Code after PCV Valve repalcement
JonMon27
C?ID=364527
I had this code pop up after PCV valve and other hoses were changed. Can not tell if it is sensor issue or something else, I figured it wouldnt be sensor since its on both sides.
Thursday,29,October,2020,11:26:46:32728
VIN: WAUHGAFC8FN028305   License Plate:
Mileage: 218846km-135984mi   Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 3C 42 44 46 47 52
          53 55 56 5F 62 6C 72 82 8F 90
VIN: WAUHGAFC8FN028305   Mileage: 218846km-135984miles
Address 01: Engine (J623-CTUA)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551 J    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0004
   Revision: --H07---
   Coding: 0A2A0034052601060000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551J 001004
   ROD: EV_ECM30TFS0214G0907551J.rod
   VCID: 303911F60AA4AE0BE23-8064
6427 - Intake Manifold Flap; Bank 1
          P2006 00 [237] - Stuck Closed
                    Mileage: 218813 km
                    Date: 2020.10.28
                    Time: 16:52:21
                    Engine speed: 2154.00 /min
                    Normed load value: 56.9 %
                    Vehicle speed: 33 km/h
                    Coolant temperature: 97 °C
                    Intake air temperature: 65 °C
                    Voltage terminal 30: 13.609 V
                    Engine speed: actual: 1984 /min
                    MAF_ENVD: 397.63528 mg/stroke
                    Coolant temperature (unfiltered): 65.25 °C
                    Engine: operating status: PL
                    V_PORT_1_ENVD: 0.68359 V
                    Vehicle speed: actual: 30 km/h
6428 - Intake Manifold Flap; Bank 2
          P2007 00 [237] - Stuck Closed
                    Mileage: 218813 km
                    Date: 2020.10.28
                    Time: 16:52:21
                    V_PORT_2_ENVD: 0.80078 V
Readiness: 0000 0100
   Part No SW: 4G1 927 158 A    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H19 1006
   Revision: --H19---
   Coding: 000002
   VCID: 2D0708821D96C3E3C95-8078
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Coding: 44A7970122E5E9804B00
   ASAM Dataset: EV_ESPPremiAU57X 004039
   VCID: 3A2D33DEDCD8645B5C7-806E
   Part No SW: 4H0 907 064 FR    HW: 4H0 907 064 ER
   Component: BCM2 2.0      H36 0551
   Coding: 0DA82046000000000000
   VCID: 7EA5FFCE80F0887B20F-802A
   Serial number: 3214000109154003
   Part No SW: 4G0 820 043 AN    HW: 4G0 820 043 AN
   Component: KLIMA 4 ZONEN H14 0096
   Serial number: 10101400040430
   Coding: 6601207A59
   ASAM Dataset: EV_AirCondiComfoUDS 004003
   ROD: EV_AirCondiComfoUDS_004.rod
   VCID: 6B83C69AE3020DD3971-803E
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001940217
   Coding: 09072091073C9FE081000884A0003800CF9CD208A60802258001085C7B00
   VCID: 6FBBD28AD79AF1F3BB9-803A
   Component: WWS57X 140923  H37 0080
   Serial number:         140926220152
   Coding: 0045F7
   Serial number: 23305602
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AN    HW: 4G0 941 531 AN
   Component: E1 - LDS  H07 0044
   Serial number: 10 10 2014  00001012
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z009D7FB0
   Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0116263591
   Coding: 853000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000010101400010344
   Coding: 110000
   Subsystem 7 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000003101400010252
   Coding: 110000
   Subsystem 8 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA109324000009531512
   Coding: 020300
   Subsystem 9 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 54298F47000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061428301959
   Coding: A8C306
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71BFD4F2C12EE703ADD-8024
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G0001GR3N
   Coding: 303331343131303134354A55304C34473053
   VCID: 34311DE6FEBC922B86B-8060
   Serial number: 6940000Y14000188UC0V
   Serial number: 3575HRB405D2R8PE1OI1
   Serial number: 3585HRB40592OJSO5GEB
   Serial number: 3515JRB405731BAK58N$
   Serial number: 3525JRB405P31BAKM0IJ
   Serial number: 3554VRB400S52QV49PMR
   Serial number: 3564VRB400S52QV4DHMO
