(2021) (Golf 8), (1.5 eTSI) (DFYA)
AINils
Germany (AIB)
Wednesday,11,November,2020,12:09:44:56071
VCDS Version: 20.9.1.0 (x64)  HEX-NET2 CB: 0.4530.4
Data version: 20200919 DS322.0
VIN: WVWZZZCDZMW314405   License Plate: E-
Mileage:    Repair Order: NReimann
Chassis Type: CD-VW38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 36 3C 42 44 4B 4B 52
          5F 61 6C 75 82 A5 C4 CA CC D6 D7 8107 811E 811F 8120 8121
6C-Back-up Cam. -- Status: Cannot be reached 0100
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
8107-Antenna -- Status: OK 0000
Address 01: Engine (J623-DFYA)       Labels: None
   Part No SW: 05E 906 012 B    HW: 05E 907 309 G
   Component: R4 1.5l TFS   H20 9973
   Revision: 89H20000
   Coding: 012500322364150830086000000000000000000000000000
   ASAM Dataset: EV_ECM15TFS01105E906012B 002009
   ROD: EV_ECM15TFS01105E906012B.rod
   VCID: 9E6E3531403AE58BF57-80CA
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0CW 906 556     HW: 0CW 300 050 K
   Component: GSG DQ200G2.1 H06 0362
   Revision: 00006009    Serial number: CU502006225523
   ASAM Dataset: EV_TCMDQ200022 001001
   ROD: EV_TCMDQ200022.rod
   VCID: 8944766DE9B47233B05-80DC
   Part No SW: 5WA 614 517 BF    HW: 5WA 614 517 P
   Component: ESC           H14 0127
   Serial number: 62560000000103
   Coding: 24FC249022214470527B600006C86186ADB558504AC8670880BCA231018FF141822814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013051
   ROD: EV_Brake1ESCEPBMQB37W_013_VW38.rod
   VCID: 8D4C427D9DDC6E139CD-80D8
Address 05: Acc/Start Auth. (J518)       Labels: None
   Part No SW: 5WA 959 436 C    HW: 5WA 959 436 C
   Component: Kessy IOBOX   070 0703
   Serial number: ---------------
   ASAM Dataset: EV_Kessy37w 003022
   ROD: EV_Kessy37w_003_VW38.rod
   VCID: D4FA97197E767FDB133-8080
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 5WA 907 007 K    HW: 5WA 907 007 K
   Component: AC Automat    H31 3130
   Coding: 002000110211120010100010111011110000131100200000000000000000
   ASAM Dataset: EV_ACClimaPREVW38X 001098
   ROD: EV_ACClimaPREVW38X.rod
   VCID: CFF0987557501C032E1-809A
   Part No SW: 5WA 937 086 Q    HW: 5WA 937 086 J
   Component: BCM 37W BOSCH 016 0137
   Serial number: BXJ53F120920940
   ASAM Dataset: EV_BCM37w 005001
   VCID: DF90483507B0AC83BE1-FFFE
   Part No SW: 5WA 919 298     HW: 5WA 919 298
   Component: PLA 12K Kanal H04 0026
   Serial number: 000004082094560
   Coding: 8200026011
   ASAM Dataset: EV_EPHBO2CVW3800000 002027
   ROD: EV_EPHBO2CVW3800000_VW38.rod
   VCID: 93785405BBF8B8E34A9-80C6
1080304 - Parking Sensor(s); Rear
          B107B F0 [032] - Function Limitation due to External Factors
1113328 - Parking Sensor(s); Front
          B10FC F0 [032] - Function Limitation due to External Factors
          [Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse]
13688835 - Databus
          U1123 00 [040] - Received Error Message
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                    Reset counter: 22
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 08:27:49
13959168 - Parking Sensor(s); Rear
          [Geber für Einparkhilfe - Schmutz bzw. Eisbildung hinten]
   Part No SW: 5WA 907 572 A    HW: 5WA 907 572
   Component: ACC Bosch MQB H10 0246
   Coding: 2E0318FF0077404512474000000040054E4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 003012
   ROD: EV_FRONTRADARBOSCHVW380_003_VW38.rod
   VCID: CCCA8F79A646271B4B3-8098
0800 - Databus
          [FAULT_SWA_RELEVANT_ERROR]
                    Reset counter: 37
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 08:27:41
   Part No SW: 5WA 959 655 J    HW: 5WA 959 655 J
   Component: AirbagVW40    007 0636
   Serial number: 000000003C0J0R6
