2011 Caddy CAY DPF light on
dysonauto
Whitsundays, Australia
C?ID=417482
Hi, new here.
Cannot perform a forced DPF regen. When I try, it comes up finalised straight away.
Symptoms are no power (40kph max)
Engine is at normal operating temperature.
Any ideas?
Cheers
Dyson
Wednesday,28,October,2020,16:04:46:49579
VCDS Version: 20.4.2.0 (x64) HEX-NET2 CB: 0.4527.4
Dealer/Shop Name: Dyson Automotive
VIN: WV1ZZZ2KZBX273052 License Plate:
Address 01: Engine (03L 906 023 FK)
16:04:03
IDE00025 Coolant temperature 88 °C
IDE00427-ENG101722 Particle filter: difference pressure-DIP_PF 14.84 hPa
IDE00428-ENG100917 Particle filter: offset for differential press.-DIP_PF_AD[0] -5.72 hPa
IDE00433-ENG103279 Particle filter: oil ash volume-MASS_ASH_PF 42.7863333 g
IDE00434-ENG102050 Particle filter: soot mass calculated-MASS_SOOT_SIM_PF 25.52 g
IDE00435-ENG101197 Particle filter: soot mass measured-MASS_SOOT_PHY_PF 3.59 g
IDE06060-ENG111632 Particulate filter ash load limit-C_MASS_ASH_PF_LIM_TEST 70.00 g
Mari
C?ID=150535
... we need to see a complete unedited autoscan ;) so we know how the car is equipped, how modules are coded and which software version they are on...
dysonauto
C?ID=417482
Thursday,29,October,2020,17:12:52:49579
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
Mileage: 99290km-61695mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WV1ZZZ2KZBX273052   Mileage: 99290km-61695miles
Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 FK    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 8686
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00254014032500080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023FK 003005
   ROD: EV_ECM16TDI02103L997557M.rod
   VCID: F4BA37740E37B51BC6B-80A0
16848 - Diesel Particulate Filter
          P2458 00 [173] - Regeneration Duration
                    Mileage: 99250 km
                    Date: 2020.10.28
                    Time: 00:02:09
                    Engine speed: 0.00 /min
                    Coolant temperature: 69 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 12.198 V
                    Particle filter: soot mass measured-MASS_SOOT_PHY_PF: -0.51 g
                    Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 13.30 g
                    Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H: 640 km
                    Zähler der Regenerationszeit des Partikelfilters-T_INT_RGN_ACT_INI_PF_ENVD_H: 12596.0189 s
                    Particle filter: difference pressure-DIP_PF: 0.00 hPa
                    Particle filter: offset for differential press.-DIP_PF_AD[0]: -2.74 hPa
                    Service regeneration: Release conditions 3-FRF_STATE_RGN: 9
Readiness: 1110 1000
   Part No SW: 0AM 300 050 R    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 9030
   Revision: 00043014    Serial number: CU501512136510
   Shop #: WSC 04940 001 00001
   VCID: B822C3445E5F117B2A3-80EC
006279 - Wheel-Speed Signal from ABS Control Module
               P1887 - 000 - Implausible Signal - Intermittent
                    Reset counter: 10
                    Mileage: 99296 km
   Revision: 00H31001
   Coding: 633C400D092903FDC60B02E9901BC081310000
   Shop #: WSC 35110 377 08192
   VCID: F6BE0D7C18CBA70BF8F-80A2
                    Fault Status: 00101100
                    Reset counter: 103
                    Mileage: 99296 km
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 56
                    Count: 43008
                    Count: 65535
   Part No SW: 7N0 907 426 K    HW: 7N0 907 426 K
   Component: AC Manuell    H17 0202
   Revision: 00012001
   Coding: 0000001002
   ROD: EV_ClimaBasis_VW32.rod
   VCID: BC2ADF5466E73D5BCEB-80E8
   Part No SW: 2K5 937 085     HW: 2K5 937 085
   Component: BCM PQ35 B+   011 1044
   Revision: BB011001
   Coding: 401A583A8025186B088000829000006401017288524F8160648000000040
   VCID: F2B6316C74A3BB2BD47-80A6
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 18011  26  0512
   Coding: 009795
01834 - Bulb for Side-Blinkers; Left (M18)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 102
                    Mileage: 99295 km
                    Date: 2015.03.21
                    Time: 00:02:19
                    Voltage: 13.75 V
   Component: VW10Airbag00X H06 0013
   Revision: --------    Serial number: 003HL003V3ME
   Coding: 000000000000000000000000000000003058
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: B53CCA7045CDEC13315-80E0
   Part No SW: 5K0 953 507 AD    HW: 5K0 953 549
   Revision: --------    Serial number:  90422KAQ0009G
   Coding: 1880160000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: F2B6316C7423BB2BD47-80A6
   Part No SW: 2K0 920 865 A    HW: 2K0 920 865 A
   Component: KOMBI         H04 0404
   Coding: 180200
   VCID: AC0AEF149687ADDB5EB-80F8
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 060211F1002449
   Coding: 357401
   VCID: B032FB64BA2FC93B623-80E4
   Component: IMMO          H04 0404
   VCID: EA86290C5CF373EB6C7-80BE
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0000560
   VCID: C8C2B3842EBF61FB5A3-809C
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 140    3201
   Revision: 00H20000
   VCID: B43AF7744237F51B06B-80E0
                    Fault Status: 00101101
                    Reset counter: 144
                    Mileage: 99296 km
                    Date: 2015.03.21
                    Time: 21:50:08
                    Voltage: 11.88 V
                        DD
                    Temperature: 30.0°C
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000560
   VCID: C7C0B0B823A16E83539-8092
   Part No SW: 5K0 035 156     HW: 5K0 035 156
   Component: Radio         H30 0072
   Revision: R0000000    Serial number: VWZAZ1L0687445
   Coding: 0500020001
   VCID: E49A4734BE57259B56B-80B0
End----(Elapsed Time: 00:56, VBatt start/end: 12.1V/11.9V. VIgn 11.9V)-----
Thank you
What other fault codes did it have when you cleared them most recently? ;)
I believe P2458 is indicative of the ECU refusing to do a regeneration due to other problems, for example a wonky reading from one of the sensors.
dysonauto
C?ID=417482
There was only the one engine code, plus the ABS and trans codes. Intermittent speed sensor codes but watching live data the speed sensors appear to be working.
Could the other codes influence the P2458?
Cheers
dysonauto
C?ID=417482
Have done a Bluechem DPF clean and the differential pressure has come down a bit.
Have tested the DPF pressure sensor and it appears to be working fine.
In tank fuel pump works
Checked and replaced the fuel filter - no unleaded fuel in system
P2458 fault will not clear, even with ignition on engine off
No acceleration/no power.
Only 90,000 km's so not expecting manifold to be carboned up and blocked as yet (I could be wrong though)
Thanks for your help
dysonauto
C?ID=417482
Problem solved.
Went into adaptions, particle filter initialisation and saw soot levels still being recorded at 40g even though DPF had been cleaned and was no longer a restriction.
Changed value manually to 5g soot accumulation, cleared fault code, started engine and hooray, engine power restored and check engine light staying off.
Cheers
