Battery code confusion help please
den9112
C?ID=362794
-Monday,19,October,2020,12:07:36:04136-
VIN: TRUZZZ8P1B1004211   License Plate: V20OWL
Mileage: 174860km-108652mi   Repair Order:
Hi, i am about to replace my battery and i have checked the current code to the current battery via vcds and all match up..I know that there is a BEM code a part No code and a serial number ..I have watched the procedure for putting the code in however when i check my code it as Amps first 3 digit  068 ,then vender JCB 3 digit , then the 10 digit serial number  no part number in it at all..When i check the pop up box  information on vcds it does give me this format..Would this be correct in leaving out the part number ..
Chassis Type: 8P-AU35 (8P0)
Scan: 01 03 08 09 10 15 16 17 19 25 26 42 44 46 52 56 61 62 72 77
VIN: TRUZZZ8P1B1004211   Mileage: 174860km-108652miles
   Part No SW: 03L 906 023 M    HW: 03L 906 023 L
   Component: 1,6l R4 CR td H23 9973
   Revision: --H23---    Serial number: AUX7Z0J8FN70SN
   Coding: 00114034030501080000
   Shop #: WSC 01236 785 00200
   ASAM Dataset: EV_ECM16TDI02103L906023M 003014
   ROD: EV_ECM16TDI02103L997557R.rod
   VCID: 303911D20AA2510BE23-8064
   Revision: 00H31001
   Coding: 13422012092200FEC80D04E5901A0091380800
   Shop #: WSC 01236 758 00200
   VCID: 76B5E7CAA8C63F3B78F-8022
   Part No SW: 8P0 820 047 E    HW: 8P0 820 047 E
   Component: J255  Klima Man H08 0060
   Revision: 00H08004    Serial number: 00000000000000
   VCID: 323D1BDA082E631B947-8066
   Part No SW: 8P0 907 063 F    HW: 8P0 907 063 F
   Component: BCM PQ35  B   107 0615
   Revision: 00107 AF
   Coding: 46000A3FAA13F140207060E00500004C53325CAA0000C522E4008F000055
   VCID: 372B2ACEEF4C8633A39-8062
   Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H11 0050
   Coding: 00DD13
   Subsystem 2 - Part No: 8P7 951 177
   Component: DWA-Sensor H0  H03 0050
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 G    HW: 8P0 919 475
   Component: PARKHILFE 4K  H06 0120
   Revision: 11001001    Serial number: 93631028726473
   VCID: 42DD4B1AB48ED39B047-8016
Address 15: Airbags        Labels: 8P7-959-655.clb
   Part No SW: 8P7 959 655     HW: 8P7 959 655
   Component: SR Airbag 9.43  H01 0020
   Revision: 93H01002    Serial number: 003BS0015N0S
   Coding: 0021330
   VCID: 0655970AD4262FBB68F-8052
   Subsystem 1 - Serial number: 6332DRB40CEB8CB3B
   Subsystem 2 - Serial number: 6342DRB40CED95262
   Subsystem 3 - Serial number: 63747RB405E00EE6-
   Subsystem 4 - Serial number: 63847RB405E012FAV
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0003011
   VCID: 46D5570A94A6EFBB28F-8012
   Component: E0221           H04 0100
   Part No SW: 8P0 920 982 H    HW: 8P0 920 982 H
   Component: KOMBIINSTR. VDO H01 0090
   Revision: D0H01003    Serial number: 2248J003006189
   Coding: 0260418
   VCID: 3E253FEACC76B77B60F-806A
   Part No SW: 8P0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H33 5304
   Revision:   H33       Serial number: 071010F1001261
   Coding: E9A07F2600060204009101
   VCID: 313F14D60D285803EDD-8064
   Revision: D0H01003    Serial number: AUX7Z0J8FN70SN
Address 26: Auto Roof        Labels: Redir Fail!
