VW Scirocco
bdaw
Miri, Malaysia
C?ID=392177
hi all,
im having 1 unit VW Scirocco having funny problem. the car sometimes cannot start or engage gear during the Christmas tree light at meter console. there is also 3 times buzzer sound when the problem pop up.
Tuesday,10,November,2020,11:44:22:16992
VCDS Version: 20.4.2.0  HEX-NET CB: 0.4513.4
VIN: WVWZZZ13ZAV403866   License Plate:
Chassis Type: 13-VW36 (1K0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 25 2E 37 42 44 46 4F 52 56
VIN: WVWZZZ13ZAV403866   Mileage: 114160km-70935miles
02-Auto Trans -- Status: Malfunction 1010
04-Steering Angle -- Status: Sporadic communication error 1000
10-Park/Steer Assist -- Status: Malfunction 1010
14-Susp. Elect. -- Status: Malfunction 1010
15-Airbags -- Status: Malfunction 1010
25-Immobilizer -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: Malfunction 1010
44-Steering Assist -- Status: Malfunction 1010
Address 01: Engine (CAW)       Labels:. 06J-906-026-CAW.clb
   Part No SW: 06J 906 026 AR    HW: 06J 906 026 D
   Component: MED17.5             5271
   Revision: A7H06---    Serial number:
   Coding: 040300031C070060
   Shop #: WSC 66565 257 00032
   VCID: 7AB8D299359D39565D-802E
11 Faults Found:
049154 - Powertrain Databus
               U0002 - 000 - No Communications - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 14:41:13
                    RPM: 757 /min
                    Load: 32.9 %
                    Temperature: 57.0°C
                    Temperature: 36.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.097 V
               U0155 - 000 -  - Intermittent
                    Fault Frequency: 20
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 15:24:24
                    RPM: 760 /min
                    Load: 31.8 %
                    Temperature: 81.0°C
                    Temperature: 43.0°C
                    Voltage: 13.843 V
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 000 -  - Intermittent
                    Fault Frequency: 15
                    Mileage: 114167 km
                    Date: 2015.03.30
                    Time: 02:04:27
                    Temperature: 54.0°C
                    Temperature: 39.0°C
                    Voltage: 12.319 V
049682 - Steering Column Control Module
               U0212 - 000 - No Communications - Intermittent
                    Fault Frequency: 16
                    Mileage: 114167 km
                    Date: 2015.03.30
                    Time: 02:04:27
                    Temperature: 54.0°C
                    Temperature: 39.0°C
                    Voltage: 12.319 V
049478 - No Communication with Diagnostic Gateway
               U0146 - 000 -  - Intermittent
                    Fault Frequency: 18
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 83.0°C
                    Temperature: 43.0°C
                    Voltage: 12.446 V
049409 - No Communication with Transmission Control Module
               U0101 - 000 -  - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    RPM: 744 /min
                    Load: 36.8 %
                    Temperature: 47.0°C
                    Temperature: 28.0°C
                    Voltage: 13.970 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
               P1624 - 000 -
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 15:22:38
                    RPM: 768 /min
                    Load: 40.0 %
                    Temperature: 80.0°C
                    Temperature: 44.0°C
                    Voltage: 13.462 V
049153 - Powertrain Databus
               U0001 - 000 - Unspecified Malfunction - Intermittent
                    Mileage: 114167 km
                    Date: 2015.03.30
                    Time: 02:42:01
                    Temperature: 67.0°C
                    Temperature: 36.0°C
                    Voltage: 12.446 V
008852 - Fuel Pressure Regulator Valve (N276)
               P2294 - 000 - Open Circuit - Intermittent
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 00:22:37
                    Temperature: 66.0°C
                    Temperature: 44.0°C
                    Voltage: 12.319 V
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    RPM: 751 /min
                    Load: 36.8 %
                    Temperature: 49.0°C
                    Temperature: 28.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.843 V
049489 - No Communications with Airbag Control Module
               U0151 - 000 -  - Intermittent
                    Fault Frequency: 12
                    RPM: 770 /min
                    Load: 36.8 %
                    Temperature: 48.0°C
                    Temperature: 28.0°C
                    Voltage: 13.843 V
   Part No SW: 02E 300 051 R    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1926
   Revision: 00044002    Serial number: 00000905061016
   Shop #: WSC 00020 000 90108
   VCID: 2208CAF9FD8D919625-8076
12 Faults Found:
28775 - No Communication with Gear Selector Module
            U0103 - 000 -  - Intermittent - MIL ON
                    Fault Frequency: 255
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 14:41:13
18259 - Powertrain Data Bus
            P1851 - 000 - Missing Message from ABS Controller - Intermittent
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:48:33
18258 - Powertrain Data Bus
            P1850 - 000 - Missing Message from ECU - MIL ON
                    Fault Status: 11100000
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 14:41:13
18036 - Powertrain Data Bus
            P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:48:33
18097 - Powertrain Data Bus
            P1689 - 000 - Implausible Message from Elect. Load Controller - Intermittent
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:48:33
18270 - Powertrain Data Bus
            P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:48:35
18275 - Powertrain Data Bus
            P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
18274 - Powertrain Data Bus
            P1866 - 000 - Missing Messages - MIL ON
18288 - Powertrain Data Bus
            P1880 - 000 - Missing Message from Diagnostic Gateway - Intermittent
18262 - Powertrain Data Bus
            P1854 - 000 - Hardware Malfunction
                    Mileage: 114167 km
                    Date: 2015.04.03
                    Time: 01:13:20
01196 - Engine-Transmission Data Bus
