2019 Jetta, 1.4T DGXA
Jef
HQ
AutoScan: 3VWC57BU2KM121617
VCDS Version: 20.9.1.0 (x64)  HEX-NET2 CB: 0.4529.4
Data version: 20200919 DS322.0
VIN: 3VWC57BU2KM121617   License Plate:
Chassis Type: BU-VW37 (3Q0)
Scan: 01 02 03 08 09 13 15 17 19 3C 42 44 52 5F
VIN: 3VWC57BU2KM121617   Mileage: 67972km-42235miles
Address 01: Engine (J623-DGXA)       Labels: None
   Part No SW: 04E 906 024 AF    HW: 04E 907 309 BT
   Component: R4 1.4l TSI   H20 6809
   Revision: D4H20000
   Coding: 012A0012232411086000
   Shop #: WSC 00066 790 00384
   ASAM Dataset: EV_ECM14TFS01104E906024AF 002004
   ROD: EV_ECM14TFS01104E906024AF.rod
   VCID: E59C5ADE35E2DF7374D-80B0
17158 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
4675 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [032] - -
          [ABS brake control moduleRead out DTC]
23620 - Oxygen (Lambda) Sensor B1 S1
          P0133 00 [096] - Response too Slow
Address 02: Auto Trans (J217)       Labels: Redir Fail!
   Part No SW: 09S 927 158 R    HW: 09S 927 158
   Component: AISIN 8G30/18 301 3587
   Coding: 0100000100000000000000000000000000000000
   Shop #: WSC 00066 790 00134
   ASAM Dataset: EV_TCMAQ300031 001008
   ROD: EV_TCMAQ300031_VW37.rod
   VCID: CECE857240543C2B257-809A
33963 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
   Part No SW: 5Q0 614 517 DG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0654
   Revision: 00000000    Serial number: 52278000000585
   Coding: 70FB6AA12422216DC57D0201A0CA250E562484A34005A4701041F058C282430B00000012121212B835351919323200
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: F9A406AEA95A4B93A05-80AC
blockmap-01-04E-906-024-AF_3VWC57BU2KM121617-20201017-1231.CSV
;Component:R4 1.4l TSI   H20 6809, Coding:012A0012232411086000
;EV_ECM14TFS01104E906024AF,002004,EV_ECM14TFS01104E906024AF.rod
;Saturday,17,October,2020,12:31:45:14741
;VCDS Version: Beta 20.9.1 (x64)  Data version: 20200919 DS322.0
;VCID: E59C5ADE35E2DF7374D-80B0
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),3VWC57BU2KM121617,
IDE00019,Voltage terminal 30,13.260, V
IDE00020-ENG57549,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine RPM,876, /min
IDE00025,Coolant temperature,36, °C
IDE00078,Time since engine start,89, s
IDE00083,Throttle valve position (absolute),12.9, %
IDE00084,Absolute load value,25, %
IDE00085,Normed load value,21.6, %
IDE00086,Accelerator pedal position,15, %
IDE00090-ENG57549,selected gear-Bits 0-7,0,
IDE00094,Kick-down status,Not operated,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00100,Engine torque,31.6, Nm
IDE00148,Mean injection time,1.031, ms
IDE00150,Pressure in brake servo unit,342.30, hPa
IDE00151,Oil fill level,66.320, mm
IDE00152,Oil warning threshold,45.000, mm
IDE00155,Ignition timing angle retard cylinder 1,0.0, °
IDE00156,Ignition timing angle retard cylinder 2,0.0, °
IDE00157,Ignition timing angle retard cylinder 3,0.0, °
IDE00158,Ignition timing angle retard cylinder 4,0.0, °
IDE00167,Exhaust temperature 1 bank 1,420.6, °C
IDE00172,A/C compressor torque,20.0, Nm
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-24.102, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-23.820, °
IDE00178,Camshaft adjustment intake bank 1: specified value,20.813, °
IDE00179,Camshaft adjustment intake bank 1: actual value,20.945, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.00, °
IDE00187,Coolant temperature at engine start,12.0, °C
IDE00188,Fuel high-pressure: actual value,10.004, MPa
IDE00190,Charge air pressure: specified value,364.77, hPa
IDE00191,Charge air pressure: actual value,989.45, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,13.2, °C
IDE00194,Coolant temperature at radiator output: specified value,95.3, °C
IDE00196,Engine oil temperature,11.0, °C
IDE00201,High fuel pressure: specified value,10.000, MPa
IDE00202,Low fuel pressure: specified value,415.0, kPa
IDE00304,Fuel level,43.00, l
IDE00348,Intake air temperature,18, °C
IDE00349,Throttle valve position: normed,3, %
IDE00350,Air mass: specified value,11.5, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG57549,Cruise Control System (CCS): status-Bits 0-7,0,
IDE00357,Fuel temperature,10.5, °C
IDE00358,Limitation: torque,1000.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,993.98, hPa
IDE00371,Fuel consumption,0.99, l/h
IDE00375,Generator: load signal,32.23, %
IDE00380,Coolant fan 1: activation,29.29, %
IDE00392,Accelerator pedal: sensor voltage 1,739.8, mV
IDE00393,Accelerator pedal: sensor voltage 2,377.0, mV
IDE00394,Camshaft position: start of phase window,111.67, °
IDE00406,Camshaft RPM,437.0, /min
IDE00407-ENG57549,Rail pressure regulation: status-Bits 0-7,1,
IDE00412-ENG57549,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG57549,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG57549,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG57549,Starter control: terminal 50 feedback-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,1,
IDE00432,Particle filter: time since last regeneration,0.000, H
IDE00434,Particle filter: soot mass calculated,324, mg
IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,9,
IDE00451,Currently running routine,Unknown (0),
IDE00474,Ambient air pressure,99, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,11.7, Nm
IDE00496-ENG57549,Oil pressure switch valve activation-Bits 0-7,1,
IDE00497-ENG57549,Status of oil pressure switches-Bits 0-7,37,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside temperature,16, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),1.005 Lambda / -0.016 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.850, V
IDE00582,Specified value of equivalence ratio,1.000, Lambda
IDE00583,Throttle valve specified value,4, %
IDE00584,Distance driven since erasing DTC memory,65535, km
IDE00588,Fuel tank fill level,90.6, %
IDE00592,Status of oxygen sensor control,Closed loop,  / using O2 sensors ,
