Audi A5 no errors but not Cranking
Ridvan
Skopje, Macedonia
C?ID=411090
Here it is the auto scan.
Thursday,29,October,2020,12:49:48:51132
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WAUZZZ8T48A019685   License Plate:
Mileage: 228430km-141939mi   Repair Order:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 36 42 46 52 53 55 56
VIN: WAUZZZ8T48A019685   Mileage: 228430km-141939miles
36-Seat Mem. Drvr -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CAMA)       Labels:| 059-907-401-V1.clb
   Part No SW: 8K1 907 401 D    HW: 8K0 907 401
   Component: 2.7TDI EDC17  H01 0004
   Revision: --H01---
   Coding: 0114002C02070128
   ASAM Dataset: EV_ECM27TDI8K1907401D A01004
   ROD: EV_ECM27TDI8K1907401D.rod
   VCID: 2D12248B7CD682EE88-8078
5188 - Diesel Particulate Filter (Bank 1)
          P242F 00 [167] - Restricted/Clogged
                    Engine speed: 0.00 /min
                    Coolant temperature: 11 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 12.940 V
                    Crankshaft speed (RPM): 0.0 /min
                    Vehicle speed: 0.00 km/h
                    Field regeneration status-Bits 0-7: 00000000
                    Field regeneration status-Bits 0-7: 00010000
                    Field regeneration status-Bits 0-7: 10000000
                    Particle filter: difference pressure: -1 hPa
                    Exh t Adap TP Flt Us: -270.0 °C
                    Exhaust gas vol.flow particulate filter: 0.0 mі/h
                    Particle filter: kilometers since last regeneration: 0 m
5189 - Particulate Trap Bank 1
          P2002 00 [039] - Efficiency Below Threshold
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K0 927 155 C    HW: 0AW 927 156 E
   Component: 0AW 27 TDIRdW H03 0006
   Revision: --H03---    Serial number: 0000000098
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMVL381 A01009
   ROD: EV_TCMVL381_A01.rod
   VCID: 332632F39AF2D41EDE-8066
2223 - Load Signal
          P1857 00 [047] - Error Message from ECU
                    Mileage: 228430 km
                    Date: 2007.08.01
                    Time: 23:15:08
                    Engine speed: 100.00 /min
                    Transmission input speed: 1 /min
                    Transmission output speed: 1 /min
                    Engine torque: 0 Nm
                    Transmission fluid temperature: 13 °C
                    Accelerator position: 0.0 %
                    Clutch status: 1
   Part No SW: 8K0 907 379 K    HW: 8K0 907 379 K
   Component: ESP8 front    H03 0180
   Coding: 1A0500
   VCID: 41CA683BD84E768E5C-8014
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 9
                    Reset counter: 19
                    Mileage: 228430 km
                    Date: 2007.08.01
                    Time: 23:14:18
                    Hex Value: 0x00C0
                    Hex Value: 0x0782
                    Hex Value: 0x0009
                    Hex Value: 0x46A0
                    Hex Value: 0x00FF
                    Reset counter: 19
                    Mileage: 228430 km
                    Date: 2007.08.01
                    Time: 23:14:18
                    Hex Value: 0x00C0
                    Hex Value: 0x0782
                    Hex Value: 0x0013
                    Hex Value: 0x02A0
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 289 C    HW: 8K0 907 289 C
   Component: BCM2.01       H38 0253
   VCID: 393A00DBB09E2E4E14-806C
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H34 0050
   Serial number: 0107000147210006
   Subsystem 2 - Part No SW: 8K0 905 852 C    HW: 8K0 905 852 C
   Component: ELVAUDIB8  H35 0039
   Serial number: 0207000001084009
00166 - Access/Start Authorization Switch (E415)
                    Fault Status: 00101110
                    Reset counter: 59
                    Mileage: 228430 km
                    Date: 2007.08.01
                    Time: 23:14:56
00956 - Key 2
                    Fault Status: 00100101
                    Reset counter: 59
                    Mileage: 228430 km
                    Date: 2007.08.02
                    Time: 00:54:15
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 19
                    Mileage: 228430 km
                    Date: 2007.08.02
                    Time: 00:55:47
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
   Component: MEM-BFS       H09 0042
   Revision: AA000000    Serial number: 00001001044232
   Coding: 08017025002444111000
   VCID: 42C86737DD486D9645-8016
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 59
                    Mileage: 228430 km
                    Date: 2007.08.02
                    Time: 00:01:53
   Part No SW: 8T1 820 043 P    HW: 8T1 820 043 P
   Component: KLIMA 1 ZONE  H05 0112
   Revision: A1000000    Serial number: 0112.10.070113
   Coding: 36020000
   VCID: 3E3013C7A9B0097621-806A
                    Fault Status: 01101000
                    Reset counter: 19
                    Mileage: 228430 km
                    Date: 2007.08.01
                    Time: 23:10:00
   Component: BCM1 1.0      H21 0253
   Revision: 05021001    Serial number: 00000000048244
   Coding: 2600D0910114AF010009000300005D5D0F1C438800010101000000
   Shop #: WSC 40512 222 93061
   VCID: 302C3DFF63E4EF06A3-8064
   Subsystem 1 - Part No SW: 8T1 955 119 B    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 201007  H13 0040
   Serial number: SWFBIE 0000239