   Coding: 88FC000000C0C000000000400000000051540000205400004000F68000130065
   ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
   ROD: EV_AirbaVW40SMEVW38X_VW38.rod
   VCID: DEEE753100BAA58BB57-808A
1050634 - Databus
          [NWD: 0x322 PCR_01 error value PCR_Sensorstatus]
                    Reset counter: 45
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 08:27:48
1050629 - Databus
          [NWD: 0x322 PCR_01 error value PCR_Obj_vx_rel]
                    Reset counter: 45
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 08:27:49
1050630 - Databus
          [NWD: 0x322 PCR_01 error value PCR_Obj_vy_rel]
                    Reset counter: 45
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 08:27:49
1050631 - Databus
          [NWD: 0x322 PCR_01 error value PCR_Obj_TTC]
                    Reset counter: 45
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 08:27:49
1050632 - Databus
          [NWD: 0x322 PCR_01 error value PCR_Obj_Guete]
                    Reset counter: 45
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 08:27:49
1050633 - Databus
          [NWD: 0x322 PCR_01 error value PCR_Crashwahrscheinlichkeit]
                    Reset counter: 45
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 08:27:49
   Part No SW: 5H0 920 340 A    HW: 5H0 920 340 A
   Component: KOMBI         203 3450
   Coding: 04A400406B9C00080180620B2000080810300400
   ASAM Dataset: EV_DashBoardVDDMQB37W 003032
   ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
   VCID: A0120BC97A4ED37BC7B-80F4
16777018 - Control unit for information electronics 1
          U1054 00 [008] - No Communication
          [Audio_0x31 communication error bap_error_timeout heartbeat]
                    Reset counter: 47
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 08:48:02
16777020 - Control unit for information electronics 1
          [TEL_0x28 communication error bap_error_timeout heartbeat]
                    Reset counter: 47
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 08:48:02
16777022 - Control unit for information electronics 1
          [NAV_SD_0x32 communication error bap_error_timeout heartbeat]
                    Reset counter: 47
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 07:58:55
16777024 - No Communication with Diagnostic Gateway
          U0146 00 [009] - -
          [BCME_0x23 communication error bap_error_timeout heartbeat]
                    Reset counter: 7
                    Mileage: 10 km
                    Date: 2020.11.10
                    Time: 16:37:59
   Part No SW: 5WA 907 530 E    HW: 5WA 907 530 C
   Component: GW2020 High   752 7075
   Revision: --------    Serial number: 771049050020261
   Coding: 0000110D6700000003000000010301367301610902000100030100010001010000000000000000000000000000000000
   ASAM Dataset: EV_GatewMQB2020 004003
   ROD: EV_GatewMQB2020_VW38.rod
   VCID: CAC68961AC32392B79F-809E
2502759 - Unknown Error Code
          U1642 00 [040] - -
          [Emergency-call_module_no_communication_vlan]
                    Reset counter: 38
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 08:13:00
2494569 - Unknown Error Code
          U1643 00 [047] - -
          [Rearview_camera_system_control_module_no_communication_vlan]
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 07:55:52
2097338 - Unknown Error Code
          U1646 00 [046] - -
          [Antenna_control_module_1_no_communication_vlan]
                    Fault Frequency: 27
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 07:57:55
8482816 - Activatable Functions
          B18D3 F4 [044] - Authentication of Transmission Failed
          [Fs_id_authentification_failed]
                    Mileage: 384 km
