Bentley GT radiator outlet constantly at 105 degrees.
Bentley
South Wales, UK
C?ID=263294
Hi,
got an odd one on a Bentley 2015 GT
The radiator outlet is constantly reading 105*c. From start up to full running temperate. Tried anew sensor. IDE00194
Fan comes on about 30 seconds after start up whatever the engine temp is. It runs for about a minute after the engine is turned off.
If I disconnect the sensor it gives a too high error code and if I bridge it I get a too low error code. 105*c doesn't change, fan speed doesndoesn't change.
Has any body come across this before?
TIA, Paul.
Tuesday,22,September,2020,08:17:13:45172
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
Dealer/Shop Name: CMC
VIN: SCBFF63W5GC054305   License Plate: STU SAM
Mileage: 114540km-71171mi   Repair Order:
Chassis Type: 3W-BY62 (3W0)
Scan: 01 02 03 05 06 07 08 09 11 31 13 15 16 17 19 23 2E 34 36 37
          38 46 47 53 56 65 68 6C 6D 71 76 77
VIN: SCBFF63W5GC054305   Mileage: 114540km-71171miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
38-Roof Electronics -- Status: OK 0000
68-Wiper Electr. -- Status: OK 0000
71-Battery Charger -- Status: Malfunction 0010
Address 01: Engine (J623-DBDE)       Labels: Redir Fail!
   Part No SW: 07C 906 023 AT    HW: 07C 907 309
   Component: ME17.1.6      H17 1472
   Revision: MHH17---    Serial number: VWX3Z0P3013028
   Coding: 052A0032436F00010006
   Shop #: WSC 00083 790 00194
   ASAM Dataset: EV_ECM60TMP11107C906023AT 001003
   ROD: EV_ECM60TMP11107C906023AT_001.rod
   VCID: F3A67ECC5A05DC1E9E-80A6
16672 - Please Check DTC Memory of ECU Number 2
          P1923 00 [039] - -
                    Mileage: 114544 km
                    Date: 2020.09.22
                    Time: 08:12:58
                    Engine speed: 0.00 /min
                    Coolant temperature: 16 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 11.473 V
                    Unlearning counter according OBD: 0
                    Engine torque: 0.0 Nm
                    Fuel level: 0.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 0.9792
4527 - Coolant Fan Control Circuit 1
          P0480 00 [047] - Electrical Malfunction
                    Mileage: 113434 km
                    Date: 2020.02.04
                    Time: 16:18:40
                    Coolant temperature: 69 °C
                    Voltage terminal 30: 10.955 V
                    Fuel level: 36.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
Address 02: Auto Trans (J217)       Labels:| 0CM-325-025.clb
   Part No SW: 3W3 927 158 E    HW: 0CU 927 760 A
   Component: OBL 60 MPIRdW H19 0003
   Revision: --H19---    Serial number: VWX3Z0P3013028
   Shop #: WSC 00083 790 00192
   ASAM Dataset: EV_TCMAL450211 002010
   ROD: EV_TCMAL450211_BY62.rod
   VCID: C2C8EB08553F2596C5-8096
Address 03: ABS Brakes        Labels: None
   VCID: D5E2205438B1A22E90-8080
No Faults Found
   Part No SW: 3D0 909 137 F    HW: 3D0 909 137 F
   Component: C3 Kessy            6850
   Revision: 00H24072    Serial number: VWX3Z0P3013028
   Coding: 0422125
   Shop #: WSC 00083 790 00174
   VCID: AA18A3A8014FDDD6ED-80FE
00955 - Key 1
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Fault Frequency: 0
                    Reset counter: 184
                    Date: 2020.09.21
                    Time: 11:01:24
   Part No SW: 4W0 959 760 A    HW: 4W0 959 760
   Component: MEM-BFS       H04 0700
   Revision: AA000000    Serial number: 00000163988468
   Coding: D03A1B2485A70000090001010101010000212727000000
   Shop #: WSC 00083 790 00236
   VCID: C0CCE10057333786D3-8094
Address 07: Control Head        Labels: 3D0-907-048.clb
   Part No SW: 3D0 907 048     HW: 3D0 907 048
   Component: J127 KBT vorn       0100
   Revision: ABH27001    Serial number: VWZ6Z7R0246091
   VCID: E3860E8C26E54C9EEE-80B6
Address 08: Auto HVAC        Labels: 3W7-907-040.clb
   Part No: 3W0 907 040 L
   Component: Climatronic BY624   3019
   Coding: 0000101
   VCID: BA3893E8F1EF6D569D-80EE
00019 - Motor for Warm-Air Flap (V198)
00041 - Indirect Ventilation Flap Motor (V213)
Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
   Part No SW: 3D0 937 049 Q    HW: 3D0 937 049 Q
   Component: J519                7700
   Revision: -4007---    Serial number: --------------
   Coding: 40820000AB2A11802508030000000000
   VCID: B83C89E0CFE37F466B-80EC
Address 11: Engine II (J624)       Labels: None
   ASAM Dataset: EV_ECM60TMP21107C906023AT 001003
   ROD: EV_ECM60TMP07C906023AT_A01.rod
12646 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [096] - -
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Engine speed: 5201.00 /min
                    Normed load value: 65.5 %
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 13.876 V
                    Unlearning counter according OBD: 16
                    Fuel level: 37.00 l
10597 - Cylinder 7
          P0307 00 [096] - Misfire Detected
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
18910 - Cylinder 11
          P0311 00 [096] - Misfire Detected
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 4W0 907 567 B    HW: 4W0 907 567 B
   Component: AC201  RDW BY684   00951
   Revision: 00041000    Serial number: 00000000664301
   Coding: 0010684
   Shop #: WSC 23375 002 1048576
   VCID: BFCEE2FCEACD487EAA-80EA
   Part No SW: 3W3 959 655 A    HW: 3W3 959 655 A
   Component: VW10Airbag20I H01 0004
   Revision: --------    Serial number: 003FW000EFUN
   Coding: 000000000000000000000000000000003049
   ASAM Dataset: EV_AirbaVW10BPABY62X 001002
   ROD: EV_AirbaVW10BPABY62X.rod
   VCID: C5C2F014441112AEE0-8090
   Serial number: 3572DRB40000F735226Q
   Serial number: 3582DRB40000F79CBACK
