VW Touareg 2019 Coding rejected. Error 00: Unknown (0x00)
eimantasgabrielius
Lithuania
C?ID=401658
I've been trying VCDS on my VW Touareg. The first time it was not working and showing Error 00. After that, I changed VCDS devices and it started working, I was able to make all the modifications I wanted to.
At the moment I'm unable to do any coding again. It allows coding only 1 module (gateway) out of 40. On every other module, it shows this error - Coding rejected. Error 00: Unknown (0x00). However, it is possible to scan all the modules, but not to code.
I saw the other post here in the forums that it's possible to fix by shutting down an engine or rebooting the car and/or device. None of that helped. Spent the last 2 days in the car, nothing really helped.
Here are the AutoScan results:
Sunday,08,November,2020,14:45:01:59867
VCDS Version: 20.4.2.0  HEX-NET CB: 0.4513.4
VIN: WVGZZZCRZJD002389   License Plate:
Mileage: 85582km-53178mi   Repair Order: 20201108
Chassis Type: CR-VW53 (4N2)
Scan: 01 02 03 06 09 13 15 16 17 18 19 29 2B 36 39 3C 42 44 46 52
          5F 65 69 6C 6D 74 81 A5 AC BB BC CA CB CF D6 D7 DB DC DE
VIN: WVGZZZCRZJD002389   Mileage: 85582km-53178miles
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (J623-DENA)       Labels: None
   Part No SW: 760 907 401 G    HW: 059 907 309 L
   Component: 3.0l V6 TDI   H25 0002
   Revision: CAH25---
   Coding: 292A403A057E050335380000000400000000000000000000
   Shop #: WSC 79227 188 00000
   ASAM Dataset: EV_ECM30TDI011760907401G 001002
   ROD: EV_ECM30TDI011760907401G.rod
   VCID: 197AEBF31870694EF4-804C
Address 02: Auto Trans (J217)       Labels:* Redir Fail!
   Part No SW: 760 927 158 B    HW: 0D5 927 156 N
   Component: 0D5  30TDIRdW H05 1003
   Revision: --H05---
   Coding: 100000
   Shop #: WSC 05745 128 28889
   ASAM Dataset: EV_TCMALX52011 002014
   ROD: EV_TCMALX52011_VW53.rod
   VCID: 1F0EC5EB0654077E0A-804A
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4M6 907 379 N    HW: 4M6 907 379
   Component: ESP9 Premium  H06 0850
   Coding: 1DA732B730A20B98DEA14C99188616EAE93AE9B84C0CD07B32186857975C97
   ROD: EV_ESP9BOSCHCMP_VW53.rod
   VCID: 48DC7EB7F35A20C69B-801C
   Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0042
   Serial number: 00000309297537
   Coding: 011BBE400084BEA5C0000101210100008900000707008F8F00000000015000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
   VCID: 3D321F63AC98756E38-8068
   Valve Block 1 In Passenger Side Front Seat:
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ8001220218402583D7
   Coding: BF2F00
458791 - Databus
          U1121 00 [041] - Missing Message
          [Mem_Taster_HBF_01_missing_message]
                    Reset counter: 90
                    Mileage: 85581 km
                    Date: 2020.11.08
                    Time: 12:41:20
458867 - Valve block 2
          B13BE 31 [041] - No Signal
                    Reset counter: 90
                    Mileage: 85573 km
                    Date: 2020.11.08
                    Time: 12:35:17
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 DG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0652
   Coding: 07501140E13B0009070F870A58BF8040800B30106000009301100A00FB24F6019BC501BB12B7C6370000030100D122195902000044010104000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 014010
   ROD: EV_BCM1BOSCHAU651_014.rod
   VCID: 76A0C04FC92EE63639-8022
   Subsystem 1 - Part No SW: 761 955 113     HW: 761 955 113
   Component: WIPER 160218  010 0380
   Serial number: VZ1SKA 0100023316021
   Serial number: 21212264X81A955555A0
   Coding: 02006D
   Subsystem 3 - Part No SW: 761 941 633     HW: 761 941 633
   Component: E1 - LTM  H06 0054
   Serial number: 13S15.03.1800140215
   Subsystem 4 - Part No SW: 3G0 857 511 AL    HW: 3G0 857 511 AL
   Serial number: GX1CE117111720910120
   Coding: 030000
   Interior Light Module:
   Subsystem 5 - Part No SW: 760 947 105 S    HW: 760 947 105 S
   Component: Dachelektroni  H32 0057
   Serial number: 00000086960000000000
   Seat Backrest Fan 1 Front Left:
   Subsystem 6 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V512 LLR1SLvL  H01 0012
   Serial number: L84AH32801220
   Seat Cushion Fan 1 Front Left:
   Subsystem 7 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V514 LLR1SKvL  H01 0012
   Serial number: L84AH35902247
   Seat Backrest Fan 1 Front Right:
   Subsystem 8 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V516 LLR1SLvR  H01 0012
   Serial number: L84AH35300545
   Seat Cushion Fan 1 Front Right:
   Subsystem 9 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V518 LLR1SKvR  H01 0012
   Serial number: L84AH35800871
   Part No SW: 760 907 561 B    HW: 760 907 561 A
   Component: LRR4R         H04 0330
   Coding: 32657FDB78000400000020A000000014051246484401009E00
   ASAM Dataset: EV_ACCBOSCHAU65X 002022
   ROD: EV_ACCBOSCHAU65X_VW53.rod
   VCID: 1B76F1FB124C1B5EE6-804E
   Part No SW: 4M0 959 655 J    HW: 4M0 959 655 C
   Component: AirbagVW31    H32 2710
   Serial number: 003TZM003309
   Coding: 99FCC0C00C800000585400EF300D41A80065
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001028
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 42C86C9FD5660A9645-8016
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4N0 980 945 B    HW: 4N0 980 945 B
   Component: BeltPretRevFL  H20 0115
   Serial number: 00AH2018067601300000
   Coding: 04F001
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4N0 980 946 B    HW: 4N0 980 946 B
   Component: BeltPretRevFR  H20 0115
   Serial number: 00AH2018068600300000
   Coding: 04F001
   Subsystem 3 - Part No SW: -----------    HW: 480 000 503 18
   Serial number: 35700000000A43485B2J
   Subsystem 4 - Part No SW: -----------    HW: 480 000 503 18
   Serial number: 35800000000ED4185B2V
   Subsystem 5 - Part No SW: -----------    HW: 480 030 303 18
   Serial number: 351001C0C3F0558069BA
   Subsystem 6 - Part No SW: -----------    HW: 480 030 303 18
   Serial number: 352001C0C3F89CF08BE1
   Subsystem 7 - Part No SW: -----------    HW: 480 031 312 17
   Component: FrontSensor_D  002 0189
   Serial number: 355001C08F00C5F0BB0H
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 480 031 312 17
   Component: FrontSensor_P  002 0189
   Serial number: 356001C08F08CE30EE6Z
   Pedestrian Protection Driver:
   Subsystem 9 - Part No SW: -----------    HW: 480 032 402 18
   Component: PedP_Sensor_D  002 014A
   Serial number: 228001C0C7C391803C6C
   Subsystem 10 - Part No SW: -----------    HW: 480 032 402 18
   Component: PedP_Sensor_P  002 014A
   Serial number: 229001C0C7CBDE307C2X
   Pedestrian Protection Center:
   Subsystem 11 - Part No SW: -----------    HW: 480 030 203 18
   Component: PedP_Sensor_C  002 014A
   Serial number: 230001C0C3FB15708ACG
   Subsystem 12 - Part No SW: -----------    HW: 480 002 912 17
   Serial number: I0M00000000FC12591A9
   Subsystem 13 - Part No SW: -----------    HW: 480 002 912 17
   Serial number: I0N000000007332591A
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 760 953 507 B    HW: 760 953 507 B
   Component: Lenks.Modul   H03 0006
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 1C74F2E717421C66EF-8048
   Part No SW: 761 920 790     HW: 761 920 790
   Component: FBenRDW       H12 0106
   Coding: 85A600E07F9C0008008A632FF0E06819E40000A0
   ASAM Dataset: EV_DashBoardAU65X 001011
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 59FAABF358F0A94E34-800C
   Operating Unit Drive Mode Selection:
   Subsystem 1 - Part No SW: 760 927 531 G    HW: 760 927 531 G
   Component: E881 BedieFPA  001 0460
   Level control system control head:
   Subsystem 2 - Part No SW: 760 927 135 B    HW: 760 927 135 B
   Component: E281 BedieNiv  001 0110
Address 18: Aux. Heat (J364)       Labels:* None
   Part No SW: 4M0 265 105 E    HW: 4M0 265 105 E
   Component: HSG           H11 0090
   Coding: 0D0F01
   Shop #: WSC 31414 030 00001
   ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
   ROD: EV_AuxilParkHeateEBEAU736.rod
   VCID: 291ADB334810F9CE64-807C
   Part No SW: 4N2 907 468 AB    HW: 4N2 907 468 AB
   Component: Gateway       H14 0035
   Revision: 8P000001    Serial number: 0188P771318316
   Coding: 0701000701000F707F07000001DB05325E9E00071C000000037D078030000100
   ASAM Dataset: EV_CGateCONTIAU491 003150
   ROD: EV_CGateCONTIAU491_003_VW53.rod
   VCID: 79BACB73F830894E54-802C
   Subsystem 1 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 39170002923950128115
   Coding: 2FFFFF
   Serial number: 2036507204
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 3F0 907 155     HW: 3F0 907 155
   Component: U13  DCAC  H14 0017
   Serial number: 00000000000002005058
Address 29: Left Light (J1018)       Labels: None
