Error 22 when coding Instrument module
jf83
C?ID=404585
Hi guys,
I just changed the coding in my instrument module to allow for bigger wheels, when I changed from the standard version 3 to version 8 it accepted the new coding without issue, now when I try to change it back again I always get the error 22 message “Coding rejected Error 22 Conditions not correct or request sequence error”, any ideas what I’m doing that isn’t allowing me to make the changes? I’m always making changes with the engine off and ignition on.
Further to the above if I change anything else for example the seat belt warning it accepts the change, it just seems to be blocking me from changing the wheel circumference more than once.
I also tried on another van and again it only allows one change and doesn't allow any further changes after that, could it possibly be that only one change is allowed?
Any suggestions gratefully accepted.
Thanks,
JF
Thursday,29,October,2020,07:57:20:25128
VCDS Version: 20.4.2.0 (x64) HEX-NET CB: 0.4513.4
VIN: WV1ZZZ7HZLH081705   License Plate:
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 44 5F 6D 75 BB BC BE BF
VIN: WV1ZZZ7HZLH081705   Mileage: 1667km-1035miles
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 SA HW: 04L 907 445 M
Component: R4 2.0l TDI H01 9697
Revision: 23301001
Coding: 002540144364050900000000000000000000000000000000
Shop #: WSC 00012 790 00047
ASAM Dataset: EV_ECM20TDI03004L906056SA 004004
ROD: EV_ECM20TDI03004L906056QE.rod
   VCID: 7EB0D758E1955D7661-802A
Readiness: N/A
Part No SW: 0BT 300 046 N HW: 0GC 927 711 H
Component: GSG DQ500 H06 3107
Revision: 00H06V11
ROD: EV_TCMDQ500021_VN46.rod
   VCID: 41CA6CA4D0EBE28E5C-8014
Part No SW: 7LA 614 517 A HW: 7LA 614 517
Component: ESC_high H01 0700
Serial number: 08508212200701
Coding: 10552452C84FE686085B24A4136B6706393720B8
ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
ROD: EV_Brake1ESP90iBOSCHVN46X_002.rod
   VCID: 3D321054AC13866E38-8068
Address 08: Auto HVAC (J301) Labels:* None
Part No SW: 7LA 907 426 HW: 7LA 907 426
Component: AC Manuell H01 0502
Coding: B03110000810000001000800504001050000000000010000800000000000
ASAM Dataset: EV_AirCondiBHTCT6PA 001004
ROD: EV_AirCondiBHTCT6PA.rod
   VCID: 55E2A8F434637E2E10-8000
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 2Q5 937 090 HW: 2Q5 937 090
Component: BCM T6PA Std+ H10 0936
Serial number: 01102018900457
Shop #: WSC 00012 790 00164
ASAM Dataset: EV_BCMA0 205001
ROD: EV_BCMA0_205.rod
   VCID: 74A4F570DFD9072607-8020
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 050 0105
Serial number: SAY20M06D25H07M20S12
   Coding: 02B8EE
   Drivers Door Control Module:
Subsystem 2 - Part No SW: 7L1 959 405 B HW: 7L1 959 163 B
Component: FHSG_DRV 001 0002
Serial number: 00000000000039764111
   Coding: 1F0007
Subsystem 3 - Part No SW: 7L1 959 406 B HW: 7L1 959 164 B
Component: FHSG_PSG 001 0002
Serial number: 00000000000038916411
   Coding: 050007
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
   Serial number: 000000000ZY2015522G9
   Serial number: 00000000000048432732
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000150058320183
Coding: 0459051811
ASAM Dataset: EV_EPHVA18AU3700000 009046
ROD: EV_EPHVA18AU3700000_009_VW27.rod
   VCID: 50EC59E00B811B06C3-8004
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 3200670201FF8748949C815580508700000000000000000004
