Hi All.
Yesterday I fitted a westfalia towbar with specific wiring kit to my SQ5 8R and today while trying to code it I have a few faults I hope the more knowledgable among you could help me out with. Things I changed - First in 19 Can Gateway I checked 69-Trailer. It then asked me to used default setting or current settings in the module supplied so I choose to use the CURRENT settings. Then 01 - Engine, checked byte 5 bit 4 which changed the code from 26 to 36 and did the same for 6C - Back Up Cam.
Now on the instrument display I have ESC and TPMS faults. Below is the auto scan. I always had 46 and 5F faults so its just 01 Engine I want to rectify.
Forgot to add, after reading another post on here from another member with a similar fault, I tried to change a setting in 03 ABS but was allowed/didn’t accept the coding change.
Thanks in advance
Thanks in advance
VIN: License Plate:
Mileage: 57870km-35958mi Repair Order:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62
69 6C 6D 72 A9 AC C0
VIN: Mileage: 57870km-35958miles
Address 01: Engine (J623-CVUC) Labels:. 059-907-401-V2.clb
Part No SW: 8K5 907 589 C HW: 4G0 907 589 B
Component: 3.0BTD EDC17 H23 0008
Revision: 54H23---
Coding: 2A2A4032253603030000
Shop #: WSC 37635 003 104857
ASAM Dataset: EV_ECM30BTD0118K5907589C 001010
ROD: EV_ECM30BTD0118K5907589C.rod
VCID: 41DEB525910D43631DD-8014
U1113 00 [039] - -
Mileage: 57874 km
Date: 2020.11.10
Time: 12:40:29
Engine speed: 0.00 /min
Coolant temperature: 22 °C
Intake air temperature: 16 °C
Voltage terminal 30: 11.960 V
Cruise Control System (CCS): switch position-Bits 0-7: 129
Cruise Control System (CCS): status-Bits 0-7: 236
Cruise control switch-off: irreversible-Bits 0-7: 255
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise Control System: specified speed: 0.00 km/h
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
U1113 00 [039] - -
Mileage: 57874 km
Date: 2020.11.10
Time: 12:40:29
Part No SW: 8R0 927 158 AR HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H19 1006
Revision: --H19---
VCID: 0D4659159DD5D703295-8058
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 BA HW: 8R0 907 379 BA
Component: ESP8 quattro H09 0020
Coding: 355DCC01
Shop #: WSC 77879 028 461382
VCID: 00587021DA078A6B523-8054
Part No SW: 8K0 907 064 GH HW: 8K0 907 064 FH
Component: BCM2 2.0 H11 0621
Coding: 01B54040000000000000
VCID: 7CA004D1B6EFEE8B0EB-8028
Subsystem 1 - Part No SW: 8K0 959 754 BM HW: 8K0 959 754 BM
Serial number: 3715000027263009
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 3215000087853003
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K2 820 043 AQ HW: 8K2 820 043 AQ
Revision: D1000000 Serial number: 01130520150499
Coding: 3625028080
Shop #: WSC 06335 000 00000
VCID: 78A818C182D7C2AB6A3-802C
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00001072684901
Coding: 260000108034AFE0018140C300001D0D0F9DC708A7090229000008004400010200020034000000
VCID: 7AAC02C9BCDBD0BB1C7-802E
Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 150416 H12 0050
Serial number: 90243015150407200811
Coding: 01DD13
Component: G397_RLFS H06 0004
Serial number: 20297023
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000003004151175
Subsystem 4 - Part No SW: 4G0 907 410 HW: 4H0 907 410
Component: EHL2 V07.03 H30 0030
Serial number: 0000000094CE01E7836D
Subsystem 5 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 6 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 8C580AA7000000000001
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 G HW: 8R0 959 655 G
Component: AirbagVW-AU10 H48 0610
Serial number: 003JPDC38EW0
Coding: 30473531313030303030554A305238523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 48C8A801B237722BDA3-801C
Serial number: 6334MSME5068731DG
Serial number: 6344MSME4E784826R
Serial number: 6352QSME51540A4EK
Serial number: 6362QSME5A54314EO
Serial number: 63732SME2E4B48425
Serial number: 63832SME58560A641