                    Date: 2020.11.11
                    Time: 09:22:01
   Part No SW: 5WA 909 059 G    HW: 3Q0 909 059 A
   Component: EBKV          H06 0111
   Serial number: BPA085170920013
   Coding: 1302C104730000CE39E79C73000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 013023
   ROD: EV_BrakeBoostG2BoschVW37W_013_VW38.rod
107024 - Unknown Error Code
          U14E4 00 [032] - -
          [Scl_Getriebe_11_GE_Fahrstufe_Error]
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H09 0040
   Serial number: 20000221770011
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: B236F18124A251EB21F-80E6
   Part No SW: 5WA 959 760 H    HW: 5WA 959 760 H
   Component: MEM-FS        009 0361
   Serial number: 2090701KA02505
   Coding: 01589A400000B0508803010101010000000000212100000000000000215000
   VCID: D9E4662D199442B3C05-808C
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 D    HW: 2Q0 907 686 D
   Component: HRE_Master    H25 0276
   Serial number: 00000556198040
   Coding: 56A945D0
   ASAM Dataset: EV_HREntryHellaGen3Mstr 001013
   ROD: EV_HREntryHellaGen3Mstr_VW38.rod
   VCID: BB28DCA5F3E890A3F29-80EE
2228226 - Local Data Bus
          U10B8 00 [040] - Defective
          [Datenbus defekt - P-CAN]
                    Fault Frequency: 18
                    Reset counter: 38
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 08:21:28
2228229 - Local Data Bus
          U10BA 00 [040] - No Communication
          [keine Kommunikation - P-CAN]
                    Reset counter: 38
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 08:27:48
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0330
   Serial number: YE007THO08693
   Coding: 003B1220D200048000001000
   ROD: EV_DCU2DriveSideMAXHKLO_VW38.rod
   VCID: C9C4B66DA9343233705-809C
   Subsystem 1 - Part No SW: 5Q0 959 408 G    HW: 5Q0 959 164 C
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000043010626
   Coding: 110000
   Part No SW: 5WA 907 144 H    HW: 5WA 907 144 C
   Component: BASGEN1MQB37  101 1030
   Serial number: 00005567
   Coding: 0000000000000100000102010100010000000101010101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 006037
   ROD: EV_SteerAssisBASGEN1MQB37_006_VW38.rod
   VCID: CECE8571505A150B257-809A
   Part No SW: 5WA 907 338     HW: 5WA 907 338
   Component: FCM2020 Low   009 1372
   Serial number: 150151220335326
   Coding: 00000000090007CA00002F10020003000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW38X 002010
   ROD: EV_MultiModulContiVW38X_002_VW38.rod
   VCID: 8B484C65E3C86023829-80DE
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0330
   Serial number: YE007THQ05306
   Coding: 003B1020DE00048000801000
   ROD: EV_DCU2PasseSideMAXHKLO_VW38.rod
   VCID: C8C2B369B23ECB3B6FB-809C
   Subsystem 1 - Part No SW: 5Q0 959 407 G    HW: 5Q0 959 163 C
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000043348373
   Coding: 090000
   Part No SW: 5H0 035 816 B    HW: 5H0 035 816
   Component: MU-O-ND-EU    H56 1664
   Serial number: WG8LGM250920000
   Coding: 23800000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: EV_MUOIMQB37w_VW38.rod
   VCID: A61E1DD1186A3D4BBD7-80F2
Address 61: Battery Regul. (A6)       Labels: None
   Part No SW: 5WA 915 107     HW: 5WA 915 107
   Component: BMS_48V_LiIon H10 0442
   Serial number: 252000006874800
   ASAM Dataset: EV_BMSmHevCATL 003004
   ROD: EV_BMSmHevCATL.rod
   VCID: 845A6759CE962F5BC33-80D0
28709 - HV Battery Pack
          P0A7D 00 [174] - State of Charge Low
          [BMS_SOC_LL1]
                    Fault Frequency: 122
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 5WA 980 556 A    HW: 5WA 980 556 A
   Component: RV eCompact   H21 0193