18082 - Powertrain Data Bus
            P1674 - 000 - Implausible Message from Instrument Cluster - Intermittent
                    Mileage: 114167 km
                    Date: 2015.04.03
                    Time: 00:07:33
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 763B60F5092200FD6E1306EA901F0081B10000
   Shop #: WSC 00046 123 12345
   VCID: 7AB8D299F59D39565D-802E
10 Faults Found:
01312 - Powertrain Data Bus
                    Fault Status: 00101110
                    Reset counter: 0
                    Mileage: 114167 km
                    Date: 2015.03.30
                    Time: 15:53:24
                    Count: 2
                    Count: 4
                    Count: 8704
                    Count: 161
                    Count: 49920
                    Count: 63488
                    Reset counter: 118
                    Count: 2
                    Count: 12
                    Count: 12288
                    Count: 8207
                    Count: 43264
                    Count: 65279
01310 - Level Control System Control Module (J197)
                    Reset counter: 0
                    Mileage: 114167 km
                    Count: 2
                    Count: 14
                    Count: 24576
                    Count: 8199
                    Count: 43264
                    Count: 65024
                    Reset counter: 0
                    Mileage: 114167 km
                    Date: 2015.03.30
                    Time: 00:36:16
                    Count: 2
                    Count: 14
                    Count: 24576
                    Count: 8194
                    Count: 43776
                    Count: 65024
                    Reset counter: 118
                    Mileage: 114167 km
                    Date: 2015.03.30
                    Time: 15:54:55
                    Count: 2
                    Count: 12
                    Count: 8192
                    Count: 8195
                    Count: 45568
                    Count: 54016
                    Count: 64768
                    Reset counter: 118
                    Mileage: 114167 km
                    Date: 2015.03.30
                    Time: 00:36:16
                    Count: 2
                    Count: 14
                    Count: 24576
                    Count: 8226
                    Count: 43776
                    Count: 65024
                    Reset counter: 120
                    Date: 2029.08.00
                    Time: 18:02:39
                    Count: 288
                    Count: 8822
                    Count: 256
                    Count: 8223
                    Count: 8226
                    Count: 257
                    Count: 26486
                    Count: 288
                    Reset counter: 118
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:46:39
                    Count: 2
                    Count: 14
                    Count: 28672
                    Count: 166
                    Count: 44800
                    Reset counter: 0
                    Mileage: 198661 km
                    Date: 2002.08.01
                    Time: 00:16:07
                    Count: 2311
                    Count: 187
                    Count: 294
                    Count: 288
                    Count: 1793
                    Count: 166
                    Count: 30209
                    Reset counter: 118
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:48:33
                    Count: 2
                    Count: 14
                    Count: 25088
                    Count: 8255
                    Count: 49408
                    Count: 1
   Part No SW: 1K0 907 044 DA    HW: 1K0 907 044 DA
   Component: ClimatronicPQ35 133 1213
   Revision: 00133026    Serial number: 00000000000000
   VCID: 699A9DD5403B82CEA4-803C
11 Faults Found:
            013 - Check DTC Memory
00538 - Reference Voltage
00757 - Right Vent Temp Sensor (G151)
            010 - Open or Short to Plus
   Part No SW: 5K0 937 086     HW: 5K0 937 086
   Component: BCM PQ35 M    008 0019
   Revision: BC008001
   Coding: 48100A3B9025E100408800803400002643553B88436D8D605C8000000000
   Shop #: WSC 00020 790 12345
   VCID: 71AAF5B5A8EB7A0EEC-8024
   Subsystem 1 - Part No: 1K8 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 11020  22  0602
   Coding: 009795
   Component: RLS 200509 05  54  0402
   Coding: 0330ED
   Subsystem 4 - Part No: 1K8 951 171
30 Faults Found:
                    Fault Status: 00101011
                    Reset counter: 161
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 14:24:13
                        Term 15 Off
                    Voltage: 12.65 V
                    Fault Frequency: 8
                    Reset counter: 161
                    Mileage: 114167 km
                    Date: 2015.03.30
                    Time: 15:49:05
                    Voltage: 14.00 V
                    Fault Status: 00101001
                    Reset counter: 161
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 14:24:13
                        Term 15 Off
                    Voltage: 12.65 V
00927 - Terminal 30 (Right)
                    Reset counter: 161
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 14:24:13
                        Term 15 Off
                    Voltage: 12.65 V
                    Fault Status: 01101010
                    Reset counter: 123
                    Mileage: 114167 km
                    Date: 2015.04.03
                    Time: 00:23:07
                    Voltage: 12.05 V
                    Reset counter: 123
                    Mileage: 114167 km
                    Date: 2015.04.03
                    Time: 00:22:56
                    Voltage: 11.90 V
00985 - Right Tail Light (M2)
                    Fault Status: 00101010
                    Reset counter: 161
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 14:34:51
                    Voltage: 12.40 V
                    Reset counter: 161
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 14:34:51
                    Voltage: 12.40 V
                    Fault Frequency: 64
                    Reset counter: 123
                    Voltage: 12.80 V
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:37:30
                    Voltage: 13.75 V
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:37:30
