Hi
I got a 2011 S5 , it was sitting in a dealer warehouse since 2014 , I could start the engine and mechanically everything works fine .
driver side windows are not working they just click that comes from the door module (passenger front rear are ok)
dealer replaced few modules component protection is active on some .
my main issue is the driver side window and convertible roof (that I thin it is due windows) and remote
Thank you
Thank you
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 20.4.2(x64) Data version: 20200730 DS317.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Friday,16,October,2020,21:37:27:33305
VIN: xxxx License Plate: S52
Mileage: 12570km-7810mi Repair Order:
Chassis Type: FH-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 26 36 42 46 52 53 55 56
5F 62 6C 72
VIN: WAUCGAFH4BN017754 Mileage: 12570km-7810miles
06-Seat Mem. Pass -- Status: Cannot be reached 1100
10-Park/Steer Assist -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Cannot be reached 1100
5F-Information Electr. -- Status: Cannot be reached 1100
Self-Diagnosis Log
Page 2
VIN: WAUCGAFH4BN017754 License Plate: S52
Address 01: Engine (J623-CCBA) Labels:| 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 B HW: 8K0 907 551 A
Component: 3.0T SIMOS84 H07 0002
Revision: --------
Coding: 011C000A240F0128
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_ECM30TFS0218K0907551B 001002
ROD: EV_ECM30TFS0218K0907551B.rod
VCID: 3039ED8AAAAB721BE23-8064
6201 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:22
Engine speed: 682.00 /min
Normed load value: 8.6 %
Coolant temperature: 96 °C
Intake air temperature: 39 °C
Voltage terminal 30: 12.491 V
Engine speed: actual: 672 /min
MAF_ENVD: 87.15294 mg/stroke
Coolant temperature (unfiltered): 96.0 °C
Engine: operating status: IS
Engine load: 8.593750 %
Vehicle speed: actual: 0 km/h
6062 - No Communications with Parking Brake Control Module
U0128 00 [039] - -
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:22
Self-Diagnosis Log
Page 3
Voltage terminal 30: 12.898 V
T_AST_ENVD: 1002.30 s
Gear: 0
Battery voltage: 12.492188 V
Readiness: 1110 1101
Part No SW: 8K1 927 156 K HW: 0B5 927 156 F
Component: 0B5 30TFSINAR H10 0010
Revision: --H10--- Serial number: 0000000329
ASAM Dataset: EV_TCMDL501 A02087
ROD: EV_TCMDL501.rod
VCID: 3D27C4BE6DF98F73795-8068
8002 - No Communications with Parking Brake Control Module
U0128 00 [039] - -
Reset counter: 40
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:22
Engine speed: 683 /min
Transmission input speed: 683 /min
Engine torque: 4 Nm
Transmission fluid temperature: 50 °C
Accelerator position: 0.0 %
Clutch status: Beide Kupplungen offen
Self-Diagnosis Log
Page 4
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0060
Coding: 290D18
Shop #: WSC 02391 823 56573
VCID: 025D77425407308B447-8056
Part No SW: 8K0 907 064 CF HW: 8K0 907 064 CF
Component: BCM2 2.0 H05 0435
Coding: 090300
Shop #: WSC 02399 823 56573
VCID: 76B51B9208CF1C2B78F-8022
Subsystem 1 - Part No SW: 8K0 959 754 AB HW: 8K0 959 754 AB
Serial number: 0812000195551014
Component: J764 ELV MLB H37 0042
Serial number: 2311000049675005
Address 06: Seat Mem. Pass
Self-Diagnosis Log
Page 5
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AL HW: 8T1 820 043 AL
Component: KLIMA 3 ZONEN H08 0180
Revision: C3000000 Serial number: 01130720100142
Coding: 6613200E
VCID: 7BA30AA633ED4143071-802E
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
Temperature: 23.0°C
Voltage: 13.30 V
Output: 0 W
Output: 0 W
Temperature: 22.0°C
00461 - Control Module for Seat Memory; Passenger (J521)
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
Self-Diagnosis Log
Page 6
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:26
03037 - Rear Temperature Selection Potentiometer (G538)
007 - Short to Ground
Fault Status: 01100111
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:19
Voltage: 13.00 V
Voltage: 5.00 V
Self-Diagnosis Log
Page 7
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000839654
Coding: 26001091063CAF010000080000003D3D0F1C528802010161000003
VCID: 3C21C9BA7663867B4EB-8068
Subsystem 1 - Part No SW: 8F1 955 119 HW: 8K1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 240311 H07 0021
Serial number: SWF11030245238
Coding: 00FD11
Component: RLS H04 0003
Serial number: 11345163
Coding: 02562A
Subsystem 3 - Part No SW: 8K0 941 531 BA HW: 8K0 941 531 BA
Component: E1 - LDS H03 0031
Serial number: 00000000000703110965
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:00
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:00
Self-Diagnosis Log
Page 8
Address 10: Park/Steer Assist
Self-Diagnosis Log
Page 9
Address 15: Airbags (J234) Labels:| 8F0-959-655.clb
Part No SW: 8F0 959 655 A HW: 8F0 959 655 A
Component: AirbagVW-AU10 H10 0430
Serial number: 003A5D065YND
Coding: 303737353631303030304A55304C38463053
Shop #: WSC 02135 785 00200