IDE00593,Ignition timing adjustment cylinder 1,3.5, Degrees
IDE00594,Absolute intake pressure,33, kPa abs
IDE00597,Long term adaptation of mixture formation bank 1,-3.9, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,255,
IDE00604,Short term adaptation of mixture formation bank 1,5.5, %
IDE00608,Fuel type,Gasoline,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00699,ESI: minimum oil level in service interval,-0.048, mm
IDE00700,ESI: maximum oil level in service interval,14.012, mm
IDE00738,Oxygen sensor test: bank 1: delta lambda,0.00021,
IDE00752,Oxygen sensor control test,Test off,
IDE00752-ENG127302,Oxygen sensor control test-Test_Program_Channel 213,235,
IDE00773,Terminal 15 status via CAN,1,
IDE00949,Hide cylinder,not active,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE00973,Outside temperature,16.5, °C
IDE01098,Test of knock sensors: short trip result,Test off,
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,0.0000,
IDE01260,Generator performance,546.637, W
IDE01267,Height correction,0.98120,
IDE01378,Fuel high pressure: control deviation,-0.0080, MPa
IDE01385-ENG57549,Wear index-Bits 0-7,0,
IDE01386-ENG57549,Soot index-Bits 0-7,0,
IDE01407,Particle filter: fuel consumption since last regeneration,0.000, l
IDE01644,Oxygen sensor voltage B1 downstream CAT,0.850, V
IDE01650,Throttle valve position 2,13, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test off,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,235,
IDE01680,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve,Test off,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
IDE01773,Misfire totalizer,0,
IDE01774,Status misfire recognition,activated,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,103,
IDE01834,Battery voltage,13260, mV
IDE01869,Long-term fuel trim bank 1 at idle,-0.52, %
IDE01870,Oxygen sensor after catalytic converter: operating status,B1-S2 OK,
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,209,
IDE01872,Result of oxygen sensor aging test after catalytic converter,Test off,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,235,
IDE01873,Test of catalytic converter: measured value,9.1538,
IDE01874,Test of catalytic converter: result,Test off,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
IDE01876,Adaptation of loss torque,2.4, Nm
IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,5,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000100 ,
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator pedal position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01884,Camshaft adjustment intake bank 1: activation,31.743, %
IDE01885,Shut off of oxygen sensor control,l-Reg.ON,
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,4,
IDE01888,Cold start enrichment: adaptation area 1,0.953,
IDE01889,Cold start enrichment: adaptation area 2,0.922,
IDE01890,Cold start enrichment: adaptation area 3,0.875,
IDE01891,Cold start enrichment: adaptation area 4,0.852,
IDE01892,Cold start enrichment: adaptation area 5,0.852,
IDE01893,Fuel pump: specified value,48.599, %
IDE01898,Load value: specified value,106.24, %
IDE01900,Charge press. ctrl.: spec. value,99.6, %
IDE01901,Lost torque adaptation: idle,0.5, Nm
IDE01902,Lost torque adaptation A/C compressor,2.4, Nm
IDE01903,Lost torque adaptation driving mode,-1.6, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,-2.4, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,1.04340,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,1.07910,
IDE01911,Leakage air,3.7, kg/h
IDE01912,Oxygen sensor B1: sensor 1: specified value,1.0000,
IDE01914-ENG57549,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bits 0-7,170,
IDE01922,Vehicle distance driven,67972, km
IDE01923,Control module distance driven,67961591, m
IDE01928,Close cam shaft angle at quantity control valve,25.4, °
IDE01929,Open cam shaft angle at quantity control valve,-4.4, °
IDE01930,High pressure regulation: adaptation value,-0.024, MPa
IDE01932,High pressure pump injection volume,-0.10, mm³
IDE01975,Numb.of misfir.: cylinder 1,10084,
IDE01976,Numb.of misfir.: cylinder 2,9521,
IDE01977,Numb.of misfir.: cylinder 3,7925,
IDE01978,Numb.of misfir.: cylinder 4,7756,
IDE02115-ENG57549,Requirements for basic setting-Bits 0-7,158,
IDE02116,Exhaust gas temperature before catalytic converter,256.96, °C
IDE02117,Relative load value,23.18, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,2.67, MPa
IDE02540-ENG57549,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02756,Number of manual engine starts,4003,
IDE02757,Number of automatic engine starts,4616,
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function prevention,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,active,
IDE03008-MAS06604,Stop process prevented-Start/stop sensors:,active,
IDE03008-MAS06605,Stop process prevented-Regeneration Mode,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,1299,
IDE03010-MAS01627,Number of prevented stop processes-Steering,1760,
IDE03010-MAS02040,Number of prevented stop processes-Anti-play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function prevention,8,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,1798,
IDE03010-MAS04591,Number of prevented stop processes-Air system diagnosis,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery performance too low,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary equipment power consumption too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Thermostat testing not completed,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,4379,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,1079,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration Mode,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,107,
IDE03010-MAS08032,Number of prevented stop processes-DTC memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Learning function active,0,
