Friday,06,November,2020,10:23:59:51259
VCDS Version: 20.4.2.0 (x64) HEX-NET CB: 0.4513.4
Dealer/Shop Name: ELMAR
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 18 19 32 42 44 47 4B 52 5F A9
D6 D7
VIN: WVWZZZAUZJW141050 Mileage: 35051km-21779miles
Address 01: Engine (J623-DLBA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 N HW: 06K 907 425 J
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0925001A4464050B2000
ASAM Dataset: EV_ECM20TFS0205G0906259N 002003
ROD: EV_ECM20TFS0205G0906259N_002.rod
VCID: 393A2C1DB891A94E14-806C
Readiness: 1110 0001
Part No SW: 0GC 300 020 C HW: 0GC 927 711 G
Component: GSG DQ381 H06 1401
Revision: 00H06V07
ROD: EV_TCMDQ381061.rod
VCID: 2208EB713507CA9625-8076
Part No SW: 5Q0 614 517 CR HW: 5Q0 614 517 AD
Component: ESC H25 0523
Revision: 00000000 Serial number: 63147000002879
Coding: 01FA6BA15424216D4777060560C36980D62A84E26006967738425079C208430B00000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 03468EF58ADD239E0E-8056
Part No SW: 5G0 907 044 CG HW: 5G0 907 044 CG
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 00020004204111011005000000101022
VCID: 6E90CF41B15F3EF6F1-803A
Air quality sensor:
Part No SW: 5Q0 937 084 CP HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H36 0253
Serial number: 01001732403109
ROD: EV_BCMBOSCH_018.rod
VCID: 085C99D9B3FB00C65B-805C
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 170929 043 0551
Serial number: 171007113746
Component: RLHS 047 0105
Serial number: S9Y17M11D21H10M07S04
Coding: 00A8DD
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418617319
Coding: 0471151811
VCID: 4BD666D5E20D2BDEB6-801E
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 3300670159FFC728949C810580400600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
VCID: 3E303F01A1BF8E7621-806A
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_ALIGNMENT_NOT_OK]
Reset counter: 113
Mileage: 35051 km
Date: 2020.10.14
Time: 03:26:12
Control Module temperature: 30 °C
Voltage terminal 15: 14.7 V
Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_MISALIGNMENT_VERTICAL]
Reset counter: 113
Mileage: 35051 km
Date: 2020.10.14
Time: 03:26:12
Part No SW: 5Q0 959 655 BH HW: 5Q0 959 655 BH
Component: AirbagVW21 005 0336
Serial number: 003VVR3KSVUW
Coding: 98CCC000000000005C0000CF000800000065
VCID: 075E9AE5BEE50FBE52-8052
Subsystem 1 - Part No SW: ----------- HW: 480 001 811 17
Serial number: 357000000003A5FCF920
Subsystem 2 - Part No SW: ----------- HW: 480 001 211 17
Serial number: 35800000000692EC782X
Subsystem 3 - Part No SW: ----------- HW: 480 402 011 17
Serial number: 3510001A5274D885147+
Subsystem 4 - Part No SW: ----------- HW: 480 402 011 17
Serial number: 3520001BF286E2D4932E
Subsystem 5 - Part No SW: ----------- HW: 480 401 911 17
Serial number: 3550001AB27DBDA286F-
Part No SW: 5Q0 953 507 GH HW: 5Q0 953 549 E
Revision: -------- Serial number: 17111704221236
Coding: 0410
VCID: 02488BF195C72A9605-8056
Part No SW: 5G1 920 791 A HW: 5G1 920 791 A
Component: KOMBI 407 3193
Coding: 07AD11082F80000801886A011401000080000000
VCID: 2A1803514D3712D66D-807E
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 H HW: 5Q0 963 272 H
Component: STH-MQB 008 0075
Coding: 9309
VCID: 3B363615B2AD9B5E06-806E
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000332387
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 08111710801799
Coding: 030100047F085900FA0002681C0F00010001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 383C2919839BB046EB-806C
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29170002561030087454
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 2886935804
8526363 - Crash Shut-Down
B189C F0 [009] - Active
Reset counter: 113
Mileage: 35051 km
Date: 2020.10.14
Time: 03:26:12
Supply voltage: Terminal 30: 14.8 V
Terminal 15: On
Address 32: Differential Locks (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 P HW: 0CQ 907 554 P
Component: Quersperre H52 8043
Serial number: HA1-00014.09.17
Coding: 0001
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
VCID: 52E87BB105277A16F5-8006
Component: TSG FS 020 0041
Serial number: 071117EK610866
Coding: 003E03208000040000001000
VCID: 43C64EF5CA5DE39E4E-8016
Subsystem 1 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000017574587
Coding: 110000
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 0107
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A383311BD97A2561D-806E
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1HMD018YR6
Coding: 12000000008AAA8A000000000000
ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
ROD: EV_AMPMst11CGen2ALPI.rod
VCID: 2E100F4171DF7EF6B1-807A
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 09111710802965
Coding: 000000070100164A01000101020000000000000000000000000000000000
VCID: 72A8DB31A5671A1615-8026
Component: TSG BFS 020 0041
Serial number: 071017EJ634644
Coding: 003E01208E00040000801000
VCID: 42C84BF1D547EA9645-8016
Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000017540171
Coding: 090000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 5NA 035 043 B HW: 5NA 035 043
Component: MU-H-N-EU H54 1161
Serial number: A848K0HB015272
Coding: 02731001000000004111000200080A231F0103F401200400DF
VCID: 3522202D94894D2EF0-8060
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H50 9130
Serial number: VWZ6ZJT3166576
Subsystem 2 - Part No SW: V03 959 800 QR HW: -----------
Component: ECE 2017/2018 --- 0161
Compact Disc Database:
Component: Gracenote2 --- 1016
Part No SW: 5G0 907 159 G HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 171027201198
VCID: 32281B3165E75A16D5-8066
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A
Component: LED1L H06 0005
ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
VCID: 7EB0FF01E13F4E7661-802A
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0005
End----------(Elapsed Time: 01:40, VBatt start/end: 14.8V/14.8V)-----------