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaAU10SMEAU485.rod
VCID: 3635DB9248CF5C2BB8F-8062
Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
Component: BF-Gewichtss. H02 0060
Serial number: 5810000R10000009Q3
Serial number: 6334MSME5C752502B
Serial number: 6344MSME5E0151257
Serial number: 6352QSME0B062574C
Serial number: 6362QSME3E082146G
Serial number: 63832SME7B1D2B56D
9440026 - Driver's side; side-airbag igniter
B100B 1A [137] - Resistance Too Low
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:21
9440795 - Front Passenger's Knee Airbag Igniter
B100E 1B [137] - Resistance Too High
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:22
Self-Diagnosis Log
Page 10
9443859 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open or Short to Plus
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:20
13697280 - Component Protection
U1101 00 [137] - Active
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:20
Self-Diagnosis Log
Page 11
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KCL000FG
Coding: 000036
VCID: 3D27C4BE6D798F73795-8068
Component: E221 - MFL H02 0010
014 - Defective
Fault Status: 01101110
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
(no units): 44.0
Text: 2C8CFFFFFFFF00C0FF
Temperature: -255°C
Raw, Index/Key Err.: 255 255 000
Text: 3EA2FFFFFFFFFFFFFF
Angle: 29131.200°
Raw, Index/Key Err.: 255 255 255
Raw, Index/Key Err.: 255 255 118
Self-Diagnosis Log
Page 12
Part No SW: 8T0 920 983 D HW: 8T0 920 983 D
Component: KOMBIINSTR. H41 0258
Revision: 00000000 Serial number: EI127EG3C
Coding: 8B1719000300D705020000
VCID: 3FDBBEB667759D636B9-806A
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:19
Self-Diagnosis Log
Page 13
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial number: 5600E1130805CE
Coding: 00C303
VCID: 035372464B1D39834F1-8056
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
Bin. Bits: 11111
Voltage: 12.80 V
Count: 6
01327 - Control Module for Parking Aid (J446)
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:19
Bin. Bits: 11111
Voltage: 12.70 V
Count: 6
Bin. Bits: 00000
Time: 25.40 s
Reset counter: 82
Self-Diagnosis Log
Page 14
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:23
Bin. Bits: 11111
Voltage: 12.80 V
Count: 6
Bin. Bits: 00000
Time: 25.40 s
Address 26: Auto Roof (J256) Labels:* 8F0-959-255.clb
Part No SW: 8F0 959 255 HW: 8F0 959 255
Component: VSG-AUDI-B8 H11 0190
Coding: 030000
ASAM Dataset: EV_ElectRoofContr 001008
ROD: EV_ElectRoofContr.rod
VCID: 71BF288E61213B13ADD-8024
Self-Diagnosis Log
Page 15
Part No SW: 8T0 959 760 D HW: 8T0 959 760 D
Component: MEM-FS H10 0074
Revision: AA000000 Serial number: 00001002037543
Coding: C8197B250D2400001000
VCID: 44D1B15A0E93FEBB36B-8010
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
03332 - Motor for Height Adjustment
Fault Status: 01100101
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:22
Reset counter: 82
Self-Diagnosis Log
Friday,16,October,2020,21:37:28:33305
Page 16
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:22
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1501
Coding: 011C43724008332C03
VCID: 53F38206FBFD6903BF1-8006
00532 - Supply Voltage B+
Fault Status: 01101011
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:17
Self-Diagnosis Log
Page 17
Revision: 00002001 Serial number: 0146533075
Coding: 010602BA00FA442080B0033200000000
Subsystem 1 - Part No SW: 8F0 959 719 B HW: 8F0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000377857
00166 - Access/Start Authorization Switch (E415)
008 - Implausible Signal - MIL ON
Fault Status: 11101000
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
01134 - Alarm Horn (H12)
014 - Defective
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:21
Self-Diagnosis Log
Page 18
00218 - Humidity Sensor (G355)
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:22
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1501
Coding: 011C43324008332C03
VCID: 52FD8702C4E7600BB47-8006
Address 53: Parking Brake
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
VCID: 392FD0AE7551B35355D-806C
Address 56: Radio
Self-Diagnosis Log
Page 19
Part No SW: 8T0 959 795 L HW: 8T0 959 795 C
Component: TSG HL H07 1501
Coding: 010C03324008372C03
VCID: 54F1811AFEF36E3BA6B-8000
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
Self-Diagnosis Log
Page 20
Part No SW: 8F0 907 441 HW: 4L0 907 441 B
Revision: --H04--- Serial number: 525PA8-J06B0AY
Coding: 1001009
Shop #: WSC 02391 785 00200
VCID: 678B46D65365F5A3F39-8032
03110 - Active Steering Control Module (J792)
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:17
Term 15 On
Reverse OFF
Count: 3
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:17
Term 15 On
Reverse OFF
Count: 3
Self-Diagnosis Log
Page 21
Component: TSG HR H07 1501
End----------(Elapsed Time: 01:39, VBatt start/end: 12.8V/13.0V)-----------
