MQB Tiguan - Default option for heated steering wheel
bjornix
Norway
C?ID=222439
On the MQB Tiguan the seat- and steering wheel heating share the same button. On press you can then adjust the two individually from the touch screen. Is there a coding option or adaption channel to have the heated steering wheel set to OFF by default? I use heated seats as soon as it gets a little chilly outside, but I don't like to have heating on the steering wheel until it is FREEZING.
TBAx
C?ID=287144
I am not sure about the HVAC module in your car, since you did not attach an Auto-Scan, but you might want to take a look at it‘s Byte 13, Bit 2-3 where you can set the automatic activation of the steering wheel heater.
When you set it to be regulated by the outside temperature,the heater should be detached from the seat heating button. The automatic activation can then also be deactivated using the HVAC settings inside the HMI.
bjornix
Norway
C?ID=222439
Here is an autoscan:
Thursday,23,April,2020,20:53:53:56463
VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVGZZZ5NZHW403822   License Plate:
Mileage: 75474km-46897mi   Repair Order:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 18 19 22 29 2B 36 39 42
          44 4B 52 5F 69 6C 6D 82 A5 BB BC CA D6 D7
VIN: WVGZZZ5NZHW403822   Mileage: 75474km-46897miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 EJ    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H24 3661
   Revision: B4H24---
   Coding: 0125003A04761D083000
   ASAM Dataset: EV_ECM20TDI01104L906026EJ 004003
   ROD: EV_ECM20TDI01104L906026EJ_004.rod
   VCID: 76B5E00EF84AF547E39-8022
   Part No SW: 0DL 300 011 N    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2001
   Revision: 00H06V07
   VCID: 3333191AABB8A06F047-8066
   Revision: 00000000    Serial number: 60337000000485
   Coding: 0AEE6B9A54200B6F477F070262C54950D62AD0E2E046927D38625078C22A4200002F641A1B13111435351919323200
   VCID: 77ABED0AFF408C4FF8F-8022
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0430687081
   Coding: 032C2C070F
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   VCID: 3C21322686E66F17D5D-8068
   Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
   Component: GEB.F.Heckoef  H17 0903
   Serial number: 98136002
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006RLE36677
   Coding: 0010000000000500818281808181000000008181000000F400
   Shop #: WSC 39116 002 1048576
   ASAM Dataset: EV_SeatMemorPasseSide 002022
   ROD: EV_SeatMemorPasseSide.rod
   VCID: 3D273F229DFC661FE23-8068
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 5NB 907 044 J    HW: 5NB 907 044 J
   Component: AC Automat    H35 4301
   Revision: 20K08000    Serial number: 00000B00399017
   Coding: 00020124204111011105100C0010102A
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 47CB5DCACF203CCF48F-8012
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
197122 - Temperature Sensor for Left Vent
          B1087 15 [008] - Open or Short to Plus
                    Reset counter: 187
                    Mileage: 75166 km
                    Date: 2020.04.15
                    Time: 20:50:58
                    Outside air temperature: 17.5 °C
                    Voltage terminal 30: 12.4 V
263425 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Fault Frequency: 11
                    Reset counter: 191
                    Mileage: 75263 km
                    Date: 2020.04.21
                    Time: 13:53:50
                    Outside air temperature: 19.0 °C
                    Voltage terminal 30: 13.3 V
                    System run time-Engine running time: 253 s
                    Air quality status: ERROR
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001703000732
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F5B052AD770B40FB0F-802A
   Subsystem 1 - Part No SW: 5NB 955 119     HW: 5NB 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 170112  033 0372
   Serial number: 00000001701070401325
   Component: RLHS  042 0105
   Serial number: S6Y17M02D07H16M14S33
   Coding: 00A8DD
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
                    Reset counter: 147
   Part No SW: 3Q0 919 298 A    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H10 0021
   Serial number: 003101177478014
   Coding: 0231563A51
   ASAM Dataset: EV_EPHBO2CVW3260000 010016
   ROD: EV_EPHBO2CVW3260000.rod
   VCID: 3B23313A83E8682FDC7-806E
   Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0156
   Coding: 320147CB58FF8728749C8065804085
   ASAM Dataset: EV_ACCMRRCONTIVW376 001011
   ROD: EV_ACCMRRCONTIVW376_001.rod
   Part No SW: 5Q0 959 655 AS    HW: 5Q0 959 655 AS
   Component: AirbagVW21    003 0317
   Serial number: 003TMR2LB8HB
   Coding: 98FCC0C00C0000005C5400CF000800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 117FB392F1E4B27F56B-8044
   Belt Pretensioner left:
   Serial number: 5NB857705C0030R01048
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 5NB857706C0030R01280
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 000 802 17
   Serial number: 357000000002A84D912L
   Subsystem 4 - Part No SW: -----------    HW: 480 000 802 17
   Serial number: 35800000000CA84D912W
   Subsystem 5 - Part No SW: -----------    HW: 480 400 602 17
   Serial number: 3510001A9247FF9603CG
   Subsystem 6 - Part No SW: -----------    HW: 480 400 602 17
   Serial number: 3520001A9247FF9684CQ
   Subsystem 7 - Part No SW: -----------    HW: 480 400 202 17
   Serial number: 3550001A5244A734430R
   Pedestrian Protection Driver:
   Subsystem 8 - Part No SW: -----------    HW: 480 400 602 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001C5247FF96263D