   Serial number: 35128RB400007449EA5S
   Serial number: 35228RB400007447435A
   Serial number: 35547RB4000073AA263L
   Serial number: 35647RB400007483A00D
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 K
   Component: J527                3601
   Coding: 0000042
   Shop #: WSC 00083 790 00244
   VCID: C7DEFA1CB21D00BE12-8092
Address 17: Instruments        Labels: 3Wx-920-xxx-17.lbl
   Part No SW: 3W0 920 851 S    HW: 3W0 920 851 S
   Component: J285 KOMBI-INST.    6666
   Revision: KPH10V06
   Coding: 0038414
   Shop #: WSC 08796 796 45678
   VCID: C6C0F718B11719B6E9-8092
Address 19: CAN Gateway        Labels: None
   Part No SW: 3W0 909 901     HW: 3W0 920 851 S
   Component: J533  GW-K-CAN TP20 6666
   Revision: KPH10V06
   Coding: DFFBFFAEEB154701
   VCID: F6A047D88177C936B9-80A2
Address 23: Brake Booster        Labels: None
   Part No: 3W0 907 563 B
   Component: BREMSBOOSTER    007 0430
   Revision: 00007000    Serial number: 00000000035283
   Revision: A1001003    Serial number: 7665891982
   Coding: 030100
   VCID: AB16A6ACCAB5C4DE16-80FE
Address 34: Level Control        Labels: None
   Part No: 3W0 907 553 J
   Component: LUFTFDR.-CDC- 3C3V0 7509
   Coding: 0005531
   Shop #: WSC 00083 790 00166
   VCID: C1CAE4049C393E8EDC-8094
   Component: MEM-FS        H04 0700
   Revision: AA000000    Serial number: 00000162719068
   Shop #: WSC 00083 790 00242
03323 - Switch for Fore/Aft Adjustment: Back
                    Fault Status: 00100011
                    Reset counter: 125
                    Mileage: 113611 km
                    Date: 2020.04.08
                    Time: 22:27:32
Address 37: Navigation (J0506)       Labels: None
   Part No SW: 3W0 035 017 T    HW: 3W0 035 017 T
   Component: RNS-MID       H27 0290
   Revision: AB001001    Serial number: VWZ6Z7R0246091
   Coding: 04010002000000010000
   VCID: BE309FF829C74176A1-80EA
   Subsystem 1 - Part No: 3W0 919 859 CB
   Component: EU West V5  8195
Address 38: Roof Electronics        Labels: None
   Part No: 3W0 907 135 H
   Component: Dachmodul           0910
   Coding: 0022941
   VCID: BB3696ECFED5545E86-80EE
Address 46: Central Conv.
Address 47: Sound System        Labels: None
   Part No SW: 3W8 035 465 F    HW: 3W8 035 465 F
   Component: R12___DSP 12 Kanal  0402
   Revision: DBH01001    Serial number: BP081051454863
   VCID: BFCEE2FCEECD487EAA-80EA
Address 53: Parking Brake (J540)       Labels: None
   Part No SW: 4W0 907 801     HW: 4W0 907 801
   Component: EPB-4         H01 0002
   Revision: --------    Serial number: 00000000014090
   ASAM Dataset: EV_BY62XParkiBrake 001008
   ROD: EV_BY62XParkiBrake.rod
   VCID: F4A47DD05F0BDB2687-80A0
Address 56: Radio (J0506)       Labels: None
Address 65: Tire Pressure        Labels: Redir Fail!
   Part No SW: 3W7 907 273 E    HW: 3W7 907 273 E
   Component: J0502 RDK           0008
   Revision:   004008    Serial number: 00000600002837
   Coding: 30007C63B8FD63FD0063B8FD63FD0063B8FD4B6E4B6E4B6E4B6E4B6E
   Shop #: WSC 00083 790 00175
   VCID: C2C8EB08993F2596C5-8096
Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
   Part No: 3W2 955 023 L
   Component: Wischermodul       ª0401
   Shop #: WSC 00000 725 65552
   VCID: C0CCE10097333786D3-8094
   Part No SW: 3W3 907 441 C    HW: 3W3 907 441 C
   Revision: 00H13000    Serial number: 525 PA8JA80288
   Coding: 2022002
   VCID: B93A8CE4F0E9664E94-80EC
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 3W3 959 108     HW: 3W3 959 108
   Component: HDSG-Modul    H02 0803
   Revision: 00000000    Serial number: 247500006
   Coding: 184006C020
   ASAM Dataset: EV_HDSGBY6245 002001
   ROD: EV_HDSGBY6245_002.rod
   VCID: FDB258F46C419A6EF8-80A8
Address 71: Battery Charger (J367)       Labels:* None
   Part No SW: 3W3 915 181 B    HW: 3W3 915 181 B
   Component: EMM Batt Man  H05 0570
   Coding: 5E0100
   ASAM Dataset: EV_BatteChargVaria1 002019
   ROD: EV_BatteChargVaria1_002.rod
   VCID: B83C89E003E37F466B-80EC
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0141
   Serial number: 22189A43241041382232
13705472 - Databus
          [DTC_TIMEOUT_ESP]
                    Reset counter: 148
16777010 - Databus
          [DTC_TIMEOUT_SMLS]
                    Reset counter: 148
   Part No SW: 3W0 919 283 H    HW: 3W0 919 283 E
   Component: J446  ST Parkhilfe  0115
   Revision: 11H02001    Serial number: 58131519700001
   Coding: 0308026
   Shop #: WSC 37234 001 1048576
Address 77: Telephone (J412)       Labels:* None
   Part No SW: 3D0 035 730 E    HW: 3D0 035 730 E
   Component: Telefon       026 0983
   Revision: --------    Serial number: 35502105280507
   Coding: 020105010100010000000000
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 9E707F788107217681-80CA
End----(Elapsed Time: 02:25, VBatt start/end: 11.2V/11.1V. VIgn 11.1V)-----
                Address 11: Engine II       Labels: None
Control Module Part Number: 07C 906 023 AT    HW: 07C 907 309
  Component and/or Version: ME17.1.6      H17 1472
           Software Coding: 052A0032436F00010006
            Work Shop Code: WSC 00083 790 00194
              ASAM Dataset: EV_ECM60TMP21107C906023AT 001003 (BY62)
          P0300 00 [096] - -
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
10597 - Cylinder 7
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
18910 - Cylinder 11
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
          P0300 00 [096] - -
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
10597 - Cylinder 7
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
18910 - Cylinder 11
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
Address 11: DTCs cleared
                Address 01: Engine       Labels: Redir Fail!
