I have a customer who wants me to tweak cars for them so that when the light controller is set to 0 it turns of all exterior lighting.
The cars are used by the police and security companies.
The cars are almost always new cars so the first cars I have looked at didn’t have that possibility yet or I didn’t find it.
Am I looking at the wrong place in VCDS or are they just to new?
Se attached the latest car they brought.
is it possible to do it in this one?
Best regards/
Tintin Kanrell
Scuderia Kanrell AB
Best regards/
Tintin Kanrell
Scuderia Kanrell AB
Chassityp: A1-VW27 (3Q0)
Skanna: 01 02 03 08 09 10 13 15 17 18 19 22 42 44 4B 52 5F 75 A5 BB
BC D6 D7
VIN: WVGZZZA1ZMV031133 Mätarställning: 139km
01-Motor -- Status: OK 0000
02-Automatväxel -- Status: OK 0000
03-Bromselektronik -- Status: Felfunktion 0010
08-Klimatanläggning -- Status: OK 0000
09-Elektron. elcentral -- Status: OK 0000
10-park/styr-hjälp -- Status: OK 0000
13-Distansreglering -- Status: OK 0000
15-Krockkuddar -- Status: OK 0000
17-Instrument -- Status: OK 0000
18-Extra/p-värmare -- Status: OK 0000
42-Dörrel. förare -- Status: OK 0000
44-Styrservo -- Status: OK 0000
4B-Flerfunktionsenhet -- Status: OK 0000
52-Dörrelektr. pass. -- Status: OK 0000
5F-Information Elektr. -- Status: OK 0000
75-Larmmodul -- Status: Felfunktion 0010
A5-Främ sens för.hjälp -- Status: OK 0000
BB-bakre dörr förar -- Status: OK 0000
BC- bakre dörr pass -- Status: OK 0000
D6-Light Ctrl Vänster 2 -- Status: OK 0000
D7-Light Ctrl Höger 2 -- Status: OK 0000
Adress 01: Motor (J623-DKZA) Labels: saknas
Artikelnr SW: 81A 907 115 A HW: 06K 907 309 B
Komponent: R4 2.0l TFSI H61 0002
Revision: O1H61000
Kodning: 0125401A2466050B24000000000000000000000000000000
Verkstad #: WSC 00020 999 00000
ASAM Dataset: EV_ECM20TFS01181A907115A 001004
ROD: EV_ECM20TFS0112G0907115A_VW27.rod
VCID: 2208E8E03553C99624-8076
Ingen felkod funnen.
Adress 02: Automatväxel (J743) Labels:. AER\0BH-927-711.clb
Artikelnr SW: 0GC 300 013 T HW: 0GC 927 711 H
Komponent: GSG DQ381 H06 2809
Revision: 00H06V11
Kodning: 0014
Verkstad #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ381061 001001
ROD: EV_TCMDQ381061.rod
VCID: 352223BC94DD4E2EF1-8060
Adress 03: Bromselektronik (J104) Labels: saknas
Artikelnr SW: 5Q0 614 517 GB HW: 5Q0 614 517 BP
Komponent: ESC H35 0114
Revision: 00000000 Serienummer: 62620000000635
Kodning: 46FA6A7DA023246D4778070362C62962560524E2E046947538425078D22A4B0B00400523525212121035351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
VCID: 77BEE9B4CE517C3E23-8022
1 fel funnet:
0202 - Backväxel info.
C109E 29 [008] - orimlig signal
[no valid Reverse Gear Switch signal received via CAN]
Intermittent fel - Bekräftad - Testad efter att minnet rensats
frysta data:
Felstatus: 00000001
Felprioritet: 3
Felfrekvens: 1
Reset-räknare: 40
Mätarställning: 14 km
Datum: 2020.11.03
Tid: 11:08:27
Adress 08: Klimatanläggning (J255) Labels:| AER\5G0-907-044.clb
Artikelnr SW: 5G0 907 044 GA HW: 5G0 907 044 GA
Komponent: Climatronic H04 2402
Revision: 00001K10
Kodning: 060200042041110D1105000000101032
ASAM Dataset: EV_ACClimaBHBVW37X 006151
ROD: EV_ACClimaBHBVW37X_006_VW27.rod
VCID: 6C94C6D88717CFE6DE-8038
Styrdon för friskluftsfläkt (fram):
Sensor för luftkvalitet:
Adress 09: Elektron. elcentral (J519) Labels: saknas
Artikelnr SW: 5Q0 937 084 DP HW: 5Q0 937 084 DP
Komponent: BCM MQBAB M+ H42 0411
Serienummer: 01102025801208
Kodning: 000000000000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_BCMMQB 021001
ROD: EV_BCMBOSCH_021.rod
VCID: 095A9F4CA8A57ACE45-805C
regn- och ljussensor:
Subsystem 1 - Artikelnr SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: AER\5Q0-955-547.CLB
Komponent: RLHS 054 0206
Serienummer: SBY20M09D11H11M47S00
Kodning: 0018DD
Rattomkopplare:
Subsystem 2 - Artikelnr SW: 5Q1 953 521 HW: 5Q1 953 569
Komponent: Lenks.Modul H03 0170
Serienummer: 0100010420200C104777
Adress 10: park/styr-hjälp (J446) Labels:| AER\5Q0-919-294.clb
Artikelnr SW: 5QA 919 294 J HW: 5QA 919 294
Komponent: PDC 8 Kanal H08 0073
Serienummer: 000150058320268
Kodning: 8471051811
ASAM Dataset: EV_EPHVA18AU3700000 009053
ROD: EV_EPHVA18AU3700000_009_VW27.rod
VCID: 53E67D243A69701EFF-8006
Adress 13: Distansreglering (J428) Labels:| AER\2Q0-907-572.clb
Artikelnr SW: 2Q0 907 572 T HW: 2Q0 907 572 B
Komponent: ACCCONTIMQB H03 0383
Kodning: 320467C218FF8748949C810580408700000000000000000004
ASAM Dataset: EV_ACCMRRCONTIVW376 003018
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: 45C2537CC43DDEAE61-8010
Adress 15: Krockkuddar (J234) Labels:| AER\5Q0-959-655.clb
Artikelnr SW: 5Q0 959 655 BT HW: 5Q0 959 655 BT
Komponent: AirbagVW21 008 0403
Serienummer: 003FNR6KLDBA
Kodning: 88CCC0C0000000005C5400CF004800000065
Verkstad #: WSC 00020 043 00000
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
ROD: EV_AirbaVW20SMEVW37X_VW27.rod
VCID: 1366BD24FAE9B01EBF-8046
Bältessträckare vänster:
Subsystem 1 - Artikelnr SW: 4M0 980 945 A HW: 4M0 980 945 A
Komponent: BeltPretRevFL 106 1040
Serienummer: 2GA857705B0263U00150
Kodning: 80000D
Bältessträckare höger:
Subsystem 2 - Artikelnr SW: 4M0 980 946 A HW: 4M0 980 946 A
Komponent: BeltPretRevFR 106 1040
Serienummer: 2GA857706B0265U00910
Kodning: 80000D
krocksensor för sidoairbag på förarsidan:
Subsystem 3 - Artikelnr SW: ----------- HW: 480 000 509 20
Komponent: SideSensor_Df 001 0887
Serienummer: 35700000000910FCFA4
Kodning: 2D2D2D
krocksensor för sidoairbag på passagerarsidan:
Subsystem 4 - Artikelnr SW: ----------- HW: 480 000 509 20
Komponent: SideSensor_Pf 001 0887
Serienummer: 35800000000DC3C0CA4$
Kodning: 2D2D2D
krocksensor för sidoairbag bak på förarsidan:
Subsystem 5 - Artikelnr SW: ----------- HW: 480 401 809 20
Komponent: SideSensor_Dr 004 6149
Serienummer: 35100010862F6DC643CB
Kodning: 2D2D2D
Krocksensor för sidoairbag bak: passagerarsidan:
Subsystem 6 - Artikelnr SW: ----------- HW: 480 401 709 20
Komponent: SideSensor_Pr 004 6149
Serienummer: 352000106630544322CF
Kodning: 2D2D2D
krocksensor för airbag fram på förarsidan:
Subsystem 7 - Artikelnr SW: ----------- HW: 480 403 108 20
Komponent: FrontSensor_D 004 6149
Serienummer: 35500012C6380025459R
Kodning: 2D2D2D
Adress 17: Instrument (J285) Labels:* saknas-SRI3
Artikelnr SW: 17A 920 320 A HW: 17A 920 320 A
Komponent: KOMBI 502 5175
Kodning: 05A40008EF800008018862031000000000600706
ASAM Dataset: EV_DashBoardVDDMQBA0 001044
ROD: EV_DashBoardVDDMQBA0_VW27.rod
VCID: 1A78D0001D038156FC-804E
Adress 18: Extra/p-värmare (J364) Labels:* saknas
Artikelnr SW: 5WA 963 272 HW: 5WA 963 272
Komponent: STH-VW37x 006 0010
Serienummer: 000000000000034
Kodning: 250B155A5C25152CE44D18
ASAM Dataset: EV_AuxilHeateWOSVW38X 001009
ROD: EV_AuxilHeateWOSVW38X_VW27.rod
VCID: 0A58A040ADA371D64C-805E
Fjärrkontroll parkeringsvärmare:
Adress 19: CAN Gateway (J533) Labels:| AER\3Q0-907-530-V1.clb
Artikelnr SW: 3Q0 907 530 AG HW: 3Q0 907 530 C
Komponent: GW MQB High 442 4424
Revision: -------- Serienummer: 0001140628
Kodning: 030500046F085900FB13225C1A0F00010001070000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 74A4DEB8DF27172606-8020
Generator:
Komponent: 4-01-13-01-04
Styrdon för multifunktionsratt:
Subsystem 2 - Artikelnr SW: 5G0 959 442 AE HW: 5G0 959 442 AE Labels: AER\3C8-959-537.CLB