                    Voltage: 13.75 V
01259 - Fuel Pump Relay (J17)
                    Reset counter: 161
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 14:24:13
                        Term 15 Off
                    Voltage: 12.65 V
                    Fault Status: 00100101
                    Reset counter: 161
                        Term 15 Off
                    Voltage: 12.45 V
                    Fault Frequency: 21
                    Reset counter: 163
                        Term 15 Off
                    Voltage: 12.75 V
                    Fault Frequency: 63
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:48:37
                    Voltage: 13.65 V
                    Fault Frequency: 14
                    Reset counter: 163
                    Voltage: 12.60 V
                    Fault Frequency: 155
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:48:36
                    Voltage: 13.70 V
                    Reset counter: 158
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 10:46:43
                        Term 15 Off
                    Voltage: 12.70 V
                    Reset counter: 118
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:45:37
                    Voltage: 12.75 V
                    Reset counter: 161
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 14:34:51
                    Voltage: 12.40 V
01501 - Bulb for Blinkers; Rear Left (M6)
                    Reset counter: 161
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 14:34:51
                    Voltage: 12.40 V
01502 - Bulb for Rear Fog; Left (L46)
                    Reset counter: 161
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 14:34:51
                    Voltage: 12.40 V
                    Reset counter: 161
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 14:34:51
                    Voltage: 12.40 V
01800 - Light Switch (E1)
                    Fault Status: 01101000
                    Reset counter: 123
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:37:27
                    Voltage: 13.75 V
                    Fault Status: 01100010
                    Reset counter: 118
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:37:28
                    Voltage: 13.75 V
                    Reset counter: 118
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:37:31
                    Voltage: 13.75 V
                    Reset counter: 118
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:37:31
                    Voltage: 13.75 V
03156 - Sensor for Anti-Theft System (G578)
                    Reset counter: 158
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 10:23:11
                    Voltage: 13.90 V
                    Reset counter: 161
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 14:24:13
                        Term 15 Off
                    Voltage: 12.65 V
                    Reset counter: 161
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 14:24:13
                        Term 15 Off
                    Voltage: 12.65 V
Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
   Part No SW: 1K0 919 475 K    HW: 1K0 919 475 K
   Component: PARKHILFE     005 1706
   Revision: 00005000    Serial number: 0 263 004 388
   Coding: 100101
   Shop #: WSC 00020 790 00000
   VCID: 3A381299B51DF9561D-806E
                    Fault Frequency: 35
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2015.04.03
                    Time: 01:24:36
01543 - Parking Aid Warning Chime (H15)
                    Fault Status: 01101001
                    Reset counter: 123
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0070
   Revision: 00000000    Serial number: 12050900570001
   Coding: 000180
   VCID: 271EDBED56AF74BE72-8072
8 Faults Found:
03264 - Functionalty Shut Off
            000 - - - MIL ON
                    Reset counter: 123
                    Error Code: 9
                    Bin. Bits: 00000000
01769 - Sensor for Vehicle Leveling; Front Right (G289)
                    Reset counter: 118
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:34:19
00142 - Left Front Dampening Adjustment Valve (N336)
            011 - Open Circuit - MIL ON
                    Fault Status: 11101011
                    Reset counter: 118
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:34:22
                    Bin. Bits: 00000000 00100000
00143 - Front Right Dampening Adjustment Valve (N337)
                    Reset counter: 118
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:34:22
00144 - Rear Left Dampening Adjustment Valve (N338)
                    Reset counter: 118
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:34:22
00145 - Rear Right Dampening Adjustment Valve (N339)
                    Reset counter: 118
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:34:22
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2015.04.03
                    Time: 00:07:51
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00000110
                    Fault Frequency: 8
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2015.03.30
                    Time: 18:28:01
                    Bin. Bits: 00000000 00000011
   Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
   Component: 0H AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 003D1D01698B
   Coding: 0012360
   VCID: 6FAEF3CD7EDF6CFEFA-803A
   Subsystem 1 - Serial number: 6332MSME47346C05C
   Subsystem 2 - Serial number: 6342MSME40312E4FF
   Subsystem 3 - Serial number: 6352QSME702D013EH
   Subsystem 4 - Serial number: 6362QSME312D02245
            014 - Defective - Intermittent - MIL ON
            004 - No Signal/Communication - Intermittent - MIL ON
   Part No SW: 1K0 953 549 CE    HW: 1K0 953 549 CE
   Component: J0527           055 0111
   Coding: 0001602
   VCID: 77BECBAD068F243E22-8022
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000131
00002 - Transmission Control Unit
   Part No SW: 1K8 920 971     HW: 1K8 920 971
   Component: KOMBI         H05 0206
   Coding: 470B00
   Shop #: WSC 00020 999 00000
   VCID: 70ACF0B1ABE17306E3-8024
8 Faults Found:
1416448 - Oil Level Thermal Sensor
          B1041 29 [008] - Signal Implausible
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2020.11.10
                    Time: 00:03:06
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