              ASAM Dataset: EV_ECM60TMP11107C906023AT 001003 (BY62)
          P0480 00 [039] - Electrical Malfunction
                    Mileage: 114544 km
                    Date: 2020.09.22
                    Time: 08:20:44
                    Engine speed: 1825.00 /min
                    Normed load value: 15.3 %
                    Coolant temperature: 29 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 12.133 V
                    Engine torque: 98.1 Nm
                    Fuel level: 16.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0710
Readiness: 1110 0001
                    Mileage: 114544 km
                    Date: 2020.09.22
                    Time: 08:20:44
                    Fuel level: 16.00 l
Address 01: DTCs cleared
          P1923 00 [039] - -
                    Mileage: 114544 km
                    Date: 2020.09.22
                    Time: 08:55:35
                    Coolant temperature: 32 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 12.298 V
                    Fuel level: 16.00 l
                    Mileage: 114544 km
                    Date: 2020.09.22
                    Time: 08:21:20
                    Engine speed: 668.50 /min
                    Normed load value: 22.0 %
                    Coolant temperature: 35 °C
                    Engine torque: 173.0 Nm
                    Fuel level: 16.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 0.9929
Readiness: 1110 1001
          P1923 00 [039] - -
                    Mileage: 114544 km
                    Date: 2020.09.22
                    Time: 08:12:58
                    Fuel level: 0.00 l
                    Mileage: 113434 km
                    Date: 2020.02.04
                    Time: 16:18:40
                    Fuel level: 36.00 l
No Faults Found
   Coding: 0422125
00955 - Key 1
                    Fault Frequency: 0
                    Reset counter: 184
                    Date: 2020.09.21
                    Time: 11:01:24
   Coding: 0000101
          P0300 00 [096] - -
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
10597 - Cylinder 7
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
18910 - Cylinder 11
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
   Coding: 0010684
   Coding: 0000042
   Revision: KPH10V06
   Coding: 0038414
   Revision: KPH10V06
   Coding: 030100
   Coding: 0005531
                    Reset counter: 125
                    Mileage: 113611 km
                    Date: 2020.04.08
                    Time: 22:27:32
   Coding: 0022941
   Coding: 2022002
   Coding: 184006C020
   Coding: 5E0100
13705472 - Databus
          [DTC_TIMEOUT_ESP]
                    Reset counter: 148
16777010 - Databus
          [DTC_TIMEOUT_SMLS]
                    Reset counter: 148
   Coding: 0308026
          P0300 00 [096] - -
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
10597 - Cylinder 7
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
18910 - Cylinder 11
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
          P0300 00 [096] - -
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
10597 - Cylinder 7
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
18910 - Cylinder 11
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
                    Mileage: 114544 km
                    Date: 2020.09.22
                    Time: 08:20:44
                    Fuel level: 16.00 l
                    Mileage: 114544 km
                    Date: 2020.09.22
                    Time: 08:20:44
                    Fuel level: 16.00 l
          P1923 00 [039] - -
                    Mileage: 114544 km
                    Date: 2020.09.22
                    Time: 08:55:35
                    Fuel level: 16.00 l
                    Mileage: 114544 km
                    Date: 2020.09.22
                    Time: 08:21:20
                    Fuel level: 16.00 l
          P1923 00 [039] - -
                    Mileage: 114544 km
                    Date: 2020.09.22
                    Time: 08:12:58
                    Fuel level: 0.00 l
                    Mileage: 113434 km
                    Date: 2020.02.04
                    Time: 16:18:40
                    Fuel level: 36.00 l
No Faults Found
   Coding: 0422125
00955 - Key 1
                    Fault Frequency: 0
                    Reset counter: 184
                    Date: 2020.09.21
                    Time: 11:01:24
   Coding: 0000101
          P0300 00 [096] - -
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
10597 - Cylinder 7
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
18910 - Cylinder 11
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
   Coding: 0010684
   Coding: 0000042
   Revision: KPH10V06
   Coding: 0038414
   Revision: KPH10V06
   Coding: 030100
   Coding: 0005531
                    Reset counter: 125
                    Mileage: 113611 km
                    Date: 2020.04.08
                    Time: 22:27:32
   Coding: 0022941
   Coding: 2022002
   Coding: 184006C020
   Coding: 5E0100
13705472 - Databus
          [DTC_TIMEOUT_ESP]