Shop #: WSC 00012 790 00026
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 43C666ACCAF7F09E4E-8016
Address 15: Airbags (J234) Labels:* None
Part No SW: 2Q0 959 655 AD HW: 2Q0 959 655 AD
Component: VW22Airbag 016 0506
Revision: --------
Coding: 8800C00000000000800000CF008C40000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
ROD: EV_AirbaVW22BPAVW27X_VW27.rod
   VCID: 7F4E2A5CE69F547E6A-802A
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 7LA 920 941 HW: 7LA 920 941
Component: KOMBI 205 6750
Coding: 27A40A0F2580260001882A011401000000200000
ASAM Dataset: EV_DashBoardVDDMQBAB 009069
ROD: EV_DashBoardVDDMQBAB_VW27.rod
   VCID: 7DB2D054EC93466E78-8028
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 24062011600503
Coding: 030100044F05730001100018100F00010001070000000000000000000000
ROD: EV_GatewNF_VW27.rod
   VCID: 70ACF960ABC13B06E3-8024
   Component: 4-00-11-01-04
Subsystem 2 - Part No SW: 3G0 959 442 F HW: 3G0 959 442 F
Component: E221__MFL-PR6 H06 0110
Serial number: PR6-0440036134200125
   Coding: 2C1D00
Subsystem 3 - Part No SW: 7E0 915 181 L HW: 7E0 915 181 L
Component: J367-BDMConti H03 1051
   Serial number: 7719720000200324042F
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 7LA 909 144 F HW: 7LA 909 144 D
Component: EPS_MQB_ZFLS 751 7150
Coding: 0106
ASAM Dataset: EV_SteerAssisMNB 002012
ROD: EV_SteerAssisMNB_VN46.rod
   VCID: 45C278B4C4C3CEAE60-8010
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 3G0 035 869 B HW: 3G0 035 869 B
Component: MU-E-D-ER 720 0740
Serial number: 18062000020957
Coding: 066401003C00000041110101008000001F0000C60000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001044
ROD: EV_MUEnt4CGen2LGE_VW27.rod
   VCID: 2B162E0C426718DE96-807E
Address 6D: Trunk Elect. (J605) Labels:* None
Part No SW: 7LA 959 107 HW: 4M0 959 107 C
Component: HDSG-Modul H14 0672
Revision: -------- Serial number: A2-C769-9790-2
Coding: 4100
ASAM Dataset: EV_DeckLidCONTIVN46T 001017
ROD: EV_DeckLidCONTIVN46T.rod
   VCID: 0346A6AC8A77309E0E-8056
Part No SW: 5WA 035 282 HW: 5WA 035 282
Component: OCUGen3Low H14 0083
Serial number: 0000000003NVZC1
Coding: 06462000196818208005460160000607
ASAM Dataset: EV_OCUGen3Low 002036
ROD: EV_OCUGen3Low_AU27.rod
   VCID: 014AACA4906B228E1C-8054
Address BB: Door Rear Drv (J1093) Labels: None
Part No SW: 7LA 035 593 A HW: 7LA 035 593 A
Component: SLD_Rx-Unit_d H07 0031
Serial number: 19005AF3
Coding: 00
ASAM Dataset: EV_ReceiRearDriveSideHuf 002002
ROD: EV_ReceiRearDriveSideHuf.rod
   VCID: 3E301758A1159D7621-806A
Address BC: Door Rear Pass (J1094) Labels: None
Component: SLD_Rx-Unit_p H07 0031
Serial number: 19005AF4
Coding: 00
ASAM Dataset: EV_ReceiRearPasseSideHuf 002002
Address BE: Slid. Door Rear Left (J926) Labels:* None
Part No SW: 7LA 959 244 E HW: 7LA 959 244 E
Component: Slidingdoor_d H09 0034
Serial number: 17002488
Coding: 10
ASAM Dataset: EV_SlideDoorDriveHufT6PA 001010
ROD: EV_SlideDoorDriveHufT6PA.rod
   VCID: 4AD84B88EDDD21D68D-801E
Address BF: Slid. Door Rear Right (J927) Labels:* None
Component: Slidingdoor_p H09 0034
Serial number: 1700242F
Coding: 10
ASAM Dataset: EV_SlideDoorPasseHufT6PA 001010
ROD: EV_SlideDoorPasseHufT6PA.rod
End----(Elapsed Time: 01:30, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
Moving to Tweaks.
