Audi e-tron - Ignition/Engine - Disable Auto-off function
UWSCSI
Norway
C?ID=134408
Audi e-tron, MLB-platform.
When ignition and engine are on and the driver door is opened, both turn off.
That is not alway preferable, e.g. in a situation where I leave the car for just 20 seconds to help someone with the luggage in the trunk.
I am trying to figure out if it is possible to tweak this so that at least the ignition is on, but preferably both ignition AND engine stays on.
I have been looking around in the modules, but there are so many options and many expressions/labels that I really do not understand what everything actually is or does...
So, any suggestions and/or thoughts would be much appreciated.
Tuesday,03,November,2020,12:50:22:42591
Chassis Type: GE-AU58 (4K1)
Scan: 01 03 09 13 15 16 17 19 2B 36 42 44 46 47 51 52 5F 69 6C 6D
74 75 81 8C A5 BB BC C5 C6 CA CD CE D6 D7 DE 8104 8111 8112
Mileage: 29303km-18208miles
51-Electric Drive -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CD-Laser Scanner -- Status: Malfunction 0010
CE-Drive Motor 2 -- Status: Malfunction 0010
8104-DC/DC Converter HV -- Status: OK 0000
8111-Rearview Mirror Right -- Status: OK 0000
8112-Rearview Mirror Left -- Status: OK 0000
Address 01: Engine (J623- ) Labels: None
Part No SW: 4KE 907 558 E HW: 4KE 907 558
Component: I99 99.9l XXX H02 0001
Coding: 2A0A0012007E040034080000000000000000000000000000
ASAM Dataset: EV_VCU00XXX0204KE907558E 001001
ROD: EV_VCU00XXX0204KE907558E.rod
VCID: 4BC361F9634F75A3F71-801E
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 4KE 909 059 AC HW: 4KE 909 059 G
Component: ESC H09 0078
Revision: 00000000 Serial number: 63368000000549
Coding: 008800BA3D940B9ED3510871187AD2E025BEA10000BCD0CB10184B07A47D85
Shop #: WSC 00150 218 00000
ASAM Dataset: EV_BRSContiMKC1AU516 009376
ROD: EV_BRSContiMKC1AU516_009.rod
VCID: 08499EF532B95EBB1A3-805C
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 4N0 907 063 EG HW: 4N0 907 063 AG
Component: BCM1 MLBevo H10 0671
Coding: 07000943C13900DD0700F7889CBF8C68131B33100806009789030A00792216810A4509BB42B6260B00000303004918180802800044010000000000000000000000
Shop #: WSC 00046 412 00046
ASAM Dataset: EV_BCM1BOSCHAU651 015009
ROD: EV_BCM1BOSCHAU651_015.rod
VCID: 77ABED094F472143639-8022
Subsystem 2 - Part No: 81A 955 555 A
Coding: 02005E
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE105101823811407
Interior Light Module:
Subsystem 5 - Part No SW: 4K0 947 135 L HW: 4K0 947 135 L
Component: Dachmodul H42 0413
Serial number: C00153219
Coding: 0D0104
Front windshield washer pump:
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 4KE 907 561 B HW: 4K0 907 561
Component: LRR4R H04 0332
Coding: 7E61FF4B58082C0001038020000000BA4A1246494481009E01
ASAM Dataset: EV_ACCBOSCHAU65X 002023
ROD: EV_ACCBOSCHAU65X_AU58.rod
VCID: 42DD4CDD5405B4EB047-8016
2342 - Databus
[FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
Fault Frequency: 23
Reset counter: 247
Mileage: 27910 km
Date: 2020.10.29
Time: 13:59:15
Control Module temperature: 18 °C
Voltage terminal 15: 14.6 V
Velocity_vehicle_reference: 5.02 m/s
Longitudinal_acceleration_vehicle_reference: 0.72 m/s²
Steering_angle-Data: 82.900 °
Yaw_rate-Data: 2.029 rad/s
adjustment_calculation: On
Misalignment angle: horiz: -0.182 °
Misalignment angle: horiz: fast algorithm: -0.120 °
Congestion pilot: status: OFF
Outside air temperature: 10.50 °C
Sensor blindness: radar: no blindness detected
2102 - Databus
