Audi S5 B8 Flooded
majixr
C?ID=325920
Hi
I got a 2011 S5 , it was sitting in a dealer warehouse since 2014 , I could start the engine and mechanically everything works fine .
driver side windows are not working they just click that comes from the door module (passenger front rear are ok)
dealer replaced few modules component protection is active on some .
my main issue is the driver side window and convertible roof (that I thin it is due windows) and remote
Thank you
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 20.4.2(x64) Data version: 20200730 DS317.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Friday,16,October,2020,21:37:27:33305
VIN: xxxx                    License Plate: S52
Mileage: 12570km-7810mi Repair Order:
Chassis Type: FH-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 26 36 42 46 52 53 55 56
5F 62 6C 72
VIN: WAUCGAFH4BN017754 Mileage: 12570km-7810miles
06-Seat Mem. Pass -- Status: Cannot be reached 1100
10-Park/Steer Assist -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Cannot be reached 1100
5F-Information Electr. -- Status: Cannot be reached 1100
Self-Diagnosis Log
Page 2
VIN: WAUCGAFH4BN017754 License Plate: S52
Address 01: Engine (J623-CCBA) Labels:| 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 B HW: 8K0 907 551 A
Component: 3.0T SIMOS84 H07 0002
Revision: --------
Coding: 011C000A240F0128
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_ECM30TFS0218K0907551B 001002
ROD: EV_ECM30TFS0218K0907551B.rod
VCID: 3039ED8AAAAB721BE23-8064
6201 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:22
Engine speed: 682.00 /min
Normed load value: 8.6 %
Coolant temperature: 96 °C
Intake air temperature: 39 °C
Voltage terminal 30: 12.491 V
Engine speed: actual: 672 /min
MAF_ENVD: 87.15294 mg/stroke
Coolant temperature (unfiltered): 96.0 °C
Engine: operating status: IS
Engine load: 8.593750 %
Vehicle speed: actual: 0 km/h
6062 - No Communications with Parking Brake Control Module
U0128 00 [039] - -
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:22
Self-Diagnosis Log
Page 3
Voltage terminal 30: 12.898 V
T_AST_ENVD: 1002.30 s
Gear: 0
Battery voltage: 12.492188 V
Readiness: 1110 1101
Part No SW: 8K1 927 156 K HW: 0B5 927 156 F
Component: 0B5 30TFSINAR H10 0010
Revision: --H10--- Serial number: 0000000329
ASAM Dataset: EV_TCMDL501 A02087
ROD: EV_TCMDL501.rod
VCID: 3D27C4BE6DF98F73795-8068
8002 - No Communications with Parking Brake Control Module
U0128 00 [039] - -
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:22
Engine speed: 683 /min
Transmission input speed: 683 /min
Engine torque: 4 Nm
Transmission fluid temperature: 50 °C
Accelerator position: 0.0 %
Clutch status: Beide Kupplungen offen
Self-Diagnosis Log
Page 4
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0060
Coding: 290D18
Shop #: WSC 02391 823 56573
VCID: 025D77425407308B447-8056
Part No SW: 8K0 907 064 CF HW: 8K0 907 064 CF
Component: BCM2 2.0 H05 0435
Coding: 090300
Shop #: WSC 02399 823 56573
VCID: 76B51B9208CF1C2B78F-8022
Subsystem 1 - Part No SW: 8K0 959 754 AB HW: 8K0 959 754 AB
Serial number: 0812000195551014
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 2311000049675005
Address 06: Seat Mem. Pass
Self-Diagnosis Log
Page 5
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AL HW: 8T1 820 043 AL
Revision: C3000000 Serial number: 01130720100142
Coding: 6613200E
VCID: 7BA30AA633ED4143071-802E
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
Temperature: 23.0°C
Voltage: 13.30 V
Output: 0 W
Output: 0 W
Temperature: 22.0°C
00461 - Control Module for Seat Memory; Passenger (J521)
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
Self-Diagnosis Log
Page 6
Fault Status: 01101000
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:26
03037 - Rear Temperature Selection Potentiometer (G538)
007 - Short to Ground
Fault Status: 01100111
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:19
Voltage: 13.00 V
Voltage: 5.00 V
Self-Diagnosis Log
Page 7
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000839654
Coding: 26001091063CAF010000080000003D3D0F1C528802010161000003
VCID: 3C21C9BA7663867B4EB-8068
Subsystem 1 - Part No SW: 8F1 955 119 HW: 8K1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 240311 H07 0021
Serial number: SWF11030245238
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11345163
Coding: 02562A
Subsystem 3 - Part No SW: 8K0 941 531 BA HW: 8K0 941 531 BA
Component: E1 - LDS H03 0031
Serial number: 00000000000703110965
