Parking Brake Error Codes on VW Passat
steamship
Londonderry, Northern Ireland
C?ID=225205
The car in question is a 2011 VW Passat 2.0tdi Bluemotion which belongs to my brother. There are no warning lights on the dash related to the electronic parking brake, but have two error codes showing up, both 03182, 008 - Implausible Signal - Intermittent and 007 - Short to Ground - Intermittent.
As I write this up, I have literally just noticed that the date on both of them is 2015.03.21 despite never come across them before. The following is the latest scan:
Wednesday,04,November,2020,13:48:38:42449
VCDS Version: 20.4.2.0 (x64)
VIN: WVWZZZ3CZBE303151   License Plate: BJ11BYU
Mileage: 169100km-105073mi   Repair Order: EML
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 4F 52 53 56 61 62 72
          77
VIN: WVWZZZ3CZBE303151   Mileage: 169100km-105073miles
   Part No SW: 03L 906 018 BF    HW: 03L 907 309 N
   Component: R4 2.0l TDI   H24 9978
   Revision: 47H24---    Serial number: 00000000000000
   Coding: 00190012042501080000
   Shop #: WSC 44171 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018BF 003008
   ROD: EV_ECM20TDI01103L906018BE.rod
   VCID: 6FEA5ABAB638DDFEFA-803A
4891 - EGR Valve (N18)
          P0403 00 [237] - Malfunction
                    Mileage: 169055 km
                    Date: 2020.11.04
                    Time: 09:35:00
                    Engine speed: 1621.50 /min
                    Normed load value: 34.1 %
                    Vehicle speed: 63 km/h
                    Coolant temperature: 79 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 14.660 V
                    Air mass: actual value (mg/stroke): 569.9 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 15.00 %
                    EGR Solen.val.: actual value: 90.44 %
                    EGR valve: offset closed: 0.00 %
                    Actuator for high pressure EGR: status-Bits 0-7: 0
                    Actuator for high pressure EGR: status-Bits 0-7: 55
                    Actuator for high pressure EGR: status-Bits 0-7: 7
                    High press EGR actuator: actual unconditioned volt val: 1287.2 mV
4892 - EGR Valve (N18)
          P0403 00 [101] - Malfunction
                    Mileage: 169098 km
                    Date: 2020.11.04
                    Time: 13:11:39
                    Engine speed: 2119.00 /min
                    Normed load value: 13.7 %
                    Vehicle speed: 57 km/h
                    Coolant temperature: 66 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 14.900 V
                    Air mass: actual value (mg/stroke): 384.0 mg/stroke
                    EGR Solen.val.: actual value: 42.07 %
                    High press EGR actuator: actual unconditioned volt val: 2738.8 mV
Readiness: 1 1 0 0 0
   Part No SW: 3AA 614 109 N    HW: 3AA 614 109 N
   Component: J104   C2 450M VD7A 0005
   Revision: --H07---    Serial number: 00000003473288
   Coding: 0004016
   Shop #: WSC 05311 000 00000
   VCID: 3878A1E64BF65A46EB-806C
   Part No SW: 7N0 907 426 K    HW: 7N0 907 426 K
   Component: AC Manuell    H17 0202
   Revision: 00012001
   Coding: 0000000003
   Shop #: WSC 00015 115 00000
   ROD: EV_ClimaBasis_VW46.rod
   VCID: 3C70BDF6B7CE76660F-8068
          B10AB F0 [009] - Too Low
                    Reset counter: 243
                    Mileage: 166796 km
                    Date: 2020.01.22
                    Time: 12:57:29
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087     HW: 3AA 937 087
   Component: BCM PQ47 M    413 0452
   Revision: BA413001
   Coding: 000000000000000000180080140000E443510088426D81606480C7200041
   VCID: 77FA62DAC668953E22-8022
   Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 31101  26  0612
   Coding: 00B795
   Component: RLS 241110 05  54  0403
   Coding: 0330ED
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__102 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PPEDJWM
   Coding: 0012338
   VCID: 4C90ED362F6EC6E6BF-8018
   Subsystem 1 - Serial number: 6332MTS690163060
   Subsystem 2 - Serial number: 6342MTS630373120
   Subsystem 3 - Serial number: 6351HTS6VCV1G6KR
   Subsystem 4 - Serial number: 6361HTS6AGD1G6KR
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C9 953 501 BN    HW: 5K0 953 569 AB
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20101128100874
   Coding: 1182250000
   VCID: 76E46FDEC962EC3639-8022
   Coding: E20000
   Part No SW: 3AA 920 970 A    HW: 3AA 920 970 A
   Coding: 461F01
   Shop #: WSC 05314 115 00000
   VCID: 316E9CC2608C8B0EAC-8064
   Part No SW: 7N0 907 530 G    HW: 1K0 907 951
   Component: J533  Gateway H41 1614
   Revision:   H41       Serial number: 211110F1003117
   Coding: 462007
   Shop #: WSC 05314 000 00000
   VCID: 346095D6979EBE26C7-8060
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0399
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 76E46FDE0162EC3639-8022
02861 - Electronic Steering Column Lock Check Sum Error
