Golf 7 abs long code needed (MK100IPB)
turandos
Pretoria, South Africa
C?ID=232762
Good morning. I am in need with a long code for abs. if anyone can please help.
here is a scan of the vehicle.
Friday,30,October,2020,06:07:41:39486
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 20.4.2.0
VIN: WVWZZZAUZFW228012   License Plate: GOLF7 SAVE 1
Mileage: 83800km-52070mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 42 44 52 55 5F A9
VIN: WVWZZZAUZFW228012   Mileage: 83800km-52070miles
Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259     HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0010
   Revision: --H13---
   Coding: 091D00324424050B2000
   Shop #: WSC 63125 003 1048576
   ASAM Dataset: EV_ECM20TFS0215G0906259 001014
   ROD: EV_ECM20TFS0215G0906259.rod
   VCID: 6BD3256F821FCEDED6-803E
17169 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
                    Mileage: 83800 km
                    Date: 2020.10.10
                    Time: 20:05:53
                    Engine speed: 0.00 /min
                    Coolant temperature: 76 °C
                    Intake air temperature: 58 °C
                    Ambient air pressure: 860 mbar
                    Voltage terminal 30: 12.109 V
                    ACC variants (coding): CCS
                    CCS Switch: ACC operating unit
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
                    ACC variants: ACC
                    Engine: operating status: ES
19875 - No Communication with ABS Brake Control Module
          U0121 00 [167] - -
                    Mileage: 83800 km
                    Date: 2020.10.10
                    Time: 20:05:53
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 72.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 17 min
                    STATE_ERR_ABC_PRED: 0
Readiness: 1110 0001
   Part No SW: 0D9 300 041 C    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H54 4936
   Revision: 06354004    Serial number: TFK01607091475
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 18392AA3E3099546CB-804C
21221 - No Communications with Parking Brake Control Module
          U0128 00 [011] - -
                    Mileage: 83800 km
                    Date: 2020.10.10
                    Time: 20:05:53
   Revision: 00000000    Serial number: 600740000004E5
   ROD: EV_Brake1UDSContiMK100IPB_033.rod
   VCID: 7BF3152FF27F5E5E46-802E
13 Faults Found:
0195 - Control module not coded
          U1013 00 [137] - -
                    Reset counter: 34
                    Date: 2020.10.09
                    Time: 00:11:01
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 34
                    Date: 2020.10.09
                    Time: 00:11:01
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 34
                    Date: 2020.10.09
                    Time: 00:11:01
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 34
                    Date: 2020.10.09
                    Time: 00:11:01
0295 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 34
                    Date: 2020.10.09
                    Time: 00:11:01
0297 - Steering angle sensor
          B1168 16 [008] - Voltage Too Low
                    Reset counter: 74
                    Date: 2020.10.09
                    Time: 00:11:01
0398 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 34
                    Mileage: 83796 km
                    Date: 2020.10.09
                    Time: 00:11:02
8278 - Control Module Incorrectly Coded
          U1014 00 [137] - -
                    Reset counter: 34
                    Date: 2020.10.09
                    Time: 00:11:01
8286 - Databus
                    Reset counter: 36
                    Date: 2020.10.09
                    Time: 00:11:01
8290 - Coding Not Possible
          U10BC 00 [137] - -
                    Reset counter: 34
                    Mileage: 83796 km
                    Date: 2020.10.09
                    Time: 00:11:06
8306 - Databus
          U1122 00 [137] - Implausible Message
                    Reset counter: 34
                    Mileage: 83796 km
                    Date: 2020.10.09
                    Time: 00:11:06
8308 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 34
                    Date: 2020.10.09
                    Time: 00:11:01
32848 - Control Module for Electric Parking Brake
          C10E2 F1 [137] - Switches/Motors Detected
                    Reset counter: 34
                    Date: 2020.10.09
                    Time: 00:11:01
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00120014200100001005000012101400
   VCID: 6ADD206B8DE5D7D6AD-803E
   Air quality sensor:
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 36
                    Mileage: 83800 km
                    Date: 2020.10.10
                    Time: 20:06:29
                    Outside air temperature: 29.5 °C
                    Engine speed: 0 /min
                    Temperature after evaporator: 39.3 °C
                    System run time-Terminal 15 on: 255 s
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011500900872
   Coding: 03101B46C241225B0BA44080B10C0708100A000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 000962C39B993D8613-8054
   Component: WWS    141209  042 0551
   Serial number:         141215172724
   Component: RLHS  037 0059
   Serial number: S4Y15M01D10H12M49S22
   Coding: 00A8DD
   Serial number: 000000000ZY1434409B9
