RETROFIT CLIMA LDC TOUCH ON GOLF MK7
   #22
Trowbridge, UK
I still have problems with A/C button
And rear window heating
What is your meaning. Do you want to be important
All DV52 is asking is for more of an explanation about the problems you still have (e.g. a more thorough description of the problems with the A/C button and the rear window heating), and if the Auto-Scan you have posted is not the current one to post an updated one.
   #23
JimJim
C?ID=224137
Ok good. The way you to write is more politely then his. I don’t post everyday. So he could use other words to tell this
   #24
JimJim
C?ID=224137
But no problem.
   #25
iichel
Eindhoven, NB, NL
C?ID=284912
To be fair, your tone is also a bit rude and passive agressive. And we are still missing some more detailed information to help you out here.
   #26
JimJim
C?ID=224137
Thursday,16,September,2021,13:12:38:48826
VCDS Version: 21.9.0.1 (x64)
Data version: 20210824 DS330.0
VIN: WVWZZZ3CZGE0542xx   License Plate:
Chassis Type  3C-VW48 (5QE)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 23 2B 36 3C 42 44 47
          51 52 55 5F 69 6C 75 82 8C A5 A9 BB BC C6 CA CF
VIN: WVWZZZ3CZGE054227   Mileage: 147607km-91718miles
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CUKC)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023 AH    HW: 04E 907 309 F
   Component: R4 1.4l TFS   H21 3379
   Revision: X3H21---    CVN: 861A8C11
   Coding: 011D0012647405083000
   Shop #: WSC 00470 211 00000
   ASAM Dataset: EV_ECM14TFS01104E906023AH 006006
   ROD: EV_ECM14TFS01104E906023AH_006.rod
   VCID: 66C6129699D977B9D8-8032
   VINID: 9E69EAAAA0D3A975401440821C343C5ECD
Readiness: 1110 0001
   Part No SW: 0DD 300 045 T    HW: 0DD 927 770 B
   Component: GSG DQ400E    H31 1601
   Revision: 00031033    Serial number: TFK01504270192 CVN: F52AF510
   Shop #: WSC 00149 211 00000
   ROD: EV_TCMDQ400021.rod
   VCID: 387A8CEE83ED3149BA-806C
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 3Q0 907 379 S    HW: 3Q0 907 379 G
   Component: ESC           H42 0823
   Revision: 00000000    Serial number: 61825000000047 CVN: 03BBAF11
   Coding: 0EEC408F382533700779060241CA4970021CCCE0608292F1B8B1F0F8C2A9
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 002001
   ROD: EV_Brake1UDSContiMK100OMG_002.rod
   VCID: 4A9EC626ED01B3D9DC-801E
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0709
   Revision: 00036000    Serial number: 0374878427
   Coding: 0F00000703
   Shop #: WSC 05311 115 00304
   VCID: 3A7E96E6BDE123594C-806E
Address 08: Auto HVAC (E87)       Labels: None
   Part No SW: 17G 907 044 K    HW: 17G 907 044 K
   Component: AC Automat    H11 1201
   Revision: 20K07000    Serial number: 00000A00810908
   Coding: 12021024200110010815504000101822
   ASAM Dataset: EV_ACTouchPrehVW37X 001010
   ROD: EV_ACTouchPrehVW37X_VW48.rod
   VCID: 326EBEC66591DB1984-8066
   Subsystem 2 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 06294CB7000000000001
No ASAM data for: "EV_ACTouchPrehVW37X" (VW48)
262658 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 147
                    Mileage: 147593 km
                    Date: 2021.09.16
                    Time: 12:56:01
655618 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 147
                    Mileage: 147593 km
                    Date: 2021.09.16
                    Time: 12:56:00
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 86581607152811
   Coding: 00971E46C3D10AF727885094B11807381880000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 03002B028AABA2915F-8056
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    150701  042 0607
   Serial number:         150703050506
   Component: RLHS  037 0059
   Serial number: S2Y15M07D28H17M04S20
   Coding: 90A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 S    HW: 3G0 941 633 S
   Serial number: 25 05 2015  00000605
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY200750LXH
   Serial number: 00000000000032857393
   Humidity sensor: interior:
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183615204
   Coding: 1A71267951
   Shop #: WSC 05311 115 00088
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 0D140D3ADCEFE4E139-8058
Address 13: Auto Dist. Reg (J428)       Labels:. 3Q0-907-572.clb
   Part No SW: 5Q0 907 572 R    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0771