                    Reset counter: 148
16777010 - Databus
          [DTC_TIMEOUT_SMLS]
                    Reset counter: 148
   Coding: 0308026
          P0300 00 [096] - -
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
10597 - Cylinder 7
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
18910 - Cylinder 11
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
          P0300 00 [096] - -
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
10597 - Cylinder 7
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
18910 - Cylinder 11
                    Mileage: 113611 km
                    Date: 2020.03.24
                    Time: 16:04:57
                    Fuel level: 37.00 l
                    Mileage: 114544 km
                    Date: 2020.09.22
                    Time: 08:20:44
                    Fuel level: 16.00 l
                    Mileage: 114544 km
                    Date: 2020.09.22
                    Time: 08:20:44
                    Fuel level: 16.00 l
          P1923 00 [039] - -
                    Mileage: 114544 km
                    Date: 2020.09.22
                    Time: 08:55:35
                    Fuel level: 16.00 l
                    Mileage: 114544 km
                    Date: 2020.09.22
                    Time: 08:21:20
                    Fuel level: 16.00 l
;SW:07C-906-023-AT HW:07C-907-309 --- Engine
;Component:ME17.1.6 H17 1472Coding:052A0032436F00010006
;EV_ECM60TMP11107C906023AT
1003​
;Tuesday
29​
September
2020​
15:01:31:45172
;VCDS Version: Release 20.4.2 (x64) Data version: 20200730 DS317.0
;VCID: F3A67ECC5A05DC1E9E-80A6
GroupDescriptionActual
IDE00019Voltage terminal 30
13.311​
V
IDE00021Engine speed
590​
/min
IDE00025Coolant temperature
91​
°C
IDE00030Status of actuator testnot active
IDE00075Vehicle speed
0​
km/h
IDE00076Status of initial fuel fillingwas not yet started
IDE00078Time since engine start
1144​
s
IDE00083Throttle valve position (absolute)
11.8​
IDE00084Absolute load value
24​
IDE00085Normed load value
18​
IDE00086Accelerator position
15​
IDE00090-ENG57549selected gear-Bits 0-7
0​
IDE00094Kick-down statusNot operated
IDE00094-ENG127320Kick-down status-Test_Program_Channel 284
167​
IDE00097OBD - requirements for which this vehicle is designedEuro-OBD
IDE00100Engine torque
111.4​
Nm
IDE00150Pressure in brake booster
509.8​
hPa
IDE00151Oil fill level
54​
mm
IDE00152Oil warning threshold
41.1​
mm
IDE00155Timing angle retardation cylinder 1
0​
IDE00156Timing angle retardation cylinder 2
0​
IDE00157Timing angle retardation cylinder 3
0​
IDE00158Timing angle retardation cylinder 4
0​
IDE00159Timing angle retardation cylinder 5
0​
IDE00160Timing angle retardation cylinder 6
0​
IDE00167Exhaust temperature 1 bank 1
412.2​
°C
IDE00172A/C compressor torque
25​
Nm
IDE00173Cruise Control System: specified speed
0​
km/h
IDE00174Camshaft adjustment: exhaust: bank 1: specified value
-20​
IDE00175Camshaft adjustment: exhaust: bank 1: actual value
-20.797​
IDE00178Camshaft adjustment intake bank 1: specified value
25​
IDE00179Camshaft adjustment intake bank 1: actual value
24.555​
IDE00182Camshaft adaptation intake bank 1: phase position
0.07​
IDE00184Camshaft adaptation exhaust bank 1: phase position
-0.18​
IDE00186Fuel low pressure: actual value
496.4​
kPa
IDE00187Coolant temperature at engine start
53.3​
°C
IDE00190Charge air pressure specified value
0​
hPa
IDE00194Coolant temperature at radiator output: specified value
105​
°C
IDE00196Engine oil temperature
74.1​
°C
IDE00202Low fuel pressure: specified value
499​
kPa
IDE00252Brake system vacuum pumpPump off
IDE00252-ENG127370Brake system vacuum pump-Test_Program_Channel 601
112​
IDE00304Fuel level
12​
l
IDE00322Status of basic settingwas not yet started
IDE00323Security Access: Number of invalid keys
0​
IDE00347Air mass: actual value:
4.13​
g/s
IDE00348Intake air temperature
31​
°C
IDE00350Air mass: specified value
14.7​
kg/h
IDE00354Engine start: start synchronizationEPM_MODE_OK
IDE00354-ENG127291Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE
48​
IDE00355-ENG57549Cruise Control System (CCS): status-Bits 0-7
20​
IDE00356-ENG57549Cruise Control System (CCS): switch position-Bits 0-7
0​
IDE00357Fuel temperature
57​
°C
IDE00358Limitation: torque
1200​
Nm
IDE00360Limitation: accelerator pedal
0​
Nm
IDE00361Ambient air pressure
1002.42​
hPa
IDE00371Fuel consumption
2.7​
l/h
IDE00375Generator: load signal
99.9​
IDE00380Coolant fan 1: activation
15​
IDE00392Accelerator pedal: sensor voltage 1
738.6​
mV
IDE00393Accelerator pedal: sensor voltage 2
371​
mV
IDE00408-ENG57549Engine mount 1-Bits 0-7
1​
IDE00410-ENG57549Transmission mount 1-Bits 0-7
0​
IDE00412-ENG57549Starter control: terminal 50-Bits 0-7
0​
IDE00413-ENG57549Starter control: Interlock- or P/N-signal-Bits 0-7
1​
IDE00414-ENG57549Starter control: relay 1-Bits 0-7
0​
IDE00416-ENG57549Starter control: terminal 50 acknowledgment-Bits 0-7
4​
IDE00417-ENG57549Starter control: shut-off conditions 1-Bits 0-7
33​
0​
IDE00443-ENG57549Accelerator pedal: switch positions-Bits 0-7
9​
IDE00445Unlearning counter according OBD
255​
IDE00450Operating Instructions---
