Good Day All,
I am a relatively new VCDS owner - I bought this vehicle as a lease-return with certified pre-owned warranty at the end of 2016. It had 24k miles on it and now has 103k so no more warranty
About 2 months ago the occasional "acc not available" message became a permanent issue. For several months prior it would clear itself after a couple of start/stop cycles.
I've done some basic troubleshooting work:
1) Removed and re-inserted the infamous camera image processing cable from the camera in the rearview mirror base.
2) Followed another thread suggestion that I shave a little off the plastic to see if it seats better. Same result.
3) Here in AZ, rocks regularly mess with windshields and mine had a good sized chip, so I took my car to Audi dealer and had windshield replaced, knowing that my insurance company would pay for OEM windshield plus $580 more for Audi adjustments to this system. Dealer explained that they could not get the system back running and suggested $1,500 for replacement of the image processing cable - no guarantee that was the problem.
4) Hoping I could save $1,300, I bought the cable - OEM part 4G1-971-192-A and connected this morning. I used VCDS to clear all codes, drove the car for about 5 minutes and same result.
The following VCDS scan is essentially the same as I have been getting. I am only concerned about the camera/lane assist/acc/auto-brake function.
I hope I have included all pertinent info here - thank you in advance:
Sunday,08,November,2020,09:39:38:65410
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
VIN: WAU2GBFC9EN041865 License Plate:
Mileage: 166722km-103596mi Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3B 3C 42 44 46 47
52 53 55 56 5F 62 6C 6D 72 82 84 85 8B 8E 8F 90
VIN: WAU2GBFC9EN041865 Mileage: 166722km-103596miles
Address 01: Engine (J623-CTUA) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 J HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0004
Revision: --H07---
Coding: 1A2A0034056601060000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551J 001004
ROD: EV_ECM30TFS0214G0907551J.rod
VCID: 303916877AACABABE23-8065
Readiness: 0000 0100
Part No SW: 4G1 927 158 A HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H16 1006
Revision: --H16---
Coding: 000002
VCID: 2D070FF36D9EC643C95-8079
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 M HW: 4G0 907 379 M
Component: ESP PREMIUM H09 0450
Coding: 44A7970322E5E9C04B00
ASAM Dataset: EV_ESPPremiAU57X 004039
VCID: 3B2331ABA3EA58F3471-806F
Part No SW: 4H0 907 064 DR HW: 4H0 907 064 DR
Component: BCM2 2.0 H35 0510
Coding: 0DAA2046000000000000
VCID: 7CA1F2B7E6E49FCB0EB-8029
Serial number: 2313000129342008
Part No SW: 4G0 820 043 AF HW: 4G0 820 043 AF
Component: KLIMA 4 ZONEN H13 0087
Serial number: 17071300040605
Coding: 668320BA5D
ASAM Dataset: EV_AirCondiComfoUDS 002040
VCID: 6393A9CB7BDA40332F1-8037
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001465407
Coding: 0D072091073E9FE28F000884A0003820CF9CD308A6090225800308457B00
VCID: 6FBBD5FBA792F453BB9-803B
Component: WWS57X 130704 H36 0080
Serial number: 130712104402
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 21581582
Coding: 02006E
Subsystem 3 - Part No SW: 4G0 941 531 H HW: 4G0 941 531 H
Component: E1 - LDS H07 0044
Serial number: 18 07 2013 00001036
Component: USHL4.2 H30 0030
Serial number: 0000002274555R6ZD602
Subsystem 5 - Part No SW: 8K0 959 772 E HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0069195332
Coding: 853000
Subsystem 6 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A31 LED Mod1L H02 0002
Serial number: 00000000001306200658
