VW Touareg O2 SENSOR FAULT ?
chillout1983
C?ID=162783
HI ALL
I recently Scanned a friends Touareg it came up with the following codes that i think are related to the 2nd O2 sensor however i am unsure how best to diagnose this issue and struggled to find anything useful on elsawin any help appreciated on how to fault find/test this to confirm that the sensor is at fault or possibly another cause.
thanks in advance
Tuesday,27,October,2020,17:53:33:35088
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN:
Mileage: 36050km-22400mi   Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 32 42 46 52 53 56 5F 62
          65 72
VIN:    Mileage: 36050km-22400miles
Address 01: Engine (J623-CVVA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P1 907 401 F    HW: 7P0 907 401 K
   Component: 3.0TDI EDC17  H21 0004
   Revision: 56H21---
   Coding: 296A4012232601030000
   Shop #: WSC 00864 210 00000
   ASAM Dataset: EV_ECM30TDI0117P1907401F 001005
   ROD: EV_ECM30TDI0117P1907311.rod
   VCID: 332616679ABC781EDE-8066
9569 - NOx Sensor 2 Bank 1
          P229E 00 [101] - Electrical Malfunction
                    Mileage: 36048 km
                    Date: 2020.10.27
                    Time: 16:22:27
                    Engine speed: 1660.00 /min
                    Normed load value: 39.6 %
                    Vehicle speed: 101 km/h
                    Coolant temperature: 80 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 14.600 V
                    NOx sensor 2: NOx concentration: -100 ppm
                    Com r Lam Lin Rec Cat2 Ds: 1.4640
                    NOx sensor 2: feed voltage: 14400 mV
                    Target value of heating temperature of NOx sensor 2-Bits 0-7: 0
                    Com st N Ox Vld Cat2 Ds-Bits 0-7: 0
                    Exh st Lam Stat No Cat2 Ds-Bits 0-7: 0
                    Exh.gas temp.sen 4: 581.1 °C
9570 - NOx Sensor 2 Bank 1
          P229E 00 [237] - Electrical Malfunction
                    Mileage: 35991 km
                    Date: 2020.10.26
                    Time: 16:14:23
                    Engine speed: 1328.50 /min
                    Normed load value: 70.2 %
                    Vehicle speed: 55 km/h
                    Coolant temperature: 89 °C
                    Voltage terminal 30: 14.660 V
                    NOx sensor 2: NOx concentration: 768 ppm
                    Com r Lam Lin Rec Cat2 Ds: 0.2760
                    NOx sensor 2: feed voltage: 13920 mV
                    Exh.gas temp.sen 4: 338.2 °C
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217)       Labels: 0C8-927-755.clb
   Part No SW: 0C8 927 755 C    HW: 0C8 927 755
   Component: AL1000 AISIN  130 2881
   Coding: 010100011C008400000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_TCMAL991031 003118
   ROD: EV_TCMAL991031_003.rod
   VCID: 312A1C6F60A04A0EAC-8064
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 R    HW: 7P0 907 379 A
   Component: MK25A         H37 0521
   Revision: --------    Serial number: 41726443497018
   Coding: 4B6B13C30924255AD2FBC89890D6A470F701
   ASAM Dataset: EV_MK25AXT 010001
   ROD: EV_ESPMK25A01000.rod
   VCID: 4CD46D9BE74207E6BF-8018
   Part No SW: 4H0 907 064 JL    HW: 4H0 907 064 JL
   Component: BCM2 2.0      H43 0582
   Coding: 01B60010000000000000
   VCID: 7CB4FD5BFF6277664F-8028
   Subsystem 1 - Part No SW: 7P6 959 754 AP    HW: 7P6 959 754 AP
   Component: FBSTOUAREGIDG  H08 0084
   Serial number: 3616000130967004
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 3216000141807016
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 CR    HW: 7P6 907 040 CR
   Component: Klima 2 Zonen H23 1608
   Coding: B626000890
   VCID: 06409FB3B9AE3DB629-8052
   Part No SW: 4H0 907 063 DE    HW: 4H0 907 063 AE
   Component: BCM1 2.0      H20 0311
   Revision: 24020001    Serial number: 00001415154601
   Coding: 2600005481345D010001000300004D4C431D470827010241000000000080130200000000000000
   VCID: 6E90C713B91E15F6F1-803A
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    160716  033 0021
   Serial number: 90243401160804141756
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 80880623
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 R    HW: 7P6 941 431 R
   Component: E1 - LDS  H02 0040
   Serial number: 00000000001108160178
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 D    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0030
   Revision: --------    Serial number: 28261619401665
   Coding: 108504
   ASAM Dataset: EV_VW526ParkiAssis2 001013
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 44C445BBCF12CFA677-8010
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 F    HW: 7P0 959 655 F
   Component: VW10Airbag00K H10 0044
   Revision: --------    Serial number: 003S8003ZMKX
   Coding: 00000000000000000000000000000000304B
   ASAM Dataset: EV_AirbaVW10BPAVW526 002001
   ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
   Serial number: 3575LRB4006572C6FHTA
   Serial number: 3585LRB401C570I6GP79
   Serial number: 3517ARB405L3OQ480PBN
   Serial number: 3527ARB405J3OQ48CGBP
   Serial number: 3557BRB4067452A2B9BB
   Serial number: 3567BRB4069452A27ON.