[FAULT_ESP_CONTROL_FAIL]
Fault Frequency: 23
Reset counter: 247
Mileage: 27910 km
Date: 2020.10.29
Time: 13:59:14
Velocity_vehicle_reference: 4.57 m/s
Longitudinal_acceleration_vehicle_reference: 0.95 m/s²
Steering_angle-Data: 37.600 °
Yaw_rate-Data: 1.103 rad/s
Address 15: Airbags (J234) Labels:* None
Part No SW: 4KE 959 655 HW: 4KE 959 655
Component: AirbagVW32 H36 3122
Serial number: 003XPM00D65L
Coding: AAFCF0C0002000009A5400FFF80D41A800C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001034
ROD: EV_AirbaVW31SMEAU65x_VW53.rod
VCID: 0B43A1F923CF35A3371-805E
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H10 0115
Serial number: 00AI2019010332500000
Coding: 03F002
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H10 0115
Serial number: 00AI2019012394400000
Coding: 03F002
Subsystem 3 - Part No SW: ----------- HW: 480 001 512 18
Serial number: 35700000000733281635
Subsystem 4 - Part No SW: ----------- HW: 480 001 512 18
Serial number: 35800000000877E8763X
Subsystem 5 - Part No SW: ----------- HW: 480 030 301 19
Component: SideSensor_Dr 002 0149
Serial number: 351001C18645548048B0
Subsystem 6 - Part No SW: ----------- HW: 480 030 301 19
Component: SideSensor_Pr 002 0149
Serial number: 352001C18F7CD0D06FA.
Subsystem 7 - Part No SW: ----------- HW: 480 020 901 19
Component: FrontSensor_D 000 0149
Serial number: 3550001B32E7F5156603
Front Sensor Passenger:
Subsystem 8 - Part No SW: ----------- HW: 480 020 901 19
Component: FrontSensor_P 000 0149
Serial number: 3560001B92F0DDC4A20K
Sensor High Voltage System 1:
Subsystem 9 - Part No SW: ----------- HW: 480 020 612 18
Component: HVSensor_gSat 000 0149
Serial number: 3510001A72E698B493FM
Side Sensor B-Pillar Driver Front:
Subsystem 10 - Part No SW: ----------- HW: 480 020 612 18
Component: SideSens_B_Df 000 0149
Serial number: 3520001A72ECF895822J
Side Sensor B-Pillar Passenger Front:
Subsystem 11 - Part No SW: ----------- HW: 480 020 612 18
Component: SideSens_B_Pf 000 0149
Serial number: 3550001B32E698B44189
1065477 - Databus
[NWD: 0xTBD BV_SensorHeader error value BV2_Fehler_MOD]
Fault Frequency: 9
Reset counter: 245
Mileage: 27931 km
Date: 2020.10.29
Time: 17:16:02
Part No SW: 4N0 907 129 AJ HW: 4N0 907 129 AJ
Component: Lenks.Modul H03 0005
ROD: EV_SMLSKLOAU736_AU58.rod
VCID: 79AFEB317953373315D-802C
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4KE 920 795 B HW: 4KE 920 795
Component: FHybRDWACC--- H13 0031
Coding: 850C00C87C90000801A6E570B284680008000100
ROD: EV_DashBoardAU65X_VW53.rod
VCID: 46D550CD782D88CB28F-8012
Part No SW: 4K1 907 468 D HW: 4K1 907 468 C
Component: Gateway H04 0323
Serial number: 1DF05028243901
Coding: 02030005000100C000810000005B01329C8A004718000000090000DF00000000
ASAM Dataset: EV_Gatew31xAU65x 003170
ROD: EV_Gatew31xAU65x.rod
VCID: 3635200D08CD184BB8F-8062
Subsystem 1 - Part No SW: 4N0 951 523 G HW: 4N0 951 523 G
Component: E221__MFL H06 0003
Subsystem 2 - Part No SW: 4N0 915 181 D HW: 4N0 915 181 D
Component: J367-BDMConti H03 1051
Serial number: 7674960100190114008D
Control module for steering wheel touch recognition:
Subsystem 3 - Part No SW: 4N0 419 508 HW: 4N0 419 508
Component: J1158 KLR H44 0030
Serial number: 18295043106S00304401
197169 - Controls in Steering Wheel
U108E 00 [008] - No Communications
[Break_Down_LIN_Communication_Mfl]
Reset counter: 245
Mileage: 28679 km
Date: 2020.11.01
Time: 21:52:25
262693 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[BAP_Timeout_BatteryControl]