IDE03010-MAS11563,Number of prevented stop processes-hood open,15,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,551,
IDE03010-MAS12864,Number of prevented stop processes-Slow traffic detected,2920,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Engine protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel gelling protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust treatment diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,2,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function prevention,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery performance too low,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary equipment power consumption too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,158,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-CAT heating,0,
IDE03011-MAS11563,Number of requested start processes-hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,9,
IDE03011-MAS13644,Number of requested start processes-Engine protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel gelling protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test off,
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,235,
IDE03262,Adapt of angle sensor 1 f throttle valve,0.492, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.504, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.839, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.153, V
IDE03362,Requested transmission torque,1000.0, Nm
IDE03377,Coolant temp at radiator output: unconditioned voltage,3814.2, mV
IDE03393-ENG57549,Selector lever position-Bits 0-7,8,
IDE03584-ENG57549,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03586-ENG57549,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stopping requirements for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stopping requirements for active participants-Air Conditioning,not active,
IDE03587-MAS00127,Stopping requirements for active participants-brakes,not active,
IDE03587-MAS00506,Stopping requirements for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stopping requirements for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stopping requirements for active participants-Transmission,not active,
IDE03587-MAS01106,Stopping requirements for active participants-Level control system,not active,
IDE03587-MAS01490,Stopping requirements for active participants-Energy management,not active,
IDE03587-MAS01627,Stopping requirements for active participants-Steering,not active,
IDE03587-MAS02237,Stopping requirements for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stopping requirements for active participants-All-wheel drive electronics,not active,
IDE03587-MAS03757,Stopping requirements for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stopping requirements for active participants-Motor,active,
IDE03587-MAS06709,Stopping requirements for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stopping requirements for active participants-Parking aid,not active,
IDE03587-MAS13018,Stopping requirements for active participants-Front sensor for drivers assistant systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-Air Conditioning,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel drive electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Motor,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor for drivers assistant systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication malfunction,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03692-ENG57549,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,138,
IDE03693-ENG57549,Monitoring status of additional Onboard Diagnosis-Bits 0-7,161,
IDE03709,Angle difference actual-specified camshaft adjuster,-0.305, °
IDE03711,Mass flow through throttle valve,10.7, kg/h
IDE03767,Engine status,COENG_RUNNING,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,21.802, %
IDE03805,Test of brake booster pump: result,Test off,
IDE03805-ENG127323,Test of brake booster pump: result-Test_Program_Channel 603,235,
IDE03806-ENG57549,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,3,
IDE03807-ENG57549,O2 Sensor B1-S2: Status-Bits 0-7,2,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,816.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,0,
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.OFF,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,147.38, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,38.065, %
IDE03932,Charge pressure actuator: specified position,160.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3203.4, mV
IDE03935,Charge air pressure actuator: adaptation for upper stop,103.4, mV
IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,1,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.99042,
IDE04002,Charge air pressure control,BP_A act:99, kPa
IDE04003,Charge air temperature sensor,B1S1:18 °C /  °C,
IDE04010,Engine torque: normalized,10, %
IDE04011,Nominal torque,280, Nm
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:9920/--- kPa,
IDE04083,Coolant temperatures,ECT 1:38 °C / ECT 2:13 °C,
IDE04088,Turbocharger 1: temperature,Compr. in/out---/21 °C / Compr. in/out---/--- °C,
IDE04110,Additional inputs and outputs,,
IDE04278,Bypass valve f high press turboch turbine inlet: target value,100.00, %
IDE04279,Bypass valve f high press turboch turbine inlet: actual value,98.89, %
IDE04280,Bypass valve f high press turboch turbine inlet: offset closed,0.43, %
IDE04281,Bypass valve f high press turboch turbine inlet: offset open,-0.43, %
IDE04301,Bypass valve for high press turboch turbine inlet: activation,10.54, %
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,7,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,64,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,18,
IDE04303,Bypass valve for high press turboch turbine inlet: uncond volt,3171.8, mV