Komponent: E221__MFL-MD9 H12 0052
Serienummer: 36200000813930020322
Kodning: 2DFFFF
Styrdon för batteriövervakning:
Subsystem 3 - Artikelnr SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Komponent: J367-BDMHella H11 9070
Serienummer: 3226325405
Adress 22: AWD (-----) Labels:* saknas
Artikelnr SW: 5WA 907 554 P HW: 5WA 525 130
Komponent: 4Motion H65 0724
Serienummer: HA1-00031.08.20
Kodning: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 005001
ROD: EV_AllWheelContrHA1VW37X_005_VW27.rod
VCID: 5BF6950452B9B85E27-800E
Adress 42: Dörrel. förare (J386) Labels:* saknas
Artikelnr SW: 5Q4 959 593 N HW: 5Q4 959 593 N
Komponent: TSG FS 010 0820
Serienummer: 0000420202489
Kodning: 003A03208000028000001000
VCID: 50EC72280B7F0B06C2-8004
Dörrstyrdon förarsidan bak:
Subsystem 1 - Artikelnr SW: 5Q0 959 407 D HW: 5Q0 959 163 C
Komponent: FOND_FHSG_DRV 007 0011
Serienummer: 00000000000043711831
Kodning: 010000
Adress 44: Styrservo (J500) Labels:| AER\5Q0-909-144.clb
Artikelnr SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA
Komponent: EPS_MQB_ZFLS 131 1082
Kodning: 951F0000
ROD: EV_SteerAssisMQB_015.rod
Adress 4B: Flerfunktionsenhet (J745) Labels:| AER\3Q0-907-338-V2.clb
Artikelnr SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Komponent: FCM MQB Low 003 0367
Serienummer: 14092010803404
Kodning: 000000070900204A00000900000000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_003_VW27.rod
VCID: 373E29B48ED1BC3EE3-8062
Adress 52: Dörrelektr. pass. (J387) Labels:* saknas
Artikelnr SW: 5Q4 959 592 N HW: 5Q4 959 592 N
Komponent: TSG BFS 010 0820
Serienummer: 0000420699820
Kodning: 003A01208000028000001000
VCID: 4FEE7154164114FEDB-801A
Dörrstyrdon passagerarsidan bak:
Subsystem 1 - Artikelnr SW: 5Q0 959 408 D HW: 5Q0 959 164 C
Komponent: FOND_FHSG_PSG 007 0011
Serienummer: 00000000000043654959
Kodning: 190000
Adress 5F: Information Elektr. (J794) Labels:* saknas
Artikelnr SW: 3G5 035 820 B HW: 3G5 035 820 B
Komponent: MU-O-ND-EU H22 0270
Serienummer: VWZAZ2X0776621
Kodning: 22760000000000000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001001
ROD: EV_MUOIMQB_VW27.rod
VCID: 2306EDE42A49C09E2F-8076
Adress 75: Larmmodul (J949) Labels:* saknas
Artikelnr SW: 5WA 035 284 B HW: 5WA 035 284 B
Komponent: OCUGen3High H20 0035
Serienummer: 0000000009VIVR4
Kodning: 022760001968A8209025460161002607
ASAM Dataset: EV_OCUGen3High 003005
ROD: EV_OCUGen3High_003_VW27.rod
1 fel funnet:
1644017 - Online-tjänster
B1915 F1 [008] - Tillfälligt nedsatt funktion på grund av batteribudgeten
[Functional restriction due to insufficient power budget]
frysta data:
Felstatus: 00000001
Felprioritet: 6
Felfrekvens: 1
Reset-räknare: 37
Datum: 2020.11.03
Tid: 11:09:27
Spänning klämma 30: 12.5 V
Återstående långtid energibudget: 2613 mAh
Återstående korttid energibudget: 2 mAh
Räknare väckningsförlopp: 62
Adress A5: Främ sens för.hjälp (R242) Labels:| AER\3Q0-980-65X-A5.clb
Artikelnr SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Komponent: MQB_B_MFK H14 0610
Serienummer: 17092012K13003
Kodning: 0002070600000401002213448140A90084000E20000000
ROD: EV_MFKBoschMQBB_002.rod
VCID: 40CC4268DB1FFB8652-8014
Adress BB: bakre dörr förar
Kan ej nås
Adress BC: bakre dörr pass
Kan ej nås
Adress D6: Light Ctrl Vänster 2 (A31) Labels: AER\7P5-941-591.clb
Artikelnr SW: 7P5 941 591 AJ HW: 7P5 941 591 A
Komponent: LED1L H07 0011
ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
VCID: 04448E788F8727A636-8050
Adress D7: Light Ctrl Höger 2 (A27) Labels: AER\7P5-941-591.clb
Komponent: LED1R H07 0011
Slut--------(Förfluten tid: 01:47, Vbatt start/stopp: 12.9V/12.9V)---------