   Part No SW: 4H0 953 568 P    HW: 7P6 953 507 AL
   Component: Lenks.Modul   H06 0010
   Revision: --------    Serial number: 01374PHH000A5
   Coding: 000015
   VCID: 40CC49ABD30AD38653-8014
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H05 0028
   Serial number: 0056676 TRW 20160714
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 983 R    HW: 7P6 920 983 R
   Component: Kombi         H13 0607
   Revision: 13240312    Serial number: 658130816592011
   Coding: 33273300AB00260001000C
   ASAM Dataset: EV_KombiUDSRBVW526 001030
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 4ED06793115E35F6D1-801A
   Part No SW: 7P6 907 530 Q    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H15 6051
   Revision: --------    Serial number: 00000002339178
   Coding: 000D07AD00
   ASAM Dataset: EV_GatewVW526UDS 001008
   ROD: EV_GatewUDS_VW52.rod
   VCID: 46C05FB3F92EFDB669-8012
   Subsystem 1 - Part No SW: 7P0 915 181 C    HW: 7P0 915 181 C
   Component: Batt_Sensor  H07 0270
   Serial number: 43202G19415811383628
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
   Serial number: 16222002435021200181
16384 - Function Restriction due to Driver Fatigue Recognition
          B130E 00 [008] - -
          [Funktionseinschraenkung Pausenempfehlung]
                    Fault Frequency: 11
                    Reset counter: 78
                    Mileage: 35543 km
                    Date: 2020.10.14
                    Time: 11:39:59
                    Voltage terminal 30: 12.8 V
                    Voltage terminal 15: 12.8 V
                    Control Module temperature: 31 °C
                    System status: Terminal 15 on
                    IN ESP_standstill flag: no standstill detected
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Part No SW: 0BV 927 755 A    HW: 0BV 927 755 A
   Component: TRANSFERCASE        0218
   VCID: 4CD46D9B2F4207E6BF-8018
Address 32: Differential Locks        Labels: None
   Part No SW: 0BN 927 771     HW: 0BN 927 771
   Component: Quersperre          5220
   Revision: H08         Serial number: 627707251808
   VCID: 014A8CAF58801A8E1C-8054
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H03 0306
   Revision: --------    Serial number: 0000213237811
   Coding: 011D0620D001451005080002
   VCID: 7AB8FB43F55649565D-802E
   Revision: 00002001    Serial number: 0413359464
   Coding: 011B1622A8B9008083200624000000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 172
   Component: Sensor, DWA  005 0502
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H03 0306
   Revision: --------    Serial number: 0000213595285
   Coding: 011D0620D001451005080000
   VCID: 48DC518BFB3AEBC69B-801C
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 G    HW: 7P0 907 801 G
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1672200474
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 373E22778EC4943EE2-8062
   Slave 3:
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109H20G2618297
   Coding: 010105020100000003
   VCID: 2D12001F74982EEE88-8078
   Part No SW: 7P6 035 670 M    HW: 7P6 035 670 A
   Component: H-BNT-EU      H42 1023
   Revision: --------    Serial number: 603H10G7562267
   Coding: 010101050040E1ED01000B0E00000003500401020000000000
   VCID: 3FCE4A57AEF4AC7E2A-806A
   Subsystem 1 - Part No: 7P6 060 884 E
   Component: EUR 2016/2017  2302
   Subsystem 2 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
   Component: DU8 SV Touch  H56 0046
   Serial number: VWZ8Z9SGF00YHY
   Subsystem 3 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
   Component: CD-Database  6890
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H04 0306
   Revision: --------    Serial number: 0000213404894
   Coding: 011804200001251005080000
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 L    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0003
   Serial number: 40000000046143
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_005.rod
   VCID: 45C258BFC428F6AE60-8010
   Component: TSG HR        H04 0306
   Revision: --------    Serial number: 0000213400181
End----(Elapsed Time: 01:51, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
DrPeter
16.4905° S, 151.7375° W
You may want to check out erWin, they have all the repair information from current model years to early vehicles.
I found a document in erWin that should help called:
Repair Manual
Touareg 2013 ➤
Generic Scan Tool​
In there, the section for the fault code P229E says to use section [3.6.26] for the "Nox Sensor Control Module - J583- /Nox Sensor Control Module 2 - J881- , Checking "
In this section the "Test Procedure" has four checks/steps to test these components, which includes checking for wiring concerns, checking power/grounds, etc.
If needed, the Official Factory Repair Information links can be found on the Ross-Tech wiki.
Hope this helps,
drpeter
chillout1983
C?ID=162783
Hi thank you for your reply I will try and find it I did look but I didn't find erwin very easy to use
chillout1983
C?ID=162783
Hi I can't find that info on erwin ,does the us differ from the European site .
chillout1983
C?ID=162783
Hi thanks for your reply I am either looking in the wrong place or possibly the data from above does not exist on the eu site
I did find a recall to calibrate the sensor to the Nox module however it never mentioned the lack of correct calibration causes error codes
