Hi, issue started about 4 months ago after car sat in 2 day light rainfall there were about 15 engine codes on and car would be in limp mode. After drying the car out and putting leaf blower in the engine bay the codes disappeared. This week we had a wet snowfall and car sat out in it, after short drive car went into limp mode, again with numerous engine codes. I put it in heated garage now for 2 days, it's bone dry, cleaned all the ground could find, still many many codes on the car and now it won't even start. It turns over fine but won't run. Checked battery its healthy, tried boosting as well, no start. There is a loud ticking sound now coming from the fuel injector area when I turn the key on, also the tachometer goes crazy when I turn the key on sometimes. Attached is my VCDS report of codes
The first time this happened I found water sitting on top of the ECM. I checked connector, no corrosion at that time and blew some electrical cleaner in it to be safe.
My best guess is that I either have some corrosion happening on some wires somewhere or the ECM is faulty.
Suggestions?
Suggestions?
Thursday,12,November,2020,16:23:15:04508
VIN: 3VWPL8AJ4BM649339 License Plate: BKS8251
Mileage: 263460km-163706mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
77
VIN: 3VWPL8AJ4BM649339 Mileage: 263460km-163706miles
Part No SW: 03L 997 030 B HW: 03L 906 019 DA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H13--- Serial number:
Coding: 0050078
Shop #: WSC 55306 001 1048576
VCID: 2D0709F0511027A3C95-8078
8 Faults Found:
001601 - Sensor Reference Voltage A
P0641 - 000 - Open Circuit - MIL ON
Fault Status: 11100000
Mileage: 263462 km
Date: 2015.04.05
Time: 00:25:58
Voltage: 11.86 V
Temperature: 18.9°C
(no units): 0.0
Torque: 51.0 Nm
001617 - Sensor Reference Voltage B
P0651 - 000 - Open Circuit - MIL ON
Mileage: 263462 km
Date: 2015.04.05
Time: 00:25:58
Voltage: 11.86 V
Temperature: 18.9°C
(no units): 0.0
Torque: 51.0 Nm
008201 - Intake Manifold Flap; Bank 1
P2009 - 000 - Short to Ground
Fault Frequency: 18
Mileage: 263462 km
Date: 2015.04.05
Time: 00:26:19
Load: 100.0 %
Lambda: 99.4 %
Mass Air / Rev.: 0.0 mg/str
Temperature: 19.8°C
005000 - Control Module Malfunction - DBW Throttle Monitoring
P1388 - 005 - - Intermittent
Fault Status: 00100101
Mileage: 263462 km
Date: 2015.04.05
Time: 00:29:05
Voltage: 13.38 V
Voltage: 0.000 V
Voltage: 0.000 V
Torque: 1270.0 Nm
Bin. Bits: 0111000
000897 - Glow Plug/Heater Indicator Circuit
P0381 - 000 - Implausible Signal - Intermittent
Temperature: 16.2°C
Voltage: 11.02 V
Bin. Bits: 01000000
Torque: 219.0 Nm
Temperature: 30.6°C
008208 - Intake Manifold Flap; Bank 1
P2010 - 002 - Short to Plus - Intermittent
Mileage: 263462 km
Date: 2015.04.05
Time: 13:38:32
Load: 100.0 %
Lambda: 99.4 %
Temperature: 12.6°C
004665 - Fuel Injector for Cylinder 3 (N32)
P1239 - 000 - Open Circuit - Intermittent
Mileage: 263462 km
Date: 2015.04.05
Time: 17:50:58
RPM: 897 /min
Voltage: 11.70 V
Temperature: 24.3°C
Temperature: 9.9°C
Inj. Quantity: 50.8 mg/str
Bin. Bits: 0111000
004664 - Fuel Injector for Cylinder 2 (N31)
P1238 - 000 - Open Circuit - Intermittent
Mileage: 263462 km
Date: 2015.04.05
Time: 17:51:17
RPM: 897 /min
Voltage: 11.70 V
Temperature: 25.2°C
Temperature: 9.9°C
Bin. Bits: 0111000
Readiness: 0 0 0 1 1
Part No SW: 02E 300 052 G HW: 02E 927 770 AL
Component: GSG DSG AG6 511 9136
Revision: 05151112 Serial number: 00001009081821
Shop #: WSC 00066 000 00000
VCID: 1869C824CE92B20B8A3-804C
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU - Intermittent - MIL ON
Fault Status: 10100000
Fault Frequency: 255
Mileage: 263462 km
Date: 2015.04.05
Time: 00:28:58
01196 - Engine-Transmission Data Bus
Mileage: 263462 km
Date: 2015.04.05
Time: 00:28:60
17100 - Transmission Input Speed Sensor (G182)
P0716 - 000 - Implausible Signal - Intermittent
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 114B600C49260003880E06E792220042310000
VCID: 76B5E69CE8C6247B78F-8022
Reset counter: 24
Mileage: 263462 km
Date: 2015.04.05
Time: 00:28:58
Count: 16386
Count: 12
Count: 20736
Count: 8194
Count: 48128
Count: 65280
Count: 5376
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 24
Mileage: 263462 km
Date: 2015.04.05
Time: 00:01:41
Count: 12
Count: 20736
Count: 8196
Count: 45056
Count: 65280
Part No SW: 3C8 907 336 AC HW: 3C8 907 336 AC
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000000002
Shop #: WSC 00066 000 00147
ROD: EV_ClimaBasis_VW36.rod
VCID: 6E85CEFC90161CBBB0F-803A
U1111 00 [008] - -
[Motorsteuergerät - kein Signal/Kommunikation]
Reset counter: 64
Mileage: 263462 km
Date: 2020.11.12
Time: 00:28:57
9479697 - Control Circuit for Front Left Seat Heater
B10A6 11 [009] - Short to Ground
