Camshaft Position Sensor, EPC Code, Many Non Communication Codes
djb76
Washington, USA
C?ID=419991
Hi,
My name's Dan.
I have a 2009 Jetta with 2.5 motor.
Stock vehicle without known modifications.
The battery died a few weeks ago. It had a bad cell and I replaced it.
I then drove about 10 miles without issue, parked for a few hours and on the way home had a flashing EPC light.
The car then refused to start.
I can now start it if I push the gas pedal down, but it will not rev over 3000 rpm.
This is the scan:
Friday,30,October,2020,15:08:01:27635
VIN: 3VWTZ71K29M267949 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 4F 52 56 62 65 72
VIN: 3VWTZ71K29M267949 Mileage: 338600km-210396miles
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 N HW: 07K 906 055 M
Component: 2,5l R5/4V G 9971
Revision: G6H01--- Serial number: VWX7Z0H624T0EF
Coding: 0000071
Shop #: WSC 43487 001 1048576
VCID: 392F2931355F2DF355D-806C
7 Faults Found:
001575 - Fuel Pump Relay Control Circuit
P0627 - 000 - Open Circuit - Intermittent
Mileage: 338607 km
Time: 21:00:10
Temperature: 8.0°C
Temperature: 7.0°C
Absolute Pres.: 960.0 mbar
Voltage: 12.192 V
049682 - Steering Column Control Module
U0212 - 000 - No Communications - Intermittent
Mileage: 338607 km
Time: 21:39:49
Temperature: 9.0°C
Temperature: 8.0°C
Voltage: 11.938 V
049508 - No Communications with HVAC Control Module (J301)
U0164 - 000 - - Intermittent
Mileage: 338607 km
Time: 21:39:49
Temperature: 9.0°C
Temperature: 8.0°C
Voltage: 11.938 V
049478 - No Communication with Diagnostic Gateway
U0146 - 000 - - Intermittent
Mileage: 338607 km
Time: 21:39:49
Temperature: 9.0°C
Temperature: 8.0°C
Voltage: 11.938 V
U0155 - 000 - - Intermittent
Mileage: 338607 km
Time: 21:39:49
Temperature: 9.0°C
Temperature: 8.0°C
Voltage: 11.938 V
000801 - Engine Speed Sensor (G28)
P0321 - 000 - Implausible Signal - Intermittent
Mileage: 338607 km
Time: 05:57:36
Temperature: 12.0°C
Temperature: 12.0°C
Voltage: 11.811 V
000835 - Camshaft Position Sensor (G40)
P0343 - 000 - Signal too High - MIL ON
Fault Status: 11100000
Mileage: 338607 km
Time: 01:59:08
RPM: 271 /min
Load: 75.3 %
Temperature: 15.0°C
Temperature: 15.0°C
Absolute Pres.: 970.0 mbar
Voltage: 10.795 V
Readiness: 0110 0101
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 113B400D49280001881402E8922200413000
Shop #: WSC 03176 002 1048576
VCID: 7EA5FA2D60F1CACB20F-802A
Part No SW: 1K0 820 047 HS HW: 1K0 820 047 HS
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 7CA1F0257AEDD8DB0EB-8028
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000001015577
Coding: 148D8F2340041500070000001C000000000873075C000120000000000000
Shop #: WSC 00066 000 00000
VCID: 323D1E1DE829DEAB947-8066
Component: Wischer 080808 021 0501
Coding: 00038805
Shop #: WSC 00066
02399 - Control Circuit for Terminal 30 for Interior Illumination
Fault Status: 00101001
Reset counter: 136
Mileage: 338609 km
Voltage: 11.55 V
Reset counter: 136
Mileage: 338609 km
Voltage: 11.55 V
01800 - Light Switch (E1)
Reset counter: 100
Mileage: 338609 km
Voltage: 11.55 V
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0374271
Coding: 0000100
VCID: 33331B191733D7A39F1-8066
00003 - Control Module
Fault Status: 00101110
Reset counter: 224
Mileage: 222085 km
Time: 05:06:40
Reset counter: 96
Mileage: 338609 km
Time: 17:44:19
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 78 AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M06A0Y6
Coding: 0014136
VCID: 6C81C0650A8D485B9EB-8038
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME2B331A4CH
Subsystem 3 - Serial number: 6342MSME3B3404243
Subsystem 4 - Serial number: 6351HSME16613431Z
Subsystem 5 - Serial number: 6361HSME16721E5FJ
Subsystem 6 - Serial number: 63727SME173A4101U
Subsystem 7 - Serial number: 63827SME173C2063
Part No SW: 1K0 953 549 CA HW: 1K0 953 549 CA
Component: J0527 051 0101
Coding: 0000022
VCID: 73B3DB1957B397A35F1-8026
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
Part No SW: 1K0 920 954 S HW: 1K0 920 954 S
Component: KOMBIINSTRUMENT 3HL 1222
Revision: V0003000 Serial number: VWX7Z0H624T0EF
Coding: 0007203
VCID: 3C2130253A6D18DB4EB-8068
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 R HW: 1K0 907 951
Component: J533 Gateway H06 0062
Revision: H06 01 Serial number: 011107F2000962
Coding: E9807F070003032002
VCID: 3635220D0441C28BB8F-8062
Component: IMMO 3HL 1222
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000034888709
Coding: 0001205
VCID: 6FBBD7693B9BB343BB9-803A
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A0D067DC0F9966B2C7-807E
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 139007885283281B0904058FB0880F0488DCA0
VCID: 045188C5021DA01B76B-8050
Reset counter: 136
Mileage: 338609 km
Time: 23:17:22
Reset counter: 136
Mileage: 338609 km
Time: 23:17:22
Address 4F: Centr. Electr. II (J533) Labels:. 1K0-907-532.clb
Part No SW: 1K0 907 532 HW: 1K0 907 951
Coding: 050B0500
VCID: 6695B24D1861720BC8F-8032
Subsystem 1 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB10 H01 0180
Subsystem 2 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J394EE16SKB10 H01 0180
01512 - Control Module for Sliding Roof
Fault Status: 01100101
Reset counter: 96
Mileage: 338609 km
Time: 17:44:08
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 00000067888804
Coding: 0001204
VCID: 70B9D41526A5ACBBA23-8024
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio ZSW 019 0035
Revision: 00019000 Serial number: VWZ5Z7H6079650
Coding: 0040401
VCID: 290FF971C5FF9D7325D-807C
00856 - Radio Antenna
Fault Status: 01111011
Reset counter: 96
Mileage: 338609 km
Time: 00:08:07
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003346281
Coding: 0001168
VCID: 76B5E20D44C1828B78F-8022
Component: RDK 0450
Coding: 0100101
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003339721
Coding: 0001168
VCID: 77ABEF0943CBFB83639-8022
End----(Elapsed Time: 01:30, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
I've checked relevant fuses and have cleaned up some ground connections but get the same faults.
I have ordered the Cam Position Sensor (G40) but am concerned related to the wide variety of intermittent non-communication codes.
Any suggestion would be appreciated regarding points of further investigation.
NostraJackAss
0x16 screaming a possible bad ignition switch + mini harness!
It would be wise to load test current tracks to G28 & G40 and anything shared in observation of WD.
I have often seen the wiring harness fail, less likely a bad G40, however, have seen a handful G28 sensors fail or reluctor float for G28.
Base timing for chain should be checked mechanically.