IDE00451Currently running routine
0​
IDE00474Ambient air pressure
100​
kPa abs
IDE00477Torque request: sum of auxiliary aggregate
45.7​
Nm
IDE00496-ENG57549Activation of oil pressure switch valve-Bits 0-7
0​
IDE00541Acceleration
0​
m/s²
IDE00555Alcohol content in fuel
6​
IDE00556Outside air temperature
17​
°C
IDE00559Current of oxygen sensor bank 1 sensor 1 (broadband sensor)0.998 Lambda / -0.020 mA
IDE00560-MAS04121Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage
0.72​
V
IDE00560-MAS04122Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation
99.2​
IDE00582Equivalence ratio target value
1​
Lambda
IDE00584Distance driven since erasing DTC memory
0​
km
IDE00585Dist. driven with exh. Malfunction Indicator Lamp activated
0​
km
IDE00588Fuel tank fill level
12.9​
IDE00592Oxygen sensor control statusClosed loop/ using O2 sensors
IDE00593Ignition timing adjustment cylinder 1
3​
Degrees
IDE00595Allocation of oxygen sensorsB1S1 B1S2
IDE00597Long term adaptation of mixture formation bank 1
-2.3​
IDE00598Long term adaptation of mixture formation bank 2
-3.1​
IDE00601Monitoring status since erasing DTC memory
IDE00602Monitoring status in current driving cycle
IDE00603Number of driving cycles since erasing DTC memory
1​
IDE00604Short term adaptation of mixture formation bank 1
-0.8​
IDE00605Short term adaptation of mixture formation bank 2
-0.8​
IDE00608Type of fuelGasoline
IDE00612Target position of EVAP canister valve
16.9​
IDE00699ESI: minimum oil level in service interval
32​
mm
IDE00700ESI: maximum oil level in service interval
-32​
mm
IDE00727Test steps still to be performed
0​
IDE00738Test of oxygen sensors bank 1: Delta-Lambda
0​
IDE00752Test of oxygen sensor control.Syst. OK
IDE00752-ENG127302Test of oxygen sensor control.-Test_Program_Channel 213
228​
IDE00787Cause for cancellation
0​
IDE00949Hide cylindernot active
IDE00949Hide cylinderactive
IDE00949-ENG127318Hide cylinder-Test_Program_cylinder 1
1​
IDE00949-ENG127309Hide cylinder-Test_Program_cylinder 10
0​
IDE00949-ENG127308Hide cylinder-Test_Program_cylinder 11
0​
IDE00949-ENG127307Hide cylinder-Test_Program_cylinder 12
0​
IDE00949-ENG127306Hide cylinder-Test_Program_cylinder 13
0​
IDE00949-ENG127305Hide cylinder-Test_Program_cylinder 14
0​
IDE00949-ENG127304Hide cylinder-Test_Program_cylinder 15
0​
IDE00949-ENG127303Hide cylinder-Test_Program_cylinder 16
0​
IDE00949-ENG127317Hide cylinder-Test_Program_cylinder 2
1​
IDE00949-ENG127316Hide cylinder-Test_Program_cylinder 3
0​
IDE00949-ENG127315Hide cylinder-Test_Program_cylinder 4
0​
IDE00949-ENG127314Hide cylinder-Test_Program_cylinder 5
1​
IDE00949-ENG127313Hide cylinder-Test_Program_cylinder 6
1​
IDE00949-ENG127312Hide cylinder-Test_Program_cylinder 7
1​
IDE00949-ENG127311Hide cylinder-Test_Program_cylinder 8
0​
IDE00949-ENG127310Hide cylinder-Test_Program_cylinder 9
0​
IDE01098Test of knock sensors: short trip resultTest off
IDE01098-ENG127299Test of knock sensors: short trip result-Test_Program_Channel 165
235​
IDE01196Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.
0.7002​
IDE01260Generator power
0​
W
IDE01267Height correction
0.9895​
IDE01385-ENG57549Wear index-Bits 0-7
0​
0​
IDE01386-ENG57549Soot index-Bits 0-7
0​
0​
IDE01405-ENG57549Status of starter activation-Bits 0-7
2​
IDE01590Status of brakesNot operated
IDE01590-ENG127367Status of brakes-Test_Program_Channel 600
167​
IDE01638Result O2 sensor aging test bank 1 or 3 before cat. conv.Test off
IDE01638-ENG127368Result O2 sensor aging test bank 1 or 3 before cat. conv.-Test_Program_Channel 951
235​
IDE01641-ENG57549Result of oxygen sensor test bank 1 after catalytic converter-Bits 0-7
161​
IDE01644Oxygen sensor voltage bank 1 after catalytic converter
0.724​
V
IDE01650Throttle valve position 2
12​
IDE01665Result of test of camshaft adjustment intake bank 1Test off
IDE01665-ENG127298Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140
235​
IDE01667Result of test of camshaft adjustment outlet bank 1Test off
IDE01667-ENG127371Result of test of camshaft adjustment outlet bank 1-Test_Program_Channel 619
235​
IDE01834Battery voltage
13240​
mV
IDE01869Long-term fuel trim bank 1 at idle
-0.52​
IDE01870Oxygen sensor after catalytic converter: operating statusB1-S2 OK
IDE01870-ENG127295Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113
209​
IDE01872Result of oxygen sensor aging test after catalytic converterB1-S2 OK
IDE01872-ENG127321Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378
209​
IDE01873Test of catalytic converter: measured value
1.51​
IDE01874Test of catalytic converter: resultTest off
IDE01874-ENG127322Test of catalytic converter: result-Test_Program_Channel 486
235​
IDE01875Required torque adjustment by idling regulator
0.006​
IDE01876Adaptation of loss torque
12.4​
Nm
IDE01877-ENG57549Operating condition of idle speed control-Bits 0-7
5​
IDE01878-ENG28465Adaptation of throttle valve-Byte
100​
IDE01879Adaptation of throttle valve: resultADP is OK
IDE01879-ENG127324Adaptation of throttle valve: result-Test_Program_Channel 698
2​
IDE01880Accelerator position 2
15​
IDE01881Adaptation of kick-down shifting point