Reset counter: 24
Mileage: 263462 km
Date: 2020.11.11
Time: 09:58:34
Part No SW: 5K0 937 086 H HW: 5K0 937 086 H
Component: BCM PQ35 M 011 1035
Revision: BJ011001
Coding: 2D380E1F902F3EC4008800816000054401000086535D8560648020000040
VCID: 392F2DA099588B0355D-806C
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 17111 21 0512
Coding: 009795
Reset counter: 64
Mileage: 263462 km
Date: 2015.04.05
Time: 00:28:58
Voltage: 10.85 V
Reset counter: 64
Mileage: 263462 km
Date: 2015.04.04
Time: 19:46:53
Voltage: 10.25 V
Fault Status: 00101010
Reset counter: 42
Mileage: 262387 km
Date: 2015.03.13
Time: 18:05:34
Voltage: 14.25 V
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R01428I
Coding: 00003047
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 392F2DA099D88B0355D-806C
Subsystem 1 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME37504558ZZZU
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME32094658ZZZV
Serial number: 3511HSME05523C24ZZZE
Serial number: 3521HSME1B1E3C24ZZZU
Serial number: 35527SME61014B23ZZZ4
Serial number: 35627SME7A264B23ZZZM
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JJB00015
Coding: 188A140000
Shop #: WSC 00066 000 00158
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76B5E69CE846247B78F-8022
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H07 0013
Serial number: 0080912
Coding: 820000
Part No SW: 5K0 920 871 A HW: 5K0 920 871 A
Component: KOMBI H23 0204
Revision: X0023007 Serial number:
Coding: 370F00
ASAM Dataset: EV_KombiUDSMM9RM10 A04203
ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
VCID: 2C0104F4668A2EABDEB-8078
12648448 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Motor: keine Kommunikation]
Reset counter: 64
Mileage: 263462 km
Date: 2020.11.12
Time: 00:28:56
13631488 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Komfortsysteme: keine Kommunikation]
Reset counter: 36
Mileage: 262313 km
Date: 2020.10.20
Time: 11:10:38
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H25 5603
Revision: H25 Serial number: 12111001201192
Coding: ED807F0600161300002002
VCID: 2E050EFC5C165CBBF0F-807A
Reset counter: 64
Mileage: 263462 km
Date: 2015.04.05
Time: 00:28:58
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223RAG1W06
Coding: 0000002
VCID: 7EA5FEBCCCF66C3B20F-802A
Part No SW: 5K0 953 234 HW: 5K0 920 871 A
Component: IMMO H23 0204
ASAM Dataset: EV_ImmoUDSMM9RM10 A01200
VCID: 6A8DC2ECACFEF09BEC7-803E
10485760 - Internal Control Module Memory Check Sum Error
B2000 00 [008] - -
Mileage: 146390 km
Date: 2017.12.31
Time: 18:48:42
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Revision: A1001003 Serial number: 7668338880
VCID: 270BFBD87FEC0DF3339-8072
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0001501406
Coding: 0004B5
Shop #: WSC 01383 790 50316
ROD: EV_DCU42BroseDriveSide.rod
VCID: 270BFBD87F6C0DF3339-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005193646
Coding: 000490
67589 - Turn Signal in Exterior Mirror
B11FD 01 [009] - Electrical Failure
Fault Frequency: 165
Reset counter: 24
Mileage: 255794 km
Date: 2020.07.31
Time: 02:22:21
68108 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Front CAN MSG]
Reset counter: 64
Mileage: 263462 km
Date: 2020.11.12
Time: 17:44:03
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 313F15804D284343EDD-8064
00750 - Warning Lamp
Fault Status: 00101101
Voltage: 10.75 V
DD
Temperature: 16.0°C
Reset counter: 64
Mileage: 263462 km
Date: 2015.04.05
Time: 20:38:11
Voltage: 12.00 V
DU
Temperature: 11.0°C
RPM: 1498 /min
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H25 5603
Coding: 050B0500
VCID: 6FBBD3F8979C15B3BB9-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
02071 - Local Databus
Fault Status: 00101100
Reset counter: 51
Mileage: 261899 km
Date: 2015.03.07
Time: 09:02:37
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0001466878
Coding: 0004B4
ROD: EV_DCU52BrosePasseSide.rod
VCID: 2809F8E47272028B3A3-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005192433
Coding: 000490
B11EC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 24
Fault Frequency: 48
Reset counter: 18
Mileage: 254111 km
Date: 2020.07.07
Time: 07:01:24
U1111 00 [008] - -
[Front CAN MSG]
Reset counter: 64
Mileage: 263462 km
Date: 2020.11.12
Time: 17:44:03
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H13 0043
Revision: -----26S Serial number: VWZ4Z7K3126846
Coding: 2100040004
VCID: 619FA5C05148B3C33DD-8034
Reset counter: 24
Mileage: 254110 km
Date: 2014.11.28
Time: 02:18:59
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668517367
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 323D1A8C44AE785B947-8066
End----------(Elapsed Time: 01:27, VBatt start/end: 12.0V/12.1V)-----------