   Coding: 551D7FCB5DFFC728979C8145814006000000000000B9400000
   ASAM Dataset: EV_ACCBOSCHVW416 003014
   ROD: EV_ACCBOSCHVW416_003_VW48.rod
   VCID: 4686F216F91957B938-8012
No ASAM data for: "EV_ACCBOSCHVW416" (VW48)
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H16 0120
   Serial number: 14071541350573
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 37788FD28EF33E31B3-8062
   Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
   Component: AirbagVW20    010 0870
   Serial number: 003MFR0122D%
   Coding: 88CCC000002000005C5400CF004800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 50AAD44E0B5D890992-8004
   Left seat belt tensioner:
   Right seat belt tensioner:
   Subsystem 3 - Part No SW: -----------    HW: 480 001 607 15
   Serial number: 35700000000B7909651K
   Subsystem 4 - Part No SW: -----------    HW: 480 001 607 15
   Serial number: 3580000000089A09651L
   Subsystem 5 - Part No SW: -----------    HW: 480 400 107 15
   Serial number: 3510002AD1C52F30615+
   Subsystem 6 - Part No SW: -----------    HW: 480 400 107 15
   Serial number: 3520002C71B65D55B1BE
   Subsystem 7 - Part No SW: -----------    HW: 480 400 107 15
   Serial number: 3550002A51C52F35C234
   Part No SW: 3Q0 953 521 B    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150725500002
   Coding: 0810
   Shop #: WSC 00015 115 00001
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 2F68B7B276A3F6F1EB-807A
   Part No SW: 3G0 920 794     HW: 3G0 920 794
   Component: KOMBI         409 1340
   Coding: 07A503187FCC000800807B1B3601002000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009048
   VCID: 69DC19AA88C758C1F5-803C
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 5QE 907 530 D    HW: 5QE 907 530 A
   Component: GW MQB EV     312 3226
   Revision: --------    Serial number: 07071510803087
   Coding: 0A03001726F21000FB00527EDC1F00000001070100010000000300000000
   GVL: 01543C1800000608D0DC90008002CC1810040000000000000000000000000000
   ASAM Dataset: EV_GatewEVConti 013020
   ROD: EV_GatewEVConti_013.rod
   VCID: 4798FF12FE134EB1C3-8012
   Subsystem 1 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29180000602330098124
   Coding: 2DFFFF
   Subsystem 2 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 6421337103
   Inverter for electrical outlet:
   Subsystem 3 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: WECHSELRICHTE  H56 0033
   Serial number: 0128249
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
Address 23: Brake Booster
   Serial number: 15000063946018
   Coding: 0800000000000000
   Shop #: WSC 00015 115 08193
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71EC71CAA017A001BD-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 3Q0 959 760 B    HW: 3Q0 959 760 B
   Component: Sitzmemory    H04 0016
   Serial number: Y0006OGI14826
   Coding: 0010000200000500818280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002019
   Part No SW: 3Q0 907 566 B    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0230
   Revision: --------
   Coding: 14C002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
   Serial number: 070715BG709439
   Coding: 001F1E20D200028000001000
   Shop #: WSC 12345 123 61029
   VCID: 4380EB02CA2B62911F-8016
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2033
   Revision: 00000000    Serial number: 0000318426
   Coding: 01010011005101
   Shop #: WSC 00015 115 00304
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008.rod
   VCID: 3B7093E2B2DB1A5157-806E
Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
   Part No SW: 3Q0 035 466 C    HW: 3Q0 035 466 C
   Component: MIB2_amp_P_VW H45 0210
   Revision: 00000001    Serial number: VWZ8Z1FAT0078B7
   Coding: 1284010001AA0A20AA0000000000
   ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
   ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
Address 51: Electric Drive
   Serial number: 090715BG904492
   Coding: 001F1020DE00028200001000
   VCID: 428EEE06D5316B9914-8016
   Component: AFS-ECU       H01 0110
   Coding: 039202004F210200
   Shop #: WSC 05311 000 08193
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   VCID: 3F88E7F2A6C306717B-806A
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
   Part No SW: 5NA 035 022 D    HW: 5NA 035 022
   Component: MU-H-TNDL-EU  H42 1367
