Accesscode for changing glowtime - where do I find it?
ErikHM
Norway
C?ID=165552
Hello!
I have a 2.5 AXD engine in my T5. The car is a bit hard to start in the morning. I have read that you can extend the glowplugtime. I found the steps on how to do it via this forum, and therefor borrowed VCDS from a friend. When I try to login via VCDS to get access for changing the glowtime with the 12233-code, it gets denied. Does anybody know where I can find the righet code? I have tried to search for other similar posts, but I can't find any. I use the HEX + CAN cable, and I have the newest software insalled.
I apologize for the somewhat bad English 😅
Does anybody have any clue on where I should look for the code?
ErikHM
Norway
C?ID=165552
Thanks!
I will post it later today
ErikHM
Norway
C?ID=165552
Here is the complete scan. Had to use the K-line methond if that is information you need
Tuesday,10,November,2020,16:31:14:58395
VCDS Version: 20.4.2.0 (x64)
VIN: WV1ZZZ7HZ5H021773   License Plate:
          57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ5H021773   Mileage: 337640km-209799miles
Address 01: Engine        Labels: 070-906-016-AXD.clb
   Part No SW: 070 997 016 C    HW: 028 101 126 6
   Component: R5 2,5L EDC 0000AG  7595
   Revision: 12345678    Serial number: VWZ7Z0D0416074
   Coding: 0001075
   Shop #: WSC 00490 218 89105
   VCID: 1A30C9A2D67BA256FD-5102
18062 - Please check DTC Memory of Instrument Cluster
            P1654 - 000 -  - Intermittent
                    Torque: 297.7 Nm
                    Load: 0.0 %
                    Voltage: 12.08 V
                    Temperature: 20.7°C
                    Temperature: 18.9°C
                    Temperature: 19.8°C
Readiness: 0 0 0 X 1
   Part No: 09K 927 750 H
   Component: AQ 250 6F           1257
   Coding: 0000008
   VCID: 3A70292276BB82561D-50E6
Address 03: ABS Brakes        Labels: 7H0-907-37x-ASR-F.lbl
   Part No: 7H0 907 379 G
   Component: ASR FRONT MK25      0103
   Coding: 0007205
   Shop #: WSC 02756 785 00200
   VCID: 3972362E73BD894E14-5102
   Part No: 7H0 820 045 R
   Component: CLIMA/AC            0202
   VCID: 346C071A54DF7426C7-50C8
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Part No: 7H0 937 049 L
   Component: BORDNETZ SGVER 1.0  1901
   Coding: 0000039
   VCID: 3B7E2C267981BB5E06-50C8
   Part No: 1C0 909 605 A
   Component: 3C AIRBAG VW51      0008
   Coding: 13123
   Shop #: WSC 02756
   VCID: 2240F142AE2BEA9625-50E6
   Part No: 7H0 920 850 S
   Coding: 01112
   Shop #: WSC 00186
   VCID: 3A70292226BB82561D-50C8
   WV1ZZZ7HZ5H021773     VWZ7Z0D0416074
Address 18: Aux. Heat        Labels: 7H0-819-008.lbl
   Part No: 7H0 815 071 C
   Component: Standheizung        0207
   VCID: 2854E36A981700C67B-50E6
02251 - Heater Unit Locked
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 02737
   VCID: 70E4CB0A30470806E3-50E6
   Part No: 7H0 959 433 B
   Component: C   Komfortgerát     0004
   Coding: 00025
   Shop #: WSC 02756
   VCID: 32600102FECB7A16D5-4ACE
End-------------------------(Elapsed Time: 06:01)--------------------------
ErikHM
Norway
C?ID=165552
Thought I should bump this post. does anybody have any suggestion on how I can solve this? ✌😊
Have you tried 12233?
ErikHM
Norway
C?ID=165552
Yes I have ✌
Jacek
C?ID=360566
Have you checked that the glow plugs are working?
ErikHM
Norway
C?ID=165552
I installed new glowplugs approximatley 3 weeks ago, so they should work fine. The glowplug-light only stays on for a second before it turns off.
Jacek
C?ID=360566
When the light goes out, the engine can be started (the lower the temperature, the longer it shines), and the candles are still warming up to the engine temperature (40 or 60 degrees Celsius).
ErikHM
Norway
C?ID=165552
I am aware of that. The only thing is that it glows for 1 sec regardless of the outside temp (have checked this between 20 and 2 degrees Celsius). Plus the van is harder to start the colder it gets.
Viking
C?ID=151455
That doesn't mean they're working, just that the light is working.
Connect one of the old (functional) glow plugs to the harness and see if it works.
ErikHM
Norway
C?ID=165552
Sorry for the late reply. I have tested to see if the glowplugs work, and they do. I am also 100% sure that it is the glowplug-time that is the problem. When I turn the key to glow, i can hear a relay click when the light comes on, and another click when it turns off (only comes on for about 1 second). If I turn the key, the car has to crank a bit before it starts. If I turn the key on and off 5-8 times before i start the car, it fires right up.
(I am not too sure if that was well enough explained, so do tell me if it was not understandable).
So I am back to the initial question. Does anybody know the access code I need to modify the glowplug-time?
I have tried 12233 several times, but it doesn't work.
Are you sure there is there an adaptation channel on your engine ECU to change the glowplug time?
Might be an idea to post a channel map from the engine ECU.
Viking
C?ID=151455
So with a glowplug connected outside of the block, how long does it glow for before it shuts off?
I'd be more inclined to suspect a temperature sender fault reporting an incorrect temperature than a glowplug controller ignoring the correct reading. Not altogether certain how the glowplugs are controlled, but I would presume from the coolant temperature sender in the block maybe?
ErikHM
Norway
C?ID=165552
I'm not to sure if there is an adaptation channel on the ECU.
I can post a channel map from the ECU, just have to figure out how to do it..
ErikHM
Norway
C?ID=165552
It did just glow for 1 - 2 seconds.
Have to check the tempsensor then...
VWT6
C?ID=295527
Applications --> Controller Channel Map --> Single Controller Address = 01, Tick Adaptations, CSV file
The resulting file (adpmap-01-...CSV) will be in folder C:\Ross-Tech\VCDS\Logs
ErikHM
Norway
C?ID=165552
I haven't got around to to do the ECU channel map, but I did get around to check the tempsencor with another handheld codereader. the sensor measured about the same as the outside temp, so I guess it is fine?
I will do the ECU channel map tomorrow morning!
ErikHM
Norway
C?ID=165552
Just tried to do as you described, but did unfortunately not manage. See pictures:
I am actually considering to wire up a glowplug relay to a switch inside the car. It's not ideal but then it will work, and I don't have to turn the key on and off 8 times when it's a bit chilly outside. I got the car cheap, so it is a sollution I can live with.