IDE04410,Intake manifold pressure: specified value,342.81, hPa
IDE04420,Secondary air system activation,Atmosphere/off,
IDE04604,Accelerator pedal travel,0.00, %
IDE04651,Torque request: A/C compressor,5.5, Nm
IDE04654-ENG57549,CAN status - engine control module-Bits 0-7,0,
IDE04670,Crankshaft signal evaluation: status,GAPFOUND,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,7,
IDE04677,Oxygen sensor 1 bank 1: lambda actual value,0.9995,
IDE04685,Setpoint generation interior torque,30.6, Nm
IDE04693,Increasing desired torque intervention of ESP,-55705.6, Nm
IDE04695-ENG99946,Immobilizer snapshot A-Sia Error Snap A,00 00 00,
IDE04696-ENG102592,Immobilizer snapshot B-Sia Error Snap B,00 00 00,
IDE04858,Brake booster low pressure actual value,655.98, hPa
IDE04887,Powertrain target torque,-23.0, Nm
IDE04889,Target torque for combustion engine crankshaft level,11.1, Nm
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05140,Intake manifold pressure raw value,332.97, hPa
IDE05221,Electric drive torque: actual value,0.0, Nm
IDE05240-ENG57549,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG57549,A/C compressor release status-Bits 0-7,1,
IDE05261-ENG57549,Gear position sensor: last valid value-Bits 0-7,14,
IDE05332-ENG57549,Heat request from heater to thermal management-Bits 0-7,3,
IDE05436,Engine operating condition,Idle,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05437,Outside air temperature via CAN,15.8, °C
IDE05438,Rear cat conv temp main cat conv model value,243.25, °C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000008,
IDE05441,ESI: Wear equivalent 2 calculated from wear index,0.00000000,
IDE05442,Roadway slope angle acceleration interface: calculated,0.0000, rad
IDE05444,Air filling: specified value,23.93, %
IDE05449,O2 sensor 2: B1: internal resistance limit,34500, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00046,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,719.92, °C
IDE05470,Cat converter oxygen storage capacity,601.8, mg
IDE05472,Cat converter oxygen storage capacity ref standardized,0.0000,
IDE05474,Main cat converter OSC age correction factor,0.797,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05478,Exh mss flw bef main cat conv bank 1 filtered,11.5, kg/h
IDE05479,Misfire recognition reference moment,7.745, %
IDE05482,Tank venting adaptation factor,0.000,
IDE05485-ENG57549,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05508,Adaptation val cyl 1 with slow diagnosis,1.00000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,1.00000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,1.00000,
IDE05511,Adaptation val cyl 2 with slow diagnosis,1.00000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,1.00000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,1.00000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,1.00000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,1.00000,
IDE05593,Secondary air injection sensor 1,993.87, hPa
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,30,
IDE05797,Throttle valve adapter: specified value,3.929, %
IDE06015,Time since terminal 15 off: start/stop,65535, s
IDE06017,Camshaft position deviation from reference position,0.00, °
IDE06020,Intake air temperature in intake manifold bank raw value,18.8, °C
IDE06021,Intake air temperature before throttle valve: raw value,21.0, °C
IDE06023-ENG57549,BDE operating mode flag register-Bits 0-7,1,
IDE06039,Required RPM at idle speed,875.0, /min
IDE06040,High fuel pressure: regulator output value,-0.0060, MPa
IDE06045-ENG57549,Output diagnostic test status-Bits 0-7,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06049,Pressure in brake booster: raw value,338.01, hPa
IDE06059,Particulate filter: oil ash mass,0.00, g
IDE06098,Sensor control factor: output value,1.05350,
IDE06307-MAS00106,Stop prevention history data-Year,2020,
IDE06307-MAS00107,Stop prevention history data-Month,10,
IDE06307-MAS00108,Stop prevention history data-Day,15,
IDE06307-MAS00109,Stop prevention history data-Hours,17,
IDE06307-MAS00110,Stop prevention history data-Minutes,14,
IDE06307-MAS00111,Stop prevention history data-Seconds,36,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Driving situation,
IDE06308-MAS00106,Start request history data-Year,2020,
IDE06308-MAS00107,Start request history data-Month,8,
IDE06308-MAS00108,Start request history data-Day,5,
IDE06308-MAS00109,Start request history data-Hours,12,
IDE06308-MAS00110,Start request history data-Minutes,50,
IDE06308-MAS00111,Start request history data-Seconds,14,
IDE06308,Start request history data,not active,
IDE06308,Start request history data,Brake under pressure too low,
IDE06386,Oil level: static measurement,69.904, mm
IDE06387,Oil level: last valid dynamic value,-0.048, mm
IDE06388,Oil level: condition for static measurement fulfilled,0,
IDE06393,Oil level: dynamic average value,21.356, mm
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06446-ENG57549,Status: incline angle-Bits 0-7,1,
IDE06567,Frequency counter deactivate start/stop function,2117,
IDE06568,Stop prevention by driver frequency counter,15300,
IDE06569,Frequency counter vehicle standstill,29069,
IDE06610,Frequency counter vehicle standstill with stop,6445,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,130,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,0,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,8,
IDE06703-ENG57549,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06704-ENG57549,Drivetrain coordinator: brake fault status-Bits 0-7,0,
IDE06706-ENG57549,ACC variants-Bits 0-7,0,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,0,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,32,
IDE06709-ENG57549,ACC variants (coding)-Bits 0-7,1,
IDE06711-ENG57549,Cruise control system: temporary deactivation-Bits 0-7,255,
IDE06758,Air mass since engine start,0.64, kg