Reset counter: 245
Mileage: 28673 km
Date: 2020.11.01
Time: 16:02:03
8913155 - Development Code 4
B2F04 00 [009] - -
[RWB_TME_Init_Abwurf_Dauerinit]
Reset counter: 198
Mileage: 27929 km
Date: 2020.10.29
Time: 15:44:46
8913156 - Development Code 5
B2F05 00 [009] - -
[RWB_BCME_Init_Abwurf_Dauerinit]
Reset counter: 198
Mileage: 27910 km
Date: 2020.10.29
Time: 13:58:14
8978691 - Unknown Error Code
B18D3 F1 [008] - Unknown Error Elaboration
Reset counter: 239
Mileage: 27929 km
Date: 2020.10.29
Time: 17:11:33
Part No SW: 3Q0 905 861 C HW: 3Q0 905 861 C
Component: ELV-MLBevo H05 0020
Serial number: 18000398473018
Coding: 8800000000000000
ROD: EV_ELVMarqMQBA0_VW41.rod
VCID: 34311A051EB10A5B86B-8060
Part No SW: 4M6 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0064
Serial number: 00000355664429
Coding: 01581A400000B4010003010101010000000000000000000000000000004000
VCID: 7BA3F139736F0523071-802E
Part No SW: 4M0 959 593 M HW: 4M0 959 593 J
Component: TSG FS 007 0387
Serial number: 0000353279745
Coding: 001DDA0143000480A000B002
Shop #: WSC 00535 218 00000
Part No SW: 4N0 909 144 D HW: 4N0 909 144 A
Component: EPS_MLBEVO2BS H21 0504
Coding: B4110101010000
ASAM Dataset: EV_EPSVWBSAU426 009015
ROD: EV_EPSVWBSAU426_009.rod
VCID: 313F1311E1A33F73EDD-8064
Part No SW: 8W0 907 064 GH HW: 8W0 907 064 DH
Component: BCM2 MLBevo 025 0424
Coding: 017400076FB103616301A0046C00C80200004000804F02582F0400000504823B001F0100030F23
ASAM Dataset: EV_BCM2HellaAU736 016016
ROD: EV_BCM2HellaAU736_016_AU58.rod
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY183062V1R
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000045952201
Rear Light Left 1:
Subsystem 3 - Part No SW: 4KE 945 423 HW: 4KE 945 423
Component: T1 LH ECE HD H10 0403
Serial number: A1W700005LV
Subsystem 4 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 11406418
Dedicated Short Range Communication Aerial:
Subsystem 5 - Part No SW: 4N1 927 753 HW: 4N1 927 753
Component: NFCTGS H13 0050
Serial number: 382905855
Antenna 2 for short-range communication:
Subsystem 6 - Part No SW: 4N0 959 428 A HW: 4N0 959 428 A
Component: NFCMIKO H41 0034
Serial number: 4418000245201012
Rear Light Left 2:
Subsystem 7 - Part No SW: 4KE 945 429 B HW: 4KE 945 429 B
Component: T2 LH ECE HD H12 0403
Serial number: A1WK0001NDH
Rear Light Right 1:
Subsystem 8 - Part No SW: 4KE 945 424 HW: 4KE 945 424
Component: T1 RH ECE HD H10 0403
Serial number: A1WD0000786
Rear Light Right 2:
Subsystem 9 - Part No SW: 4KE 945 430 B HW: 4KE 945 430 B
Component: T2 RH ECE HD H12 0403
Serial number: A1WL0001NDJ
131193 - Virtual Radio Key
B16E9 29 [008] - Signal Implausible
Reset counter: 247
Mileage: 27967 km
Date: 2020.10.29
Time: 17:56:05
Supply voltages-Supply voltage: Terminal 30: 65.535 V
Supply voltages-Supply voltage Terminal 30 - 2: 65.535 V
Supply voltages-Supply voltage Terminal 30 - 3: 65.535 V
general_additional_freeze_frame-production_mode: active
general_additional_freeze_frame-Stall_current_cutoff_level: Not available
general_additional_freeze_frame-Stall_Current_Measuring_Mode: Not available
general_additional_freeze_frame-terminal_control_intern_status: FF FF FF FF FF FF
general_additional_freeze_frame-Transport_Mode: Not available
general_additional_freeze_frame-Vehicle speed: Not available
Part No SW: 4N0 035 223 C HW: 4N0 035 223
Component: MIB2_amp_P_D5 H01 0170
Revision: 00000001 Serial number: AUZ8ZAJ7D002445
Coding: 0115160000AAAA2FAA0000010002
ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001010
ROD: EV_AMPMst16C1Gen2pALPI.rod
VCID: 2411EA45AE519ADB16B-8070
Address 51: Electric Drive (J841) Labels: None
Part No SW: 0EF 907 080 G HW: 0EF 907 080 C
Component: CUFZD683Q0AD2 H02 0010
Revision: -------- Serial number: -00125.10.18000
Coding: 01000000000000000000
Shop #: WSC 61609 003 1048576
ASAM Dataset: EV_DMCMHITACAU516 003007
ROD: EV_DMCM2HITACAU516_003.rod
VCID: 3A2D343D3CD5FC2B5C7-806E
13828096 - Component protection
U1115 00 [047] - No basic setting for SHE key
[CmpntPrtctn_SHEKeyNoCnfg]
Mileage: 27910 km
Date: 2020.10.29
Time: 12:22:27
Part No SW: 4M0 959 592 M HW: 4M0 959 592 J
Component: TSG BFS 007 0387
Serial number: 0000360553005
Coding: 001DDA0143000480A000B000
VCID: 45D757C1452B83D3215-8010
Part No SW: 4K0 035 063 D HW: 4KE 035 063
Component: MU-H-LND-EU 046 2711
Coding: 0115760100000000C3111102C00802302F0001E4037008008E
Subsystem 1 - Part No: V03 959 807 SB
Component: MIB2P_EU_Q220 0450
Subsystem 2 - Part No SW: 4KE 919 605 C HW: 4KE 919 605
Component: DU AU516 High H41 0147
Serial number: INX00116101800130154
Compact Disc Database:
Component: Gracenote2 1009
Volume Control 1:
Subsystem 4 - Part No SW: 4K1 919 616 B HW: 4K1 919 616 A
Component: LSR-D5/C8 H33 0110
Serial number: 00004418000241010013
Display Unit 5 For Multimedia System:
Subsystem 5 - Part No SW: 4KE 919 603 A HW: 4KE 919 603
Component: DU AU516 Bot H41 0147
Serial number: INX00119101800140466
Media socket:
Subsystem 6 - Part No SW: 4N0 035 736 A HW: 4N0 035 736
Component: MediaConnectH 014 0133
Serial number: 051800780905006
6190 - Display Module 1 for Multimedia System
B1297 FC [008] - Haptic Unit Defective
Reset counter: 245
Mileage: 28636 km
Date: 2020.10.31
Time: 12:50:03
Voltage terminal 30: 14.7 V
Part No SW: 4M0 907 383 E HW: 4M0 907 383
Component: Anhaenger H27 0253
Revision: 9C001003 Serial number: 0501911391
Coding: 0110000202000000
ROD: EV_TrailFunctGener2Hella_VW27.rod
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H15 0250
Coding: 0215060103002005C20040
ROD: EV_CamSysRVRVCPANAMLBEv_005_VW53.rod
VCID: 333319191BBF0D639F1-8066
Part No SW: 8W8 959 107 D HW: 8W8 959 107
Component: HDSG-Modul H13 0170
Revision: -------- Serial number: A2-C744-8781-0
Coding: 33B0
VCID: 4ACD64FD6C356CABCC7-801E
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 4KE 907 777 AD HW: 4KE 907 777 A
Component: Fahrwerk-SG H52 2311
Serial number: 1201191193
Coding: 98D86083DA4010
ASAM Dataset: EV_ChassContrContiAU651 003018
ROD: EV_ChassContrContiAU651_003.rod
VCID: 0E45A8ED50DD008BD0F-805A
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004130469760
Coding: 303030
Part No SW: 4K1 035 282 D HW: 4K1 035 282 B
Component: ConBox H09 0232
Serial number: 005CCA11F120292
Coding: 01C0E0FFC040800000
ROD: EV_ConBoxAU651_002.rod
VCID: 2809FE75D2797EBB3A3-807C
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4KL 713 041 A HW: 4KL 713 041
Component: GSM-LL H04 0036
Serial number: 92145RLK00043
ASAM Dataset: EV_GSMKLOAU516 001008
ROD: EV_GSMKLOAU516.rod
VCID: 3C21322536E1C21B4EB-8068
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 4KE 915 233 F HW: 4KE 915 233 B
Component: BMC_MLBCBEV H15 0231
ASAM Dataset: EV_BECM0842071 001004
ROD: EV_BECM0842071_AU58.rod
VCID: 41DF43D15103AFF31DD-8014
Battery Junction Box:
Subsystem 1 - Part No SW: 4KE 915 250 C HW: 4KE 915 250 B
Component: BJB_MLBBEV H12 0369
Cell module: control module 1:
Subsystem 2 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module: control module 2:
Subsystem 3 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module: control module 3:
Subsystem 4 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module: control module 4:
Subsystem 5 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module: control module 5:
Subsystem 6 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module: control module 6:
Subsystem 7 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module: control module 7:
Subsystem 8 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module: control module 8:
Subsystem 9 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module: control module 9:
Subsystem 10 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module: control module 10:
Subsystem 11 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module: control module 11:
Subsystem 12 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module: control module 12:
Subsystem 13 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* None
Part No SW: 4KE 907 107 AB HW: 4N0 907 107 G
Component: zFAS Var B H09 0291
Coding: 0421840000000000000C060000D4462E189E57000000000000000000000000000019000000000000000000000000000000000000000000000000400000000000000078D80000009000800080000000000080400000A0
ASAM Dataset: EV_ZFASAU516 001003
ROD: EV_ZFASAU516_001.rod
VCID: 7F5B0529677719032B9-802A
221284 - Front Camera for Driver Assist Systems
C12B3 FD [008] - View Temporarily Restricted
[temp view limitations]
Reset counter: 245
Mileage: 28722 km
Date: 2020.11.02
Time: 08:11:07
EyeQ temperatures-CPU: -40 °C
EyeQ temperatures-VPM: 30 °C
Vehicle speed: 117.90 km/h
Front camera: blinding detection-Status: not active
Front camera: blinding detection-Blinding detected by light assistance assessment module: No
Front camera: blinding detection-Blinding detected by road sign recognition assessment module: No
Front camera: blinding detection-Blinding detected by pedestrian recognition assessment module: No
Front camera: blinding detection-Blinding detected by lane recognition assessment module: No
Front camera: blinding detection-Blinding detected by object recognition assessment module: No
Front camera: blinding detection-Blinding detected by distance regulation assessment module: Yes
Front camera: blinding detection-Blinding detected by road profile estimation assessment module: No
Front camera: blinding detection-Blinding detected by free space recognition assessment module: No
Front camera: blinding detection-Request for window defogger for front sensor system due to blinding: No
Front camera: blinding detection-Glare detected: No
Front camera: blinding detection-free view detected once: Yes
81922 - Matrix Headlamps
C1299 F0 [008] - Fog Mode Active
Reset counter: 240
Mileage: 28143 km
Date: 2020.10.30
Time: 07:17:54
4107 - Databus
[reversibler_Fehler_im_ACC_System]
Fault Frequency: 23
Reset counter: 247
Mileage: 27910 km
Date: 2020.10.29
Time: 13:59:15
Part No SW: 4M0 959 595 M HW: 4M0 959 595 J
Component: TSG HFS 006 0387
Serial number: 0000360561597
Coding: 000DD80100000480A000B000
ROD: EV_DCU2RearDriveMAXHCONT_AU58.rod
VCID: 48C95EF572399EBBDA3-801C
Component: TSG HBFS 006 0387
Serial number: 0000360561596
ROD: EV_DCU2RearPasseMAXHCONT_AU58.rod
Address C5: Therm. mgt. (J1024) Labels:* None
Part No SW: 4KE 965 429 C HW: 4KE 965 429
Component: TME-Max H08 0312
Serial number: 0017640
Coding: 00