   Serial number: FCL-K2003.09.20
   Coding: 02030004E43000
   ASAM Dataset: EV_CamSysRVCCompaFicos 009020
   ROD: EV_CamSysRVCCompaFicos_VW38.rod
10489856 - No Basic Setting
          B2010 00 [046] - -
          [System not calibrated]
                    Fault Frequency: 13
13705507 - Databus
          U1121 00 [047] - Missing Message
          [Oldbit-monitoring Gateway_72.Anhaenger_01_alt]
                    Fault Frequency: 13
                    Mileage: 589824 km
                    Date: 2021.05.03
                    Time: 25:60:16
   Part No SW: 5WA 035 284 A    HW: 5WA 035 284 A
   Component: OCU3HMQB37W   H12 0067
   Serial number: 0000000006VIVR4
   Coding: 023800009068AC209405460071502E07
   ASAM Dataset: EV_OCU3HMQB37W 001039
   ROD: EV_OCU3HMQB37W_001_VW38.rod
   VCID: C4DAA7598E16EF5B833-8090
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 5H1 919 608     HW: 5H1 919 608
   Component: HeadupDisplay H15 0027
   Coding: 5740C0
   ASAM Dataset: EV_HeadUpDisplMQB37W 001017
   ROD: EV_HeadUpDisplMQB37W.rod
   VCID: EFB038F5F7103C030E1-80BA
16777040 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [NAV_0x32_communication_error_bap_error_timeout_heartbeat]
                    Mileage: 359 km
                    Date: 2020.11.11
                    Time: 08:11:46
   Part No SW: 5WA 980 653 A    HW: 5WA 980 653
   Component: MQB MFK 3.0   H05 3129
   Serial number: E26735111202720
   Coding: 00000888116CC040109E40001030008000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005050
   ROD: EV_MFK3ValeoMQB_005_VW38.rod
   VCID: CDCC827D5D5C2E135CD-8098
1124435 - Activatable Functions
          B18D3 F4 [008] - Authentication of Transmission Failed
                    Reset counter: 1
                    Mileage: 10 km
                    Date: 2020.11.10
                    Time: 16:57:41
1124501 - Databus
          [APS_04_US_Fehler_VRS]
                    Reset counter: 2
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 08:34:03
1124499 - Databus
          [APS_04_US_Fehler_VLS]
                    Reset counter: 2
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 08:34:03
1124502 - Databus
          [APS_04_US_Fehler_HRS]
                    Reset counter: 2
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 08:34:03
1124500 - Databus
          [APS_04_US_Fehler_HLS]
                    Reset counter: 2
                    Mileage: 9 km
                    Date: 2020.11.10
                    Time: 08:34:03
Address C4: DC/DC Converter (A7)       Labels: None
   Part No SW: 5WA 959 663     HW: 4K0 959 663
   Component: DCDC_GEN_2 H20 0111
   Serial number: DC20383000356
   ASAM Dataset: EV_DCDC48VFLEXAU581 004003
   ROD: EV_DCDC48VFLEXAU581_004_VW38.rod
Address CA: Sunroof (J245)       Labels:* None
   Part No SW: 4K1 907 594 CB    HW: 4K1 907 594
   Component: SAD_STG_1     006 0040
   Coding: 608000738001
   VCID: F7A000958F4074C3D61-80A2
   Slave 2:
Address CC: Starter-Generator (C29)       Labels: None
   Part No SW: 05E 903 018 G    HW: 05E 903 018 G
   Component: iBSG4U_000    H16 0223
   Serial number: 5200923105823
   ASAM Dataset: EV_SGCM600210005E903018G 002004
   ROD: EV_SGCM600210005E903018G.rod
   Part No SW: 992 941 571 AE    HW: 992 941 571 A
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
   VCID: E59C5ADD25ECF65374D-80B0
   Component: LED1R         H08 9202
131337 - Databus
          U1121 00 [172] - Missing Message
          [CAN message LED_x_SABL missing]
                    Reset counter: 0
                    Mileage: 20 km
                    Date: 2020.11.10
                    Time: 17:37:23
Address 8107: Antenna (J666)       Labels:* None
   Part No SW: 5WA 035 741 A    HW: 5WA 035 741 A
