Q5 2.0TDI reductant agent tank level issue
fast79
Finland
C?ID=208284
Hello!
Car is 2015 Q5 2.0TDI. I got a message "refill adblue" and 2400km left to drive. I've got this message many times in past months and I'm 100% sure that the reducing agent tank is full. I used to fill the tank every time when I got the message and last time it overfilled so it's definitely full. I have done the scr tank level reset three times and the warning goes off. I've also reset scr lock. Now it's been only two weeks since last reset and the warning is on again. I checked the fill level in measuring blocks and it's a bit over 96%. Is there a faulty tank level sensor or is there something else wrong? There's no fault codes and the reductant system works fine except this issue.
Here's full scan:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 42 44 46 52 53 56 62 69 6D
          72 77 AC
VIN: WAUZZZ8R6GA025166   Mileage: 185840km-115475miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 CK    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 8507
   Revision: 85H23---
   Coding: 2A25401A243601080000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906021CK 002009
   ROD: EV_ECM20TDI01104L906021CK_002.rod
   VCID: 70EFDB9CABA04206E3-8024
   Part No SW: 8R2 927 156 M    HW: 0B5 927 156 K
   Component: 0B5 20 TDIRdW H03 0004
   Revision: --H03---
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMDL501021 001016
   ROD: EV_TCMDL501021.rod
   VCID: 479D5040FEAEA5BE92-8012
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 BA    HW: 8R0 907 379 BA
   Component: ESP8 quattro  H09 0020
   Coding: 2CDDCC01
   VCID: 000F8B5C9300528613-8054
   Part No SW: 8K0 907 064 KG    HW: 8K0 907 064 KG
   Component: BCM2 2.0      H15 0711
   Coding: 01A54000000000000000
   VCID: 7F0D08A0EEFE2D7E6A-802A
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0815000075584009
   Part No SW: 8K1 820 043 AT    HW: 8K1 820 043 AT
   Component: KLIMA 1 ZONE  H02 0123
   Revision: A1000000    Serial number: 01290620150347
   Coding: 342900A000
   VCID: 7AFBF9B4F5DC08565D-802E
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00001105256601
   Coding: 2600C01080348FC00781400300001D0D001C670826090201000004004401030100000020000000
   Shop #: WSC 06335 123 12345
   VCID: 78FFE3BCCBD01A462B-802C
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 150619  H12 0050
   Serial number: 90243014150614024932
   Coding: 01DD13
   Serial number: 20393614
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001706150884
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: EA68C4B7000000000001
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H49 0610
   Serial number: 003JPDD06M1G
   Coding: 30463531313030303030554A304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 489F537CF3B0AAC69B-801C
   Serial number: 6334MSME526C740CL
   Serial number: 6344MSME526D1939M
   Serial number: 6352QSME04542B74E
   Serial number: 6362QSME5E533A48U
   Serial number: 63732SME3E584F60B
   Serial number: 63832SME4958444A5
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862OFT001DM
   Coding: 000017
   VCID: 489F537CFBB0AAC69B-801C
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 932     HW: 8R0 920 932
   Component: KOMBIINSTR.   H36 0567
   Revision: 00100000    Serial number: 037465Z3G
   Coding: 138F220003010008010000
   VCID: 73E5D490D2B6791E1E-8026
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 J    HW: 4H0 265 105 J
   Component: Standheizung  H26 0260
   Revision: 77007007    Serial number: 20150613020640
   Coding: 554501
   VCID: 2959F6F840FA73CE64-807C
   Part No SW: 8R0 907 468 R    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0070
   Revision: 1V100031    Serial number: 3141V156070A5F
   Coding: 80CF07FF00
   VCID: 4E93656419D474F6D1-801A
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 9642617003
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 15177002620011200410
   Part No SW: 8K0 959 793 S    HW: 8K0 959 793 Q
   Component: TSG FA        H02 0511
   Revision:             Serial number: 0000156102671
   Coding: 011003204000440004
   VCID: 50AF7B1C03E06206C3-8004
   Part No SW: 8R0 909 144 P    HW: 8R0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0003897240
   Coding: 100000010001
   Shop #: WSC 06334 123 12345
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 45815A48C4A2B7AE60-8010
   Revision: 00002001    Serial number: 0372849102
   Coding: 0100063820B930008720053680040047
   Part No SW: 8K0 959 792 S    HW: 8K0 959 792 Q
   Component: TSG BF        H02 0511
   Revision:             Serial number: 0000156115126
   VCID: 4FAD78601EDE7DFEDA-801A
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000646947
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A7B39B4BD5CC8561D-806E
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8R1 035 186 N    HW: 8R1 035 186 N
   Component: Concert3      H09 0470
   Revision: 00000004    Serial number: AUZ5Z6P2165924
   Coding: 0500048204058500455B071003
   VCID: 408F4B5CD380928653-8014
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000156542019
   Coding: 010003204000240004
   VCID: 46835D44F1A4BCB669-8012
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 D    HW: 8K0 907 383 D
   Component: Anhaenger     H12 0100
   Revision: 1G001001    Serial number: 00000372992472
   Coding: 0109080000000000
   Shop #: WSC 25397 000 00000
   VCID: 35612A889C42272EF0-8060
Address 6D: Trunk Elect. (J605)       Labels: 4L0-910-945.clb
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D7132A8A472FF6E38-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000156542211
   Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005843423
   Coding: 0010390
   VCID: 3D7132A86472FF6E38-8068
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 151680802
   ROD: EV_RDCMA00100.rod
   VCID: 2F6D18E0761E1DFEBA-807A
End-------------------------(Elapsed Time: 03:41)--------------------------
bonzo
Romania
C?ID=334156
the simple way it to reflash ecu and made addblue off.i have same problem as you
fast79
Finland
C?ID=208284
That's one option, I'm not going to spend too much money fixing that issue.