   Subsystem 9 - Part No SW: -----------    HW: 480 400 602 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001C9247FF95036F
   Pedestrian Protection Center:
   Subsystem 10 - Part No SW: -----------    HW: 480 400 602 17
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001C9247FF952336
   Subsystem 11 - Part No SW: -----------    HW: 480 000 502 17
   Serial number: I0M0000000038C48412$
   Subsystem 12 - Part No SW: -----------    HW: 480 000 502 17
   Serial number: I0N0000000049784B121
   Part No SW: 3Q0 953 521 EK    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0225
   Revision: FF036036    Serial number: 20170202500329
   Coding: 0C10
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7DA7FF22DD7CA61FA23-8028
291104 - Temperature Sensor for Heated Steering Wheel
          B1455 01 [008] - Electrical Failure
                    Fault Frequency: 94
                    Reset counter: 191
                    Mileage: 75166 km
                    Date: 2020.04.15
                    Time: 20:56:53
                    Ubat 30 Voltage: 12.50 V
                    Internal error state: 0
                    LIN_Temp: 254
                    Isense: 0
                    Max.Leistung: 110
                    PWM: 0
                    Offset: 254
                    Slope: 133
                    kp: 18
                    OUT: 50
                    Temperatur Statisch: 30
                    p_t_soll_0: 34.00 °C
                    p_t_soll_1: 39.00 °C
                    p_t_soll_2: 44.00 °C
   Part No SW: 5NA 920 791 A    HW: 5NA 920 791 A
   Component: KOMBI         408 2170
   Coding: 07A400186F84000801886B031401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   VCID: 41DF43D2E10402FF86B-8014
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 G    HW: 5Q0 963 272 G
   Component: STH-MQB       008 0075
   Coding: 9309
   VCID: 3A2D343E8CD25127C71-806E
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000182047
   Component: GW MQB High   515 5286
   Serial number: 01021710800659
   Coding: 030500345F087300FB07225E1E0F00010001050000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 2F3B156A4790848F60F-807A
   Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 0191711145601236AP2B
   Coding: 2F0000
   Serial number: 0417452904
   Serial number: HA1-00010.01.17
   Coding: 0101
   VCID: 4ACD64FEDC32C1A7571-801E
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH07 0014
   VCID: 45D757C2F52C2EDFBA3-8010
   Serial number: 17000024576014
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD3129124D27F36B-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Serial number: Y0006RLE16943
   Coding: 0010000000000500018281808181000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 140117EAE23529
   Coding: 003F1B20D200048000001000
   VCID: 43D349DAFB1810EF947-8016
   Revision: 00000000    Serial number: 0001402414
   Coding: 01010011004001
   ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
   VCID: 40D946D6EA0E0BF7895-8014
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Component: FCM MQB Low   001 0285
   Serial number: 15011710524062
   Coding: 000000050100085200104F010A0000000000000000000000000000000000
   VCID: 72BDDC1E9422E967CF1-8026
   Serial number: 060117EA602032
   Coding: 003F1120DE00048000001000
   VCID: 42DD4CDEE40219E79F1-8016
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0751
   Coding: 02730601FF0000005111010100880A231F0100E4012000008E
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 313F131251A4927F76B-8064
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL06THZ
   Subsystem 2 - Part No SW: 3G0 919 866 AQ    HW: -----------
   Component: ECE1 2017  --- 0730
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0204
   Revision: 8A001003    Serial number: 0429536384
   Coding: 0100000202000000
   Coding: 0123060123002017000040
   VCID: 392F2B3289D45A3FCEB-806C
   Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0261
   Revision: --------    Serial number: 31152414400000
   Coding: 0AA8
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 5NA 919 608 A    HW: 5NA 919 608 A
   Component: HeadupDisplay 015 0207
   Coding: 574060
   ASAM Dataset: EV_HeadUpDisplContiVW481 001013
   ROD: EV_HeadUpDisplContiVW481.rod
   VCID: 46D550CEC82A25C7B39-8012
   Serial number: 07021711K11625
   Coding: 000307060000040100221345C050A90094000E200040
   Shop #: WSC 38999 002 1048576
   Serial number: 090916EI809896
   Coding: 002A11200101048000001000
   Serial number: 261016EJP35385
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     013 0005
   Coding: 208040732602
   ROD: EV_SunRoofCONTIAU736_006.rod
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 1675C08ED80A5547039-8042
   Component: LED1R         H09 0003
   ROD: EV_LEDModLeftMELCOAU736_VW48.rod
End----------(Elapsed Time: 02:27, VBatt start/end: 12.2V/12.2V)-----------
jonese
Calgary, CANADA
C?ID=408961
On my 2020 Tiguan (NAR) there is a setting to "syncronize" (or not) the seat and stering wheel heaters. It's a user preference setting accessed from the radio unit (perhaps from the HVAC menu settings, not sure). VCDS was not needed.
bjornix
Norway
C?ID=222439
I completely forgot about the HVAC menu. Even went into the "CAR" menu and thought it was a little strange there were no options for heating and ventilation there... :banghead:
Anyway, you were spot on! :thumbs: Press the physical "MENU" button on the HVAC controller, go to settings on the HU and the option to connect / disconnect seat- and steering wheel heaters is right there. Even an option to lower the intensity on the steering wheel heater which may have sufficed (I set it to 'low' from 'medium', haven't tested that yet).