          U0056 00 [008] - Performance
          [Datenbus Kombi/Fahrwerk: keine Kommunikation]
                    Fault Frequency: 18
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2020.11.05
                    Time: 10:05:36
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Motor: keine Kommunikation]
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2020.11.05
                    Time: 09:48:32
12648704 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Getriebe: keine Kommunikation]
                    Fault Frequency: 250
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2020.11.05
                    Time: 09:46:38
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Bremse: keine Kommunikation]
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2020.11.05
                    Time: 09:48:32
12669184 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Airbag: keine Kommunikation]
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2020.11.05
                    Time: 09:48:32
13638912 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Lenkhilfe: keine Kommunikation]
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2020.11.05
                    Time: 09:48:32
12671232 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Einparkhilfe: keine Kommunikation]
                    Fault Frequency: 163
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2020.11.05
                    Time: 09:48:35
   Part No SW: 1K0 907 530 AB    HW: 1K0 907 951
   Component: J533  Gateway   H06 0081
   Revision:   H06 01    Serial number: 140509F1001611
   Coding: EDA81F06400213004001
   VCID: 679E9BED562FB4BEB2-8032
13 Faults Found:
                    Fault Frequency: 102
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:48:36
                    Fault Frequency: 129
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:48:34
                    Fault Frequency: 135
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:46:40
                    Fault Frequency: 128
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:48:34
                    Fault Frequency: 150
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:48:34
                    Fault Frequency: 162
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:48:34
                    Fault Frequency: 151
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:48:34
                    Fault Status: 00110100
                    Reset counter: 161
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 00:24:28
                    Fault Frequency: 14
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2015.03.30
                    Time: 02:23:28
                    Reset counter: 161
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 00:24:28
                    Reset counter: 118
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:35:25
00471 - Control Module for Elect. Regulated Dampers (J250)
                    Fault Frequency: 78
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:48:36
03075 - Parallel Parking Assistance Control Module (J791)
                    Fault Frequency: 82
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 09:48:36
   Component: IMMO          H05 0206
Address 2E: Media Player 3
Address 37: Navigation
   Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
   Component: Tuer-SG         009 2116
   Coding: 0016949
   VCID: 393A0D95701BF24E14-806C
01034 - Electric Window Thermal Protection Active; Driver
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 184    2901
   Revision: 00H15000
   VCID: 2F2E33CDBE5F2CFEBA-807A
                    Fault Frequency: 233
                    Reset counter: 163
                    Mileage: 114167 km
                    Date: 2015.04.03
                    Time: 01:13:20
                    Voltage: 14.38 V
                        DU
                    Temperature: 38.0°C
                    RPM: 1498 /min
                    Speed: 6.0 km/h
                    Speed: 50.0 km/h
                    Count: 3
            000 - - - MIL ON
                    Battery Volts: 13.0 V
                        PD
                    Temperature: 29.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Component: EZE_2         H06 0081
   Coding: 01030100
   VCID: 668096E99125ADB689-8032
   Subsystem 1 - Part No SW: 6R0 959 591     HW: 6R0 959 591
   Component: J245/J878  H04 0054
   Serial number: 915400062888
   Coding: 000005
01512 - Control Module for Sliding Roof
                    Reset counter: 161
                    Mileage: 114167 km
                    Date: 2015.03.29
                    Time: 11:20:51
   Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
   Coding: 0016948
   VCID: 3A381299751DF9561D-806E
01035 - Electric Window Thermal Protection Active; Passenger
01817 - Exterior Door Handle Switch in Pass. Door (F273)
Address 56: Radio
End----------(Elapsed Time: 01:37, VBatt start/end: 14.4V/14.5V)-----------
iichel
Eindhoven, NB, NL
C?ID=284912
Hey, this car is a big mess.
Could you perhaps do something?
Go to VCDS, applications, gateway installation list and wait a bit. You'll probably see a big red list of all the modules in your Scirocco.
Then, in the left hand column click 'clear all DTCs' and cycle the ignition.
Now make a new autoscan please and see when the errors return for the first time. Then make a new scan.
Why? Well, this car is a big list of many many intermittent errors and it's very difficult to see what's going on.
It looks like the gateway or BCM is sometimes losing power/connection to just about everything (comfort CAN, powertrain CAN, LIN).
What's the history of this car? BCM ever removed? Accident? Signs of corrosion, bad module somewhere?
My first feeling is that the BCM and/or gateway have been removed with ignition on given that it's lost connection to everything including horn, light, sunroof, you name it.
Or something like a faulty ignition switch or steering column module.
bdaw
Miri, Malaysia
C?ID=392177
hi, yup... this car is having a big mes...
i have clear the DTC and below is the list of problem still occur.
the history of the car, the owner was driving & hit a pot hole, then all the Christmas tree light lights up. after that the car cannot engage any gear at all. we did suspect is the gateway faulty as we disconnect the gateway to test, the same Christmas tree lights on the meter console.