ASAM Dataset: EV_ThermContrVISAU49X 002036
ROD: EV_ThermContrVISAU49X_AU58.rod
Subsystem 1 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G395 pT-Sens1 H11 0010
Subsystem 2 - Part No SW: 3Q0 963 231 E HW: 3Q0 963 231 E
Component: J848 HV-PTC 200 0204
Serial number: -00105.0V.3A20370116
Air Conditioning Compressor Sub:
Subsystem 3 - Part No SW: 4G0 816 797 B HW: 4G0 816 797 B
Component: J842 EKK es33 H03 0004
Serial number: 00000000018092100748
Geber für Kältemitteldruck/Kältemitteltemperatur 2:
Subsystem 4 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G826 pT-Sens2 H11 0010
Coolant heater:
Subsystem 5 - Part No SW: 3Q0 963 231 E HW: 3Q0 963 231 E
Serial number: -00105.1V.2C20370080
Refrigerant Expansion Valve 2:
Subsystem 6 - Part No SW: 4M0 816 682 E HW: 4M0 816 682 E
Component: N637 EV2_KaMi H12 0102
Serial number: 00000000000150542289
Refrigerant Shut Off Valve 2:
Subsystem 7 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N640 AV2_KaMi H12 0102
Serial number: 00000000000130515295
Refrigerant Shut Off Valve 3:
Subsystem 8 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N641 AV3_KaMi H12 0102
Serial number: 00000000000130515303
Refrigerant Shut Off Valve 4:
Subsystem 9 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N642 AV4_KaMi H12 0102
Serial number: 00000000000130515291
Refrigerant Shut Off Valve 5:
Subsystem 10 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N643 AV5_KaMi H12 0102
Serial number: 00000000000130515301
Radiator shutter:
Subsystem 11 - Part No SW: 95B 965 501 S HW: 95B 965 501 S
Component: V544KJS1 H12 0109
Serial number: 20181209060404054408
Radiator Shutter 2:
Subsystem 12 - Part No SW: 95B 965 501 S HW: 95B 965 501 S
Component: V550KJS2 H12 0109
Serial number: 20181114020103053861
Coolant valve 1:
Subsystem 13 - Part No SW: 4KE 963 375 K HW: 4KE 963 375 K
Component: N632 V1_KUEMI 010 0103
Serial number: 00000000000000039605
Coolant valve 2:
Subsystem 14 - Part No SW: 4KE 963 375 J HW: 4KE 963 375 J
Component: N633 V2_KUEMI 010 0103
Serial number: 00000000000000019454
Coolant valve 3:
Subsystem 15 - Part No SW: 4KE 963 375 H HW: 4KE 963 375 H
Component: N634 V3_KUEMI 010 0103
Serial number: 00000000000000031023
Coolant valve 4:
Subsystem 16 - Part No SW: 4KE 963 375 N HW: 4KE 963 375 N
Component: N635 V4_KUEMI 010 0103
Serial number: 00000000000000026154
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 684 J HW: 5QE 915 684 J
Component: OBC KOSTAL H24 0023
Serial number: ---------------
Coding: 2B48844542080E000000
ASAM Dataset: EV_OBC3Phase1KLOMLBev14B 002001
ROD: EV_OBC2PhaseKLOMLBev14P.rod
VCID: 56F5808DA88D384B58F-8002
2097938 - Charging Socket B; Charging Plug Lock
P33E9 00 [040] - Mechanical Malfunction
Reset counter: 32
Mileage: 28414 km
Date: 2020.10.30
Time: 11:35:00
13705549 - Databus
U1121 00 [040] - Missing Message
[DCDC_01_Timeout]
Reset counter: 38
Mileage: 29101 km
Date: 2020.11.02
Time: 14:05:09
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 005 0002
Coding: 628040051602
VCID: 75B7E701554B5353715-8020
Address CD: Laser Scanner (J1122) Labels: None
Part No SW: 4K8 907 660 B HW: 4N0 907 660
Component: LASER_SCANNER H36 0202
ASAM Dataset: EV_LaserScannAU651 013013
ROD: EV_LaserScannAU651_013.rod
VCID: 3537270115CB1353B15-8060
11567105 - Cleaning Failed
B17FC 00 [008] - -
Reset counter: 247
Mileage: 28406 km
Date: 2020.10.30
Time: 11:26:25
Control Module temperature-Host: external temperature: 19 °C