Subsystem 7 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A27 LED Mod1R H02 0002
Serial number: 00000000001306200476
Subsystem 8 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA107413000004156167
Coding: 020300
Subsystem 9 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 71D8CDB6000000000001
Subsystem 10 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A32 LED Mod2L H02 0002
Serial number: 00000000001306192385
Subsystem 11 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A28 LED Mod2R H02 0002
Serial number: 00000000001306192671
00471 - Control Module for Elect. Regulated Dampers (J250)
Reset counter: 89
Mileage: 166713 km
Date: 2020.11.08
Time: 09:21:00
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0083
Revision: 11001001 Serial number: 61031320701768
Coding: A8EB04
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 71BFD383B126E2A3ADD-8025
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Coding: 7E01010201
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
VCID: 2809FEE7427CE36B3A3-807D
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[FAULT_CIS_VIDEO_FAIL]
Reset counter: 89
Mileage: 166713 km
Date: 2020.11.08
Time: 09:21:59
Control Module temperature: 28 °C
Voltage terminal 15: 11.809 V
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D8003AF5E
Coding: 303145313131303031324A55304C34473853
VCID: 3333198B8BBA90B39F1-8067
Serial number: 6940000Y130000VJJP0M
Serial number: 3575HRB400K50GS479NJ
Serial number: 3585HRB400K50J0M9OIP
Serial number: 3515JRB401650KJOFPU5
Serial number: 3525JRB401650KJOF969
Serial number: 3554VRB400M50M2E49FB
Serial number: 3564VRB400I50M2EPPTG
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Revision: -------- Serial number: 90372MGN000FA
Coding: 0004DC
VCID: 38292EA7925C73EBAA3-806D
Subsystem 1 - Part No SW: 4G0 951 528 F HW: 4G0 951 528 F
Component: E221 - MFL H09 0010
Serial number: 26 06 2013 A1203373
Part No SW: 4G8 920 984 S HW: 4G8 920 984 S
Component: TBenUsaAccNv H80 0618
Revision: 30460230 Serial number: 658150713596011
Coding: 0BC701060F53D705020100
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 46D5505FE828151B28F-8013
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000001039050
Coding: 00CD073000
ASAM Dataset: EV_GatewPkoUDS 001018
Serial number: 3711041003
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 13052700000000000211
Part No SW: 4G0 919 158 K HW: 4G0 919 158 K
Component: KLIMA FOND H07 0087
Serial number: 25071300040250
Coding: 20
ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
VCID: 372B2D9B9FC27C93A39-8063
0033 - Motor for Rear Right Upper Body Vent
B10D4 22 [009] - Signal Amplitude Too High
Reset counter: 89
Mileage: 166713 km
Date: 2020.11.08
Time: 09:22:08
Voltage terminal 30: 11.91 V
Outside air temperature: 22.0 °C
Right Rear Upper Body Vent Motor-Act.val.: 12001
Right Rear Upper Body Vent Motor-Specified value: 12001
Right Rear Upper Body Vent Motor-Stop open: 10000
Right Rear Upper Body Vent Motor-Stop closed: 10000
0094 - No Basic Setting
B2010 00 [009] - -
[Basic settings not carried out]
Reset counter: 89
Mileage: 166713 km
Date: 2020.11.08
Time: 09:21:59
Basic setting of flap motors-Left Rear Upper Body Vent Motor: OK
Basic setting of flap motors-Right Rear Upper Body Vent Motor: ERROR
Part No SW: 4G8 959 760 A HW: 4G8 959 760 A
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000068432864
Coding: C0581B008F006001000001010101102030303232203232
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H02 0056
Revision: -------- Serial number: EJ1BPA8204CW4D
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3635209F98C8859BB8F-8063