Tuesday,10,November,2020,16:34:26:16992
Gateway Installation List:  1K0 907 530 AB
bdaw
Miri, Malaysia
C?ID=392177
hi all, sorry.
here is the full scan
Wednesday,11,November,2020,08:19:02:16992
11 Faults Found:
                    Mileage: 114167 km
                    Date: 2015.03.30
                    Time: 14:41:13
                    RPM: 757 /min
                    Load: 32.9 %
                    Temperature: 57.0°C
                    Temperature: 36.0°C
                    Voltage: 14.097 V
                    Fault Frequency: 21
                    Mileage: 114167 km
                    Date: 2015.03.30
                    Time: 15:24:24
                    RPM: 760 /min
                    Load: 31.8 %
                    Temperature: 81.0°C
                    Temperature: 43.0°C
                    Voltage: 13.843 V
                    Fault Frequency: 16
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 01:19:49
                    Temperature: 27.0°C
                    Temperature: 30.0°C
                    Voltage: 14.478 V
                    Fault Frequency: 16
                    Mileage: 114167 km
                    Date: 2015.03.31
                    Time: 02:04:27
                    Temperature: 54.0°C
                    Temperature: 39.0°C
                    Voltage: 12.319 V
                    Fault Frequency: 18
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 83.0°C
                    Temperature: 43.0°C
                    Voltage: 12.446 V
                    Fault Frequency: 12
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 28.0°C
                    Temperature: 27.0°C
                    Voltage: 12.446 V
               P1624 - 000 -  - Intermittent
                    Mileage: 114167 km
                    Date: 2015.03.30
                    Time: 15:22:38
                    RPM: 768 /min
                    Load: 40.0 %
                    Temperature: 80.0°C
                    Temperature: 44.0°C
                    Voltage: 13.462 V
                    Mileage: 114167 km
                    Date: 2015.03.31
                    Time: 02:42:01
                    Temperature: 67.0°C
                    Temperature: 36.0°C
                    Voltage: 12.446 V
                    Mileage: 114167 km
                    Date: 2015.03.30
                    Time: 00:22:37
                    Temperature: 66.0°C
                    Temperature: 44.0°C
                    Voltage: 12.319 V
                    Fault Frequency: 12
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 28.0°C
                    Temperature: 27.0°C
                    Voltage: 14.478 V
                    Fault Frequency: 13
                    RPM: 770 /min
                    Load: 36.8 %
                    Temperature: 48.0°C
                    Temperature: 28.0°C
                    Voltage: 13.843 V
9 Faults Found:
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:25
            P1850 - 000 - Missing Message from ECU - Intermittent
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:25
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:25
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:25
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:25
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:25
            P1866 - 000 - Missing Messages - Intermittent
   Revision: 00H30001
10 Faults Found:
                    Reset counter: 118
                    Count: 2
                    Count: 12
                    Count: 12288
                    Count: 8207
                    Count: 43264
                    Count: 65279
                    Reset counter: 0
                    Mileage: 114167 km
                    Count: 2
                    Count: 14
                    Count: 24576
                    Count: 8199
                    Count: 43264
                    Count: 65024
                    Reset counter: 0
                    Mileage: 114167 km
                    Date: 2015.03.31
                    Time: 15:53:24
                    Count: 2
                    Count: 4
                    Count: 8704
                    Count: 161
                    Count: 49920
                    Count: 63488
                    Reset counter: 118
                    Mileage: 114167 km
                    Date: 2015.03.31
                    Time: 00:36:16
                    Count: 2
                    Count: 14
                    Count: 24576
                    Count: 8226
                    Count: 43776
                    Count: 65024
                    Reset counter: 118
                    Mileage: 114167 km
                    Date: 2015.03.30
                    Time: 09:48:33
                    Count: 2
                    Count: 14
                    Count: 25088
                    Count: 8255
                    Count: 49408
                    Count: 1
                    Reset counter: 0
                    Mileage: 114167 km
                    Date: 2015.03.31
                    Time: 00:36:16
                    Count: 2
                    Count: 14
                    Count: 24576
                    Count: 8194
                    Count: 43776
                    Count: 65024
                    Reset counter: 118
                    Mileage: 114167 km
                    Date: 2015.03.31
                    Time: 15:54:55
                    Count: 2
                    Count: 12
                    Count: 8192
                    Count: 8195
                    Count: 45568
                    Count: 54016
                    Count: 64768
                    Reset counter: 118
                    Mileage: 114167 km
                    Date: 2015.03.30
                    Time: 09:46:39
                    Count: 2
                    Count: 14
                    Count: 28672
                    Count: 166
                    Count: 44800
                    Reset counter: 0
                    Mileage: 133127 km
                    Date: 2001.04.00
                    Time: 16:24:07
                    Count: 2314
                    Count: 187
                    Count: 294
                    Count: 288
                    Count: 1793
                    Count: 166
                    Count: 30209
                    Reset counter: 120
                    Date: 2029.08.00
                    Time: 18:02:39
                    Count: 288
                    Count: 8822
                    Count: 256
                    Count: 8223
                    Count: 8226
                    Count: 257
                    Count: 26486
                    Count: 288
   Revision: BC008001
   Coding: 009795
   Coding: 0330ED
   Subsystem 4 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
   Subsystem 5 - Part No: 1K8 951 171
12 Faults Found:
                    Fault Frequency: 9
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:26
                    Voltage: 12.50 V
                    Reset counter: 164
                        Term 15 Off
                    Voltage: 12.85 V
                    Reset counter: 123
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 06:05:27
                    Voltage: 13.75 V
                    Reset counter: 123