   Component: TrxModulHigh  H10 0068
   Serial number: 0000000007VIHJ8
   Coding: 02380011440080
   ASAM Dataset: EV_TrxMLGEMQB37W 005006
   ROD: EV_TrxMLGEMQB37W.rod
   VCID: C2D6A1419402E16BB1F-8096
0081 - Databus
          U1121 00 [040] - Missing Message
          [Ethernet-Datenbus - fehlende Botschaft- POS_GNSS_05_Position]
                    Fault Frequency: 0
0083 - Unknown Error Code
          U1541 00 [046] - -
          [Ethernet-Datenbus - fehlende Botschaft von der Informationselektronik]
                    Reset counter: 7
                    Mileage: 388 km
                    Date: 2020.11.11
                    Time: 11:47:16
                    11.90 V
Address 811E: Burglary Protection FL (J518)       Labels: None
   Part No SW: 5WA 962 133 B    HW: 5WA 962 133 B
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w_002_VW38.rod
   VCID: C7C0B055BF20C443661-8092
Address 811F: Burglary Protection FR (J518)       Labels: None
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w_002_VW38.rod
Address 8120: Burglary Protection RL (J518)       Labels: None
   ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518)       Labels: None
   ASAM Dataset: EV_RSADHR37w 002013
End----(Elapsed Time: 02:51, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
massimo23
Drogheda, Co. Louth, Ireland
C?ID=364379
Hi AINils do you the the side assist with Rear traffic alert?
I ordered the Golf 8 eHybrid which should arrive in January and have park assist and side assist included but I am not sure if the RTA is available.
AINils
Germany (AIB)
It`s not my car, never will buy this piece of shit. :cool: It`s a car of my colleague. Will check you question later If Iam back in office.
Golf 8 is more bad than Golf 3, bad quality and User Interface is not usable for 99% of user. Iam experienced user but it`s complicated to use.
Edit:
Cars has this PR Code
Spurwechsel/Spurhalteassistent7Y1Spurwechselassistent
massimo23
C?ID=364379
Thanks for that.
There are those who will hate this car and those that will love it.
I know many on both sides.
This is my first Golf. I have a Polo Beats and really love it.
The only way to be sure is if he has the RTA setting in the driver assist menu.
The pr-code is the same as what I have but nothing specific about rear traffic alert.
When they updated the Golf 8 brochure with cars been built after week 48 2021 models they added the rear traffic alert in it.
When I will receive the car I will upload the scan and maps.
I created an English Golf 8 Gte manual in Pdf with index. If anyone needs it I will give a link for the file.
AINils
Germany (AIB)
I have all information within coding and adaptions. Car war build in october 2020. If I sse my colleague next time will check that for you in setting of infotainment. But due to corona it is not allowed to see a part of our team.
Checked coding again, in 3C, Byte 1, bit 7-9 says "00 Rear_Cross_traffic_alert,uncoded"
So don`t think car has RCT
I kinda liked my Golf 3. That was the car I had when I started this business. ;)
Yes Stephan told me many times. We talked about beginnings with Odin during Lunch. Hope to met you in near future to talk about these nice story
massimo23
C?ID=364379
Sorry for my ignorance but i thought the total bits are 0 to 7 (8 total) so I am confused with bit 7-9.
AINils
Germany (AIB)
There is no law that sets a byte to 8 bits. It has merely been established that way. In most cases, this is handled so that the ASCII standard allows it. But VW seems to have adapted the spectrum for newer ECUs. Since the data comes from the experimental label and I have recorded this on my screen capture, the info will probably be correct.