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20141013000558
   Coding: 000034
   VCID: 303911F60A24AE0BE23-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Part No SW: 4G8 920 984 K    HW: 4G8 920 984 K
   Component: TBenUsa       H58 0622
   Revision: 29460237    Serial number: 658031014596001
   Coding: 0BE609040B41D705020000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 3E253FCEC0F0487B60F-806A
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001593792
   Coding: 00CD073000
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 72BDDBFEC428DC1B547-8026
   Serial number: 4462254703
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 140728000000000005EA
   Part No SW: 4G0 919 158 M    HW: 4G0 919 158 M
   Component: KLIMA FOND    H08 0096
   Serial number: 13101400041130
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
   VCID: 392F2CD2D9DE6F4355D-806C
   Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
   Revision: AA000000    Serial number: 00000119630086
   Coding: C0581B008F006001000001010101102030303232203232
   VCID: 382929D6E254764BAA3-806C
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H03 0056
   Revision: --------    Serial number: EJ1BPA720CZHVC
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 33331EFAFBB295139F1-8066
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH05 0060
   Revision: 00H05000    Serial number: 6PZ 010 287-03
   Coding: 0000001
   VCID: 303911F60624AE0BE23-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H05 0060
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F14.10.1400H05000AMS15618ÿ
   Subsystem 4 - Serial number: S15618ÿ
   Component: TSG FA        H03 0507
   Coding: 011F17005E00628002000012
   VCID: 47CB5A2A9FAA09B3D39-8012
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0005061713
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0349017827
   Coding: 0106023A00FA418580B0088402070E470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000248754
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO33185352
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00009671957
   Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93350891
   Revision: CJ007001    Serial number: 00000000144697
   Coding: 030000
   VCID: 1D67D8426DB63363595-8048
   Component: TSG BF        H03 0507
   Coding: 011F17005E00628002000002
   VCID: 46D5572E98A010BB28F-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001224328
   ROD: EV_ParkiBrake_VW51.rod
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 141013-0002-176
   Coding: 1221A6601002A500
   ROD: EV_HeadlRegulBasic.rod
   Revision: AB001007    Serial number: 156JB0E8079378
   Coding: 020007010000000001
   VCID: 2411EDA64EDC02AB16B-8070
   Part No SW: 4G0 035 746 G    HW: 4G0 035 746 E
   Component: H-BNT-NA      H41 0810
   Revision: --------    Serial number: 194J40E7618542
   Coding: 050200000003E5EF55128B3E00000003100001000000000000
   VCID: 2B03069A2302CDD3D71-807E
   Subsystem 1 - Part No: 8R0 060 884 CA
   Component: NAR 2014  1002
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDED005QKA4
   Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Component: E380 BDT C7  H11 0204
   Serial number: 90349NJD000Q3
   Component: CD-Database  5950
   Component: TSG HL        H03 0507
   Coding: 010F17004000628002000002
   VCID: 49CF5C1289BEFFC3C5D-801C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H08---    Serial number: 525 PA8J49GAYX
   Coding: 1080004
   VCID: 2615F7AE34E0F0BB08F-8072
   Component: TSG HR        H03 0507
Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 K    HW: 4G0 919 604 K
   Component: HeadUpDisplay 006 0203
   Coding: A20000
   ASAM Dataset: EV_HUDContiC7 001023
   ROD: EV_HUDContiC7.rod
   Coding: 0006E008031F0300070308014244CA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 313F14F201AEA703EDD-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   VCID: 323D1BFE04A89C1B947-8066
End----------(Elapsed Time: 02:37, VBatt start/end: 12.3V/12.2V)-----------
coconutaudi
Kuala Lumpur, Malaysia
C?ID=345326
Maybe while reinstalling the intake manifolds which houses the flaps on both banks, the flaps stuck to the dividers below them.
