Hi
I have a problem and not sure what to look at - if its the EVAP valve thats needed changing.
VIN: WV2ZZZ70Z1H108351
I have read the codes with Odis Service as well - and it says the lambda code is intermittent and the other two are static.
Friday,06,November,2020,10:28:33:18201
Dealer/Shop Name: Firma Johannes Bruun
Workshop Code: 000 02013 000000
VIN: License Plate: SFT984
Mileage: 213360km-132575mi Repair Order:
Chassis Type: 7D - VW Transporter/Multivan (1996 > 2004)
Scan: 01 02 03 08 15 17 18 19 22 25 35 37 56
Mileage: 213360km-132575miles
Part No: 023 906 033 B
Component: 2.5l/2V SIMOS3 00HS3603
Coding: 00001
VCID: 0C41A66AEF5F26F7A5F-51CE
16514 - Oxygen (Lambda) Sensor B1 S1
P0130 - 35-00 - Malfunction in Circuit
16688 - Cylinder 4
P0304 - 35-10 - Misfire Detected - Intermittent
17834 - EVAP Purge Valve (N80)
P1426 - 35-10 - Open Circuit - Intermittent
Readiness: 0010 0001
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 603 BL
Component: AIRBAG VW3 - V04
Coding: 16972
Shop #: WSC 02743
VCID: 74B1DE8A97AF5E37DDF-4B9A
Address 17: Instruments Labels: 7D0-920-xxx-17.lbl
Part No: 7D0 920 803
Component: T4-KOMBIINSTR. VDO V22
Coding: 01151
VCID: 619FA7DE385DDB9FA69-5160
End----(Elapsed Time: 03:08, VBatt start/end: 12.1V/12.0V. VIgn 0.0V)------
