Golf R 2019 blink light confirmation when lock/unlock cancellation
TechAm
Laval, Canada
C?ID=401793
Hello, i'm new on the forum. I want to remove the blink confirmation when lock/unlock with remote on a Golf R 2019. I went to all the adaptations in 09 central electronics, since coding is not available on this car for the central electronics. I found pretty much every thing from honk when lock/unlock to windows up when rainning and adding or removing menus to the radio but nothing for the blink confirmation with the remote. Maybe i went trhu it but since it's in german, it's hard to translate and know what it means. Is somebody knows how to do it?
Thank you.
Mari
C?ID=150535
... maybe you can post a complete and unedited autoscan of the car...
TechAm
Laval, Canada
C?ID=401793
HO yeah!, i will as soon as i get to the shop! sorry. Just by curiosity, what is the use for posting the scan of the car?? What does it say??
TBAx
C?ID=287144
You should be able to just set the adaption channel
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit
to 0 ms. The channel is found inside the module 09 (BCM).
If this does not work, you can always try the version we had in the past:
Bruce
Near Philadelphia, PA, USA
An Autoscan tells us the hardware and software configuration of the modules in your particular car There are many flavors put into a model year and the only way we can know what is in the car and which modules is by viewing the Autoscan.
If you wish to have help on the Ross-Tech forum, we ask that an autoscan be with the first post of your thread. Help us to help you.
TechAm
Laval, Canada
C?ID=401793
Wow!!! it worked. Thanks TBAx. I lost so much time with this.
Thank you.
TechAm
Laval, Canada
C?ID=401793
Thanks Bruce for the clarification...TBAx solve my problem. I will do it for the next time.
Mari
C?ID=150535
Make autoscan, save it and store it on a safe place... next time you mess things up this autoscan can be of help... You can also make backup of all modules adaption-channels... also for messing things up ;)
TechAm
Laval, Canada
C?ID=401793
Thanks Mari, that’s exactly what i did.
