I've retrofitted power-folding mirrors and also on the right passenger side a mirror with memory, however I only have a power adjustable driver's seat without memory. It's been documented in a few places that in certain post (2008 I believe) Passats and MK5's that you can have mirror dip or mirror down in reverse gear if you have a memory module in the mirror.
I coded: 46 - Convenience Module-> Long Coding Helper->Byte 14 -> Bit 7
52-Door Elec. Passenger -> Long Coding Helper -> Byte 1 -> =Bit 0 (note VCDS in the non-experimental coder for 52 says this is with or without seat memory)
I've operated my car with this for some time and it's worked fairly consistently, although I have found some issues where I need to reset the down and also the normal operating point periodically. However recently I now get an intermittent implausible signal - Position Sensor for Mirror Adjustment DTC as below.
I found that if I went into the MFI menu, turned off mirror down when reversing, then uncoded the door module as well as the convenience module, then turned it all back on, it disappeared. I was then able to operate it successfully, setting the down and the up position... until I put the car in reverse, then back into neutral, and let the car sit. Then the car just left the mirror in the down position and threw this DTC. WIth this DTC, the mirror down position seems to work ok, only sometimes, the mirror tends to move in reverse as well.
I've found some discussion on this exact issue on other forums - specifically odbeleven (apologies if I should not mention that here), and it seems like there is a coding tweak somehow to fix it. I'd really like to get this working properly if possible, hoping someone has seen this before? I mean, is there some other way to reset it, do I need to operate it through the whole range, etc.?
66821 - Position Sensor for Mirror Adjustment
B11FA 29 [008] - Signal Implausible
Reset counter: 202
Mileage: 171435 km
Date: 2020.11.04
Time: 23:14:57
AUTOSCAN:
Address 19,3C0 907 530 L,recoded (Installation List),from,F9817F06020202002002,to,F9817F06020302002002,,
Address 19: DTCs cleared
Reset counter: 202
Mileage: 171435 km
Date: 2020.11.04
Time: 23:14:57
AUTOSCAN:
Wednesday,04,November,2020,23:25:20:08140
VIN: WVWNK73C09E096517 License Plate:
Mileage: 171430km-106521mi Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 53 55 56 62 6D 72
VIN: WVWNK73C09E096517 Mileage: 171430km-106521miles
0F-Digital Radio -- Status: Not registered 0011
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 06J 906 026 AF HW: 06J 906 026 AF
Component: MED17.5 TFSI 2,0 3318
Revision: AAH03--- Serial number: VWZCZ000000000
Coding: 0404010A18070160
Shop #: WSC 05314 000 00000
VCID: 6E85C81A8C96F9BBB0F-803A
006481 - Radiator Fan 2 (V177)
P1951 - 000 - Movement Restricted / Jammed - Intermittent
Mileage: 171155 km
Date: 2015.03.28
Time: 14:37:49
Temperature: 90.0°C
Temperature: 48.0°C
Absolute Pres.: 960.0 mbar
Voltage: 12.446 V
Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AJ HW: 3C0 614 109 T
Component: J104 C4 440 V2 0016
Revision: --025--- Serial number: 00000786422456
Coding: 0002421
Shop #: WSC 00017 666 02327
VCID: 6695B03AA46631FBC8F-8032
Part No SW: 1K0 820 047 JE HW: 1K0 820 047 JE
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
VCID: 70B9D66296A2EF4BA23-8024
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000009135800
Coding: 8F8C8F2700041A00870000630F000000005B3F4D00401120000000000000
Shop #: WSC 05124 123 12345
VCID: 3333196EA73494539F1-8066
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 031008 004 0206
Coding: 00046997
Shop #: WSC 05124
