Q7 4M Coolant fan control circuit fault, only start with jump starter
zore
Hi
Owned an Audi Q7 for 3 years now. Went weekend shopping and after loading the car with goodies the car did not start. A drive system error message came on. The car would make a click sound and then turn off. Luckily I had jump pack in the boot and was able to jump start the car and it switched on. I thought maybe the battery is going as its winter and they tend to pack up in the winter. Once home I checked the battery voltage it was 12.4v. the car still would not start. The voltage would drop to 12v when starting and then back up to 12.4v with no load. I replaced the battery and still the same issue. I performed a diagnostic and it contains the errors below. basically the coolant fan and glow plug control module are getting low voltage yet the battery voltage is 12.8v with the new battery and 12.3ish when on load. ive checked the fuse and its fine. I looked at the connector for the coolant fan and the voltage there is 8.5v.. the connector has no water damage. ive looked at the earth wire for the coolant fan and that is clean with no rust.
the only thing I have not done is look at the relay. I cant locate it in any diagram. So basically what is causing the low voltage? any help would be much appreciated. Thanks
Monday,26,October,2020,19:10:36:64250
VCDS Version: 20.4.2.0 (x64)
VIN: WAUZZZ4M7GD   License Plate: AA0001
Chassis Type  4M-AU73 (4M1)
Scan: 01 02 03 06 08 09 15 16 17 19 28 29 2B 36 39 42 44 46 47 50
          52 5F 6C 6D 81 82 A5 AC BB BC D6 D7
VIN: WAUZZZ4M7GD
29-Left Light -- Status: INTERFACE NOT COMPATIBLE
39-Right Light -- Status: INTERFACE NOT COMPATIBLE
50-Seat Adj. 3rd row -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: INTERFACE NOT COMPATIBLE
D7-Light Ctrl Right 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CRTC)       Labels: Redir Fail!
   Part No SW: 4M0 907 401     HW: 059 907 309 B
   Component: 3.0TDI EDC17  H45 0004
   Revision: 91H45---
   Coding: 2A2A40320326050334080000000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0114M0907401 001008
   ROD: EV_ECM30TDI0114M0907401.rod
   VCID: 66C9AC74999D37B689-8032
4527 - Coolant Fan Control Circuit 1
          P0480 00 [039] - Electrical Malfunction
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:02
                    Engine speed: 0.00 /min
                    Coolant temperature: 45 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 11.600 V
                    Air mass: specified value: 434.3 mg/stroke
                    Coolant temperature at radiator outlet: actual value: 42.0 °C
                    Heat delivery temperature in cooling system: -273.1 °C
                    Outside air temperature: 10.5 °C
                    Coolant fan 2: activation: 0.00 %
                    Coolant fan 1: activation: 10.54 %
                    Fuel temperature: 36.1 °C
5456 - Starter Will Not Turn
          P3054 00 [167] - Jammed or Electrical Malfunction
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:07
                    Voltage terminal 30: 11.080 V
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 17
                    Engine status: COENG_READY
14615 - Control Module for Glow Plugs
          P052F 00 [038] - Implausible Voltage
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:07
                    Voltage terminal 30: 11.100 V
                    Glow-control unit: activation voltage: 0 mV
                    Glow_period_control_unit_ground_offset_voltage: 0 mV
                    Glow-control unit: calculated glow voltage: 0 mV
                    Glow_period_control_unit_energy_integrator_calculated_value: 0.0 V²s
                    Glow cycles upon reaching temperature threshold-Bits 0-7: 0
                    Glow cycles upon reaching temperature threshold-Bits 0-7: 1
                    Glow status-Bits 0-7: 0
                    Co EOM st Op Mode Short-Bits 0-7: 8
   Part No SW: 4M0 927 158 J    HW: 0D5 927 156 H
   Component: 0D5 30TDIRdW  H03 1007
   Revision: --H03---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002009
   ROD: EV_TCMALX52011_AU73.rod
   VCID: 3B7F2D00B29F5A5E06-806E
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4M0 907 379 K    HW: 4M0 907 379 K
   Component: ESP9 Premium  H08 0521