IDE06759,Cam shaft adaptation inlet: counter,3,
IDE06760,Camshaft adaptation: exhaust: counter,3,
IDE06946-ENG57549,Brake actuated status-Bits 0-7,3,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,12,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,98,
IDE07051-ENG57549,Engaged gear: raw signal-Bits 0-7,0,
IDE07094,Correction factor injector cylinder 1,1.0127,
IDE07095,Correction factor injector cylinder 2,1.0000,
IDE07096,Correction factor injector cylinder 3,0.9780,
IDE07097,Correction factor injector cylinder 4,1.0090,
IDE07164,Number injections,4081,
IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
IDE07224-ENG57549,Overrun cut-off-Bits 0-7,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,66,
IDE07234,Status bid for valid static oil level,1,
IDE07235,Status bid for dynamic oil level,0,
IDE07257,Tank pressure from leakage diagnosis: calculated,0.000, hPa
IDE07573,Throttle valve adapter: actual value,4.05, %
IDE07693,Maximum supply pressure low-pressure fuel pump,0.0, kPa
IDE07697,System test status of fuel supply,32,
IDE07796-ENG57549,Turboch. 1 turb.byp.v. 1 bank 1: pos.feedback -Breakaw.attempts-Bits 0-7,0,
IDE07904-ENG57549,Brake test switch status-Bits 0-7,1,
IDE07905-ENG57549,Brake light switch status-Bits 0-7,1,
IDE07906-ENG57549,Upper clutch switch: status-Bits 0-7,0,
IDE08562,Basic correction factor: Injector cyl. 1: filtered,0.9896,
IDE08563,Basic correction factor: Injector cyl. 2: filtered,1.0013,
IDE08564,Basic correction factor: Injector cyl. 3: filtered,1.0031,
IDE08565,Basic correction factor: Injector cyl. 4: filtered,1.0057,
IDE09307-ENG57549,Pre-ignition counter cylinder 1-Bits 0-7,0,
IDE09308-ENG57549,Pre-ignition counter cylinder 2-Bits 0-7,0,
IDE09308-ENG57549,Pre-ignition counter cylinder 2-Bits 0-7,1,
IDE09309-ENG57549,Pre-ignition counter cylinder 3-Bits 0-7,1,
IDE09309-ENG57549,Pre-ignition counter cylinder 3-Bits 0-7,0,
IDE09310-ENG57549,Pre-ignition counter cylinder 4-Bits 0-7,0,
IDE09313-ENG57549,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,0,
IDE09314-ENG57549,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,0,
IDE09314-ENG57549,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,1,
IDE09315-ENG57549,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,1,
IDE09315-ENG57549,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,0,
IDE09316-ENG57549,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,0,
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
IDE09925-ENG57549,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09927,Intake camshaft bank 1: adaption hardware offset active,False result,
IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,-1.188, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,0.898, °
IDE09931,Outlet camshaft bank 1: adaption value sensor tolerance,-1.10, °
IDE09932,Intake camshaft B1: adaptation value sensor tolerance,0.83, °
IDE10040,Outlet camshaft bank 1 active operating mode,1,
IDE10041-ENG57549,Intake camshaft B1 active operating state-Bits 0-7,0,
IDE10041-ENG57549,Intake camshaft B1 active operating state-Bits 0-7,1,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10302,Time since engine start,124.3, s
IDE10303,Integrated air masse at first engine start,0.6610, kg
IDE10641,Low fuel pressure adaptation value for EFP: modeled,90.0, kPa
IDE10970-MAS11563,Number of prevented stop processes-hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2127,
IDE10989-MAS00107,Immobilizer: historic data-Month,15,
IDE10989-MAS00108,Immobilizer: historic data-Day,31,
IDE10989-MAS00109,Immobilizer: historic data-Hours,31,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,63,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,63,
IDE10989,Immobilizer: historic data,hood open,
IDE10989,Immobilizer: historic data,Brake pedal information: plausibility,
IDE10989,Immobilizer: historic data,Function locked due to frequent stalling,
IDE10994,Poor start counter at start-stop,0,
IDE11115,Start/stop driver request: counter restart by starter,356,
IDE11116,Start/stop driver request: counter internal-motor restart,193,
IDE11293,Fuel consumption difference: injectors/sensors,0.000, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,3.516, l
IDE12197,High-pressure fuel injection valve adapted value: cylinder 1,19.26, %
IDE12199,High-pressure fuel injection valve adapted value: cylinder 2,-2.72, %
IDE12200,High-pressure fuel injection valve adapted value: cylinder 3,-25.66, %
IDE12201,High-pressure fuel injection valve adapted value: cylinder 4,6.20, %
IDE12210,Particle filter: water mass,0.0, g
IDE12355,ESI: consumption equivalent of the engine control module,0.00000054,
IDE12460,Low pressure procedure: pressure regulation valve open,0.00, kPa
IDE12461,Pressure regulator valve pulse duty factor,0.00, %
IDE12462,Pressure regulator valve opening pressure,0.0, kPa
IDE12463,Pressure regulator valve minimum pulse duty factor,False result,
IDE12463-ENG127289,Pressure regulator valve minimum pulse duty factor-Test_Program_B TRUE UBYTE,0,
IDE12464,Rail pressure at end of test,0.000, MPa
IDE12936,Ignition angle: bank 1 raw value,3.8, °
IDE13084,Particle filter: high level moisture buildup,1000.0, g
IDE13085,Particle filter: high level of soot buildup,5600, mg
IDE13086,Particle filter: maximum soot build-up reached,8000, mg
IDE13087,Particle filter: maximum ash build-up reached,30, g
MAS15845,Fuel: tank fill level,43.3, l
MAS15866,High pressure buildup gradient during pressure limitation valve opening test,0.000, MPa/revolution
MAS15883,Maximum fuel high-pressure with extended value range,0.000, MPa
MAS16287,High pressure buildup process with engine of: extended range,0.000, MPa/s
MAS16534-ENG57549,A/C compressor info: switch-off status-Bits 0-7,0,
MAS16834,Particle filter threshold rate of blockage calculated,3.0000,
MAS16835,Particle filter rate of blockage calculated,1.0000,
