Developer mode Mib2
szymek
C?ID=414515
Cannot activate Dev menu of Audi A6 facelift
After 5F - Security tried 20103 security codes let me enter in adaptation menu. After that when try to change Developer mode in active I receive an error: “Request out of range:” I want to activate Green Menu.
Does anyone know how to do this ?
rhinopower
C?ID=58979
VCDS is not up to the job
Use VCP, select engineering mode, then you can do it
szymek
C?ID=414515
Thanks for answer :)
I spent 500£ on VCDS and a much cheaper interface like VCP activate Dev menu:facepalm:
siLc
Tallinn, Estonia
C?ID=330192
Each diagnostic tool has its advantages and disadvantages...
Bruce
Near Philadelphia, PA, USA
It is unclear how VCP accomplishes such feats without violating VAG's Intellectual Property standards. It is also unclear why VAG, who is normally very aggressive against those who do things "outside the rules", has not done anything to stop VCP.
VCDS has the ability to do that which is permitted by diagnostic protocol. If it goes beyond diagnostic protocols, then do not expect VCDS to have the capability unless and until VAG grants permission to modify their code without threat of punitive actions.
szymek
C?ID=414515
I don't know either, but it's weird :cry:
NEtech
Denmark
C?ID=56995
Copy this file to:
C:\Ross-Tech\VCDS\Labels\User
And try Security Access and use the shown.
szymek
C?ID=414515
AINils
Germany (AIB)
It`s also possible with VCDS, but in Facelift A6 this menu won`t give any benefits
