Hi everybody,
I recently bought a 2010 Tiguan 5N that came nicely equipped but unfortunately missed a multi function steering wheel. I then found a beautiful mint condition Polo GT 6R wheel (12-buttons + tiptronic paddles) and went about looking for a replacement SWCM.
The car is originally equipped with a 5K0-653-569F which according to the very nice Wiki page is a Midline module that supports CCS, has a steering angle sensor (G85) and also supports steering column lock. My Tiguan indeed has a DSG gearbox.
I then found a 5K0-653-569L, which seemed to tick all the boxes : Highline with everything I need + MFSW support.
Problem is now, I have installed it and I keep getting this on the ABS module and the related code on the SWCM :
I tried performing Basic settings on the ABS module for the steering angle sensor but it does not go through, the field where the value should be displayed just shows "N/A" (see the below screenshot)
I am blocked now, I just put the original SWCM back on since the car won't enable power steering if the steering angle sensor appears and my wife drives it daily.
Any idea on how I could solve the problem? Please don't tell me I need to buy another SWCM, this one is already the second I buy for this retrofit... OK the first one was my complete mistake, I ordered an 5K0-653-569AE which does not have a G85 sensor, my bad.
Thanks!
Full auto-scan if that is of any help :
Thanks!
Friday,06,November,2020,21:28:06:24005
VCDS Version: 20.4.2.0
VIN: WVGZZZ5NZBW0XXXXX License Plate:
Mileage: 125470km-77963mi Repair Order:
Chassis Type: 5N-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 37 42 44 46 47 4F 52
53 55 56 62 69 6C 72 77
VIN: WVGZZZ5NZBW045822 Mileage: 125470km-77963miles
04-Steering Angle -- Status: Sporadic communication error 1000
Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb
Part No SW: 06J 906 026 FH HW: 06J 906 026 DA
Component: MED17.5 7327
Revision: AAH18--- Serial number:
Coding: 0423000C240F0160
Shop #: WSC 01324 020 00200
VCID: 75EA11F91C9CF32E30-8020
Address 02: Auto Trans (J217) Labels:. 0BH-927-711.clb
Part No SW: 0BH 300 011 E HW: 0BH 927 711 C
Component: DSG DQ500-7A H04 1203
Revision: 00H04V01
VCID: 244C1CBD2F863AA657-8070
Address 03: ABS Brakes Labels: 5N0-614-109-C4.clb
Part No SW: 5N0 614 109 Q HW: 5N0 614 109 Q
Component: J104 C4 450 V2A7 0006
Revision: --H28--- Serial number: 00000003216757
Coding: 0010564
VCID: 3972DDC97004574E14-806C
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
VCID: 7EF80ED5E1AAB07661-802A
Part No SW: 5K0 937 087 H HW: 5K0 937 087 H
Component: BCM PQ35 H 011 0035
Revision: BE011001
Coding: 48180A3B8825F3C0408800843400092443553088736D8D605C8000000040
VCID: 3A70C2C5B5025C561D-FFFE
Subsystem 1 - Part No: 5N1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS 110910 03 32 0010
Coding: 009795
Component: RLS 210910 05 54 0403
Coding: 03304D
No Faults Found
Address 10: Park/Steer Assist (J791) Labels:. 1T0-919-475.clb
Part No SW: 1T0 919 475 H HW: 1T0 919 475
Component: PARKHILFE PLA H07 0110
Revision: -------- Serial number: 88591025868582
Coding: 310103
VCID: 4084B02DD3DE068653-8014
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__200 VW10 HI 1918
Revision: 22014000 Serial number: 003K0PKAEQA%
Coding: 0012336
VCID: 4C9C941D2F96D2E6BF-8018
Subsystem 1 - Serial number: 6332MTS605502540
Subsystem 2 - Serial number: 6342MTS651262530
Subsystem 3 - Serial number: 6351HTS6O1ESE6KR
Subsystem 4 - Serial number: 6361HTS6OEKSE6KJ
Part No SW: 5K0 953 501 BH HW: 5K0 953 569 L
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20130903201567
Coding: 1182140000
VCID: 71E225E9A0F4DF0EEC-8024
Subsystem 1 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H30 0032
Coding: 830000
1140738 - Steering angle sensor
Reset counter: 167
Mileage: 125473 km
Date: 2020.11.06
Time: 00:13:31
UBat: 14.10 V
MC1 interner Fehlercode: 0