   Coding: 249830B230A20A9F96A3589400825292E6A6D2240C0C50691A004A4967654B
   Shop #: WSC 22162 002 1048576
   ASAM Dataset: EV_ESP9BOSCHAU736 011006
   ROD: EV_ESP9BOSCHAU736_AU73.rod
   VCID: 3F875910A687467E2A-806A
8 Faults Found:
420352 - TPMS Warning; Front Left Tire
          C1054 00 [047] - Pressure too Low
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:02
                    74 00 80 00 C2 24 00 00 F0 80
416768 - TPMS Warning; Front Right Tire
          C1056 00 [047] - Pressure too Low
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:02
420096 - TPMS Warning; Rear Left Tire
          C1058 00 [047] - Pressure too Low
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:02
417024 - TPMS Warning; Rear Right Tire
          C105A 00 [047] - Pressure too Low
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:02
415488 - TPMS Warning; Front Left Tire
          C1055 00 [047] - Flat
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:02
419328 - TPMS Warning; Front Right Tire
          C1057 00 [047] - Flat
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:02
419584 - TPMS Warning; Rear Left Tire
          C1059 00 [047] - Flat
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:02
419840 - TPMS Warning; Rear Right Tire
          C105B 00 [047] - Flat
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:02
   Part No SW: 4M0 959 760 E    HW: 4M0 959 760 E
   Component: MEM-BFS       008 0014
   Serial number: 00000151565537
   Coding: 002010000000B0410000210101010000110000313100000000000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   VCID: 3A712804BDA563561D-806E
   Part No SW: 4M0 820 043 K    HW: 4M0 820 043 K
   Component: Klima Zone 4  H52 0060
   Coding: 6618003C5544451102220180800000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 2D5B13587CEBC4EE88-8078
   Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000447173
   Component: AQ_Hum_Sensor  H01 0003
   Serial number: C68885B7000000000001
262658 - High Pressure Sensor
          B10AE 31 [009] - No Signal
                    Reset counter: 244
                    Mileage: 109924 km
                    Date: 2020.09.23
                    Time: 17:25:25
                    Outside air temperature: 17.50 °C
                    Engine speed: 0 /min
                    Compressor current: actual value: 0.00 A
                    Temperature after evaporator: 22.00 °C
   Part No SW: 8W0 907 063 G    HW: 8W0 907 063 G
   Component: BCM1 MLBevo   H12 0215
   Coding: 07501943E16900CD010D87155B2F00F911033100900000000000000020001A810A450122025605
   ASAM Dataset: EV_BCM1BOSCHAU736 014003
   ROD: EV_BCM1BOSCHAU736_014.rod
   Subsystem 1 - Part No SW: 4M2 955 119 A    HW: 4H1 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 141216  042 0792
   Serial number:         150115093452
   Coding: 1BC7F7
   Serial number: 20382874
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 P    HW: 4M0 941 531 P
   Component: E1 - LDS  H05 0007
   Serial number: 03 06 2015  00029413
   Subsystem 4 - Part No SW: 4M0 857 511 A    HW: 4M0 857 511 A
   Component: Y7_Innenspieg  H08 0002
   Serial number: GX1CE111061511520276
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4M0 947 135 BE    HW: 4M0 947 135
   Component: J528-Dachele  H13 0081
   Serial number: Q00018609
   Subsystem 6 - Part No SW: 4M0 925 301 A    HW: 4M0 925 301 A
   Component: SL-Q7NF/AU736  H09 0006
   Serial number: 00000000000000003928
   Part No SW: 4M0 959 655     HW: 4M0 959 655
   Component: Airbag10.44   H50 0081
   Serial number: 003L1000A6XV
   Coding: AACCF0D80C80000058F650F3C08C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   VCID: 78F5F20CC329B1462B-802C
   Subsystem 1 - Part No SW: -----------    HW: 442 062 210 17
   Serial number: 3577Y00B728A7A7394FK
   Subsystem 2 - Part No SW: -----------    HW: 442 061 906 15
   Serial number: 3587Y00AB193B8525542
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 406 15
   Serial number: 3517700BB1AC53B4823I
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 406 15
   Serial number: 3527700B91AC53B2407D
   Subsystem 5 - Part No SW: -----------    HW: 442 0C2 906 15
   Serial number: 3557500C91B50DF5931N
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 442 0C2 906 15
   Serial number: 3567500C91B50DF1F0F.