                    Reset counter: 161
                    Mileage: 169039 km
                    Date: 2015.03.28
                    Time: 09:18:34
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Revision: A1001003    Serial number: 7668970749
   VCID: 285871A65B56CAC67B-807C
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0530
   Revision: 12110009    Serial number: 0001828355
   Coding: 0202B7
   Shop #: WSC 05311 115 00000
   VCID: 3566A8D294E4A72EF0-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0407
   Serial number: 00000001791765
   Coding: 000290
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 195    3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 316E9CC2A88C8B0EAC-8064
   Component:    KSG PQ47 ELV 043 0631
   Coding: 0191020052830E7630049F1FFC085FCE107C01
   Shop #: WSC 05311 123 12345
   Component: Neigungssensor  004 0611
                    Reset counter: 118
                    Mileage: 169001 km
                    Date: 2015.03.20
                    Time: 16:59:13
   Component: EZE_2         H41 1614
   Coding: 00000008
   VCID: 6FEA5ABABE38DDFEFA-803A
   Subsystem 1 - Part No SW: 3AA 919 204     HW: 3AA 919 204
   Component: Analoguhr  003 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0530
   Revision: 14110009    Serial number: 0001833401
   Coding: 0202B6
   VCID: 3664AFDE89E2AC36F9-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0407
   Serial number: 00000001780361
   Coding: 000290
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [008] - Electrical Failure
                    Reset counter: 162
                    Mileage: 169076 km
                    Date: 2020.11.04
                    Time: 10:50:57
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000318622
   Coding: 0022067
   Shop #: WSC 00028 028 00001
   VCID: 336296CA5290B91EDE-8066
03182 - Clutch Position Sensor (G476)
                    Fault Frequency: 25
                    Reset counter: 162
                    Mileage: 169002 km
                    Date: 2015.03.20
                    Time: 17:15:13
                    Voltage: 14.30 V
                    Count: 54
                    Speed: 14.0 km/h
                    Hex Value: 0x1260
                    Hex Value: 0x0004
                    Hex Value: 0x0101
                    Fault Status: 00100111
                    Reset counter: 162
                    Mileage: 169011 km
                    Date: 2015.03.21
                    Time: 14:00:19
                    Voltage: 14.40 V
                    Count: 56
                    Speed: 20.0 km/h
                    Hex Value: 0x1270
                    Hex Value: 0x0004
                    Hex Value: 0x0101
   Part No SW: 1K0 035 186 AB    HW: 1K0 035 186 AB
   Component: Radio RCD310  016 0049
   Revision: 00000000    Serial number: VWZ1Z2K7214147
   Coding: 0100040004
   VCID: 66C43F9E91C21CB689-8032
   Component: Batt.regelung H41 1614
   Coding: 030B185A
   VCID: 71EE5CC2A80CCB0EEC-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370203995
   Part No SW: 5K0 035 730 B    HW: 5K0 035 730 B
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007669710647
   Coding: 0200010000010101
   Shop #: WSC 00020 999 12345
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 244065962F7E2EA657-8070
End-------------------------(Elapsed Time: 03:27)--------------------------
What I find odd is the reference to the Clutch Position Sensor, and having Googled the code I can find references to the clutch master cylinder possibly needing replaced. I also came across one post where the culprit was the EPB module which seemed an obvious cause, but for the clutch reference. The worrying thing is my brother had the clutch and master cylinder replaced earlier this year after the clutch peddle dropped to the firewall. Any tests I can perform on the EPB module like output tests that might help?
If you clear these faults, do they come back, and if so, under what conditions/circumstances?
steamship
C?ID=225205
Sorry Uwe, I forgot to mention about that side of things. I cleared all the faults and scanned again and none were present. I'll have to call with my brother again to do another scan and see what has resurfaced since then.
Re-reading my own post I also noticed I forgot to mention another point I came across when researching this error code. A few people mentioned that their cruise control also didn't work as a result of this sensor error, but since my brother is only doing very short distances and on UK country roads, there's not much chance for using cruise control. However, I'll mention this to him and ask him to go out for a longer run and try the cruise control to see if that is affected.
steamship
C?ID=225205
Brother just happened to call out today and he had the orange parking brake light on again when he arrived (I said in my original post there were no lights, but turns out it seems to reset the light after ignition turned off).