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:00
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:00
Self-Diagnosis Log
Page 8
Address 10: Park/Steer Assist
Self-Diagnosis Log
Page 9
Address 15: Airbags (J234) Labels:| 8F0-959-655.clb
Part No SW: 8F0 959 655 A HW: 8F0 959 655 A
Component: AirbagVW-AU10 H10 0430
Serial number: 003A5D065YND
Coding: 303737353631303030304A55304C38463053
Shop #: WSC 02135 785 00200
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaAU10SMEAU485.rod
VCID: 3635DB9248CF5C2BB8F-8062
Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
Component: BF-Gewichtss. H02 0060
Serial number: 5810000R10000009Q3
Serial number: 6334MSME5C752502B
Serial number: 6344MSME5E0151257
Serial number: 6352QSME0B062574C
Serial number: 6362QSME3E082146G
Serial number: 63832SME7B1D2B56D
9440026 - Driver's side; side-airbag igniter
B100B 1A [137] - Resistance Too Low
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:21
9440795 - Front Passenger's Knee Airbag Igniter
B100E 1B [137] - Resistance Too High
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:22
Self-Diagnosis Log
Page 10
9443859 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open or Short to Plus
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:20
13697280 - Component Protection
U1101 00 [137] - Active
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:20
Self-Diagnosis Log
Page 11
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KCL000FG
Coding: 000036
VCID: 3D27C4BE6D798F73795-8068
Component: E221 - MFL H02 0010
014 - Defective
Fault Status: 01101110
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
(no units): 44.0
Text: 2C8CFFFFFFFF00C0FF
Temperature: -255°C
Raw, Index/Key Err.: 255 255 000
Text: 3EA2FFFFFFFFFFFFFF
Angle: 29131.200°
Raw, Index/Key Err.: 255 255 255
Raw, Index/Key Err.: 255 255 118
Self-Diagnosis Log
Page 12
Part No SW: 8T0 920 983 D HW: 8T0 920 983 D
Component: KOMBIINSTR. H41 0258
Revision: 00000000 Serial number: EI127EG3C
Coding: 8B1719000300D705020000
VCID: 3FDBBEB667759D636B9-806A
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:19
Self-Diagnosis Log
Page 13
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial number: 5600E1130805CE
Coding: 00C303
VCID: 035372464B1D39834F1-8056
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
Bin. Bits: 11111
Voltage: 12.80 V
Count: 6
01327 - Control Module for Parking Aid (J446)
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:19
Bin. Bits: 11111
Voltage: 12.70 V
Count: 6
Bin. Bits: 00000
Time: 25.40 s
Reset counter: 82
Self-Diagnosis Log
Page 14
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:23
Bin. Bits: 11111
Voltage: 12.80 V
Count: 6
Bin. Bits: 00000
Time: 25.40 s
Address 26: Auto Roof (J256) Labels:* 8F0-959-255.clb
Part No SW: 8F0 959 255 HW: 8F0 959 255
Component: VSG-AUDI-B8 H11 0190
Coding: 030000
ASAM Dataset: EV_ElectRoofContr 001008
ROD: EV_ElectRoofContr.rod
VCID: 71BF288E61213B13ADD-8024
Self-Diagnosis Log
Page 15
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 D HW: 8T0 959 760 D
Component: MEM-FS H10 0074
Revision: AA000000 Serial number: 00001002037543
Coding: C8197B250D2400001000
VCID: 44D1B15A0E93FEBB36B-8010
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
03332 - Motor for Height Adjustment
Fault Status: 01100101
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:22
Reset counter: 82
Self-Diagnosis Log
Friday,16,October,2020,21:37:28:33305
Page 16
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:22
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1501
Coding: 011C43724008332C03
VCID: 53F38206FBFD6903BF1-8006
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:17
Self-Diagnosis Log
Page 17
Revision: 00002001 Serial number: 0146533075
Coding: 010602BA00FA442080B0033200000000
Subsystem 1 - Part No SW: 8F0 959 719 B HW: 8F0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000377857
00166 - Access/Start Authorization Switch (E415)
008 - Implausible Signal - MIL ON
Fault Status: 11101000
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
014 - Defective
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:21
Self-Diagnosis Log
Page 18
00218 - Humidity Sensor (G355)
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:22
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1501
Coding: 011C43324008332C03
VCID: 52FD8702C4E7600BB47-8006
Address 53: Parking Brake
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
Coding: 0000002