   Pedestrian Protection Center:
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 906 15
   Serial number: 2307500C71B50DF27408
   Subsystem 8 - Part No SW: -----------    HW: 442 422 906 15
   Component: PedPSensor_D2  21E 0887
   Serial number: I0M8U00A5198985372DT
   Subsystem 9 - Part No SW: -----------    HW: 442 422 906 15
   Component: PedPSensor_P2  21E 0887
   Serial number: I0N8U00AF1989853B0A$
   Central Sensor XY:
   Subsystem 10 - Part No SW: -----------    HW: 410 202 505 15
   Component: CentrSensorXY  1C8 0108
   Serial number: I0O7800A9165692272D0
   Part No SW: 4M0 907 129 HD    HW: 4M0 907 129 HD
   Component: Lenks.Modul   H11 0008
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 79F3F708F823A84E54-802C
Address 17: Instruments (J285)       Labels: Redir Fail!
   Part No SW: 4M0 920 790     HW: 4M0 920 790
   Component: FBenRDW       H12 0280
   Coding: 242401D0288006000123E9601000000000000000
   ASAM Dataset: EV_DashBoardAU736 001020
   ROD: N/A
   VCID: 6CDDDE5C87710DE6DF-8038
Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
No ASAM data for: "EV_DashBoardAU736" (AU73)
   Part No SW: 4M1 907 468 A    HW: 4M1 907 468 A
   Component: Gateway       H13 4079
   Revision: 3B010050    Serial number: 5043B002115519
   Coding: 0301000100008F407F0700000059003248120007008000000100000000000000
   Shop #: WSC 55552 002 1048576
   ASAM Dataset: EV_GatewCONTIAU736 002040
   ROD: EV_GatewCONTIAU736_002_AU73.rod
   VCID: 356B3B3894BB8C2EF0-8060
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0002
   Serial number: 20150528162726 RD088
   Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9041
   Serial number: 7079276403
197149 - Generator
          U1052 00 [009] - No Communication
                    Reset counter: 1
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 18:40:59
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 4M0 919 158 C    HW: 4M0 919 158 C
   Component: Klima Zone 2  H52 0060
   Coding: 000000000000040100820080000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
   ROD: EV_AirCondiFondBHTCAU736.rod
Address 29: Left Light
Interface not compatible.
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 15000069779012
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 3261002465D59B16D5-8066
   Component: MEM-FS        008 0014
   Serial number: 00000151545539
   ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
Address 39: Right Light
   Part No SW: 4M0 959 593 H    HW: 4M0 959 593 F
   Component: TSG FS        005 0125
   Serial number: 0000288024178
   Coding: 001F9A005001000000003082
   VCID: 41835FE8D073308E5C-8014
   Part No SW: 4M0 909 144 G    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H17 0004
   Serial number: 0000986068
   Coding: 90000001000100
   ASAM Dataset: EV_EPSVWBSAU736 008020
   ROD: EV_EPSVWBSAU736_008.rod
   VCID: 336F05209ACF921EDE-8066
Address 46: Central Conv.
   Part No SW: 4M0 035 223 A    HW: 4M0 035 223
   Component: MIB2_amp_PD   H02 0420
   Serial number: 00000000005816
   Coding: 01350608008AF53AAF0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
   VCID: 2143FF683033108E3C-8074
Address 50: Seat Adj. 3rd row
   Part No SW: 4M0 959 592 D    HW: 4M0 959 592 C
   Component: TSG BFS       005 0036
   Serial number: 0000155441782
   Coding: 005F9A005C01000000003080
   VCID: 3C7D2E1CB7915D660F-8068
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M0 035 035 B    HW: 4M0 035 035
   Component: MU-P-LND-EU   042 0358
   Serial number: A270G0F7507810
   Coding: 013706010000000013111102000A00332F001BE701700100DE
   VCID: 234FF5602A2F029E2E-8076
   Subsystem 1 - Part No SW: V03 959 802 CA    HW: -----------
   Component: ECE 2015  --- 0118
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9FJ400DY5
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4M0 919 615 D    HW: 4M0 919 615 D
   Component: ControlUnit_P  H14 0165
   Serial number: 20061500000000000032
   Compact Disc Database:
   Component: Gracenote2  --- 1010
5632 - Eject button
          B13B0 07 [008] - Mechanical Failure
                    Reset counter: 32
                    Mileage: 109939 km
                    Date: 2020.09.25
                    Time: 18:44:43
                    Voltage terminal 30: 15.0 V
3086 - Antenna for Telephone Mount
          B1564 01 [008] - Electrical Failure
                    Mileage: 110445 km
                    Voltage terminal 30: 11.9 V
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): selected
                    Status of telephone-Handset holder (cradle): connected
6696 - Instrument Cluster Control Module on Optical Bus
          U10C0 00 [008] - No Communication
                    Reset counter: 37
                    Mileage: 110338 km
                    Date: 2020.09.30
                    Time: 22:07:55