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 J HW: 4G0 907 566
Component: J769 SWA MasterH04 0060
Revision: 00H04000 Serial number: 6PZ 010 287-08
Coding: 0000007
VCID: 3635209F9448859BB8F-8063
Subsystem 1 - Part No: 4G0 907 568 J
Component: J770 SWA Slave H04 0060
Subsystem 2 - Serial number: 6PZ 010 287-28
Subsystem 3 - Serial number: 5F27.07.1300H04000AMS15684ÿ
Subsystem 4 - Serial number: S15684ÿ
Component: TSG FA H04 0507
Coding: 011F5F025E00628002000413
VCID: 45D75753D5AE1E03215-8011
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H38 0010
Revision: 00001000 Serial number: 0020782121
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323D1C8F74A099BB947-8067
Revision: 00002001 Serial number: 0312357666
Coding: 0122063A20FAF08580B00A8402030D470000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000168736
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO2308606%
Coding: 101F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00003960049
Subsystem 5 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0029
Serial number: WA106239000004186004
Subsystem 6 - Part No SW: 3AA 962 243 B HW: 3AA 962 243 B
Component: GEB.F.Heckoef H16 0810
Serial number: 93044571
01403 - Glass-Break Sensors; Rear
Reset counter: 89
Mileage: 166713 km
Date: 2020.11.08
Time: 09:21:56
014 - Defective
Fault Status: 01101110
Reset counter: 89
Mileage: 166713 km
Date: 2020.11.08
Time: 09:22:00
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000014568
Coding: 030000
VCID: 1D67DF331DBE36C3595-8049
Part No SW: 4G8 959 792 H HW: 4G8 959 792 F
Component: TSG BF H04 0507
Coding: 011F5F025E00628002000402
VCID: 44D14A57DE94270B36B-8011
Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
Component: EPB-4 H03 0014
Revision: -------- Serial number: 00000000778594
ROD: EV_ParkiBrake_VW51.rod
VCID: 2C0102F75684CF4BDEB-8079
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 130729-0002-130
Coding: 1223A6601002A500
ROD: EV_HeadlRegulBasic.rod
Revision: AB001007 Serial number: 156G60D7830779
Coding: 020007010000000001
VCID: 2411EAD73ED4070B16B-8071
02983 - Connection between Impedance Converter 1 and Window Antenna
Reset counter: 89
Mileage: 166713 km
Date: 2020.11.08
Time: 09:22:07
Voltage: 11.80 V
Part No SW: 4G0 035 746 E HW: 4G0 035 746 E
Component: H-BNT-NA H40 0735
Revision: -------- Serial number: 194G+0D7541455
Coding: 090200040003EDEF7D16CB1E00000003100001000000000000
VCID: 290FFBE359F6DA6325D-807D
Subsystem 1 - Part No: 8R0 060 884 BD
Component: NAR 2013/2014 0802
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD00236TP
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349MGP000QG
Component: CD-Database 5298
Part No SW: 4G8 959 795 H HW: 4G8 959 795 F
Component: TSG HL H03 0507
Coding: 010F1F024000628002000002
VCID: 47CB5D5BEFA20C13D39-8013
Part No SW: 4H0 907 428 A HW: 7P6 907 441 D
Component: TopView H05 0150
Revision: 11001001 Serial number: 82330JF0097760
Coding: 0205000001010100000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 006025
ROD: EV_CamerSysteTopViewAUDI_006.rod
VCID: 2B0301EB538AC873D71-807F
Part No SW: 4G8 959 107 R HW: 4G8 959 107 G
Component: HDSG-Modul H13 0043
Revision: 12013001 Serial number: 180300898
Coding: 0A3305C102
ASAM Dataset: EV_HDSGAu573 001022
ROD: EV_HDSGAu571.rod
VCID: 44D14A57DE14270B36B-8011
Component: TSG HR H03 0507
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4G8 919 604 K HW: 4G8 919 604 K
Component: HeadUpDisplay 004 0201
Coding: D60000
ASAM Dataset: EV_HUDContiC7 001023
ROD: EV_HUDContiC7.rod
Address 84: Night Vision (J853) Labels:| 4H0-907-547.clb
Part No SW: 4H0 907 547 F HW: 4H0 907 547