VCID: 392FD0AE7551B35355D-806C
Address 56: Radio
Self-Diagnosis Log
Page 19
Part No SW: 8T0 959 795 L HW: 8T0 959 795 C
Component: TSG HL H07 1501
Coding: 010C03324008372C03
VCID: 54F1811AFEF36E3BA6B-8000
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:18
Self-Diagnosis Log
Page 20
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8F0 907 441 HW: 4L0 907 441 B
Revision: --H04--- Serial number: 525PA8-J06B0AY
Coding: 1001009
Shop #: WSC 02391 785 00200
VCID: 678B46D65365F5A3F39-8032
03110 - Active Steering Control Module (J792)
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:17
Reverse OFF
Count: 3
Reset counter: 82
Mileage: 12570 km
Date: 2010.01.22
Time: 00:17:17
Reverse OFF
Count: 3
Self-Diagnosis Log
Page 21
Component: TSG HR H07 1501
End----------(Elapsed Time: 01:39, VBatt start/end: 12.8V/13.0V)-----------
DrPeter
16.4905° S, 151.7375° W
Flood cars can be a like owning a boat, both are wet places where can put lots of money!
Also they can leave you stranded, at least with a car, your still on dry land when you break down :p
You may want to start with pulling the seats, carpet/insulation, trim panels and start looking for evidence of the 'high tide' water marks.
Experience has told me that the damage does not stop at the high water mark, you can have concerns anywhere due to the amount of water and residue moisture.
Also this gives you an opportunity to find any hidden places where wiring and connectors along with any controllers that may have water damage/corrosion/etc..
This is a good website to find more about these types of flood/auction vehicles: Audi S5 Premium Plus 2011 Gray 3.0L
The list of controller's that "Cannot be reached" in the Gateway list should be addressed first!
Many of these controllers live on or near the floor of the vehicle.
06-Seat Mem. Pass​
10-Park/Steer Assist​
53-Parking Brake​
56-Radio​
5F-Information Electr.​
You are going to want to invest (if you have not already done so) in the Official Factory Repair Information, this information will provide you with wiring diagrams, component locations and the information needed to correctly disassemble the vehicle as needed.
Hope this helps,
drpeter
majixr
C?ID=325920
Hello DrPeter
thank you for reply , yes I know I rebuilt an A7 before but I did not have much issue after repair , I got this car about $6k and the mileage is around 10-15k , I can buy a A5 and use it as part donor , my main concern is the roof if I can make sure it is working I can spend more time to fix other issues ,
I use that website a lot and love it but that is the actual auction listing I bought it from . I did some research and previous owner was a dealer they had it since 2014 and finally gave up !
what this code means?
( it has power and relay click when I use the switch)
I could not find any code on battery to adapt is it important at this level ? (it is a continental brand ) ,
I try to check the modules under carpet I checked the oders in trunk most of them been replaced ,
thank you
majixr
C?ID=325920
I have power on fuse box for door module but not on the door socket , is there any relay or module between fuse and door socket that control the positive door wire? I did not find anything on diagram
siLc
Tallinn, Estonia
C?ID=330192
Could you do us a favor? The current sheet-fed printer style of autoscan is rather hard to read - please post the usual style of autoscan. There should be a guide somewhere here about this.
The door modules are on constant battery power, so they should have power while ignition off. Check the appropriate fuses (2 of them for each door) using WD.
majixr
C?ID=325920
FYI I found the issue with driver side windows (front rear) , Audi did a stupid wiring design , the windows wire from driver side fuse box goes back under rear seat , inside the duct they connect the driver side rear windows wire to the fuse box wire and use another wire to bring it back to the front door (they could simply just run a wire from back to fuse box and use a separate fuse and connect the other one directly to front door) 3 wires were inside the duct with just a electrical tape and were melted !
I think I fixed the wiring issues for now and windows are functional but the roof is still not working
majixr
C?ID=325920
I think the roof wont work because of the locking mechanism (there is no fault code for roof) , my FOB can unlock the doors but it wont lock it or open the trunk (door switches cannot lock either)
any idea? J393?