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 06:05:27
                    Voltage: 13.75 V
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:28
                    Voltage: 12.50 V
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:26
                    Voltage: 12.50 V
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:26
                    Voltage: 12.50 V
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:26
                    Voltage: 12.50 V
                    Fault Frequency: 8
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:26
                    Voltage: 12.50 V
                    Reset counter: 124
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 06:12:18
                    Voltage: 13.35 V
                    Reset counter: 124
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 06:12:17
                    Voltage: 13.30 V
                    Reset counter: 124
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 06:12:17
                    Voltage: 13.30 V
   Coding: 100101
                    Reset counter: 0
                    Fault Frequency: 14
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:48
   Coding: 000180
8 Faults Found:
                        Invalid
                        Invalid
                        Invalid
                    Reset counter: 123
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 06:05:23
                    Reset counter: 124
                    Reset counter: 124
                    Reset counter: 124
                    Reset counter: 124
            000 - - - MIL ON
                    Reset counter: 0
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 06:12:20
                    Error Code: 9
                    Bin. Bits: 00000000
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:29:53
   Coding: 0012360
   Coding: 0001602
   Coding: 00000131
   Coding: 470B00
          U1111 00 [008] - -
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2020.11.11
                    Time: 21:28:24
          U1111 00 [008] - -
                    Fault Frequency: 14
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2020.11.11
                    Time: 21:28:24
          U1111 00 [008] - -
                    Fault Frequency: 11
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2020.11.11
                    Time: 21:28:24
          U1111 00 [008] - -
                    Fault Frequency: 16
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2020.11.11
                    Time: 21:28:24
          U1111 00 [008] - -
                    Fault Frequency: 15
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2020.11.11
                    Time: 21:28:24
          U1111 00 [008] - -
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2020.11.11
                    Time: 21:28:25
10 Faults Found:
                    Fault Frequency: 8
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:27
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:26
                    Fault Frequency: 13
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:26
                    Fault Frequency: 11
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:26
                    Fault Frequency: 11
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:26
                    Fault Frequency: 15
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:26
                    Fault Frequency: 13
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:26
                    Reset counter: 123
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 06:05:25
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:26
                    Reset counter: 164
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:28:27
   Coding: 0016949
   Revision: 00H15000
            000 - - - MIL ON
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 06:05:23
                    Battery Volts: 14.2 V
                        DU
                    Temperature: 35.0°C
                    Count: 2
                    Count: 1
                        SteerAng n.Init
                    Fault Frequency: 13
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:43:29
                    Voltage: 14.38 V
                        DD
                    Temperature: 33.0°C
                    RPM: 1498 /min
                    Speed: 1.0 km/h
                    Speed: 50.0 km/h
                    Count: 3
                    Mileage: 114167 km
                    Date: 2015.04.04
                    Time: 21:47:17
                    Voltage: 14.38 V
                        DD
                    Temperature: 33.0°C
                    RPM: 1498 /min
                    Count: 1
   Coding: 01030100
   Coding: 000005
   Coding: 0016948
Address 56: Radio
End----------(Elapsed Time: 01:40, VBatt start/end: 14.5V/14.5V)-----------
iichel
Eindhoven, NB, NL
C?ID=284912
Is this after clearing all DTCs? Because all errors of the first scan are still there? Or did they return?
bdaw
Miri, Malaysia
C?ID=392177
yes. this is after clearing all the DTCs... the fault still there... we have check all the modules, the one we suspect is the gateway faulty.
another thing, the gateway connector pin 1 is giving 12V but pin 2 is keep jumping up and down.. from 12v to 5v.
may i know what is the use of pin 2 to?
iichel
Eindhoven, NB, NL
C?ID=284912
1 + 30 power supply
2 linbus sunroof
3
4
5 canbus comfort
6 canbus powertrain
7
8 canbus cluster
9 canbus diag
10 canbus infotainment
11 GND
12 linbus power management (battery monitor, alternator)
13 to cluster
14 +15 power supply
15 canbus comfort
16 canbus powertrain
17
18 canbus cluster
19 canbus diag
20 canbus infotainment
bdaw
Miri, Malaysia
C?ID=392177
hi all, by your experience what else should i check on this car..
tomorrow i will try to disconnect the roof and test out the car..
- the (pin 2) linbus sunroof
NostraJackAss
Battery connections too verify all connections are good like iichel said!
Check terminal relays, and pins within or to all modules suspect especially main trans and chassis ground point.
Immediately take jumper cables to road test battery to ground and chassis.
bdaw
Miri, Malaysia
C?ID=392177
Hi all,
we have check all the fuse, ground points are good.
we disconnect the gateway J533 connector and tested on the pin 2, the voltage is 5v stable.
but when connect back to the gateway J533, the pin 2 is giving fluctuation reading of voltage from 12v to 5v.
iichel
Eindhoven, NB, NL
C?ID=284912
Don't worry about pin number two. What you're measuring is some ghost voltage of your Lin slave module. It is not the root cause of this problem.
How did you check the fuses? Visual inspection, multimeter or load test? I would suggest the latter. All fuse boxes including near the battery? Ground strap of battery ok?
bdaw
Miri, Malaysia
C?ID=392177
we are checking the fuse using multimeter & visual inspection.
my man have taken out the whole fuse box at beside battery for inspection & checking.
and also check the fuse box beside the dashboard, all good.
all the ground cable has been check from engine bay, interior grounding are good.
iichel
Eindhoven, NB, NL
C?ID=284912
Looking at the diagrams, I'd pay some special attention to SC2 (T20/14)and SB12 (T20/1) since these two fuses control the gateway.
