-Monday,19,October,2020,12:07:36:04136-
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
VIN: TRUZZZ8P1B1004211 License Plate: V20OWL
Mileage: 174860km-108652mi Repair Order:
Hi, i am about to replace my battery and i have checked the current code to the current battery via vcds and all match up..I know that there is a BEM code a part No code and a serial number ..I have watched the procedure for putting the code in however when i check my code it as Amps first 3 digit 068 ,then vender JCB 3 digit , then the 10 digit serial number no part number in it at all..When i check the pop up box information on vcds it does give me this format..Would this be correct in leaving out the part number ..
Chassis Type: 8P-AU35 (8P0)
Scan: 01 03 08 09 10 15 16 17 19 25 26 42 44 46 52 56 61 62 72 77
VIN: TRUZZZ8P1B1004211 Mileage: 174860km-108652miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 M HW: 03L 906 023 L
Component: 1,6l R4 CR td H23 9973
Revision: --H23--- Serial number: AUX7Z0J8FN70SN
Coding: 00114034030501080000
Shop #: WSC 01236 785 00200
ASAM Dataset: EV_ECM16TDI02103L906023M 003014
ROD: EV_ECM16TDI02103L997557R.rod
VCID: 303911D20AA2510BE23-8064
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 13422012092200FEC80D04E5901A0091380800
Shop #: WSC 01236 758 00200
VCID: 76B5E7CAA8C63F3B78F-8022
Part No SW: 8P0 820 047 E HW: 8P0 820 047 E
Component: J255 Klima Man H08 0060
Revision: 00H08004 Serial number: 00000000000000
VCID: 323D1BDA082E631B947-8066
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 F HW: 8P0 907 063 F
Component: BCM PQ35 B 107 0615
Revision: 00107 AF
Coding: 46000A3FAA13F140207060E00500004C53325CAA0000C522E4008F000055
VCID: 372B2ACEEF4C8633A39-8062
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Subsystem 2 - Part No: 8P7 951 177
Component: DWA-Sensor H0 H03 0050
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 G HW: 8P0 919 475
Component: PARKHILFE 4K H06 0120
Revision: 11001001 Serial number: 93631028726473
VCID: 42DD4B1AB48ED39B047-8016
Address 15: Airbags Labels: 8P7-959-655.clb
Part No SW: 8P7 959 655 HW: 8P7 959 655
Component: SR Airbag 9.43 H01 0020
Revision: 93H01002 Serial number: 003BS0015N0S
Coding: 0021330
VCID: 0655970AD4262FBB68F-8052
Subsystem 1 - Serial number: 6332DRB40CEB8CB3B
Subsystem 2 - Serial number: 6342DRB40CED95262
Subsystem 3 - Serial number: 63747RB405E00EE6-
Subsystem 4 - Serial number: 63847RB405E012FAV
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0003011
VCID: 46D5570A94A6EFBB28F-8012
Component: E0221 H04 0100
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 H HW: 8P0 920 982 H
Component: KOMBIINSTR. VDO H01 0090
Revision: D0H01003 Serial number: 2248J003006189
Coding: 0260418
Shop #: WSC 12345 123 12345
VCID: 3E253FEACC76B77B60F-806A
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 8P0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H33 5304
Revision: H33 Serial number: 071010F1001261
Coding: E9A07F2600060204009101
VCID: 313F14D60D285803EDD-8064
Revision: D0H01003 Serial number: AUX7Z0J8FN70SN
Address 26: Auto Roof Labels: Redir Fail!
Part No: 8P7 959 255 B
Component: VSG AUDI A3 H14 0130
VCID: 44D14D02A29ADDAB36B-8010
Address 42: Door Elect, Driver Labels: None
Part No SW: 8P7 959 801 G HW: 8P7 959 801 G
Component: Tuer-SG H04 0103
Coding: 0131764
03300 - Main Switch for Electric Windows in Drivers Door
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 233 3001
Revision: 00H17000
Part No SW: 8P7 959 802 F HW: 8P7 959 802 F
Coding: 0017044
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 152 F HW: 8P0 035 152 F
Component: R Chorus2+ H02 0293
Revision: 00H02000 Serial number: AUZ1Z2K1413171
Coding: 0620221
VCID: 2E050FAA1C1647FBF0F-807A
Part No SW: 8P0 907 534 HW: 1K0 907 951
Component: Batt.regelung H33 5304
Coding: 030B085A
VCID: 74B1DDC2BEBA2D2B46B-8020
Subsystem 1 - Part No SW: 1K0 915 181 E HW: 1K0 915 181 A
Component: J367-BDM H07 0140
Serial number: 00000000005650408099
Part No SW: 8P7 959 811 B HW: 8P7 959 811 B
Component: Tuer-SG H01 0054
Coding: 0131216
VCID: 42DD4B1AB88ED39B047-8016
Part No SW: 8P7 959 812 B HW: 8P7 959 812 B
Coding: 0131216
Shop #: WSC 01236 785 1012552
VCID: 43D34E1EA794DA930F1-8016
Part No SW: 8P1 862 335 HW: 8P1 862 335
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005237980
Coding: 0001202
VCID: 74B1DDC2B2BA2D2B46B-8020
End----------(Elapsed Time: 01:28, VBatt start/end: 12.2V/12.2V)-----------