MC2 interner Fehlercode: 0
Part No SW: 5N0 920 872 HW: 5N0 920 872
Component: KOMBI H20 0420
Coding: 110F01
VCID: 6FE62391B6C0C9FEFA-803A
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H25 5603
Revision: H25 Serial number: 220910F2000533
Coding: FDA37F4650461300006002
VCID: 2E58FE95B94A80F6B1-807A
Fault Status: 00110100
Reset counter: 193
Mileage: 125273 km
Date: 2015.03.27
Time: 00:00:27
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0AY 907 554 D HW: 0AY 907 554 D
Component: Haldex 4Motion 0042
Coding: 0000005
Component: IMMO H20 0420
VCID: 6AD032858D222CD6AD-803E
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Revision: A1001003 Serial number: 7668661425
VCID: 27560BB156B0D1BE72-8072
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H42 5238
Revision: AB001001 Serial number: VWZ6Z7K5268052
Coding: 04050002010000800000
VCID: 3776DBF18610413EE2-8062
Subsystem 1 - Part No: 1T0 051 859 AS
Component: EU West V17 8557
Part No SW: 5N0 959 701 E HW: 5N0 959 701 E
Component: Tuer-SG 009 2101
Coding: 0004278
VCID: 3776DBF14610413EE2-8062
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 L HW: 5N1 909 148 G
Component: J500__APA-BS KL.287 0802
Revision: 1AH03831 Serial number: 00102600518101
Coding: 0000258
VCID: 3B7EC7C17A38655E06-806E
02546 - Steering Limit Stop
Fault Status: 11100101
Reset counter: 167
Mileage: 125473 km
Date: 2015.03.30
Time: 00:07:44
RPM: 798 /min
(no units): 7.0
Voltage: 13.90 V
00566 - Steering Assistance Operation
008 - Implausible Signal - MIL ON
Fault Status: 11101000
Reset counter: 167
Mileage: 125473 km
Date: 2015.03.30
Time: 00:07:44
Hex Value: 0x7301
Hex Value: 0x7601
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0000
Reset counter: 167
Mileage: 125473 km
Date: 2015.03.30
Time: 00:07:44
(no units): 7.0
Steering Angle: 0.00°
Not OK
(no units): 15
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218109101282
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1.rod
VCID: 67D64BB19E3011BEB2-8032
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H25 5603
Coding: 050B0500
VCID: 6FE62391BEC0C9FEFA-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
02071 - Local Databus
Fault Status: 00101100
Reset counter: 195
Mileage: 125273 km
Date: 2015.03.27
Time: 16:21:33
Part No SW: 5N0 959 702 E HW: 5N0 959 702 E
Coding: 0004534
VCID: 3874D8CD4B0E4E46EB-806C
Part No SW: 3AA 907 801 D HW: 3AA 907 801 D
Component: J540 EPB4 VW-53083 0006
Revision: H18 Serial number: 00000000093523
Coding: 0023057
VCID: 3260EAE5AD72A416D5-8066
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Component: AFS-Steuergeraet 0148
Coding: 1361094
VCID: 346CECFD5766AA26C7-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Coding: 00000020
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Coding: 00000020
Reset counter: 193
Mileage: 125273 km
Date: 2015.03.27
Time: 16:16:51
Voltage: 11.64 V
ABS 1
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Part No SW: 5N0 959 703 D HW: 5N0 959 703 D
Component: Tuer-SG 007 2102
Coding: 0000144
Shop #: WSC 01324 020 1012552
Component: Anhaenger H07 0100
Revision: 3A001001 Serial number: 00000135235485
Coding: 410D000100000000
VCID: 3064E0ED637E9606A3-8064
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 5N0 907 441 A HW: 5N0 907 441 A
Component: J772__Rearview 0020
Revision: 00H08000 Serial number: 525PA8-J083270
Coding: 0030010
VCID: 2D5AF999B44CFBEE88-8078
Reset counter: 193
Mileage: 125273 km
Reverse OFF
Count: 3
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 167
Mileage: 125473 km
Reverse OFF
Count: 3
Part No SW: 5N0 959 704 D HW: 5N0 959 704 D
Coding: 0000144
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661016569
Coding: 0300040000010110
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 27560BB15EB0D1BE72-8072
End-------------------------(Elapsed Time: 04:33)--------------------------