Could you load-test these two wires please and make a new GND wire from T20/11.
My focus would be on the gateway for now but it's not a certainty by any means that this is the culprit.
bdaw
Miri, Malaysia
C?ID=392177
noted. i will do the testing later. will let you know the result.
bdaw
Miri, Malaysia
C?ID=392177
J533
SC2 (T20/14)and SB12 (T20/1) load-test passed, the bulb very bright.
GND wire from T20/11 tested ok.
we did a test, putting an external relay on the car for Terminal 50 voltage supply replay. the + voltage directly from the front fuse box.
so far the car is normal.
previously, we did replace the ori relay with a new one, but the problem still occur.
below is the scan results.
Friday,13,November,2020,15:39:14:16992
VIN: WVWZZZ13ZAV403866   Mileage: 114170km-70941miles
17106 - Transmission Output Speed Sensor (G195)
            P0722 - 000 - No Signal
                    Mileage: 114170 km
                    Date: 2015.04.06
                    Time: 23:22:16
18201 - Transmission Output Speed Sensor 2 (G196)
            P1793 - 000 - No Signal
                    Mileage: 114170 km
                    Date: 2015.04.06
                    Time: 23:22:16
   Revision: 00H30001
   Revision: BC008001
   Coding: 009795
   Coding: 0330ED
                    Reset counter: 125
                    Mileage: 114170 km
                    Date: 2015.04.06
                    Time: 23:16:40
                    Voltage: 13.75 V
                    Reset counter: 125
                    Mileage: 114170 km
                    Date: 2015.04.06
                    Time: 23:16:40
                    Voltage: 13.75 V
                    Reset counter: 125
                    Mileage: 114170 km
                    Date: 2015.04.06
                    Time: 23:23:05
                    Voltage: 13.85 V
   Coding: 100101
   Coding: 000180
7 Faults Found:
03262 - Comfort Restriction
                    Reset counter: 165
                    Mileage: 114170 km
                    Date: 2015.04.06
                    Time: 23:16:37
                    Error Code: 2
                    Bin. Bits: 00000000
                    Reset counter: 125
                    Mileage: 114170 km
                    Date: 2015.04.06
                    Time: 23:16:36
                    Reset counter: 125
                    Mileage: 114170 km
                    Date: 2015.04.06
                    Time: 23:16:40
                    Reset counter: 125
                    Mileage: 114170 km
                    Date: 2015.04.06
                    Time: 23:16:40
                    Reset counter: 125
                    Mileage: 114170 km
                    Date: 2015.04.06
                    Time: 23:16:40
                    Reset counter: 125
                    Mileage: 114170 km
                    Date: 2015.04.06
                    Time: 23:16:40
            000 - - - MIL ON
                    Reset counter: 125
                    Mileage: 114170 km
                    Date: 2015.04.06
                    Time: 23:16:40
                    Error Code: 9
                    Bin. Bits: 00000000
   Coding: 0012360
   Coding: 0001602
   Coding: 00000131
   Coding: 470B00
                    Reset counter: 125
                    Mileage: 114170 km
                    Date: 2015.04.06
                    Time: 23:16:37
   Coding: 0016949
   Revision: 00H15000
   Coding: 01030100
   Coding: 000005
   Coding: 0016948
Address 56: Radio
End----------(Elapsed Time: 01:31, VBatt start/end: 13.8V/13.7V)-----------
bdaw
Miri, Malaysia
C?ID=392177
we did a test drive just now, the same problem come back.
the gear level on D, when the problem occur.
the accelerator pedal not functioning and the gearbox in free gear mode( in neutral gear).