   Part No: 8P7 959 255 B
   Component: VSG AUDI A3     H14 0130
   VCID: 44D14D02A29ADDAB36B-8010
Address 42: Door Elect, Driver        Labels: None
   Part No SW: 8P7 959 801 G    HW: 8P7 959 801 G
   Component: Tuer-SG         H04 0103
   Coding: 0131764
03300 - Main Switch for Electric Windows in Drivers Door
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 233    3001
   Revision: 00H17000
   Part No SW: 8P7 959 802 F    HW: 8P7 959 802 F
   Coding: 0017044
   Part No SW: 8P0 035 152 F    HW: 8P0 035 152 F
   Component: R Chorus2+      H02 0293
   Revision: 00H02000    Serial number: AUZ1Z2K1413171
   Coding: 0620221
   VCID: 2E050FAA1C1647FBF0F-807A
   Part No SW: 8P0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H33 5304
   Coding: 030B085A
   VCID: 74B1DDC2BEBA2D2B46B-8020
   Subsystem 1 - Part No SW: 1K0 915 181 E    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650408099
   Part No SW: 8P7 959 811 B    HW: 8P7 959 811 B
   Component: Tuer-SG         H01 0054
   Coding: 0131216
   VCID: 42DD4B1AB88ED39B047-8016
   Part No SW: 8P7 959 812 B    HW: 8P7 959 812 B
   Coding: 0131216
   Shop #: WSC 01236 785 1012552
   VCID: 43D34E1EA794DA930F1-8016
   Part No SW: 8P1 862 335     HW: 8P1 862 335
   Component: FSE_256x BT     H41 0650
   Revision: 00000000    Serial number: 00000005237980
   Coding: 0001202
   VCID: 74B1DDC2B2BA2D2B46B-8020
End----------(Elapsed Time: 01:28, VBatt start/end: 12.2V/12.2V)-----------
C-U-B-E-_-
C?ID=327304
Hello, you can use as serial number 1111111113 or as date 2020311000,
Mainly 10 digits.
den9112
C?ID=362794
Hi,i have a serial number ,its the procedure i have watched shows the BEM part number being used in my options it only shows amps,vender then serial number ,confused why the partnumber is not used
Mari
C?ID=150535
There is no relevant information in the partnumber! It is impossible to store all partnumbers of all manufacturers and the information behind that partnumber... So put in the AMPS, Vendor and Serial and go for a little drive ;)
C-U-B-E-_-
C?ID=327304
It's so normal with your controller.
Your format for your ECU is AAA BBB NNNNNNNNN
The procedure for you is not included in Mari's video. (not even in the Wiki)
den9112
C?ID=362794
I have seen that video,mine is 19 can gateway (can) long adaptation ,batery info /replace when i get the pop up window my format is different ,it says amps,vendor ,serial number ..
In this video it shows battery,vendor,battery serial number ..Would i be correct in following my pop up info format and not this one,my confusion is my pop up info does not ask for a part number ..
den9112
C?ID=362794
Will do...:thumbs:
Mari
C?ID=150535
Then explain the procedure to OP by posting it here... then Ross-tech can make a new video ;)
It might be difficult for us to make a video of this one since I don't think that particular variate of battery management exists on any cars we would have access to.
However, it's not hard to "code" a new battery. Go to 61: Battery Regul, Adaptation channel 004, and put in the new data in the following format:
AAA BBB NNNNNNNNNN
AAA = Battery Size (e.g. 68 Ah = 068 / 3 Digits)
BBB = Battery Vendor (3 Digits)
NNNNNNNNNN = Battery Serial Number (10 Alphanumeric Digits)
Battery Vendor List:
5DO = Boading
TU3 = Exide
MLA = Moll
JCB = JCI
VA0 = Varta
UM5 = Akuma
C-U-B-E-_-
C?ID=327304
x3la
NJ, USA
C?ID=423999
I'm intrigued to know how you got on with your battery coding.
Do you mind me asking the age and model of your car?
den9112
C?ID=362794
Hi, i have the battery arriving tomorrow ,the current battery is a Varta and i have gone for the same as recommended ..I will be fitting it in the next coupe of days and will do the procedure as above (and what my pop up info tells me) Amps Vendor Serial No
Car is a 2011 1.6tdi CAYC Audi A3 Cabriolet
den9112
C?ID=362794
Received the battery this morning unfortunately it is damaged. It is being returned for a replacement. On the new battery there is just one sticker with Varta code and that is just a 12 digit code A 26 E39 004 60W .
I asked sales if they had any idea what the digits related to as i just need a serial number as i know the amps and vendor ,they couldn't help ..I presume having the old serial number i would just have to change one digit and input the new AH and vendor ..Very confusing all i want to do is change a battery..Psjust to confirm that varta vender is zero and not the letter O ..
den9112
C?ID=362794
Update - I have replaced the battery and changed Ah from 068 to 070 JCB to VAO and changed one digit in the serial number test and save ,got a pop up asking if i was sure .Done and closed .
Stop start not working this morning after a 25 mile journey but i had radio, lights and heater on ..Not to bothered about stop start as i find it a pain..
Westbury, UK
Stop/start will probably start working once the BMS has learned the new battery condition well enough.
den9112
C?ID=362794
@PetrolDave Your right it's back caught me out on the way home ,but then i suppose it's shows my battery was not up for it and the current one is fine ..Just have to get used to switching it off when i get in the car ..