Control Module temperature-Zynq: internal temperature: 34 °C
Control Module temperature-Host: internal temperature: 18 °C
Control Module temperature-Zynq: external temperature: 16 °C
Voltage terminal 15: 14.663 V
Vehicle speed: 64.69 km/h
Request for cleaning of laser scanner: not active
Washer fluid level: OK
Heating and cleaning management-Visibility: 0 %
Heating and cleaning management-Degree of contamination: 64 %
Heating and cleaning management-Heating status: 02
Heating and cleaning management-Cleaning status: 05
Outside air temperature: 4 °C
Counter_lense_cleanings-Cleaning_Sequence: 0
Counter_lense_cleanings-lense_clean_count_total: 256
Counter_lense_cleanings-lense_clean_count_trip: 2
Address CE: Drive Motor 2 (J944) Labels: None
Part No SW: 0EF 907 180 J HW: 0EF 907 180 C
Component: CUBZE683Q0AD2 H02 0010
Revision: -------- Serial number: -00106.11.18000
Shop #: WSC 12242 004 1048576
ASAM Dataset: EV_DMCM2HITACAU516 003007
VCID: 3E25382D20FDD00B60F-806A
Mileage: 27910 km
Date: 2020.10.29
Time: 12:22:27
Address D6: Light Ctrl Left 2 (A31) Labels: None
Part No SW: 4K0 941 591 BC HW: 4K0 941 591 B
Component: LMS_MLBevo H11 0031
ROD: EV_LMSLeftHELLAAU58X_AU27.rod
VCID: 71BFD31121237F73ADD-8024
Address D7: Light Ctrl Right 2 (A27) Labels: None
ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DE: Charger 1 for mobile dev (J1146) Labels:* None
Part No SW: 4N0 035 773 A HW: 4N0 035 773 A
Component: WLC Front NFC H11 0061
Coding: 808000
VCID: 2C010265C681529BDEB-8078
Address 8104: DC/DC Converter HV (A19) Labels: None
Part No SW: 4KE 907 171 B HW: 4KE 907 171 B
Component: DCDC Wandler H10 0400
ASAM Dataset: EV_DCDCHVTDKAU516 001004
ROD: EV_DCDCHVTDKAU516.rod
VCID: 3FDB452927F7D9036B9-806A
Address 8111: Rearview Mirror Right (J1030) Labels:* None
Part No SW: 4KE 907 181 B HW: 4KE 907 181 A
Component: VAS H31 0027
Coding: 00010807
ASAM Dataset: EV_RearVLeftFicosAU516 001003
ROD: EV_RearVLeftFicosAU516.rod
VCID: 40D946D55A09A6FB123-8014
Address 8112: Rearview Mirror Left (J1031) Labels:* None
Part No SW: 4KE 907 182 B HW: 4KE 907 182 A
Coding: 00010807
ASAM Dataset: EV_RearVRightFicosAU516 001003
ROD: EV_RearVRightFicosAU516.rod
End----------(Elapsed Time: 03:08, VBatt start/end: 13.2V/13.2V)-----------
Tuesday,03,November,2020,12:55:42:42591
VIN: WAUZZZGE1KB005103 License Plate: EV52014
Mileage: 29303km-18208mi Repair Order:
VIN: WAUZZZGE1KB005103 Mileage: 29303km-18208miles
CD-Laser Scanner -- Status: OK 0000
Coding: 02005E
Coding: 0D0104
Coding: 03F002
Coding: 03F002
Rear Light Left 1:
Rear Light Left 2:
Rear Light Right 1:
Rear Light Right 2:
Mileage: 29303 km
Date: 2020.11.03
Time: 12:51:40
Volume Control 1:
Media socket:
Coding: 33B0
Coding: 303030
H06 0107
H06 0107
H06 0107
H06 0107
H06 0107
H06 0107
H06 0107
H06 0107
H06 0107
H06 0107
H06 0107
H06 0107
Coding: 00
Coolant heater:
Radiator shutter:
Radiator Shutter 2:
Coolant valve 1:
Coolant valve 2:
Coolant valve 3:
Coolant valve 4:
Mileage: 29303 km
Date: 2020.11.03
Time: 12:51:40
Coding: 808000
Coding: 00010807
Coding: 00010807
End----------(Elapsed Time: 03:02, VBatt start/end: 13.2V/13.2V)-----------
UWSCSI
Norway
C?ID=134408
So, I think I found a solution...
Module 46, long coding Byte 24 and bit 0.
If set to 0, the motor and ignition stays on. When door is opened, gear is set to park positon.
UWSCSI
Norway
C?ID=134408
Found that disabling bit 0 only left the car on for approx. 30 sec.
So i also disabled bit 1 and now it really stays on 😁