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0476922
Coding: 0000000
00003 - Control Module
Fault Status: 00101110
Reset counter: 250
Mileage: 144245 km
Date: 2011.08.15
Time: 19:20:57
Reset counter: 82
Mileage: 170731 km
Date: 2015.03.28
Time: 16:32:37
Part No SW: 5N0 959 655 HW: 5N0 959 655
Component: J234__003 VW10 HI 1815
Revision: 19013000 Serial number: 0039BPQ7V11S
Coding: 0012339
Shop #: WSC 05311 000 00000
VCID: 7AADF44AC0DEA51B1C7-802E
Subsystem 1 - Serial number: 6333FTS611243198
Subsystem 2 - Serial number: 6343FTS645622908
Subsystem 3 - Serial number: 6353ETS6FOA0V5KJ
Subsystem 4 - Serial number: 6363ETS6OU4VVVNR
Subsystem 5 - Serial number: 6374CTS6H9JQVVNR
Subsystem 6 - Serial number: 6384CTS6TRF1V5KR
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ
Component: J0527 0030
Revision: 00032000 Serial number: 3C5953507CN
Coding: 0000712
VCID: 74B1DA72E2BAD36B46B-8020
Subsystem 1 - Part No: 3C8 959 537 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H4ÿ 0021
Coding: 00000226
Part No SW: 3C0 920 871 R HW: 3C0 920 871 R
Component: KOMBI H04 0107
Coding: 360D00
Shop #: WSC 05314 115 12345
VCID: 3333196EABB494539F1-8066
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 L HW: 3C0 907 951
Component: J533__Gateway H13 0152
Revision: H13 Serial number: 3300P08C05031F
Coding: F9817F06020202002002
Shop #: WSC 05314 123 12345
VCID: 2A0D040A70FED59B2C7-807E
Reset counter: 162
Mileage: 171435 km
Date: 2015.03.28
Time: 23:19:14
Part No SW: 3C0 959 433 AT HW: 3C0 959 433 AT
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 06402 785 00200
VCID: 7CA1F252CAEA9B2B0EB-8028
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0533
Revision: 12110009 Serial number: 0007371858
Coding: 0010F7
Shop #: WSC 05311 115 12345
VCID: 35372776A5C08A63B15-8060
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AD HW: 1K0 959 795 P
Component: J388__TSG-HL 004 0307
Serial number: 00000000707439
Coding: 0004D0
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 J HW: 5N1 909 148 F
Component: J500__APA-BS KL.081 0502
Revision: 1AH02240 Serial number: 00083290202402
Coding: 0000258
VCID: 392F2B4685586E0355D-806C
Component: KSG PQ46 ELV 042 0612
Coding: 13900E80D10304767604141FF08A8F0E087C41
Shop #: WSC 94718 999 15553
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0533
Revision: 14110009 Serial number: 0003568599
Coding: 0011F6
VCID: 3635207AB8C6817BB8F-8062
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AD HW: 1K0 959 794 P
Component: J389__TSG-HR 004 0307
Serial number: 00000000727654
Coding: 0004D0
Reset counter: 202
Mileage: 171435 km
Date: 2020.11.04
Time: 23:14:57
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 009 Serial number: 00000000208591
Coding: 0000057
VCID: 2809FE026EF2E78B3A3-807C
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Component: AFS-Steuergeraet 0136
Coding: 2323457
VCID: 34311A72A23A936B86B-8060
Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Coding: 00000035
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5406
Revision: -------- Serial number: VWZZZ4J6253087
Coding: 16000440010005
Shop #: WSC 127395 840 08317
VCID: 46D550BAC8A611FB28F-8012
Address 6D: Trunk Elect. Labels: 3C9-827-383.clb
Part No SW: 3C9 827 383 B HW: 3C9 827 383 E
Component: J605 HECKDECKEL 0600
Revision: 00H27001
Shop #: WSC 23250 384 715754
VCID: 303916625622AF4BE23-8064
Subsystem 1 - Part No: 3C9 827 384 B
Component: J756 HECKDECKEL 0600
Subsystem 2 - Serial number: 0800H27001001B0050ÿ
00317 - Rear Lid Control Module (J605)
Reset counter: 201
Mileage: 171431 km
Date: 2015.03.28
Time: 15:15:45
End----(Elapsed Time: 01:28, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