                    Voltage terminal 30: 14.7 V
   Part No SW: 4M0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0130
   Coding: 0237060102002001000040
   ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 004008
   ROD: EV_CamSysRVRVCPANAMLBEv_004.rod
   VCID: 72E1C024A555DB1615-8026
   Part No SW: 4M0 959 107     HW: 4M0 959 107
   Component: HDSG-Modul    H12 0143
   Revision: --------    Serial number: 30093564700000
   Coding: 0010
   ASAM Dataset: EV_DeckLidCONTIAU736 001010
   VCID: 70E5CA2CAB59E906E3-8024
   Part No SW: 4M2 713 041 D    HW: 4M2 713 041 D
   Component: GSM-LL        H07 0066
   Revision: 0L0D5012    Serial number: 20150615000294
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 2757E1705E17EEBE72-8072
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4M0 919 617 A    HW: 4M0 919 617 A
   Component: HeadUpDisplay H25 1507
   Coding: 2A00C0
   ASAM Dataset: EV_HudNSEIKAU736 001012
   ROD: EV_HudNSEIKAU736_AU73.rod
   Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
   Component: BVS           H13 0042
   Coding: 0407030600000401024023A0A50000B400F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
   VCID: 2F67095076E7B6FEBA-807A
1123600 - predictive route data
          B1630 02 [008] - Signal Failure
                    Reset counter: 38
                    Mileage: 110300 km
                    Date: 2020.09.28
                    Time: 18:36:42
                    Control Module temperature: 24 °C
                    Voltage terminal 15: 14.50 V
1123601 - predictive route data
                    Fault Frequency: 14
                    Reset counter: 41
                    Mileage: 110293 km
                    Date: 2020.09.28
                    Time: 16:19:56
                    Voltage terminal 15: 14.40 V
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355     HW: 4M0 907 355
   Component: SCR-Stg-G3H10 0003
   ASAM Dataset: EV_RDCMINERGAU736 005009
   ROD: EV_RDCMINERGAU736_AU49.rod
   VCID: 6ED9D454B16DFFF6F1-803A
   Part No SW: 4M0 959 595 D    HW: 4M0 959 595 C
   Component: TSG HFS       005 0036
   Serial number: 0000155453763
   Coding: 004F98000001000000003080
   Component: TSG HBFS      005 0036
   Serial number: 0000155456515
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
Address D6: Light Ctrl Left 2
Address D7: Light Ctrl Right 2
End-------------------------(Elapsed Time: 06:08)--------------------------
AIB Wolfgang
Hello
Many different faults with voltage masseges, Coolant Fan Control Circuit 1 > Voltage terminal 30: 11.600 V
Starter Will Not Turn > Voltage terminal 30: 11.600 V
Address 19: CAN Gateway (J533) > Generator U1052 00 [009] - No Communication and this massege:
[New feature! Extended UDS fault detail is only supported by current gen. interfaces].
I think it's time for this new Interface to read extended UDS fault details.
Error will be eliminated by a secured power supply:cool:
Teefyg1
England
Hi
VIN: WAUZZZ4M7GD
   Revision: 91H45---
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:02
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:07
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:07
   Revision: --H03---
   Coding: 100000
8 Faults Found:
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:02
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:02
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:02
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:02
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:02
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:02
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:02
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 19:04:02
                    Reset counter: 244
                    Mileage: 109924 km
                    Date: 2020.09.23
                    Time: 17:25:25
   Coding: 1BC7F7
   Coding: 02006E
   Coding: 230000
   Central Sensor XY:
   ROD: N/A
197149 - Generator
                    Reset counter: 1
                    Mileage: 110975 km
                    Date: 2020.10.26
                    Time: 18:40:59
5632 - Eject button
                    Reset counter: 32
                    Mileage: 109939 km
                    Date: 2020.09.25
                    Time: 18:44:43
                    Mileage: 110445 km
                    Reset counter: 37
                    Mileage: 110338 km
                    Date: 2020.09.30
                    Time: 22:07:55
   Coding: 0010
   Coding: 2A00C0
                    Reset counter: 38
                    Mileage: 110300 km
                    Date: 2020.09.28
                    Time: 18:36:42
                    Fault Frequency: 14
                    Reset counter: 41
                    Mileage: 110293 km
                    Date: 2020.09.28
                    Time: 16:19:56
Hey
Did you ever fix this issue?