Component: NV-ECU-Gen1 H10 0042
Serial number: 0K84AE40099271
Coding: 1411
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H09 0008
Serial number: 00000000001314200302
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Coding: 6A060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2615F0DF4868F51B08F-8073
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7E01010201
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H32 0041
Serial number: 005000121707137
Coding: 03C198180111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
0161 - Video Cable for Image Processing
C1107 02 [009] - Signal Failure
[No_camera_found_on_startup]
Reset counter: 89
Mileage: 166713 km
Date: 2020.11.08
Time: 09:22:08
Voltage terminal 15: 11.8 V
Control Module temperature: 30.0 °C
Component: RGS-VL H13 0080
Coding: 0066E608031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
VCID: 313F138371A6A2A3EDD-8065
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
End----------(Elapsed Time: 02:58, VBatt start/end: 14.4V/14.4V)-----------
Sunday,08,November,2020,09:46:48:65410
Revision: --H07---
Readiness: 1110 1101
Revision: --H16---
Coding: 000002
Coding: 668320BA5D
Coding: 0045F7
Coding: 02006E
Coding: 853000
Coding: 020300
Reset counter: 90
Mileage: 166722 km
Date: 2020.11.08
Time: 09:39:00
Coding: A8EB04
Coding: 7E01010201
U1113 00 [009] - -
Reset counter: 90
Mileage: 166722 km
Date: 2020.11.08
Time: 09:39:01
Control Module temperature: 24 °C
Voltage terminal 15: 14.313 V
Coding: 0004DC
Coding: 00CD073000
Voltage stabilizer:
Coding: 20
Reset counter: 90
Mileage: 166722 km
Date: 2020.11.08
Time: 09:39:10
Voltage terminal 30: 14.43 V
Outside air temperature: 16.5 °C
B2010 00 [009] - -
Reset counter: 90
Mileage: 166722 km
Date: 2020.11.08
Time: 09:39:00
ROD: EV_SARA2.rod
Coding: 0000007
Coding: 101F00
Reset counter: 90
Mileage: 166722 km
Date: 2020.11.08
Time: 09:38:58
014 - Defective
Reset counter: 90
Mileage: 166722 km
Date: 2020.11.08
Time: 09:39:02
Coding: 030000
Reset counter: 90
Mileage: 166722 km
Date: 2020.11.08
Time: 09:39:08
Voltage: 14.40 V
Coding: 0A3305C102
Coding: D60000
Coding: 1411
Coding: 6A060000
Coding: 7E01010201
ROD: EV_BC7.rod
Reset counter: 90
Mileage: 166722 km
Date: 2020.11.08
Time: 09:39:10
Voltage terminal 15: 14.3 V
Control Module temperature: 32.0 °C
End----------(Elapsed Time: 02:57, VBatt start/end: 14.3V/14.3V)-----------
Sunday,08,November,2020,10:01:32:65410
Revision: --H07---
Revision: --H16---
Coding: 000002
Coding: 668320BA5D
Coding: 0045F7
Coding: 02006E
Coding: 853000
Coding: 020300
Reset counter: 90
Mileage: 166722 km
Date: 2020.11.08
Time: 09:44:00
Coding: A8EB04
Coding: 7E01010201
U1113 00 [009] - -
Reset counter: 90
Mileage: 166722 km
Date: 2020.11.08
Time: 09:44:20
Voltage terminal 15: 14.237 V
Coding: 0004DC
Coding: 00CD073000
Voltage stabilizer:
Coding: 20
Reset counter: 90
Mileage: 166722 km
Date: 2020.11.08
Time: 09:44:24
Outside air temperature: 18.5 °C
B2010 00 [009] - -
Reset counter: 90
Mileage: 166722 km
Date: 2020.11.08
Time: 09:44:20
ROD: EV_SARA2.rod
Coding: 0000007
Coding: 101F00
Reset counter: 90
Mileage: 166722 km
Date: 2020.11.08
Time: 09:44:17
014 - Defective
Reset counter: 90
Mileage: 166722 km
Date: 2020.11.08
Time: 09:44:21
Coding: 030000
Reset counter: 90
Mileage: 166722 km
Date: 2020.11.08
Time: 09:44:28
Voltage: 14.40 V
Coding: 0A3305C102
Coding: D60000
Coding: 1411
Coding: 6A060000
Coding: 7E01010201
ROD: EV_BC7.rod
Reset counter: 90
Mileage: 166722 km
Date: 2020.11.08
Time: 09:44:29
Voltage terminal 15: 14.2 V
End----(Elapsed Time: 02:56, VBatt start/end: 12.1V/12.0V. VIgn 11.9V)-----