below is my latest scan
Friday,13,November,2020,16:24:50:16992
03-ABS Brakes -- Status: Cannot be reached 1100
               U0121 - 000 -  - MIL ON
                    Mileage: 114171 km
                    Date: 2015.04.06
                    Time: 00:09:21
                    RPM: 4329 /min
                    Load: 45.5 %
                    Temperature: 94.0°C
                    Temperature: 54.0°C
                    Voltage: 13.716 V
               P1624 - 000 -
                    Mileage: 114171 km
                    Date: 2015.04.06
                    Time: 00:10:25
                    RPM: 3635 /min
                    Load: 30.2 %
                    Temperature: 96.0°C
                    Temperature: 53.0°C
                    Voltage: 13.589 V
            P0722 - 000 - No Signal - Intermittent
                    Mileage: 114170 km
                    Date: 2015.04.05
                    Time: 23:22:16
            P1793 - 000 - No Signal - Intermittent
                    Mileage: 114170 km
                    Date: 2015.04.05
                    Time: 23:22:16
                    Mileage: 114171 km
                    Date: 2015.04.06
                    Time: 00:09:21
18115 - Interference in Mechatronic Module
            P1707 - 007 -  - Intermittent
                    Fault Status: 00100111
                    Mileage: 114171 km
                    Date: 2015.04.06
                    Time: 00:09:22
18203 - Vehicle Speed Signal
            P1795 - 008 - Open Circuit - MIL ON
                    Fault Status: 11101000
                    Mileage: 114171 km
                    Date: 2015.04.06
                    Time: 00:09:23
   Revision: BC008001
   Coding: 009795
   Coding: 0330ED
7 Faults Found:
                    Reset counter: 125
                    Mileage: 114170 km
                    Date: 2015.04.05
                    Time: 23:16:40
                    Voltage: 13.75 V
                    Reset counter: 125
                    Mileage: 114170 km
                    Date: 2015.04.05
                    Time: 23:16:40
                    Voltage: 13.75 V
                    Reset counter: 125
                    Mileage: 114171 km
                    Date: 2015.04.06
                    Time: 00:09:22
                    Voltage: 13.85 V
                    Reset counter: 165
                    Mileage: 114170 km
                    Date: 2015.04.05
                    Time: 23:23:05
                    Voltage: 13.85 V
                    Reset counter: 125
                    Mileage: 114171 km
                    Date: 2015.04.06
                    Time: 00:07:29
                    Voltage: 13.80 V
                    Reset counter: 125
                    Mileage: 114171 km
                    Date: 2015.04.06
                    Time: 00:10:20
                    Voltage: 13.45 V
                    Reset counter: 125
                    Mileage: 114171 km
                    Date: 2015.04.06
                    Time: 00:10:20
                    Voltage: 13.45 V
   Coding: 100101
                    Reset counter: 125
                    Reset counter: 125
                    Mileage: 114171 km
                    Date: 2015.04.06
                    Time: 00:09:22
   Coding: 000180
8 Faults Found:
                    Reset counter: 165
                    Mileage: 114170 km
                    Date: 2015.04.05
                    Time: 23:16:37
                    Error Code: 2
                    Bin. Bits: 00000000
                    Reset counter: 125
                    Mileage: 114170 km
                    Date: 2015.04.05
                    Time: 23:16:36
                    Reset counter: 125
                    Mileage: 114170 km
                    Date: 2015.04.05
                    Time: 23:16:40
                    Reset counter: 125
                    Mileage: 114170 km
                    Date: 2015.04.05
                    Time: 23:16:40
                    Reset counter: 125
                    Mileage: 114170 km
                    Date: 2015.04.05
                    Time: 23:16:40
                    Reset counter: 125
                    Mileage: 114170 km
                    Date: 2015.04.05
                    Time: 23:16:40
            000 - - - MIL ON
                    Reset counter: 125
                    Mileage: 114170 km
                    Date: 2015.04.05
                    Time: 23:16:40
                    Error Code: 9
                    Bin. Bits: 00000000
                    Reset counter: 125
                    Mileage: 114171 km
                    Date: 2015.04.06
                    Time: 00:09:21
   Coding: 0012360
   Coding: 0001602
   Coding: 00000131
   Coding: 470B00
          U1111 00 [009] - -
                    Reset counter: 125
                    Mileage: 114171 km
                    Date: 2020.11.13
                    Time: 00:09:20
                    Reset counter: 125
                    Mileage: 114171 km
                    Date: 2015.04.06
                    Time: 00:09:21
                    Reset counter: 125
                    Mileage: 114170 km
                    Date: 2015.04.05
                    Time: 23:16:37
   Coding: 0016949
   Revision: 00H15000
                    Fault Status: 11100100
                    Reset counter: 125
                    Mileage: 114171 km
                    Date: 2015.04.06
                    Time: 00:09:21
                    Voltage: 13.63 V
                        DU
                    Temperature: 68.0°C
                    RPM: 3917 /min
                    Speed: 53.0 km/h
                    Speed: 53.0 km/h
   Coding: 01030100
   Coding: 000005
   Coding: 0016948
Address 56: Radio
End----------(Elapsed Time: 01:31, VBatt start/end: 13.8V/13.9V)-----------
iichel
Eindhoven, NB, NL
C?ID=284912
Okay, good, nice.
So, let's see what is happening. Your ABS is completely missing. Which of course isn't good.
So let's have a look at that one.
Possibilities:
- Power
- Ground
- Data
- Module completely defective
So let's start with power
Fuse box B is located near the car battery
Fuse box C is located inside the dashboard on the driver side, I'm guessing you're RHD no?
- SC2 T47/8
- SB25 T47/1
- SB4 T47/32
I know you've already checked the fuses but just try the SB25 and SB4 again please and check the fuse box for any damage. Wobble the fuses to see if they are making bad contact.
Ground
T47/47 is the grounding wire of the ABS and it goes to the left suspension strut very near to the battery, the 615.
In any case I'd check the continuity of all wires with a mulitimeter set to beep. Connect one lead to the T47/x and the other lead either to the battery positive or negative. And just shake the loom where ever you can to hear the beep stopping.
Data is provided to T47/12 and /13 by canbus high and low.
The module itself could be completely defective but given the massive amount of unreached modules, my first guess would be a wiring issue.
The other theory could be a defective ABS module taking offline all your canbus communications but for now I'm personally sticking with the wiring.
What I'm seeing in the diagrams is that many of your missing lights are connected to 655, the grounding point on the left headlight.
I'd be very happy if you could also inspect that one very thoroughly
So please give a good rattle to 615 and 655 and the wires going to it.
The more and more I'm reading the schemes, I feel like your car wiring loom is damaged somewhere in the engine bay.