MAS17189,Exhaust pressure sensor 1: raw value,0.0, hPa
ENG119898,Actual_section_of_standard_test,0,
ENG112928-ENG57549,Air_conditioning_compressor_actual_status-Bits 0-7,1,
ENG101413,Calibration Identification,04E024AF6809DXAA,
ENG99697,Calibration Verification Number,D4 B4 D5 D3,
ENG126402-ENG57549,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG115973,Engine Exhaust Flow Rate,11.6, kg/h
ENG20102,Engine Friction - Percent Torque,7.0, %
ENG115974-ENG55378,Fuel Rate-Engine Fuel Rate,0.60, g/s
ENG115974-ENG116137,Fuel Rate-Vehicle Fuel Rate,0.60, g/s
ENG123647,Gsl Pfil dst Veh Cyc Rgn VW,0.000, km
ENG100634,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2,05 2D 0E FD 07 E1 05 2C 00 00 00 00 06 1F 05 2C 00 00 00 00 0B C8 05 2D 03 57 01 92 01 04 00 B8 05 6E 05 2C 00 00 00 00 02 E6 05 2D 00 00 00 00 00 00 00 00 00 00 00 00,
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2020,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,9,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,27,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,10,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,17,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,17,
ENG127734,Life_cycle_data_start_requirement_development,not active,
ENG127734,Life_cycle_data_start_requirement_development,Steering,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2020,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,10,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,6,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,11,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,45,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,30,
ENG127735,Life_cycle_data_stop_prohibition_development,not active,
ENG127735,Life_cycle_data_stop_prohibition_development,Motor,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2020,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,2,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,14,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,13,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,0,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,12,
ENG127733,Life_cycle_data_system_failure,not active,
ENG127733,Life_cycle_data_system_failure,brakes,
ENG112668,O2 sensor_controller_bank_1_p-rate,0.00000,
ENG115975-ENG116124,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG115975-ENG116108,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG115975-ENG116105,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG115975-ENG116116,Transmission Actual Gear-Transmission Actual Gear Status Supported,available.,
ENG115976,Vehicle Odometer,67972.7, km
Elapsed Time: 00:39
blockmap-01-04E-906-024-AF_3VWC57BU2KM121617-20201017-1246.CSV
;Saturday,17,October,2020,12:46:08:14741
IDE00019,Voltage terminal 30,13.320, V
IDE00021,Engine RPM,760, /min
IDE00025,Coolant temperature,79, °C
IDE00078,Time since engine start,952, s
IDE00083,Throttle valve position (absolute),11.4, %
IDE00084,Absolute load value,19, %
IDE00085,Normed load value,15.7, %
IDE00100,Engine torque,21.0, Nm
IDE00148,Mean injection time,0.607, ms
IDE00150,Pressure in brake servo unit,306.05, hPa
IDE00151,Oil fill level,75.184, mm
IDE00152,Oil warning threshold,45.976, mm
IDE00167,Exhaust temperature 1 bank 1,517.2, °C
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-24.781, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-24.633, °
IDE00178,Camshaft adjustment intake bank 1: specified value,19.906, °
IDE00179,Camshaft adjustment intake bank 1: actual value,20.016, °
IDE00182,Camshaft adaptation intake bank 1: phase position,1.21, °
IDE00188,Fuel high-pressure: actual value,10.002, MPa
IDE00190,Charge air pressure: specified value,313.91, hPa
IDE00191,Charge air pressure: actual value,991.56, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,24.7, °C
IDE00196,Engine oil temperature,58.1, °C
IDE00348,Intake air temperature,32, °C
IDE00349,Throttle valve position: normed,2, %
IDE00350,Air mass: specified value,6.6, kg/h
IDE00357,Fuel temperature,44.3, °C
IDE00371,Fuel consumption,0.59, l/h
IDE00375,Generator: load signal,35.46, %
IDE00380,Coolant fan 1: activation,10.15, %
IDE00392,Accelerator pedal: sensor voltage 1,744.6, mV
IDE00393,Accelerator pedal: sensor voltage 2,378.4, mV
IDE00394,Camshaft position: start of phase window,111.51, °
IDE00406,Camshaft RPM,372.5, /min
IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,8,
IDE00477,Torque request: sum of auxiliary aggregate,3.9, Nm
IDE00556,Outside temperature,21, °C
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.165, V
IDE00583,Throttle valve specified value,2, %
IDE00588,Fuel tank fill level,89.4, %
IDE00593,Ignition timing adjustment cylinder 1,4.5, Degrees
IDE00594,Absolute intake pressure,28, kPa abs
IDE00597,Long term adaptation of mixture formation bank 1,-3.1, %
IDE00604,Short term adaptation of mixture formation bank 1,2.3, %
IDE00612,Target position of EVAP canister valve,6.7, %
IDE00738,Oxygen sensor test: bank 1: delta lambda,0.00000,
IDE00973,Outside temperature,21.0, °C
IDE01260,Generator performance,245.044, W
IDE01644,Oxygen sensor voltage B1 downstream CAT,0.170, V
IDE01650,Throttle valve position 2,11, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Syst. OK,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,228,
IDE01834,Battery voltage,13300, mV
IDE01869,Long-term fuel trim bank 1 at idle,-0.28, %
IDE01872,Result of oxygen sensor aging test after catalytic converter,B1-S2 OK,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,209,
IDE01876,Adaptation of loss torque,0.5, Nm
IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,0,
IDE01884,Camshaft adjustment intake bank 1: activation,31.607, %
IDE01893,Fuel pump: specified value,48.035, %
IDE01898,Load value: specified value,107.58, %
IDE01909,Short term adapt. throttle valve for mass air flow sensor,0.97644,