0​
mV
IDE01884Camshaft adjustment intake bank 1: activation
6.252​
IDE01885Shut off of oxygen sensor controll-Reg.ON
IDE01885-ENG127301Shut off of oxygen sensor control-Test_Program_Channel 212
4​
IDE01887Adaptation of Fuel Pump (FP)
-37.5​
kPa
IDE01888Cold start enrichment: adaptation area 1
1​
IDE01889Cold start enrichment: adaptation area 2
1​
IDE01890Cold start enrichment: adaptation area 3
1​
IDE01891Cold start enrichment: adaptation area 4
1​
IDE01892Cold start enrichment: adaptation area 5
1​
IDE01893Fuel pump: specified value
26.453​
IDE01899Load value: corrected specified value
120.45​
IDE01901Lost torque adaptation: idle
17.9​
Nm
IDE01902Lost torque adaptation A/C compressor
12.5​
Nm
IDE01903Lost torque adaptation driving mode
6.5​
Nm
IDE01904Lost torque adaptation A/C compressor and driving mode
1.4​
Nm
IDE01909Short term adapt. throttle valve for mass air flow sensor
1.01563​
IDE01910Long term adaptation of throttle valve for mass air flow sensor
0.92273​
IDE01911Leakage air
7.8​
kg/h
IDE01912Oxygen sensor bank 1 sensor 1: specified value
1​
IDE01913Number of oxygen sensor dynamic tests: bank 1 sensor 1
0​
IDE01914-ENG57549Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bits 0-7
168​
IDE01916Leakage recognition from oxygen sensor control
0.98​
IDE01917Leakage after throttle valve
-1​
IDE01918Leakage before throttle valve
-1​
IDE01919-ENG57549Leakage recognition: status-Bits 0-7
149​
IDE01920Oxygen sensor: mixture correction with active diagnosis
-0.0664​
IDE01921-ENG100991O2 reg: evap. emiss. can. purge reg. valve w/ active diagn.-Rel uw b200 UWORD Chann 295
100​
IDE01921-ENG127296O2 reg: evap. emiss. can. purge reg. valve w/ active diagn.-Test_Program_Bitregister
0​
IDE01922Vehicle distance driven
114547​
km
IDE01923Control module distance driven
112208059​
m
IDE01932High pressure pump injection volume
0​
mm³
IDE02115-ENG57549Adjustment requirements for basic setting-Bits 0-7
31​
IDE02116Exhaust gas temperature before catalytic converter
296.59​
°C
IDE02117Relative load value
22.29​
IDE02118Oxygen sensor bank 1 sensor 1: voltage
1.509​
V
IDE02119Long term adaptation of oxygen sensor control: bank 1
0​
IDE02211Brake pressure
0​
MPa
IDE02756-ENG57549Number of manual engine starts-Bits 0-7
0​
0​
0​
0​
IDE02757-ENG57549Number of automatic engine starts-Bits 0-7
0​
0​
0​
0​
IDE03108Result of test of oxygen sensors bank 1Test off
IDE03108-ENG127369Result of test of oxygen sensors bank 1-Test_Program_Channel 976
235​
IDE03262Adapt of angle sensor 1 f throttle valve
0.529​
V
IDE03263Adapt of angle sensor 2 f throttle valve
4.481​
V
IDE03264Adaptation of angle sensor 1 throttle valve: emerg. air gap
0.726​
V
IDE03265Adaptation of angle sensor 2 throttle valve: emerg. air gap
4.28​
V
IDE03362Requested transmission torque
1200​
Nm
IDE03393-ENG57549Selector lever position-Bits 0-7
8​
IDE03406Throttle valve position bank 2: normed
4.408​
V
IDE03692-ENG57549Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7
202​
IDE03693-ENG57549Monitoring status of additional Onboard Diagnosis-Bits 0-7
235​
IDE03694-ENG57549Result of test of fuel supply system partial throttle-Bits 0-7
8​
IDE03696-ENG57549Result test of oxygen sensor heater after catalytic converter-Bits 0-7
153​
IDE03697-ENG57549Result test of oxygen sensor heater before catalytic converter-Bits 0-7
5​
IDE03698-ENG57549Result of dynamic test of oxygen sensor before cat. converter-Bits 0-7
33​
IDE03699-ENG57549Result of test of oxygen sensor before catalytic converter-Bits 0-7
229​
IDE03700Status adaptation dew point endADP is OK
IDE03700-ENG127325Status adaptation dew point end-Test_Program_Channel 860
2​
IDE03703-ENG57549Result catalytic converter diagnosis test-Bits 0-7
1​
IDE03707-ENG57549Result of NPulse test-Bits 0-7
170​
IDE03708-ENG57549Result of test 2 of oxygen sensor before catalytic converter-Bits 0-7
1​
IDE03709Angle difference actual-specified camshaft adjuster
0.422​
IDE03710-ENG57549Result of camshaft diagnostic test-Bits 0-7
1​
IDE03711Mass flow through throttle valve
14.9​
kg/h
IDE03767Engine statusCOENG_RUNNING
IDE03767-ENG127290Engine status-Test_Program_Co Eng st COMPU VERB UBYTE
3​
IDE03795Camshaft adjustment: exhaust: bank 1: activation
6.252​
IDE03805Test of brake booster pump: resultTest off
IDE03805-ENG127323Test of brake booster pump: result-Test_Program_Channel 603
235​
IDE03806-ENG57549Oxygen sensor bank 1 sensor 1: status-Bits 0-7
7​
IDE03807-ENG57549Oxygen sensor bank 1 sensor 2: status-Bits 0-7
14​
IDE03813Test of secondary air system: resultTest off
IDE03813-ENG129327Test of secondary air system: result-Test_Program_Channel 239
235​
IDE03816Exhaust flap bank 1On
IDE03816-ENG129421Exhaust flap bank 1-Test_Program_Channel 825
135​
IDE03818-ENG99405Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120
156​
Ohm
IDE03818-ENG127296Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister
1​
IDE03819Heated oxygen sensor bank 1: sensor 2: activationHtg.aC.ON
IDE03819-ENG127297Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123
216​
IDE03820Heated oxygen sensor bank 1: sensor 1: resistance
301.72​
Ohm