   Coding: 00FD11
   Component: RLS  H04 0002
   Serial number: 10015310
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000001010070078
   Part No SW: 8K0 919 475 C    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0010
   Revision: 11001001    Serial number: 75230729005080
   Coding: 100101
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H23 0409
   Serial number: 0038JD119HC/
   Coding: 30313433363030303030554A304C38543053
   ASAM Dataset: EV_AirbaECUVWAUDI010 A02001
   VCID: 3C3419CFB7AC1B660F-8068
   Serial number: 6334MSME2A742B03C
   Serial number: 6344MSME2A742642B
   Serial number: 6352QSME4467211FH
   Serial number: 6362QSME44583D5DX
   Serial number: 63732SME427A545B4
   Serial number: 63832SME434E340F4
   Component: Lenks.Modul   H10 0012
   Revision: --------    Serial number: 90304GJ90007L
   Coding: 000016
   VCID: 3D3214CBA4B6126E38-8068
   Part No SW: 8T0 920 900 L    HW: 8T0 920 900 L
   Component: KOMBIINSTR.   H26 0214
   Revision: 00100000    Serial number: 71R215UA7
   Coding: 0307000002000008010000
   Shop #: WSC 06325 123 12345
   VCID: 3C3419CFBFAC1B660F-8068
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 19
                    Mileage: 228430 km
                    Date: 2007.08.01
                    Time: 23:10:26
   Part No SW: 8T0 907 468 D    HW: 8T0 907 468 D
   Component: GW-BEM 5CAN   H04 0084
   Revision: GA801030    Serial number: 3000G079078038
   Coding: 000003
   Shop #: WSC 40512 222 93574
   Subsystem 1 - Part No SW: 8K0 915 181     HW: 8K0 915 181
   Component: J367-BDM  H06 0150
   Serial number: 17005A6B021007
                    Reset counter: 59
                    Mileage: 228430 km
                    Date: 2007.08.01
                    Time: 23:11:20
                    Reset counter: 59
                    Mileage: 228430 km
                    Date: 2007.08.02
                    Time: 00:01:52
   Component: MEM-FS        H09 0042
   Revision: AA000000    Serial number: 00001001044349
   Part No SW: 8K0 959 793     HW: 8K0 959 793
   Component: TSG FA        H09 0149
   Revision:             Serial number: „—e
   Coding: 011C022240002201
   VCID: 7DB2D4CBE436D26E78-8028
   Revision: 00002001    Serial number: 0106799155
   Coding: 011A068000390000002000
   Component: DWA-Sensor  H02 0030
02739 - Bulb for Tail/Brake Light; Right
                    Fault Status: 11101100
                    Reset counter: 19
                    Mileage: 228430 km
                    Date: 2007.08.01
                    Time: 23:10:49
                    Reset counter: 19
                    Mileage: 228430 km
                    Date: 2007.08.01
                    Time: 23:10:50
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 19
                    Mileage: 228430 km
                    Date: 2007.08.02
                    Time: 00:39:30
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 19
                    Mileage: 228430 km
                    Date: 2007.08.02
                    Time: 00:40:48
   Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
   Component: TSG BF        H08 1501
   Coding: 011C02224000450005
   VCID: 52E857770D28FD16F5-8006
                    Reset counter: 19
                    Mileage: 228430 km
                    Date: 2007.08.01
                    Time: 23:09:59
                    Fault Frequency: 64
                    Reset counter: 19
                    Mileage: 228430 km
                    Date: 2007.08.01
                    Time: 23:09:59
   Part No SW: 8K0 907 801 C    HW: 8K0 907 801 C
   Component: EPB Audi B8   H03 0040
   Revision: 00000003    Serial number: 00000000020434
   VCID: 2F2E3E837EDAF0FEBA-807A
                    Fault Status: 11101101
                    Reset counter: 19
                    Mileage: 228430 km
                    Date: 2007.08.01
                    Time: 23:09:59
                    Voltage: 11.30 V
                    Count: 58
                    Hex Value: 0x02F0
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No: 8K0 907 357 A
   Coding: 0000001
   VCID: 332632F352F2D41EDE-8066
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 186 B    HW: 8T1 035 186 B
   Component: Concert3      H13 0130
   Revision: 00000015    Serial number: AUZ5Z6G1008668
   Coding: 000004800404050001DB070000
   VCID: 36200BE78180C136F9-8062
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
End----------(Elapsed Time: 01:25, VBatt start/end: 12.7V/12.7V)-----------
Ridvan
Skopje, Macedonia
C?ID=411090
There is ignition everything works just no cranking. Tested the starter, it works.
This is my first post in the forum. If I post it in wrong place. Can delete it.
Pro Diagnostics VAG
Toronto, Canada
C?ID=23604
Reset counter: 59
Mileage: 228430 km
Date: 2007.08.01
Time: 23:14:56
Looks like your E415 switch its not working.
If you post something in the wrong place, please ask an admin to move it.
coconutaudi
Kuala Lumpur, Malaysia
C?ID=345326
Too much fault codes. I think you should clear the fault codes and see what remains.
bonzo
Romania
C?ID=334156
verify clutch pedal switch
Tonytx
Texas
C?ID=423392
It seems like the anti-theft system is not recognizing the key so the ECM is cutting up the ignition switch, and you really need to take care of the catalytic converter or Particles filters ASAP that's not healthy for the engine and that's the reason why the engine is on limp mode. good luck with it!