   Serial number: A596G0F7507378
   Coding: 028401010000000051111102008808101F0109E4012000009F
   VCID: 3462B8DE9F85D52996-8060
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H52 9130
   Serial number: VWZ6ZJV3261597
   Subsystem 2 - Part No SW: V03 959 809 P    HW: -----------
   Component: ECE 2021/2022  --- 0192
   Compact disc data bank:
   Component: Gracenote2  --- 1011
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0203
   Revision: 8A001003    Serial number: 0374601469
   Coding: 0100000202000000
   Part No SW: 5Q0 907 556     HW: 5Q0 907 556
   Component: Areaview 2    H11 0329
   Serial number: C854706JG001607
   Coding: 01840101E70F200000204814
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 003013
   ROD: EV_CamSysRVAV2ARCE2MQBAB_003_VW37.rod
   VCID: 76E642D6C979873968-8022
   Part No SW: 5QE 035 284 C    HW: 5QE 035 284 C
   Component: OCULowMQBEU   012 0715
   Coding: 028471011082BA0300F800000000
   ROD: EV_OCULowMQB.rod
   VCID: 4482E81ECF2565A926-8010
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 3G0 919 608     HW: 3G0 919 608
   Component: HeadupDisplay 029 0152
   Coding: 474060
   ASAM Dataset: EV_HeadUpDisplContiVW481 001010
   ROD: EV_HeadUpDisplContiVW481.rod
   VCID: 6BD063A2823B4AD187-803E
Address 8C: HV Battery (J840)       Labels: 5QE-915-227.clb
   Part No SW: 3Q0 915 227 P    HW: 3Q0 915 227 K
   Component: K8C           H05 0520
   Serial number: 16061512010015 CVN: 8BE8FA63B95EF858DC659A657E764ED97E764ED97E764ED97E764ED97E764ED9
   ASAM Dataset: EV_BECM09620213Q0915227P 002009
   ROD: EV_BECM09620213Q0915227P.rod
   VCID: 3E769AF6A1C90F7970-806A
   Battery interrupt switch:
   Subsystem 1 - Part No SW: 3Q0 915 227 J    HW: 3Q0 915 227 J
   Component: A2 HVSMBJBECU  H08 0410
   Serial number: 00000022061512010133
   Cell module control module 1:
   Subsystem 2 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC1  H04 0442
   Serial number: 15515ZKK311A01030938
   Cell module control module 2:
   Subsystem 3 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC2  H04 0442
   Serial number: 15515ZKK311A01030609
   Cell module control module 3:
   Subsystem 4 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC3  H04 0442
   Serial number: 15515ZKK311A01031279
   Cell module control module 4:
   Subsystem 5 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC4  H04 0442
   Serial number: 15515ZKK311A01030690
   Cell module control module 5:
   Subsystem 6 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC5  H04 0442
   Serial number: 15515ZKK311A01030053
   Cell module control module 6:
   Subsystem 7 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC6  H04 0442
   Serial number: 15515ZKK311A01030114
   Cell module control module 7:
   Subsystem 8 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC7  H04 0442
   Serial number: 15515ZKK311A01031090
   Cell module control module 8:
   Subsystem 9 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC8  H04 0442
   Serial number: 15515ZKK311A01030729
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H06 0610
   Serial number: 02011711K20780
   Coding: 000308020000040100222347C056A90098000E20004000
   Shop #: WSC 00046 123 12345
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 408AE40EDB3D798902-8014
   Part No SW: 3G0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0005
   Serial number: 150626200849
   Serial number: 020715BG110127
   Coding: 000E10200100028000001000
   Shop #: WSC 55385 002 1048576
   VCID: 4584F51AC41F5CA131-8010
   Serial number: 020715BG110216
   Part No SW: 5QE 915 682 M    HW: 5QE 915 682 M
   Component: OBC KOSTAL    H22 4006
   Revision: --------    Serial number: 2007150GH0008I
   Coding: 115068222000
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB11P 004001
   ROD: EV_OBCSinglPhaseKLOMQB11P.rod
   VCID: 57B82F522EB3DE3153-8002
Address CA: Sunroof
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
Address CF: Lane Chge Asst 2
End-------------------------(Elapsed Time: 07:22)--------------------------
JimJim
C?ID=224137
I have a passat GTE and like this topic i also wanted to install this nice LCD touch clima. My former and originel partnr was 5GE 907 044AK. It was a three zone panel because i could control the rear temperture on my MIB 2.5 screen.
