VIN: WUAZZZ8V3GA904501 License Plate: RS3 0000000R
Mileage: 68932km-42832mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 22 2B 42 44 47 52 55 5F
6C BB BC
VIN: WUAZZZ8V3GA904501 Mileage: 68932km-42832miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: OK 0000
Address 01: Engine (------CZGB) Labels:. 07K-907-309-V1.clb
Part No SW: 8V0 907 404 HW: 07K 907 309 C
Component: 2.5l R5/4V TF H52 0003
Revision: NKH52---
Coding: 12250032252601033600
Shop #: 07268 004 1048576
Dataset: EV_ECM25TFS0118V0907404 001004
ROD: EV_ECM25TFS0118V0907404.rod
VCID: 76E4357DC915743628-8022
Readiness: 0000 0001
Part No SW: 0DL 300 011 D HW: 0BH 927 711 F
Component: GSG DQ500 H10 5203
Revision: 00H10V01
Shop #: 00000 000 00000
Dataset: EV_TCMDQ500021 001001
VCID: 295E2E01482B6BCE75-807C
Address 03: Brakes (J104) Labels: None
Part No SW: 8V0 907 379 HW: 8V0 907 379
Component: ESC H42 0020
Revision: 00000000 Serial number: 62955000000078
Coding: 999CF08DAA9915AD409600644392920EC4990F55A80200C2497023
Dataset: EV_Brake1UDSContiMK100IPB 061003
ROD: EV_Brake1UDSContiMK100IPB_061.rod
VCID: 010E56A190DB438E0D-8054
Address 05: /Start Auth. (J518) Labels:| 5Q0-959-435.clb
Revision: 00021000 Serial number: 0386835566
Coding: 030C0C
Dataset: EV_KessyHellaMQBAB 002011
VCID: 3A7CE14DBD8DD0560C-806E
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H14 0060
Revision: 20028000 Serial number: 00000000797928
Coding: 03000005000000001000000000001000
Shop #: 06314 790 00021
Dataset: EV_AirCondiFrontVaAU37X 008020
VCID: 3362CC699AE7211ECF-8066
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: E3A8CAD7000000000001
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: MQBAB H H24 0175
Serial number: 01061532901299
Coding: 04051D46C24106FD03844004B31407A80800000000000000000000000000
Shop #: 35110 401 00188
Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_015.rod
VCID: 091E4E81A8EB0BCE55-805C
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 151026 043 0580
Serial number: 151114150108
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 60984212
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Component: E1 - H05 0032
Serial number: 02 09 2015 00001187
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY15285372M
Component: Sirene, DWA 005 0312
Serial number: 00000000000034048865
262912 - Sensor for Anti-Theft Alarm System
B1330 F5 [009] - Alert Emergency Activation Stage 1
Reset counter: 37
Mileage: 68932 km
Date: 2020.11.11
Time: 06:34:55
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391531800253
Coding: 0010151011
Dataset: EV_EPHVA18AU3700000 002026
VCID: 43829CA9CA47919E5F-8016
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 012 0361
Serial number: 003M2R19EDHM
Coding: 98FCC000008000005C540000004800000065
Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_VW48.rod
VCID: 4B92B489E21759DEA7-801E
Subsystem 1 - Part No SW: ----------- HW: 480 001 211 15
Serial number: 35767000000DBC60D715
Subsystem 2 - Part No SW: ----------- HW: 480 001 211 15
Serial number: 35867000000F9260D71$
Subsystem 3 - Part No SW: ----------- HW: 480 401 711 15
Serial number: 3516502C71DCBE1511FT
Subsystem 4 - Part No SW: ----------- HW: 480 401 711 15
Serial number: 3526502B11DBD614E31G
Subsystem 5 - Part No SW: ----------- HW: 480 400 611 15
Serial number: 35565029B1DCBE14302L
Part No SW: 8V0 953 521 ET HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 25111508490047
