397058 - Front Left TPMS Sensor
          C1050 31 [009] - No Signal
                    Reset counter: 16
                    Mileage: 44002 km
                    Date: 2020.11.13
                    Time: 09:45:29
8397314 - Front Right TPMS Sensor
          C1051 31 [009] - No Signal
                    Reset counter: 16
                    Mileage: 44002 km
                    Date: 2020.11.13
                    Time: 09:45:29
8397570 - Rear Left TPMS Sensor
          C1052 31 [009] - No Signal
                    Reset counter: 16
                    Mileage: 44002 km
                    Date: 2020.11.13
                    Time: 09:45:29
8397826 - Rear Right TPMS Sensor
          C1053 31 [009] - No Signal
                    Reset counter: 16
                    Mileage: 44002 km
                    Date: 2020.11.13
                    Time: 09:45:29
   Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
   Component: TopView       H09 0361
   Revision: 11001001    Serial number: 82330JG0187279
   Coding: 020F000101010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
9617697 - Function Restricted due to Insufficient Voltage
          U1400 00 [024] - -
          [Functional limitation by undervoltage]
                    Reset counter: 56
                    Mileage: 43862 km
                    Date: 2020.11.08
                    Time: 14:41:52
                    Voltage terminal 30: 8.0 V
                    Terminal 15 status: Terminal 15 on
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
   Component: HDSG-Modul    H12 0049
   Revision: 10012001    Serial number: 184600954
   Coding: 021004C120
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6FBBD8A9C71035C3BB9-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000213220
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6393A4991BD881A32F1-8036
   Component: TSG HR        H08 0280
   Revision: --------    Serial number: 0000209959192
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H09 0083
   Revision: 0L0D5015    Serial number: SN160624  0167
   ROD: EV_GSM2x3Mono_AU64.rod
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4H0 919 617     HW: 4H0 919 617
   Component: HeadUpDisplay H20 0023
   Coding: C20000
   ASAM Dataset: EV_HUDContiC7 001025
   ROD: EV_HUDContiC7.rod
   VCID: 6D87C2A1CD1CC7D3895-8038
Address 85: On Board Cam.
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00027384071801
   Coding: 764FF2
   ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00027384073101
   Coding: 364FF2
   Part No SW: 4H0 907 541 C    HW: 4H0 907 541
   Coding: 7601010101
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002023
   ROD: EV_AdaptCruisContr2AU64X_002.rod
   VCID: 290FF6B139741BF325D-807C
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H34 0090
   Serial number: 005002450807167
   Coding: 01C19A030111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 2C010FA536860EDBDEB-8078
   Component: RGS-VL        H16 0080
   Coding: 0066F609031F0376070308014240C0010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   Component: RGS-VR        H16 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   VCID: 323D11DD14A2582B947-8066
   Part No SW: 4H0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0003
   Serial number: 160423200056
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H10 0008
   Revision: 00001001    Serial number: 97813007107401
   ROD: EV_AEMLearAU64X.rod
End----(Elapsed Time: 03:27, VBatt start/end: 11.7V/11.5V. VIgn 11.5V)-----
Changed from stock to aftermarket, or...?
Do the wheels/tires you changed to have TPMS sensors?
MTHines
SC, USA
The wheels are aftermarket. The car, from everything I've read, does not use sensors in the wheels. It uses the ABS system AFAIK
South Molton, UK
If that is correct then the Tyre Pressure ECU at #65 would not appear in the Auto-Scan.
If you look at the detail of that ECU it is saying that it cannot communicate with the sensors in any of the wheels, so it looks pretty certain that your S8 has an active TPMS system.
  • Agree
MTHines
SC, USA
Well damn....makes sense. I'm putting the stocks back on today to confirm. Thank you sir!
BavarianCare
Ireland
C?ID=11022
Out of interest, on BMW with active TPMS you can recode them to use FTM (Flat Tyre Monitor).
This uses speed sensors instead of actual TPMS sensors.
Is this a possibility on VAG models?
langers2k
C?ID=224085
Yup, plenty (most?) of VAG vehicles use indirect TPMS via the ABS speed sensors rather then direct TPMS using actual pressure sensors.
For example, a MK5/6/7 Golf and a MK2/3 Octavia use indirect via the ABS :)
BavarianCare
Ireland
C?ID=11022
Sorry, maybe I was not clear.
For example you can have a BMW 5 series (F10) 2015 that had TPMS originally from factory.
However, it is possible using E-SYS to CONVERT/RECODE this to the other system and everything works ok.
Is this possible on VAG model that came with TPMS from factory?
On BMW you need to change Vehicle Order & Recode ABS/CLUSTER/HEAD UNIT
Whether it's possible or not depends on whether the ABS module in question supports Indirect TPMS. I do not know whether yours does or doesn't.
langers2k
C?ID=224085
You need to be clear if you mean direct (pressure sensors in each wheel) TPMS or indirect (ABS speed sensors) TPMS. Both are TPMS systems so which way are you trying to go?
My old PQ35 platform car (MK2 FL Octavia) came with indirect TPMS from factory, I added direct TPMS and had both systems activated without any problems. The one time I got a puncture, the indirect system alerted me first but I could confirm/monitor with the direct system. I now have a MQB platform car (MK3 FL Octavia) which again has indirect TPMS from factory, like last time I'm planning to add direct TPMS. This involves adding a module (and wiring), sensors to each wheel and finally coding.
It's also possible to do the reverse and convert from direct TPMS to indirect TPMS, it's most common when changing wheels where no sensors are fitted.
In some cases, a car will have neither from factory but indirect is just coding to enable it.
As Uwe says, it'll mostly depend on your ABS module to what's possible or required. Where possible, some are just coding and others are coding plus adding a physical button to reset the system. It's hard to give specifics when I've no idea what car you're asking about or how it's equipt :thumbs:
BavarianCare
Ireland
C?ID=11022
I was just asking a general question - sorry for not being more specific.
Regarding the abbreviations - my bad - but with BMW:
TPMS = Tyre Pressure Monitoring System = Sensors in wheels to measure temp & pressure
FTM = Flat Tyre Monitor = uses speed sensors to check indirectly
Yes, different car manufacturers have been know to use different nomenclature for things. ;)