Anyway, did another scan and got only one of faults as before so cleared them. Todays code was '03182 - Clutch Position Sensor (G476) 008 - Implausible Signal - Intermittent'
Saturday,07,November,2020,14:35:10:42449
Mileage: 169130km-105092mi   Repair Order: BrakeLight
          77
VIN: WVWZZZ3CZBE303151   Mileage: 169130km-105092miles
   Component: J104   C2 450M VD7C 0005
   Coding: 0004016
   Revision: 00012001
   Coding: 0000000003
   Revision: BA413001
   Coding: 00B795
   Coding: 0330ED
   Coding: 0012338
   Coding: 1182250000
   Coding: E20000
   Coding: 461F01
   Coding: 462007
   Coding: 0202B7
   Slave Driver:
   Coding: 000290
   Revision: 00H17000
                    Reset counter: 122
                    Mileage: 169101 km
                    Date: 2015.03.28
                    Time: 13:53:26
   Coding: 00000008
   Coding: 0202B6
   Slave Passenger:
   Coding: 000290
   Coding: 0022067
                    Fault Frequency: 13
                    Reset counter: 164
                    Mileage: 169109 km
                    Date: 2015.03.30
                    Time: 16:59:29
                    Voltage: 14.50 V
                    Count: 54
                    Speed: 22.0 km/h
                    Hex Value: 0x1260
                    Hex Value: 0x0004
                    Hex Value: 0x0101
   Coding: 0100040004
   Coding: 030B185A
   ROD: UHVNA.rod
End-------------------------(Elapsed Time: 03:25)--------------------------
I then decided to run through the output tests using the this wiki article (http://wiki.ross-tech.com/wiki/index.php/VW_Sharan_(7N)_Parking_Brake) as his is an EPB4. All the tests seemed to execute properly but I did notice something on the tests that I don't know what they mean. I could guess but that doesn't guarantee anything. The first two fields that hold variables were showing differing current loads during the tests, but I don't know if each field is for each side and would in theory show the same if both were working properly. Unfortunately I only took two screenshots.
I took the first screenshot when the first field went from approx. 2A to 6A. After that it went to 8A and finally stopped at 11A (not exact values). The photo links are direct links from my Google Photos account as it gives an error if I try to embed them as an image.
https://photos.app.goo.gl/vUexWyKdg5f7akYh6
The second screenshot was taken after the second field started showing a value, this being approx. 2A. It too then showed 6A, 8A and 11A before proceeding to the next stage of the tests.
https://photos.app.goo.gl/vBUcVEDCDmFnyQQ69
I hovered over the fields in the hope that there would be a description of what each field represented but it didn't show anything. After the tests completed I decided to physically try the parking brake, so I parked the rear wheels over some deep loose gravel, applied the parking brake and then tried to move forward very slowly. The rear of the car dropped equally on both sides and neither rear wheel showed any sign of slipping on the gravel. I tried this twice with the same result, as I've no other way of checking them.
steamship
C?ID=225205
Still having random occurrences of the warning light being displayed, which seems to clear itself after being switched off for a while, but and he had a very interesting incident today. He arrived home and stopped in the drive. Didn't apply handbrake and just knocked it out of gear and left engine running as he wanted to check his phone before getting out. He also had his lights on full. The car then stopped and started three times in quick succession with no intervention on his part, so quickly that the lights hadn't even gone out before it started again. On the final restart it ran fine. I'll get it scanned the next time he calls out to see if any new error codes appear.
I still can't find anything definite about the reference to 'clutch position sensor' and wondering if it could be the EPB module that I mentioned in my original post.
The parking brake motors are DC motors and the EPB module monitors the current they draw to determine when they can't move anymore (i.e. when they are fully clamped closed). When some current threshold has been reached, it will stop trying to close them further.
Since this is a manual transmission car, I believe the EPB module monitors the clutch position sensor so it knows when you are trying to drive off. It can be programmed to release the parking brakes automatically when you do that. I do not think that the clutch position sensor faults are indicative of anything wrong with the parking brake motors themselves.
steamship
C?ID=225205
Uwe - Are we therefore looking at the issue being with the clutch position sensor itself? The only reason for having doubts about it is that the clutch and master cylinder had been replaced earlier this year, and now about six months later he's getting this error code.
Also, on reading your response, I never thought of mentioning that it was a manual transmission, so an oversight on my side. Having said that, I 'should' also have stated that it has Stop/Start functionality, which is what I believe was happening to the car yesterday.
