Golf mk5 GTI MFSW problem
Artiforgs
Norway
Hi all!
2005 mk5 GTI, MFSW doesnt work.
Its all stock, not retrofitted.
I have only one fault on steering wheel electronics, and thats C.C button, intermitted. (New one on its way)
but also, when reading codes from engine, it says 005784, please check DTC memory of steering wheel electronics.
But i guess this is the C.C switch not working?
Any ideas??
Artiforgs
Norway
Here you go:
also, any idea what all my door electrical faults are?
It says: Company comfort databus in singlewire», for almost all doors, including CAN gateway module..
important info:
I have an Pioneer 2-din aftermarket unit, with the correct canbus adapter for steeringwheel buttons. Installed by a company who are experts on this.
(i have also myself checked all wires going to the headunit. Everything should work they said)
I have the exact same headunit in my 2010 passat b7, and same canbus adapter. Everything works like a charm there.
Sunday,08,November,2020,20:44:19:63646
VCDS Version: 20.4.1.0 (x64)
VIN: WVWZZZ1KZ5P091491   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 72 76 77
VIN: WVWZZZ1KZ5P091491   Mileage: 159910km-99363miles
37-Navigation -- Status: Cannot be reached 1100
   Part No SW: 1K0 907 115     HW: 1K0 907 115
   Component: 2.0l R4/4V TFSI G00 0070
   Revision: --H01---    Serial number: VWZ7Z0E1897679
   Coding: 0403000318070160
   Shop #: WSC 00155 218 87841
   VCID: 63FC20CAA2AD269E76-8036
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 001 -  - Intermittent
                    Fault Status: 00100001
                    Fault Frequency: 9
                    Mileage: 159847 km
                    Time: 19:58:03
                    RPM: 1255 /min
                    Load: 16.5 %
                    Speed: 17.0 km/h
                    Temperature: 48.0°C
                    Temperature: 17.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.097 V
Readiness: 0000 0001
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0004738
   Shop #: WSC 00028 028 00001
   VCID: 3A42BDAE75A7075605-806E
   Part No: 1K0 907 044 AG
   Component: ClimatronicPQ35 066 0505
   VCID: 6CEE4BF64F7369E6C7-8038
00797 - Sunlight Photo Sensor (G107)
            010 - Open or Short to Plus
00709 - Sunlight Photosensor 2 (G134)
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001585937
   Coding: EF8F8F0600141805001400001400000000087F075C
   Shop #: WSC 00160 218 58481
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00160
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 00160
01800 - Light Switch (E1)
01064 - Terminal 58d; Interior Dimming
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 07 AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED09WYG0
   Coding: 0012343
   VCID: 3744A49A46B51A3EFA-8062
   Subsystem 1 - Serial number: 6332MSME08716938D
   Subsystem 2 - Serial number: 6342MSME091F4C49Q
   Subsystem 3 - Serial number: 6351HSME066C450AA
   Subsystem 4 - Serial number: 6361HSME066A08738
   Part No SW: 1K0 953 549 G    HW: 1K0 953 549 G
   Component: Lenksäulenmodul 021 0050
   Coding: 0002042
   VCID: 365AA99E41BFE336E1-8062
   Component: Lenkradmodul    007 0050
00895 - Cruise Control Switch (E45)
   Part No: 1K6 920 870 E
   Component: KOMBIINSTRUMENT VDD 0810
   Coding: 0003103
   Shop #: WSC 80093 222 69422
   VCID: 31509A82A8D1C40EB4-8064
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H11 0110
   Revision: 11          Serial number: 290010522305E0
   Coding: 7D3F07C8070002
   VCID: 296072E28001BCCE7C-807C
                    Reset counter: 129
                    Mileage: 159570 km
                    Time: 20:29:38
                    Reset counter: 129
                    Mileage: 159570 km
                    Time: 20:29:42
01304 - Radio
                    Reset counter: 168
                    Mileage: 159847 km
                    Time: 12:53:42
   Component: IMMO            VDD 0810
   Shop #: WSC 38603 002 1048576
Address 37: Navigation
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1K0 959 701 L
   Component: Tuer-SG         024 2807
   Coding: 0000052
   Shop #: WSC 00020 218 95555
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.12      1502
   VCID: 30569F86A3DBCD06BB-8064
   Part No SW: 1K0 959 433 AR    HW: 1K0 959 433 AR
   Component: 01 KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 009002085103087F2D04850560084FC6F0A440
   VCID: 00360F4653FB9D860B-8054
   Subsystem 2 - Part No: 1K0 907 719 B
   Component: Neigungssensor  004 0003
   Subsystem 3 - Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
00896 - Trunk Lock Unit (F256)
                    Reset counter: 166
                    Mileage: 159714 km
                    Time: 13:52:11
                    Reset counter: 126
00849 - S-contact at Ignition/Starter Switch (D)
                    Reset counter: 166
                    Mileage: 159714 km
                    Time: 13:52:11
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Component: Tuersteuergeraet 09 0119
   Coding: 0000052
   Part No: 1T0 907 357
   Component: Dynamische LWR      0002
   Coding: 0000003
   VCID: 74DE53961743B1261F-8020
Address 56: Radio
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0217
   Coding: 0000016
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 01 Einparkhilfe     0101
   VCID: 2D6886F2B4E9A0EE90-8078
00437 - Rear Right Inner Parking Aid Sensor (G335)
00436 - Rear Left Inner Parking Aid Sensor (G334)
Address 77: Telephone        Labels: 1K0-035-729-UNI.lbl
   Part No: 1K0 035 729 E
   Component: CIB PAH  HW 202 SW  0308
   Coding: 0000364
   VCID: 2B6C88EA8AFDAEDE8E-807E
01530 - Radio Mute Switch
End-------------------------(Elapsed Time: 01:24)--------------------------
Almost certainly.