fast79
Finland
C?ID=208284
Anyone? I know these issues are quite common but it's hard to find which has been the original fault in these problems.
naushad2982
Kenya
C?ID=58306
Overfilling can cause a failed reset. drain some of it off and try again
fast79
Finland
C?ID=208284
It wasn't overfilled until third time I filled it past year so that's not the case. Now the period to get the refill message seems to be shorter every time after last reset.
Jef
HQ
Have you done the two Basic Setting steps back to back with key on/engine off?
  1. IDE04567 - Resetting of SCR tank level detection
  2. IDE04730 - Reset SCR lock
fast79
Finland
C?ID=208284
Yes I have, every time I get the "refill Adblue" message. Now the refill message is on again so it appears in two-three weeks period now.
Maybe have a look at the following measuring values:
IDE03147 -- Sensor for reducing agent tank temperature: voltage (mV)
IDE03148 -- Sensor for reducing agent fill level: voltage (mV)
IDE03142 -- Remaining vehicle distance until reducing agent deficiency (km)
IDE05232 -- Reducing agent fill level (%)
IDE05630 -- Reducing agent tank fill level indicator: raw value (%)
I wonder if the level sensor isn't seeing that you have filled the tank. The problem is if the tank is full, you'll have partly drain the tank in order to see if things change.
I've never understood why VAG wants to keep the amount of DEF in the tank a secret from the owner. Other manufacturers give you a dedicated gauge for it!
fast79
Finland
C?ID=208284
I've checked those values you mentioned earlier and one thing I have noticed that IDE05630 -- Reducing agent tank fill level indicator: raw value (%) is 16,70% . That value doesn't change even if I reset IDE05232 -- Reducing agent fill level (%) . I think the case is just like you said, the sensor doesn't recognize filled tank level. I've been wondering if there's anything I could do to the sensor, that's unlikely an interchangeable part? I wouldn't want to change the whole tank because a faulty sensor.
By the way the refill message is again on. Is it possible to change the fill level indicator raw value?
The VWs we've with DEF systems we've had (an NMS Passat and Touareg) also had fill-level values that basically never changed (despite never showing any indication of a malfunction). I'm really not sure what's up with that. However, they tended to be right around 80%..
I think you're going to need to check a repair manual and/or parts catalog for your specific vehicle.
fast79
Finland
C?ID=208284
Last night check engine light went on and I found a following dtc:
                Address 01: Engine       Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 906 021 CK    HW: 04L 907 309
  Component and/or Version: R4 2,0L EDC   H23 8507
           Software Coding: 2A25401A243601080000
            Work Shop Code: WSC 06208 000 00000
              ASAM Dataset: EV_ECM20TDI01104L906021CK 002009 (AU48)
                      VCID: 70EFDB9CABA04204F3-8024
9645 - Reductant
          P20E8 00 [237] - Pressure too Low
                    Mileage: 187754 km
                    Date: 2020.12.16
                    Time: 09:53:25
                    Engine RPM: 977.50 /min
                    Normed load value: 45.9 %
                    Vehicle speed: 10 km/h
                    Coolant temperature: 52 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 14.460 V
                    Outside temperature sensor 1: B1: raw value: 0.5 °C
                    Pressure sensor for reducing agent: measured pressure: 236 hPa
                    Sensor for reducing agent tank temperature: temperature: 2.3 °C
                    Reducing agent pump: activation: 50.00 %
                    Sensor for reducing agent fill level: voltage: 520.0 mV
Readiness: 1 1 0 0 0
I guess we found a problem which explains all these issues. This is a 2015 car and there's been lots of faulty pump units on this model year what I have read.
  • Informative
fast79
Finland
C?ID=208284
Today came AdBlue system fault message, no restart in 1000km. I cleared fault codes in engine control module and made reset to scr tank level and scr lock. There are no fault codes in any control modules but there's still AdBlue fault message on FIS display. Is there really 1000km or less left to do something about it or can I reset that fault message somehow?
Check for DTCs via generic OBD-II as well. Use modes 3, 7, and especially 10.
fast79
Finland
C?ID=208284
Ok, thanks for the tip. I'm going to a local software specialist next tuesday and we will say goodbye to the whole AdBlue system...
