After first oil change SRIreset- What does "poor oil quality" in log mean? - 2019 Golf 1.8 TSI CXBB
Max of Millbrook
C?ID=418347
I used Mobil1 5w30 ESP with VW504..00 spec for winter. I have and will use Castrol 5w40 VW502.00 in spring.
below is SRIreset log
Monday,02,November,2020,14:05:13:40859
VIN: 3VW117AU9KMxxxxxx   License Plate:
Mileage: 1586km-985mi   Repair Order:
VCDS Release 20.4.2:  SRI Reset-SRI3.CLB
Control Module Part Number: 5G1 920 740 D       Labels:  .*5G0-920-XXX-17.clb-SRI3
Component:KOMBI         251 2700, Coding:0BA4101AA588880902886A095000000080000000
Channel        Description                                                         Current val.                                                    New val.
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                    no warning                                                      ---
IDE00510-ESI: distance driven from inspection                                                          ESI: Distance since Inspection                                  25 km                                                           ---
IDE00511-ESI: time from inspection        ESI: Time since Inspection                                      4 d                                                             ---
IDE00515-ESI: oil quality        ESI: Oil Quality                                                    poor oil quality                                                ---
IDE00517-ESI: soot entry        ESI: Soot Quantity                                                  0 km                                                            ---
IDE00518-ESI: thermal load        ESI: Thermal Load                                                   100 km                                                          ---
IDE01153-SIA: maximum value of distance to service                                                    SIA: Maximum Distance to Service                                15000 km                                                        ---
IDE01154-SIA: maximum value of time to service                                                          SIA: Maximum Time to Service                                    365 d                                                           ---
IDE03349-FIX: Max. distance until next mileage-related inspection                                       FIX: Maximum Distance to Inspection                             30000 km                                                        ---
IDE03350-FIX: Maximum time until next time-dependent inspection                                         FIX: Maximum Time to Inspection                                 730 d                                                           ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                                  FIX: Distance since Inspection                                  1500 km                                                         ---
IDE03352-FIX: Time since last time-dependent inspection                                                 FIX: Time since Inspection                                      355 d                                                           ---
South Molton, UK
"Poor oil quality" means your car is set for fixed service intervals not variable.
Max of Millbrook
C?ID=418347
So this would be normal all the time? Or should I make a change somewhere? I'm new to this much data, just starting to read and learn about a VW.
South Molton, UK
Normal all the time if you're on fixed interval servicing.
Normal. All NAR market cars are on fixed intervals from the factory.
Max of Millbrook
C?ID=418347
Well, I truly know nothing about VW world. Acronyms like NAR.(I'm on my phone, no mouse to hover)
I tried to do the channel logs but freaked out, I thought I had done something stupid as I watched the laptop pouring out data for minutes. I tried to ESC and found about 26 log entries! I see now that it was accessing every module in the ECU? Wow so much to learn. I worked in the beginning of the digital telephone switches back in the early 80's. This Golf looks nearly as powerful as those mainframes! Hopefully you can tolerate my ignorance but I always am trying to learn new things to keep this old mind sane.
Thanks for your help.
NAR = North American Region, basically the USA and Canada.
naushad2982
Kenya
C?ID=58306
There are 2 options for service intervals, variable and fixed. we usually leave ours on fixed intervals where the service reminder comes on at the mileage or date we set it to. variable is mostly Europe i belive, where they can pull upwards of 15,000- 30,000 kms or three years.
ultimately just remember the service reminder is not intelligent. the vehicle has no way of knowing when the service is really due, or if its been done.,
