05 acc start module... cannot read 1100 plz help
Casandra2317
TN/FL, USA
C?ID=422731
Hello everyone I am new user and greatly in need of help...Took a family vacation to Florida with no issues whatsoever.The next day key fob wouldn't unlock doors so naturally I replaced battery,still no help.So I put key in ignition and when I turned it nothing came on except odometer and date/time on instrument cluster as well as Mmi/radio.So called aaa who said battery is good.Then had car towed to local indy shop who had car 3 days.On 3rd day shop calls said they called Sanford Audi and would need steering column replaced.Shop then said they can't do repair but can get car towed to another shop.So I called my friend in Nashville who suggested buying vag cable from ross tech, download software and clear code,then car should start one time to drive home ...Then the plan was to have j518 pulled out and rebuilt so module wouldn't have to be recorded to car.So bought cable with overnight delivery and went to work.As luck would have it 700 miles from home no communication.So called ross tech and wonderful man walked me thru everything he had with 15 columns under his belt for almost an hour but couldn't communicate with 05 acc start control module..😪 We tried everything including removing fuse 42 as well as hazards/high beam/ brake pedal.Replaced J329 relay with new one,checked all fuses and still no communication.Also had battery maintainer attached to front posts under hood.We did obtain this scan by jumping the j329 relay with a wire between two large prongs.Any help would be greatly appreciated.Any ideas on how to wake up one time or a bypass trick to get car and family home? Thanks and God Bless🙏 Wednesday,28,October,2020,14:31:24:37591
[URL='http://www.ross-tech.com/']www.Ross-Tech.com[/URL]
VIN: WAUKG74F86N024308 License Plate:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 65 67 72 76 77
VIN: WAUKG74F86N024308 Mileage: 187420km-116457miles
05-Acc/Start Auth. -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Cannot be reached 1100
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F2 910 559 B HW: 4F1 907 559 E
Component: 3.2l V6 FSI 0030
Revision: --H22--- Serial number:
Coding: 010D0009190F0120
Shop #: WSC 09222 444 100176
VCID: 2B030CB67F0C1D23D71-807E
005748 - Powertrain Data Bus
P1674 - 008 - Implausible Message from Instrument Cluster
Fault Status: 01011000
Mileage: 187423 km
Date: 2005.02.02
Time: 04:26:34
Mass Air / Rev.: 0.0 mg/str
Temperature: 30.0°C
Engine Off
Voltage: 11.22 V
006457 - Powertrain Databus
P1939 - 009 - Missing Message from Controller for Access & Start Auth.
Fault Status: 01010100
Mileage: 187423 km
Date: 2005.02.02
Time: 04:26:34
Temperature: 30.0°C
Engine Off
Voltage: 11.42 V
004180 - Bank2; Exhaust Cam Adjustment Valve 2 (N319)
P1054 - 009 - Open Circuit
Fault Status: 00010100
Fault Frequency: 60
Mileage: 187423 km
Date: 2005.02.02
Time: 04:26:36
Temperature: 30.0°C
Engine Off
005488 - Engine Start Blocked by Immobilizer
P1570 - 008 -
Fault Frequency: 8
Mileage: 187423 km
Date: 2005.02.02
Time: 10:35:47
Temperature: 30.0°C
Engine Off
Readiness: 0110 0101
Part No SW: 4F1 910 156 P HW: 09L 927 156 A
Component: AG6 09L 3,2 FSI USA 0010
Revision: --H01--- Serial number: 4032657
Coding: 0000002
Shop #: WSC 02325 785 00200
VCID: 313F1EDE5D2077F3EDD-8064
053258 - No Communications with Control Module for Access/Start Authorization
U100A - 000 -
Mileage: 187423 km
Date: 2005.02.08
Time: 14:18:56
(no units): 30.0
(no units): 23.0
Temperature: 29.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Coding: 0020895
VCID: 2D0702AE41181313C95-8078
Reset counter: 131
Mileage: 187423 km
Date: 2005.02.01
Time: 12:18:48
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0024
Hex Value: 0x018C
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: None
Part No SW: ÿÿÿÿÿÿÿÿÿÿÿ HW: ÿÿÿÿÿÿÿÿÿÿÿ
Revision: 05100701 Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
VCID: 74B1D7CAE2B202DB46B-8020
No Faults Found
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 Q HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 303E9057500243
Coding: 0001003
Shop #: WSC 02335 785 00200
Component: Bedienteil MMIC6H09 0060
Subsystem 2 - Serial number: 00000001083968
Subsystem 3 - Serial number: 0128.05.080000000100010609ÿ
Subsystem 4 - Serial number: 010609ÿ
01964 - Control Module for Seat & Steering Column Memory (J136)
Reset counter: 171
Mileage: 187423 km
Date: 2005.02.08
Time: 12:51:13
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 J
Component: KLIMABETAETIGUNGH11 0150
Revision: 00000026 Serial number: 00000030021690
Coding: 0524582
VCID: 5BE39C766F2CADA3671-800E
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
007 - Short to Ground
Fault Status: 01100111
Reset counter: 131
Mileage: 187423 km
Date: 2005.02.01
Time: 13:37:59
Voltage: 11.00 V
(no units): 212.0
(no units): 0.0
00456 - Control Module for Access and Start Control (J518)
Reset counter: 131
Mileage: 187423 km
Date: 2005.02.01
Time: 13:38:01
Bin. Bits: 00001000
Reset counter: 131
Mileage: 187423 km
Date: 2005.02.01
Time: 13:38:01
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Coding: 0013123
VCID: 6695BD82A46EE04BC8F-8032
Subsystem 1 - Component: Fehler Lin-Slave 01
Subsystem 2 - Component: Fehler Lin-Slave 02
Reset counter: 131
Mileage: 187420 km
Date: 2005.02.01
Time: 13:31:00
Address 0E: Media Player 1
Address 0F: Digital Radio
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 66 AIRBAG AUDI8RH29 0300
Revision: 11H29000 Serial number: 00359D0905NO
Coding: 0013878
Shop #: WSC 09223 444 84432
VCID: 2A0D09B270F6042B2C7-807E
Subsystem 1 - Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
Subsystem 2 - Serial number: 6332CSME084C1740/
Subsystem 3 - Serial number: 6342CSME0A19300D+
Subsystem 4 - Serial number: 6352QSME023C425BG
Subsystem 5 - Serial number: 6362QSME021B453DH
Subsystem 6 - Serial number: 63734SME01032549P
Subsystem 7 - Serial number: 63834SME021A7A391
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90025051350173
Coding: 0002042
Shop #: WSC 02323 785 00200
Component: Lenkradmodul H07 0080
Reset counter: 131
Mileage: 187423 km
Date: 2005.02.01
Time: 13:31:35
Part No SW: 4F0 910 930 A HW: 4F0 920 980 N
Component: KOMBIINSTR. M73 H15 0630
Revision: 01000000 Serial number: 4PY512H55
Coding: 2129263
Shop #: WSC 57818 001 1048576
VCID: 211FEE9E0DC0C7737DD-8074
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H10 0060
Revision: 10 Serial number: 120080551380C5
Coding: ECFE73CD1B7904
VCID: 270BF08663E43943339-8072
Reset counter: 131
Mileage: 187423 km
Date: 2005.02.01
Time: 13:31:35
Reset counter: 131
Mileage: 187423 km
Date: 2005.02.01
Time: 13:31:35
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 619FAE9E4D4087733DD-8034
Reset counter: 131
Mileage: 187420 km
Date: 2005.02.01
Time: 13:31:37
Address 37: Navigation
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H18 0120
Revision: 01200018 Serial number: 01004432600000
Coding: 4618813
VCID: 2E0505A24C1E680BF0F-807A
Subsystem 1 - Component: Sounder No Answer
Fault Status: 01101100
Reset counter: 9
Mileage: 162799 km
Date: 2018.01.15
Time: 06:47:43
01503 - Bulb for 3rd Brake Light (M25)
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 46
Reset counter: 131
Mileage: 187423 km
Date: 2005.02.02
Time: 10:35:49
Reset counter: 131
Mileage: 183081 km
Date: 2020.09.05
Time: 18:48:29
02071 - Local Databus
Reset counter: 131
Mileage: 183207 km
Date: 2020.09.07
Time: 09:47:56
Fault Frequency: 132
Reset counter: 131
Mileage: 187424 km
Date: 2020.10.19
Time: 14:21:56
Fault Frequency: 23
Reset counter: 131
Mileage: 187423 km
Date: 2005.02.01
Time: 13:24:05
Address 47: Sound System
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000001002
Coding: 0002114
VCID: 5EE595627C3EB88B00F-800A
Reset counter: 131
Mileage: 187420 km
Date: 2005.02.01
Time: 13:31:00
Voltage: 11.100 V
Temperature: 33.0°C
Address 52: Door Elect, Pass.
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
Shop #: WSC 02334 785 00200
VCID: 5DE7926E7138A393195-8008
Fault Status: 11100100
Fault Frequency: 17
Reset counter: 131
Mileage: 187416 km
Date: 2005.02.01
Time: 12:17:32
Voltage: 11.18 V
Count: 247
00576 - Terminal 15
Fault Status: 11101100
Fault Frequency: 18
Reset counter: 131
Mileage: 187416 km
Date: 2005.02.01
Time: 12:17:32
Voltage: 11.18 V
Count: 41
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0030
Coding: 0000016
VCID: 2615FD8264EE204B08F-8072
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH01 0010
Reset counter: 131
Mileage: 187416 km
Date: 2005.02.08
Time: 14:18:58
Address 56: Radio
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000046200
Shop #: WSC 38804 003 1048576
VCID: 2313E49617DCD5636F1-8076
Subsystem 1 - Part No: 4F0 915 105 E
Component: von VA0 1234567890
Coding: 344630393135313035452056413031323334353637383930
Reset counter: 131
Mileage: 187423 km
Date: 2005.02.01
Time: 13:31:34
02277 - Quiescent Current Stage 6
Mileage: 187423 km
Date: 2005.02.01
Time: 13:31:34
Address 62: Door, Rear Left
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 HW: 4F0 907 273
Component: Reifendruck 3 H04 0080
Revision: 00040080 Serial number: 00000900004945
Coding: 0062221
Shop #: WSC 09222 444 84347
VCID: 6099AB9A464A8E7B323-8034
Address 67: Voice Control
Address 72: Door, Rear Right
Part No SW: 4F0 910 283 B HW: 4F0 919 283 B
Component: Parkhilfe 4-Kan H09 0020
Revision: 00H09000 Serial number: 11720513005458
Coding: 0001216
Reset counter: 131
Mileage: 187423 km
Date: 2005.02.01
Time: 13:31:34
00576 - Terminal 15
Fault Status: 01101000
Reset counter: 131
Mileage: 187423 km
Date: 2005.02.01
Time: 13:37:53
Address 77: Telephone
End----(Elapsed Time: 01:46, VBatt start/end: 11.1V/11.1V. VIgn 11.1V)-----
Sent from Mail for Windows 10
Yes, 05: Acc/Start looks mighty sad in that scan. The Gateway can't talk to it either:
Have you physically inspected this module?
Casandra2317
TN/FL, USA
C?ID=422731
Hi Uwe and thanks for reply..Have lap panel off and testing all connection to module...Did find that battery was at 11.9 volts so charging up now with agm charger.. Praying it was just a voltage drop or a bad battery.If still at a dead end will pull module and go from there.Start control module is dry so no water damage as no rain here in past few days.. Praying it's a battery issue as this car has been more than reliable up until this point
Casandra2317
TN/FL, USA
C?ID=422731
Defiantly a battery issue...Had it on amg charger most of the day and wouldn't charge past 50%!!! So will purchase new agm battery in the morning and see if this gets me back going