   Serial number: 00000000000061285533
   Sun Roof:
   Component: J245 PS73.403  H02 0003
   Serial number: 0000FST0002CU8G00000
   Coding: 181801
18698 - Left LED Module for DRL and Parking Lights
          B12EC F2 [009] - Voltage Supply Open or Short to Plus
                    Reset counter: 36
                    Mileage: 83800 km
                    Date: 2020.10.10
                    Time: 20:07:01
19210 - Right LED Module for DRL and Parking Lights
          B12ED F2 [009] - Voltage Supply Open or Short to Plus
                    Reset counter: 36
                    Mileage: 83800 km
                    Date: 2020.10.10
                    Time: 20:07:01
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39391500701044
   Coding: 0031051011
   VCID: 3D77DB37ACEB906E38-8068
12658704 - Databus
                    Reset counter: 36
                    Mileage: 83800 km
                    Date: 2020.10.10
                    Time: 20:07:26
13637426 - Databus
                    Reset counter: 36
                    Mileage: 83800 km
                    Date: 2020.10.10
                    Time: 20:07:26
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Serial number: 003F6R0ESF6S
   VCID: 418FA7C7D013F48E5C-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 812 14
   Serial number: 357670000007959C521Z
   Subsystem 2 - Part No SW: -----------    HW: 480 001 812 14
   Serial number: 358670000009D720421O
   Subsystem 3 - Part No SW: -----------    HW: 480 401 612 14
   Serial number: 3516502AF1901DA392CL
   Subsystem 4 - Part No SW: -----------    HW: 480 401 612 14
   Serial number: 3526502AD1901DA1210+
   Subsystem 5 - Part No SW: -----------    HW: 480 401 302 14
   Serial number: 3556502C914D3E72D29T
          B13BC F2 [137] - No function
                    Mileage: 83800 km
                    Date: 2020.10.10
                    Time: 20:07:56
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150102500077
   Coding: 0410
   Shop #: WSC 26996 002 1048576
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3F8BA13FA6E7827E2A-806A
   Part No SW: 5G6 920 870     HW: 5G6 920 870
   Component: KOMBI         314 2210
   Coding: 27AD09083B80000800082A00040000
   VCID: 6CD126738711C9E6DF-8038
16776966 - Databus
                    Reset counter: 36
                    Mileage: 83800 km
                    Date: 2020.10.10
                    Time: 20:08:40
16776967 - Databus
                    Reset counter: 36
                    Mileage: 83800 km
                    Date: 2020.10.10
                    Time: 20:08:40
16776973 - Databus
                    Reset counter: 36
                    Mileage: 83800 km
                    Date: 2020.10.10
                    Time: 20:08:40
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1204
   Revision: --------    Serial number: 0002906580
   Coding: 030100042F085900EF00026A1C0F00010001050000000000000000000000
   Shop #: WSC 61735 001 1048576
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011.rod
   VCID: 72ED380BA5351F1615-8026
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29170000021070107041
   Coding: 2DFFFF
   Serial number: 1946300804
Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
   Part No SW: 5G0 857 511 D    HW: 5G0 857 511 D
   Component: FLA           H05 0002
   Revision: AA001001
   Coding: 02028864727264565625393E01
   ASAM Dataset: EV_HighBeamAssisAU37X 001009
   ROD: EV_HighBeamAssisAU37X.rod
   VCID: 2B53E56F429F0EDE96-807E
   Serial number: 221214BLK14552
   Coding: 003E02208001040000001000
   VCID: 428DA8CBD515EF9645-8016
   Serial number: 00000000000004802068
   Coding: 0D0000
65604 - Door Warning Lamp
          B1326 01 [009] - Electrical Failure
                    Reset counter: 36
                    Mileage: 83800 km
                    Date: 2020.10.10
                    Time: 20:10:29
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Coding: 0103
   VCID: 377BC91F8ED7BA3EE2-8062
   Serial number: 141214BLE04901
   Coding: 003E00208E01040000801000
   Serial number: 00000000000004737824
   Coding: 150000
   Coding: 029E01000B000200
   VCID: 4089A2C3DB19FD8653-8014
5276144 - Power Output Module for Left Headlamp
          C1081 F0 [137] - Not Coded
                    Reset counter: 36
                    Mileage: 83800 km
                    Date: 2020.10.10
                    Time: 20:11:51
5276400 - Power Output Module for Right Headlamp
          C1082 F0 [137] - Not Coded
                    Reset counter: 36
                    Mileage: 83800 km
                    Date: 2020.10.10
                    Time: 20:11:51
13679104 - Local Data Bus
          U10BA 00 [137] - No Communication
                    Reset counter: 36
                    Mileage: 83800 km
                    Date: 2020.10.10
                    Time: 20:11:51
   Part No SW: 5G0 035 819 A    HW: 5G0 035 819 A
   Component: MU-S--ER      041 0421
   Serial number: V1C00701153578
   Coding: 02730000FF00000011110001000900001F0203860100010001
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 275B195F5E772ABE72-8072
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H60 0030
   Serial number: VWZ8Z9PS206H7S
   Component: SAS-GEN 2     H06 0014
   Serial number: 141114200421
End-------------------------(Elapsed Time: 05:05)--------------------------
The most comprehensive coding info I have seen for these is in the spreadsheet linked in the first post of this thread:
