How to Read Adpmap- Brake Booster Setting
morris39
Canada
C?ID=395084
I am considering experimenting with amount of brake boost assist but need help reading the settings
From f[le :adpmap-03-3Q0-907-379-R_WAUFFRFF8F1141715-20200712-1544.xlsx; MY15 S3
Line: IDE04951-Brake booster 4 1
I infer that booster setting from factory is "4" ? and a possible adapted setting is " 1"? or is it the other way around? The columns are not labeled.Is there a wiki how to interpret ?
@morris39: Hi. According to the notes that I've made about the IDE04951-Brake booster, the lower the number, the "firmer" the feel! My note was made from my meanderings through the vast corridors of the web over the years, so I can't give you an exact reference (alas).
morris39
Canada
C?ID=395084
Thanks Don, I will start with that. The general question (maybe stupid) remains. What are the column headings in general after the IDE name? I would guess something like maybe a) default/factory and b) current value or vice versa but maybe that is too simple.
Anyone? Wiki I missed on this?
TBAx
C?ID=287144
4 is the value currently set
1 is the amount of Bytes used by the adaption channel (group)
morris39
Canada
C?ID=395084
Attempted to change brake booster value from "4" to "2" and also "1" but failed; "Security access required". Shop code denied if ignoring advice.
What I did: engine running; Test OK; Module 03; Adaptations; channel IDE 04951 Brake Booster; existing value shown "4" ; new value "2"
Suggestions please.
morris39
Canada
C?ID=395084
Thanks Don, that worked. I like the change to "2", it provides better sensitivity