IDE01928,Close cam shaft angle at quantity control valve,22.5, °
IDE01929,Open cam shaft angle at quantity control valve,-4.0, °
IDE01932,High pressure pump injection volume,0.10, mm³
IDE01976,Numb.of misfir.: cylinder 2,9522,
IDE01978,Numb.of misfir.: cylinder 4,7757,
IDE02115-ENG57549,Requirements for basic setting-Bits 0-7,191,
IDE02116,Exhaust gas temperature before catalytic converter,386.36, °C
IDE02117,Relative load value,17.37, %
IDE02211,Brake pressure,0.00, MPa
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03377,Coolant temp at radiator output: unconditioned voltage,3347.8, mV
IDE03587-MAS05129,Stopping requirements for active participants-Motor,not active,
IDE03692-ENG57549,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,128,
IDE03709,Angle difference actual-specified camshaft adjuster,-0.070, °
IDE03711,Mass flow through throttle valve,6.3, kg/h
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,30.293, %
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,560.000, Ohm
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,147.50, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,32.227, %
IDE04003,Charge air temperature sensor,B1S1:32 °C /  °C,
IDE04010,Engine torque: normalized,7, %
IDE04083,Coolant temperatures,ECT 1:80 °C / ECT 2:24 °C,
IDE04088,Turbocharger 1: temperature,Compr. in/out---/36 °C / Compr. in/out---/--- °C,
IDE04279,Bypass valve f high press turboch turbine inlet: actual value,99.96, %
IDE04301,Bypass valve for high press turboch turbine inlet: activation,10.53, %
IDE04303,Bypass valve for high press turboch turbine inlet: uncond volt,3205.0, mV
IDE04410,Intake manifold pressure: specified value,291.17, hPa
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04677,Oxygen sensor 1 bank 1: lambda actual value,0.9993,
IDE04685,Setpoint generation interior torque,21.4, Nm
IDE04858,Brake booster low pressure actual value,700.00, hPa
IDE04887,Powertrain target torque,28.5, Nm
IDE04889,Target torque for combustion engine crankshaft level,5.8, Nm
IDE05135,Status of compressor release,Correct result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,1,
IDE05140,Intake manifold pressure raw value,283.67, hPa
IDE05241-ENG57549,A/C compressor release status-Bits 0-7,0,
IDE05438,Rear cat conv temp main cat conv model value,341.64, °C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000000,
IDE05444,Air filling: specified value,17.63, %
IDE05449,O2 sensor 2: B1: internal resistance limit,7994, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00064,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,719.99, °C
IDE05478,Exh mss flw bef main cat conv bank 1 filtered,7.4, kg/h
IDE05479,Misfire recognition reference moment,4.897, %
IDE05482,Tank venting adaptation factor,1.078,
IDE05797,Throttle valve adapter: specified value,2.095, %
IDE06017,Camshaft position deviation from reference position,-0.02, °
IDE06020,Intake air temperature in intake manifold bank raw value,32.3, °C
IDE06021,Intake air temperature before throttle valve: raw value,36.0, °C
IDE06039,Required RPM at idle speed,750.0, /min
IDE06040,High fuel pressure: regulator output value,0.0040, MPa
IDE06049,Pressure in brake booster: raw value,293.91, hPa
IDE06098,Sensor control factor: output value,1.02811,
IDE06758,Air mass since engine start,3.64, kg
IDE06759,Cam shaft adaptation inlet: counter,0,
IDE06760,Camshaft adaptation: exhaust: counter,0,
IDE06946-ENG57549,Brake actuated status-Bits 0-7,0,
IDE07094,Correction factor injector cylinder 1,1.0253,
IDE07095,Correction factor injector cylinder 2,0.9985,
IDE07096,Correction factor injector cylinder 3,0.9644,
IDE07097,Correction factor injector cylinder 4,1.0127,
IDE07164,Number injections,38614,
IDE07573,Throttle valve adapter: actual value,2.08, %
IDE07904-ENG57549,Brake test switch status-Bits 0-7,0,
IDE07905-ENG57549,Brake light switch status-Bits 0-7,0,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,-2.109, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,0.195, °
IDE10302,Time since engine start,987.5, s
IDE10303,Integrated air masse at first engine start,3.6679, kg
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,3.770, l
IDE12355,ESI: consumption equivalent of the engine control module,0.00000016,
IDE12936,Ignition angle: bank 1 raw value,0.0, °
MAS15845,Fuel: tank fill level,43.1, l
ENG112928-ENG57549,Air_conditioning_compressor_actual_status-Bits 0-7,0,
ENG115973,Engine Exhaust Flow Rate,7.2, kg/h
ENG20102,Engine Friction - Percent Torque,4.0, %
ENG115974-ENG55378,Fuel Rate-Engine Fuel Rate,0.36, g/s
ENG115974-ENG116137,Fuel Rate-Vehicle Fuel Rate,0.36, g/s
ENG100634,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2,05 2D 0E FD 07 E1 05 2C 00 00 00 00 06 1F 05 2C 00 00 00 00 0B C9 05 2D 03 57 01 92 01 04 00 B8 05 6E 05 2C 00 00 00 00 02 E6 05 2D 00 00 00 00 00 00 00 00 00 00 00 00,
Elapsed Time: 00:40
blockmap-02-09S-927-158-R_3VWC57BU2KM121617-20201017-1232.CSV
;Component:AISIN 8G30/18 301 3587, Coding:0100000100000000000000000000000000000000
;EV_TCMAQ300031,001008,EV_TCMAQ300031_VW37.rod
;Saturday,17,October,2020,12:32:27:14741
;VCID: CECE857240543C2B257-809A
IDE00008-ENG103646,Software version-VW Application Software Version Number,3587,
IDE00018,Voltage terminal 15,13.0, V
IDE00019,Voltage terminal 30,13.3, V
IDE00019,Voltage terminal 30,13.338, V
IDE00021,Engine RPM,875, /min
IDE00022-ENG103074,Transmission input speed-Transmission Input Speed Sensor,833, /min
IDE00023,Transmission output speed,0, /min
IDE00024-ENG98981,ATF temperature-Transmission fluid temperature,13, °C
IDE00025-ENG101037,Coolant temperature-Engine coolant temperature,39.75, °C
IDE00025,Coolant temperature,40, °C
IDE00026,Vehicle speed from transmission,0.00, km/h
IDE00031-ENG101217,Torque transmitting function-Transmission function,0.0,
IDE00037-MAS02112,Programmability status-Programmability,programmable,