   Part No SW: 80A 907 397 D    HW: 80A 907 397 D
   Component: LCM_MLBevo    H07 0022
   ROD: EV_LCMLeftCONTIAU426_VW53.rod
   VCID: 302C36576BCA8806A3-8064
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 18000082249004
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 32283C5F65C6BA16D5-8066
   Component: MEM-FS        009 0042
   Serial number: 00000310514523
   Coding: 011BBC400084BEA5C0000101210100008900000707008F8F00000000015000
   ROD: EV_SCMDriveSideCONTIAU736_VW53.rod
   Valve Block 1 In Driver Side Front Seat:
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ8001220218402583EF
   Coding: BF2F00
9658370 - Motor for Seat Depth Adjustment
          B153C 54 [041] - Missing Calibration / Basic Setting
                    Reset counter: 90
                    Mileage: 85573 km
                    Date: 2020.11.08
                    Time: 12:35:14
                    Reset counter: 90
                    Mileage: 85573 km
                    Date: 2020.11.08
                    Time: 12:35:18
Address 39: Right Light (J1023)       Labels: None
   Part No SW: 4N0 907 566 E    HW: 4N0 907 566 A
   Component: MRR_HR H12 0265
   Coding: 17F300
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651_VW53.rod
   VCID: 383C0E7783BA5046EB-806C
   Part No SW: 4M1 959 793 C    HW: 4M1 959 793 B
   Component: TSG FS006 0848
   Serial number: YE007RBK09203
   Coding: 003F9A000004048210013092
   VCID: 3FCE656BA694677E2A-806A
524336 - Databus
          [Message MFG_01 missing]
                    Reset counter: 90
                    Mileage: 85573 km
                    Date: 2020.11.08
                    Time: 12:35:18
   Part No SW: 4N0 909 144 D    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H20 0504
   Coding: B2150101000100
   ASAM Dataset: EV_EPSVWBSAU426 009015
   ROD: EV_EPSVWBSAU426_009.rod
   VCID: 312A335360C0810EAC-8064
   Part No SW: 4N0 907 064 BP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H14 0144
   Coding: 01342A00AFB012687339200C7C00480203004000044F07502F0400000508803F001F31D4050001
   ASAM Dataset: EV_BCM2CONTIAU651 008007
   ROD: EV_BCM2CONTIAU651_008_VW53.rod
   VCID: 7EB0D86FE11EAE7661-802A
   Ignition key:
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY180441KCT
   Subsystem 3 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223980540124
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: >9006815
   Rear Spoiler Adjustment:
65808 - Databus
          [Control module for central driver assistance systems: zFAS_01: no signal/communication]
                    Reset counter: 90
                    Mileage: 85573 km
                    Date: 2020.11.08
                    Time: 12:35:17
                    Supply voltages-Supply voltage: Terminal 30: 12.012 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.040 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 11.998 V
                    general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 ∞C
                    general_additional_freeze_frame-interior_temperature: -50.0 ∞C
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 02 A0 98 06 60
                    general_additional_freeze_frame-Vehicle speed: 105.57 km/h
                    can_lin_communication_freeze_frame: 11111111 11111111 11111111 11111111
65815 - Databus
          [Control module for intelligent park assist: IPA_01: no signal/communication]
                    Reset counter: 90
                    Mileage: 85573 km
                    Date: 2020.11.08
                    Time: 12:35:17
   Part No SW: 4M1 959 792 C    HW: 4M1 959 792 B
   Component: TSG BFS006 0848
   Serial number: YE007RBK17743
   Coding: 003F9A00DC00048010013090
   Shop #: WSC 31414 043 00001
   VCID: 3E30186FA19E6E7621-806A
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 760 035 063     HW: 760 035 063
   Component: MU-H-LND-EU   046 2677
   Coding: 02350601FF01000043110101C08808301F0101E551F13F00DF
   ROD: EV_MUHigGen2pALPI_VW53.rod
   VCID: 4ED048AF113EFEF6D1-801A
   Subsystem 1 - Part No SW: 760 919 618     HW: 760 919 618
   Component: ABT_Prem_L  H38 5211
   Serial number: VWZ6ZGV0750084
   Subsystem 2 - Part No: V03 959 808 TL
   Component: MIB2P_EU_Q220  0450
   Compact Disc Database:
   Component: Gracenote2  1008
   Volume Control 1:
   Subsystem 4 - Part No SW: 761 927 341     HW: 761 927 341