Coding: A418
Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_019_AU37.rod
VCID: 102863E5CBB13A0692-8044
Part No SW: 8V0 920 871 L HW: 8V0 920 871 L
Component: KOMBI H02 6423
Coding: 03AD081A2B8000080804AA001000000000000000
Dataset: EV_DashBoardVDDMQBAB 009051
VCID: 458682B1C473AFAE71-8010
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 F
Component: GW High 128 1243
Revision: -------- Serial number: 0004205976
Coding: 030100043F0860005B000268380B00000001010000000000000000000000
Dataset: EV_GatewLear 013020
ROD: EV_GatewLear_013.rod
VCID: 79FE3E41F80B1B4E45-802C
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 16 11 2015 E0043495
Subsystem 3 - Part No SW: 8S0 915 181 HW: 8S0 915 181
Component: J367-BDMHella H10 9052
Serial number: 7203658403
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 8S0 857 511 C HW: 8S0 857 511 C
Component: H09 0003
Revision: AA001001
Coding: 0404000700000000000001
Dataset: EV_HighBeamAssisAU33X 001017
ROD: EV_HighBeamAssisAU33X_VW37.rod
VCID: 397EFE41B88BDB4E05-806C
Part No SW: 0CQ 907 554 C HW: 0CQ 525 130
Component: Haldex4Motion H52 7754
Serial number: HA1-00016.09.15
Coding: 0601
Dataset: EV_AllWheelContrHA1VW37X 002015
ROD: EV_AllWheelContrHA1VW37X_002.rod
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000251853002
Coding: 5D00000000000000
Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB.rod
VCID: 3460CF759FE92626D6-8060
Component: FS 020 0041
Serial number: 300915BIT22058
Coding: 005D1A205C00040000001002
Dataset: EV_DCUDriveSideEWMAXKLO 006003
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8103
Dataset: EV_SteerAssisMQB 012140
Part No SW: 8V0 035 465 D HW: 8V0 035 465
Component: MIBAMP1ALPINE H11 0420
Serial number: AUZ8ZAFN901SMDO
Coding: 01030300AAAA2AAA01
Dataset: EV_AMPMst16C1ALPI 004024
ROD: EV_AMPMst16C1ALPI_004_AU37.rod
Component: BFS 020 0041
Serial number: 081015BJ708229
Coding: 005D12205E00040000001002
Dataset: EV_DCUPasseSideEWMAXKLO 006003
VCID: 428C99ADD55D989654-8016
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: - H01 0110
Coding: 01AA00002B200200
Dataset: EV_HeadlRegulAFSMQBMLB 001001
ROD: EV_HeadlRegulAFSMQBMLB.rod
VCID: 3F8A9059A6AFF57E3B-806A
Coding: E00100
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7050
Coding: E00100
Address 5F: Information Electr. (J794) Labels:| 8V0-035--STD1.clb
Part No SW: 8V0 035 864 C HW: 8V0 035 864 B
Component: MU-S-N-ER 042 0461
Serial number: A3F01911150786
Coding: 017303010000000021110002000A00002F0003240100010006
Dataset: EV_MUStd4CPASE 002039
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 3B72E449B2B7E95E17-806E
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0014
Serial number: AUZ8Z9FY30EPFY
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 Q HW: 8V0 919 614 Q
Component: ControlUnit_B H41 0054
Serial number: C1000025091500040302
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: RVC Mid H07 0140
Coding: 027300010201000300
Dataset: EV_2CamSysRearPASE 006016
ROD: EV_2CamSysRearPASE.rod
VCID: 3068C3656BF11A06B2-8064
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: HFS 020 0041
Serial number: 281015BJR00444
Coding: 004D12204000040000001002
Dataset: EV_DCURearDriveMINKLO 006003
Component: HBFS 020 0041
Serial number: 281015BJR00448
Dataset: EV_DCURearPasseMINKLO 006003
End-------------------------(Elapsed Time: 06:54)--------------------------