IDE03821Heated oxygen sensor bank 1: sensor 1: activation
51.859​
IDE03830Status of adaptation of on-demand fuel pumpADP is OK
IDE03830-ENG129410Status of adaptation of on-demand fuel pump-Test_Program_Channel 1021
2​
IDE03832Oxygen sensor bank 1 sensor 2: response time
0​
s
IDE03833Oxygen sensor bank 2 sensor 2: response time
0​
s
IDE03836Result of O2 sensor aging test bank 1 after cat. conv.B1-S2 OK
IDE03836-ENG129323Result of O2 sensor aging test bank 1 after cat. conv.-Test_Program_Channel 2114
209​
IDE03953Oxygen control: adaptation value at partial load: bank 1
1​
IDE03968-ENG57549Camshaft adaptation results-Bits 0-7
1​
IDE04002Charge press. ctrl.BP_A act:100kPa
IDE04085Throttle valveTHR A cmd/rel:1/1 % / THR B cmd/rel:0/0 %
IDE04088Turbocharger 1: temperatureCompr. in/out---/--- °C / Compr. in/out368/--- °C
IDE04234Heat quantity f dew pt end before cat conv bank 1: modeled
3210.660083​
kJ
IDE04236Heat quantity f dew pt end behind fr cat conv bank 1: modeled
3210.779569​
kJ
IDE04238Heat quantity f dew pt end behind main cat conv bank 1: modeled
3724.416222​
kJ
IDE04240Counter start bef dew pt end f O2 sensor bef cat conv bank1
0​
IDE04242Counter start bef dew pt end f O2 sensor beh fr cat conv bank1
0​
IDE04244Count start bef dew pt end f O2 sensor beh main cat conv bank1
0​
IDE04324Long term adaptation of oxygen sensor control: bank 2
0​
IDE04410Intake manifold pressure: target value
434.45​
hPa
IDE04414Cat conv temp: modeled
-50​
°C
IDE04420Activation of secondary air systemAtmosphere/off
IDE04604Accelerator pedal travel
0​
IDE04651Torque request: A/C compressor
7.9​
Nm
IDE04654-ENG57549CAN status - engine control module-Bits 0-7
0​
IDE04655-ENG57549CAN status - transmission control module-Bits 0-7
0​
IDE04656-ENG57549CAN status - brake control module 1-Bits 0-7
0​
IDE04657-ENG57549CAN status - brake control module 2-Bits 0-7
0​
IDE04658-ENG57549CAN TimeOut meter - battery manager-Bits 0-7
0​
IDE04659-ENG57549CAN TimeOut meter - parking brake-Bits 0-7
0​
IDE04660-ENG57549CAN TimeOut meter - gateway-Bits 0-7
0​
IDE04661-ENG57549CAN TimeOut meter - steering angle-Bits 0-7
0​
IDE04662-ENG57549CAN TimeOut meter - transmission-Bits 0-7
0​
IDE04663-ENG57549Cruise control switch-off: irreversible-Bits 0-7
255​
IDE04664-ENG57549Cruise control switch-off: reversible-Bits 0-7
255​
IDE04665-ENG57549Cruise control switch-off: irreversible w. brake intervention-Bits 0-7
0​
IDE04670Crankshaft signal evaluation: statusGAPFOUND
IDE04670-ENG127292Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE
7​
IDE04685Setpoint generation interior torque
121.1​
Nm
IDE04689Starter control: Start interruption status
1​
IDE04691Calculated reducing transmission intervention torque
1200​
Nm
IDE04692Reducing desired torque intervention of ESP
50000​
Nm
IDE04693Increasing desired torque intervention of ESP
-50000​
Nm
IDE04695-ENG99946Immobilizer snapshot A-Sia Error Snap A00 00 00
IDE04696-ENG102592Immobilizer snapshot B-Sia Error Snap B00 00 00
IDE04706-ENG57549ACC interface activation condition-Bits 0-7
0​
IDE04707-ENG57549Status of reversible switch-off condition ACC_2-Bits 0-7
0​
IDE04708-ENG57549Status of reversible switch-off condition ACC_3-Bits 0-7
0​
IDE04709-ENG57549Status of ACC/CCS acceleration interface-Bits 0-7
0​
IDE04710-ENG57549ACC control module received status-Bits 0-7
4​
IDE04711-ENG57549Next status of ACC/CCS finite state machine-Bits 0-7
1​
IDE04712-ENG57549Active brake system error status-Bits 0-7
0​
IDE04713-ENG57549Active brake system status-Bits 0-7
0​
IDE04858Brake booster low pressure actual value
492.58​
hPa
IDE04889Target torque for combustion engine crankshaft level
-70.3​
Nm
IDE04914Transmission release for hybrid clutch closing
0​
IDE04976-ENG57549Oxygen sensor bank 3 sensor 1: status-Bits 0-7
7​
IDE04979-ENG57549Oxygen sensor bank 3 sensor 2: status-Bits 0-7
10​
IDE05128Intake air temperature in intake manifold bank 1
32.3​
°C
IDE05134ACC target acceleration
0​
m/s²
IDE05240-ENG57549Request for A/C compressor power reduction-Bits 0-7
0​
IDE05241-ENG57549A/C compressor release status-Bits 0-7
1​
IDE05260-ENG57549Gear position sensor: current value-Bits 0-7
0​
IDE05261-ENG57549Gear position sensor: last valid value-Bits 0-7
14​
IDE05262Gear position sensor: gear position validFalse result
IDE05262-ENG127289Gear position sensor: gear position valid-Test_Program_B TRUE UBYTE
0​
IDE05327Activation for electrical reserve coolant pump in HT circuit
0​
IDE05332-ENG57549Heat request from heater to thermal management-Bits 0-7
0​
IDE05436Engine operating conditionIdling
IDE05436-ENG127326Engine operating condition-Test_Program_Channel 87
5​
IDE05438Rear cat conv temp main cat conv model value
380.78​
°C
IDE05440ESI: Soot equiv 2 calculated from soot index
0​
IDE05441ESI: Wear equivalent 2 calculated from wear index
0​
IDE05442Roadway slope angle acceleration interface: calculated
0.0171​
rad
IDE05443Acceleration interface braking torque specified value
0​
Nm
IDE05444Air filling: specified value
22.24​
IDE05445Pressure before throttle valve of pressure sensor
1001.02​
hPa
IDE05448Long term adaptation of mixture form bank 2 at partial load