   Component: VW536LLB  H06 0109
   Serial number: 2018031200000097
   Media socket:
   Subsystem 5 - Part No SW: 5G0 035 953 D    HW: 0
H08 0014
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 3F0 907 273     HW: 4M0 907 273 B
   Component: RDKHUFVW536   H04 0003
   Serial number: 40000000002017
   ASAM Dataset: EV_RDKHUFVW536 002002
   ROD: EV_RDKHUFVW536.rod
   VCID: 6582970364881DAE80-8030
   Part No SW: 4M0 907 383 F    HW: 4M0 907 383 B
   Revision: 9A001003    Serial number: 0473806877
   Coding: 0110000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 3522074394A8AD2EF0-8060
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 760 980 568     HW: 760 980 568
   Component: RVC Compact+  H07 0250
   Coding: 0135060121002015720048
   ASAM Dataset: EV_CamSysRVRVCARPANAMLBEv 001001
   ROD: EV_CamSysRVRVCARPANAMLBEv.rod
   VCID: 618A831370A0718E7C-8034
   Part No SW: 4M0 959 107 C    HW: 4M0 959 107 C
   Component: HDSG-Modul    H14 0163
   Revision: --------    Serial number: 31825355300000
   Coding: 17F8
   ASAM Dataset: EV_DeckLidCONTIAU736 001015
   VCID: 3326395B9ADCB31EDE-8066
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4M0 907 777 M    HW: 4M0 907 777 B
   Component: Fahrwerk-SG   H37 1251
   Serial number: 1503180323
   Coding: B0505148F8
   ASAM Dataset: EV_ChassContrContiAU426 001004
   ROD: EV_ChassContrContiAU426.rod
   VCID: 43C6699BCA7C039E4E-8016
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130272545
   Coding: 303030
   Part No SW: 761 713 041 A    HW: 4M1 713 041 G
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 18020645916923
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 0F6E95ABD6B4B7FE9A-805A
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AB    HW: 4N0 907 107 G
   Component: zFAS Var B    H09 0291
   Coding: 040284000000000000F8060000D0C63C1B9F5700000000000000000000000000000000000000000000000000000000000000000000000000F9C040000000000000001890000000700000008000000000008040000020
   ASAM Dataset: EV_ZFASAU516 001005
   ROD: EV_ZFASAU516_001.rod
   VCID: 7F4E256BE614A77E6A-802A
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H04 0006
   ASAM Dataset: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736_VW53.rod
   Part No SW: 4M1 959 595 C    HW: 4M1 959 595 B
   Component: TSG HFS001 0848
   Serial number: YE007RC81258A
   Coding: 003E92000000048000013080
   Component: TSG HBFS001 0848
   Serial number: YE007RB10720B
   Part No SW: 4M0 907 594 G    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Coding: 688040753602
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3A38147FBDB642561D-806E
Address CB: Rear Axle Steering (J1019)       Labels:* None
   Part No SW: 4M0 909 145 AA    HW: 4M0 909 145 E
   Component: HAL_MLBevoH08 0698
   Revision: --------    Serial number: CCC_098_B_1122_
   Coding: 42250E00
   ASAM Dataset: EV_RearAxleSteerZFAU736 010018
   ROD: EV_RearAxleSteerZFAU736_010.rod
   VCID: 6FAEF52BB674D7FEFA-803A
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H12 0265
   Coding: 17F300
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651_VW53.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
   Part No SW: 7PP 941 592 AA    HW: 7PP 941 592 A
   Component: LED1L         H09 4002
   ROD: EV_LEDModLeftMELCOAU736_VW51.rod
   VCID: 177EEDCBEE647F3EC2-8042
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
   Component: LED1R         H09 4002
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4N0 907 669 E    HW: 4N0 907 669 A
   Component: MRR_VR H12 0265
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
   ROD: EV_FrontCorneRadarS1AU651_VW53.rod
   VCID: 3C341267B7827C660F-8068
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H12 0265
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
   ROD: EV_FrontCorneRadarS2AU651_VW53.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 A    HW: 4N0 035 502 A
   Component: WLC Front     H10 0057
   Coding: 800000
   Shop #: WSC 27115 004 1048576
   VCID: 2208CC1F35262A9625-8076
End(Elapsed Time: 02:56, VBatt start/end: 11.7V/11.7V. VIgn 11.7V, Deb=1024, udsna)
TBAx
C?ID=287144
May this car have the diagnostic firewall?
Did you try coding with the hood open and doors unlocked.
eimantasgabrielius
Lithuania
C?ID=401658
Thank you very much guys. Opening and closing the hood on running engine worked like a charm. Thanks again.
