- Oct 27, 2020
- 4
- 0
- Saskatchewan, Canada
- C?ID=377408
I've got an issue with the whole glow plug system on on my 2013 Jetta Sedan TDI.
Completely stock as far as I know. I have owned the car for the last 2.5 years.
I am starting to experience cold weather (below freezing) overnight and I am now having an issue starting the car. I pushed the car into my garage so I could work on it in warmth and a day later it started (really hard though).
Steps I have taken so far:
Why would the car be reading the cylinder #2 glow plug in this instance? Am I reading the auto scan correctly? Could this somehow be a function of the cylinder #2 glow plug wire and how would I check that wire? In my research I have read about a glow plug relay/module but I can't find it on my specific car (I have pulled the battery and the battery tray to check under the fuse box but the CPU is in the way and I don't see it anywhere in that vicinity).
If anyone can help me I would be so appreciative.
Here is my scan:
- Edit #2: when I try starting the car it does not crank. It just just gives an initial "er" and then nothing,
- put the charger on the battery for 6 hours,
- put booster cables on from my truck for 15 mins and then tried starting car with booster cables still attached and truck running,
- checked voltage across my battery and it was about 12.4v,
- at this point I eliminated the starter and solenoid from my search because the car started in the garage,
- pulled the glow plug wires off all plugs and measured the voltage from the battery to each of the plugs and I am reading about 12.4v on all 4 of them,
- Edit #1: checked fuses under the hood and the ones I think were for the glow plugs & starting system were good. They were 50 amp fuses and I checked 2 of them,
- Once I completed the auto scan I saw in the results that it isolated the cylinder #2 glow plug so I went back to verify that the wire had been firmly affixed to the glow plug during the scan and it had been.
Here is my scan:
Monday,26,October,2020,16:41:56:15900
VIN: 3VWLL7AJ7DM369930 License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 37 44 47 56
VIN: 3VWLL7AJ7DM369930 Mileage: 158820km-98686miles
Part No SW: 03L 997 030 M HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H15--- Serial number:
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 382928862E506A0BAA3-806C
001734 - Cylinder 2 Glow Plug
P06C6 - 000 - Incorrect Installation - Intermittent
Mileage: 157659 km
Date: 2015.02.08
Time: 17:27:24
RPM: 1012 /min
Voltage: 14.06 V
Temperature: 15.3°C
Bin. Bits: 10110000
Time: 2.52 s
Temperature: 15.3°C
001384 - Cruise Control Switch (E45)
P0568 - 000 - Implausible Signal - Intermittent
Mileage: 158824 km
Date: 2015.03.19
Time: 12:58:01
(no units): 255.0
(no units): 255.0
Bin. Bits: 11000001
000801 - Engine Speed Sensor (G28)
P0321 - 000 - Implausible Signal - Intermittent
Mileage: 158824 km
Date: 2015.03.19
Time: 12:58:01
Voltage: 11.70 V
Temperature: 9.9°C
Idle Stabilization: 0.0°KW
(no units): 1.0
Component: GSG DSG AG6 512 9430
Revision: 05551213 Serial number: 00001206202205
VCID: 1471BC3652786E6BE6B-8040
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: B14B400C492800038D1402E792190042211000
VCID: 7DA7F9924DF28F23395-8028
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 085 0902
Revision: 00085000 Serial number: 0176150223
Coding: 030C0C
VCID: 34311CB63EB88E6B86B-8060
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 BA HW: 5C0 820 047 BA
Component: J301 Klimaanlage 0204
Revision: 2001012S Serial number: 00000001126627
VCID: 6099A0E6D64042CB323-8034
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0257
Revision: B2066001 Serial number: 04371151120214
Coding: 7B994BBA08210F0008382000240884C50082502E6020000030A000000000
Shop #: WSC 49042 002 104857
VCID: 2F3B13DAD71EADB3FB9-807A
Subsystem 1 - Part No SW: 6R0 959 801 AF HW: 6R0 959 801 AF Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 004 3465
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AF HW: 6R0 959 802 AF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 004 3465
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H10 0007
Serial number: WRH0005YS5%
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Serial number: 0427027
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 H HW: 6R0 959 811 H
Component: J388__TSG_HL 004 3464
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 H HW: 6R0 959 812 H
Component: J389__TSG_HR 004 3464
Coding: 800000
Fault Frequency: 13
Reset counter: 89
Mileage: 158824 km
Date: 2015.03.09
Time: 18:28:31
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 014 0808
Serial number: 003GTM07M9E-
Coding: 00003936
ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
ROD: EV_AirbaVW10SMEVW360.rod
Serial number: 6940000Y120000HWZP0-
Coding: 303042
Serial number: 3572MSME53180369ZZZS
Serial number: 3582MSME2C13416EZZZ.
Serial number: 3516KSME17742F1DZZZ$
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME23141B1DZZZQ
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME080F561CZZZ+
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME7825561CZZZ+
Part No SW: 5C6 920 852 A HW: 5C6 920 852 A
Component: KOMBI H06 0705
Coding: 370C00
Shop #: WSC 00066 000 00122
VCID: 290FFDC2E97AC38325D-807C
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0257
Revision: B2066001
Coding: 102200
VCID: 70B9D0A60AA0F24BA23-8024
Component: IMMO H06 0705
Coding: 000007
VCID: 6A8DC2CE2CFC089BEC7-803E
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 12000161542003
Coding: 4900000000000000
Shop #: WSC 00066 790 50316
ROD: EV_ELVMarquMPVW36X_VW31.rod
VCID: 2F3B13DAD79EADB3FB9-807A
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662866711
Coding: 020100
VCID: 2A0D02CEECFCC89B2C7-807E
Part No SW: 1K0 035 274 D HW: 1K0 035 274 D
Component: RNS315-NAR H53 0319
Serial number: VWZAZ2M4266006
Coding: 04090041010006000000100A
Shop #: WSC 01383 790 50316
ROD: EV_RNS315NARV2UDS.rod
VCID: 2517F1F28562E7E3015-8070
Component: NAR_V3_(0037) 0037
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 372B2BBA234E6573A39-8062
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 12.2 V
PD
Temperature: 12.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Part No SW: 5C6 035 456 HW: 5C6 035 456
Component: KonzernAmp10K H07 0468
Revision: -------- Serial number: EAA083A0061883
ROD: EV_AudioVerst10KanalSTT3_VW32.rod
VCID: 6597B1F2C5E227E3C15-8030
End----(Elapsed Time: 01:27, VBatt start/end: 11.9V/12.0V. VIgn 12.0V)-----