1​
IDE05449Oxygen sensor 2 bank 1 internal resistance limit value
2674​
Ohm
IDE05462Oxy sensor 1 bank 1 char curve offset
0.00089​
IDE05464Oxygen sensor 1 bank 1 fast offset adaptation counter
0​
IDE05466Oxy sensor 1 bank 1 offset spec value
0​
IDE05468Oxygen sensor 1 bank 1 ceramic temp
780.13​
°C
IDE05470Cat converter oxygen storage capacity
0​
mg
IDE05472Cat converter oxygen storage capacity ref standardized
0​
IDE05473Cat converter oxygen storage capacity ref standardized bank 2
0​
IDE05474Main cat converter OSC age correction factor
1​
IDE05476Cat converter oxygen storage capacity measured
0​
mg
IDE05478Exh mss flw bef main cat conv bank 1 filtered
16.2​
kg/h
IDE05482Tank venting adaptation factor
1.453​
IDE05483Timer for Reed-Switch Closed Check
0​
s
IDE05484Power steering pump desired actual moment for idling control
0​
Nm
IDE05485-ENG57549Irregular shutdown of the counter control mod-Bits 0-7
0​
IDE05486Current system statusSYC_DRIVE
IDE05486-ENG127293Current system status-Test_Program_Exe Con State 02 UBYTE
4​
IDE05487Coolant temperature linearized value
91.901​
°C
IDE05488Coolant temperature modeled value
53.3​
°C
IDE05489Coolant temperature max value
91.5​
°C
IDE05490Coolant temperature min value
66.8​
°C
IDE05491Intake air temperature max value
32.3​
°C
IDE05492Intake air temperature min value
21​
°C
IDE05593Secondary air injection sensor 1
1001.88​
hPa
IDE06006Idle speed specified value
590​
/min
IDE06015Time since term 15 OFF StartStop
61​
s
IDE06020Intake air temperature in intake manifold bank raw value
32.3​
°C
IDE06039Required RPM at idle speed
590​
/min
IDE06041-ENG57549PDTC drive cycle conditions status-Bits 0-7
37​
IDE06045-ENG57549Output DTM status-Bits 0-7
0​
IDE06048Drive time with activated exhaust malfunction indicator lamp
0​
s
IDE06049Pressure in brake booster: raw value
509.8​
hPa
IDE06050Exhaust temp on O2 sensor behind cat conv from model: filtered
380.97​
°C
IDE06053-ENG57549Test of mixture adaptation bank 1: status-Bits 0-7
129​
IDE06192Knock sensor: cylinder 2: voltage
0.679​
V
IDE06193Knock sensor: cylinder 3: voltage
0.405​
V
IDE06194Knock sensor: cylinder 4: voltage
0.513​
V
IDE06195Knock sensor: cylinder 1: voltage
0.425​
V
IDE06386Oil level: static measurement
0​
mm
IDE06387Oil level: last valid dynamic value
0​
mm
IDE06388Oil level: condition for static measurement fulfilled
0​
IDE06393Oil level: dynamic average value
131.068​
mm
IDE06425-ENG57549Roller test bench mode: functional-Bits 0-7
0​
IDE06435A/C compressor: refrigerant pressure
5400​
hPa
IDE06495Results of testing of crankcase ventilation successful
4​
IDE06496Results of testing of crankcase ventilation unsuccessful
0​
IDE06706-ENG57549ACC variants-Bits 0-7
1​
IDE06709-ENG57549ACC variants (coding)-Bits 0-7
3​
IDE06758Air mass since engine start
5.01​
kg
IDE06760Camshaft adaptation: exhaust: counter
1​
IDE06800A/C main switch status
1​
IDE06944A/C compressor: load current: act. value
0​
A
IDE06946-ENG57549Brake actuated status-Bits 0-7
0​
IDE07050-ENG57549Starter control: release conditions-Bits 0-7
2​
4​
IDE07051-ENG57549Engaged gear: raw signal-Bits 0-7
0​
IDE07233-ENG57549Bit string for status of oil level-Bits 0-7
0​
0​
IDE07234Status bid for valid static oil level
0​
IDE07235Status bid for dynamic oil level
0​
IDE07904-ENG57549Brake test switch status-Bits 0-7
0​
IDE07905-ENG57549Brake light switch status-Bits 0-7
0​
IDE07906-ENG57549Upper clutch switch: status-Bits 0-7
0​
ENG105150Air_mass_integral_for_thermostat_diagnosis_limit_value
5.72​
kg
ENG111031-ENG57549DFC_status_error_debounced_counter-Bits 0-7
0​
1​
ENG111033-ENG57549DFC_status_tested_counter-Bits 0-7
2​
3​
ENG111032-ENG57549DFC_status_untested_counter-Bits 0-7
237​
0​
ENG111034Engine_temperature_modelbased_substitute_value
67.5​
°C
ENG107045Intake_manifold_model_air_mass_flow_filtered_value
15.3​
kg/h
ENG107236Knock_sensor_cylinder_5_voltage
0.767​
V
ENG107237Knock_sensor_cylinder_6_voltage
0.518​
V
ENG107964Oxygen_sensor_bank_2_sensor_1_voltage
1.499​
V
Elapsed Time: 00:30
IDE00194 is a specified value. In other words that's what the ECU is shooting for or trying to achieve. It is not a measured value.
Bentley
South Wales, UK
C?ID=263294
Ahhhh , thank you Uwe, Any suggestions ?.
What value should I be looking for or where should I be looking for the radiator outlet temp?
Can you see what might be keeping the radiator fan on or it likely to be the fan controller module?
Cheers, Paul.
The P0480 fault does make me think fan control module, or something related to it:
But I'm not familiar enough with the particulars of that car to offer any more specific guidance.
Bentley
South Wales, UK
C?ID=263294
Thanks UWE,
The constant 105 was throwing me. Mainly because of the lack of being able to see another actual reading. Wiring all seemed good, then getting fault codes when disconnecting and bridging the sensor - but still 105 . Got the gear but no idea. LOL.
Do you know if there Is a reading for the Radiator outlet temperature?
Cheers.
I don't see a measuring value for that in the data for either of your two ECUs.