So i looked for a three zone LCD touch panel. I found the 17G 907 044 K. I intalled it and went to coding. I placed the code from old in this touch version. After that i made a basisc setting mauel by putting the A/C button and Menu toghether. After that al worked. I thougt
Now it seems these problems:
-Airco not feeling cold like before wenn i put it all on LOW.
-Rear clima panel not powered. Display is of. But i do see the temperture on MIB.
-And these two faultcodes.
Some say need Odis, but i love to hear you advice.
I will try to upload any picture so it will be more visuel.
   #28
@JimJim:Hi and my apology if you read my response as being a tad rude (not my intention)
Again- no offense intended and I most certainly acknowledge the difficulties of non-English speaking members posting on this forum - I would dread writing a post on a Dutch forum!!
In answer to your question: no, I don't "want to be important" - I just want to help (as do ALL forum members). But to do that, we need to understand your problem and the key to that knowledge is information.
Put yourself in the position of those reading your post: currently all we know about your problem is that it relates to the AC/button and the rear window heating. We could assume that the car is a Tiguan, but it could equally be any one of the myriad of other MQB platform vehicles that VW/Audi manufacture. Or, the car could be a totally different platform vehicle - we just don't know!
And, we have no idea about how the car is equipped, or what if any error messages might be present - because no auto-scan has been provided
Finally, an important aspect of remote diagnostics is the back-story - meaning an explanation of any pertinent events that might be related to the car's problem. For example: have you retrofitted any new equipment to the car, was the car in an accident, have you changed any coding in the modules, has the car been repaired lately etc.?
So, I repeat - no offense intended - but, there is a huge amount of data that currently only you know about this problem. Whilst we ALL want to help you, no one in this forum is particularly concerned about not knowing what you know (again, no offense). However, we need you to help yourself - and the way to do this is to provide a full data-dump of any useful information related to your problem.
As I said - put yourself in our position, trying to help answer your questions!!
EDIT: arrhhhh......... that's better; Thank you!!:thumbs:
   #29
downtime
Finland
C?ID=280813
          - 00 [009]
                    Reset counter: 147
                    Mileage: 147593 km
                    Date: 2021.09.16
                    Time: 12:56:01
          - 00 [009]
                    Reset counter: 147
                    Mileage: 147593 km
                    Date: 2021.09.16
                    Time: 12:56:00
First error is about the pressure sensor, the second one is 655618 - Control/Display Unit for Rear Climatronic no signal.
So first, go to auto hvac module and to measurement values and check what does the pressure channel show, where does the pressure rise when you put the AC on and to low setting? It should go to over 10bars. My guess is that in your situation it stays less than 10bars.
Two options, either the coding of the auto hvac module is not correct, or the panel is not compatible and it does not control the pressure valve correctly and the pressure of the system does not go up.
Second problem I'm not sure. Maybe the rear panel is not compatible with the touch panel climatronic?
edit: Read this =>https://www.drive2.ru/l/587201057835230477/
   #30
Tharkhold
Canada
C?ID=311665
You need ODIS for an AC faceplate? There's component protection on an AC unit now?
Fk me, these are the times!
I was even thinking of getting one of these fancy(er) faces for my mk5 Jetta w/mk6 climatronic just to see how/if it can work!
   #31
Yeah, Audi has had this stuff for ~15 years in their higher-end models. It came to VW with the Mk.7 generation.
And if this annoys you, I guess you haven't heard about SFD in Mk.8. ;)
downtime
Finland
C?ID=280813
There's no component protection. I'm guessing ODIS is because it shows the coding data of the unit. I don't see why else it is required, you can copy the coding over from old unit with VCDS as well.
   #33
Tharkhold
Canada
C?ID=311665
I guess those right to repair laws better come in sooner than later!
  • Agree