Address 16: Steering wheel
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 950 T HW: 8R0 920 950 T
Component: KOMBIINSTR. H35 0567
Revision: 00200000 Serial number: 03F43G65G
Coding: 33A722000B012600010000
VCID: 47CAAB3DBFA97D53D39-8012
Part No SW: 8R0 907 468 T HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0070
Revision: 1Y090032 Serial number: 3241Y154230AC2
Coding: 80CD07FF00
VCID: 50F880614AE7BAEB823-8004
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Serial number: 1073256603
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Serial number: 15126005166021200410
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000148201074
Coding: 01781300000000000000
VCID: 42DCBA29948B587B047-8016
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000148983754
Coding: 011D02215E01440004
VCID: 4FFA831D57D9A5139B9-801A
Part No SW: 8R0 909 144 P HW: 8R0 909 144 B
Component: RCEPS H43 0510
Revision: 00001000 Serial number: 0027761902
Coding: 100000010001
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X_008.rod
VCID: 45D6A13585256F43215-8010
Revision: 00002001 Serial number: 0182353994
Coding: 013B0622B0B974948720053680040047
Component: GTO BF H01 0080
Serial number: 00000000000000970994
Subsystem 2 - Part No: 8K0 951 177
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H03 0090
Subsystem 5 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H03 0090
00218 - Humidity Sensor (G355)
Reset counter: 221
Mileage: 57874 km
Date: 2020.11.10
Time: 12:40:29
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813043839606
VCID: 2D06F9953D15B703C95-8078
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000149376373
VCID: 4EC49E1950D3AC1B90F-801A
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 20000000626059
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A2CC2C9FCDB10BB5C7-806E
Part No SW: 4G0 035 061 S HW: 4G0 035 061
Component: Radio U DAB H60 0154
Revision: AB001007 Serial number: 109EU0F8036106
Coding: 010103010000000001
Part No SW: 8R2 035 670 M HW: 8R2 035 670 J
Component: H-BNT-EU H50 1036
Revision: -------- Serial number: 517EX0FB001138
Coding: 1A0101060205A1EF45828B5E00000403040000000000000000
VCID: 3E24CED9E0733C9B60F-806A
Subsystem 1 - Part No: 8R0 060 884 GS
Component: EUR 2020 3001
Component: DU7 High H42 0104
Serial number: A130EQ0F3353903
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Serial number: 00000002237810
Component: CD-Database 6208
Reset counter: 221
Mileage: 57874 km
Date: 2020.11.10
Time: 12:40:29
Text: DUA130,Front,M,0,0,6
03623 - Invalid Security/Release Code
Reset counter: 221
Mileage: 57874 km
Date: 2020.11.10
Time: 12:40:28
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000149986978
Coding: 010C02204001240004
VCID: 46D4A639B8A3645B28F-8012
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 D HW: 8K0 907 383 D
Component: ConWys Trailer H09 0100
Revision: 1G001001 Serial number: 00000173782896
Coding: 0100000000000000
Shop #: WSC 00375 223 87350
VCID: 3536D1F5D545FFC3B15-8060
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H07--- Serial number: 525PA8-J27A2M4
Coding: 1032010
VCID: 3430ECF1D23FE6CB86B-8060
Address 6D: Trunk Elect. (J605) Labels: 4L0-910-945.clb
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D26C9D5ED752783795-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000149986910
Part No SW: 8R0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0007
Serial number: 150428201311
VCID: 79AE1DC5B95DDBA315D-802C
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 151180717
ROD: EV_RDCMA00100.rod
VCID: 2D06F9953D95B703C95-8078
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 8R0 907 160 A HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H10 0008
Serial number: 150227200125
ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
ROD: EV_ActuaForExterNoiseUDS.rod
VCID: 323CEAE924ABE8FB947-8066
End----------(Elapsed Time: 02:34, VBatt start/end: 12.1V/12.0V)-----------