IDE00037-MAS02113,Programmability status-Program consistency,Program present,
IDE00072,ASAM/ODX file identification,EV_TCMAQ300031,
IDE00075-ENG99967,Vehicle speed-Vehicle Speed Sensor,0, km/h
IDE00085,Normed load value,21.2, %
IDE00086,Accelerator pedal position,0.0, %
IDE00087-ENG102622,Tiptronic status-Tiptroni Minus,not active,
IDE00087-ENG98977,Tiptronic status-Tiptronic gate,not active,
IDE00087-ENG100388,Tiptronic status-Tiptronic Lenkrad Minus,not active,
IDE00087-ENG103352,Tiptronic status-Tiptronic Lenkrad Plus,not active,
IDE00087-ENG102721,Tiptronic status-Tiptronik Plus,not active,
IDE00089-ENG101851,Driving position-Automatic Transmission shift position,P,
IDE00090,selected gear,PN range,
IDE00094,Kick-down status,OFF,
IDE00095,Status of selector lever lock,active,
IDE00096-ENG100569,Selector lever position-Shift Position,Position P Stop,
IDE00098-ENG103732,Transmission position-POS_INFO Signal,P,
IDE00130-ENG103124,Transmission specified idle RPM-Idle Speed Commanded Value,0, /min
IDE00322-ENG100540,Status of basic setting-Basic Settings Status,was not yet started,
IDE00358-ENG101555,Limitation: torque-Engine torque limitation,102, Nm
IDE00544,Factor torque,Factor 0.5,
IDE00548-ENG101198,Converter clutch slip-Slip Speed LU,40, /min
IDE00609-ENG110904,Communication status of data bus 1-ACC ECU support/not support,Not supported,
IDE00609-ENG110905,Communication status of data bus 1-ACC Status active/not active,not active,
IDE00609-ENG110906,Communication status of data bus 1-Airbag ECU support/not support,Not supported,
IDE00609-ENG110907,Communication status of data bus 1-Airbag Status active/not active,not active,
IDE00609-ENG110902,Communication status of data bus 1-Aircon ECU support/not support,Not supported,
IDE00609-ENG110903,Communication status of data bus 1-Aircon Status active/not active,not active,
IDE00609-ENG30405,Communication status of data bus 1-BCM ECU support/not support,supported,
IDE00609-ENG30406,Communication status of data bus 1-BCM Status active/not active,active,
IDE00609-ENG110900,Communication status of data bus 1-Brake ECU support/not support,supported,
IDE00609-ENG110901,Communication status of data bus 1-Brake Status active/not active,active,
IDE00609-ENG130510,Communication status of data bus 1-Column Lock ECU support/not support,Not supported,
IDE00609-ENG130511,Communication status of data bus 1-Column Lock Status active/not active,not active,
IDE00609-ENG110898,Communication status of data bus 1-Engine ECU support/not support,supported,
IDE00609-ENG110899,Communication status of data bus 1-Engine Status active/not active,active,
IDE00609-ENG110916,Communication status of data bus 1-EPB ECU support/not support,supported,
IDE00609-ENG110917,Communication status of data bus 1-EPB Status active/not active,active,
IDE00609-ENG110912,Communication status of data bus 1-Gateway ECU support/not support,supported,
IDE00609-ENG110913,Communication status of data bus 1-Gateway Status active/not active,active,
IDE00609-ENG130512,Communication status of data bus 1-Hybrid Charge Battery Manager ECU support/not support,Not supported,
IDE00609-ENG130513,Communication status of data bus 1-Hybrid Charge Battery Manager Status active/not active,not active,
IDE00609-ENG110910,Communication status of data bus 1-Kombi ECU support/not support,supported,
IDE00609-ENG110911,Communication status of data bus 1-Kombi Status active/not active,active,
IDE00609-ENG110918,Communication status of data bus 1-Shifter ECU support/not support,supported,
IDE00609-ENG110919,Communication status of data bus 1-Shifter Status active/not active,active,
IDE00609-ENG110908,Communication status of data bus 1-Steering Wheel ECU support/not support,Not supported,
IDE00609-ENG110909,Communication status of data bus 1-Steering Wheel Status active/not active,not active,
IDE00609-ENG110914,Communication status of data bus 1-Transfercase ECU support/not support,Not supported,
IDE00609-ENG110915,Communication status of data bus 1-Transfercase Status active/not active,not active,
IDE00798-ENG28485,Number of possible access authorizations-Number of Logins,01,
IDE00820-ENG114742,Activating and deactivating all development messages-Activation of Development Messages,00,
IDE00972,Idle speed increase,OFF,
IDE02211,Brake pressure,20.70, bar
IDE02220-ENG103724,Accelerator position: qualification-Accelerator pedal position: qualification,valid value,
IDE02713-ENG98471,Brake lamp switch-Brake Light Switch,On,
IDE02714,Brake test switch,On,
IDE02715-ENG103190,Validity of brake pressure-Brake Pressure State,valid,
IDE02716,Tiptronic source,CAN,
IDE02717-ENG102076,Tiptronic upshift-Tiptronic Up,OFF,
IDE02718-ENG101063,Tiptronic downshift-Tiptronic Down,OFF,
IDE02735-ENG100209,Display of driving mode in instrument panel-Display Driving Position,P,
IDE02736-ENG100252,Display of gear in instrument panel-Display Driving Gear,1,
IDE02820,Transmission mileage,67972.0, km
IDE02989-ENG100843,Status of torque requirements on engine-State Of Torque Demand Engine,OFF,
IDE03008-ENG28321,Stop process prevented-Start_/_Stop_prohibition,not condition,
IDE03010-ENG31515,Number of prevented stop processes-Frequency_counter_Start_/_Stop_ prohibition,0,
IDE03127-ENG101616,Prevented stop processes (ring memory)-Frequency_counter_Start_/_Stop_prohibition_ring_buffer,2000,
IDE03152-ENG100761,Neutral due to driver registr. proced. cond.: cause-cause: when it happened last time,N after R,
IDE03152-ENG102840,Neutral due to driver registr. proced. cond.: cause-distance  = km: last time it occurred,0, km
IDE03152-ENG100645,Neutral due to driver registr. proced. cond.: cause-how often over life time,0, counts
IDE03171-ENG103012,Driving strategy transmission mileage-Total Driving Time2,N/A---,
IDE03172-ENG103276,Driving Strategy Percentage Driving in D or S w/Cruise-Driving Time Ecological,0, %
IDE03173-ENG103020,Driving Strategy Percentage Driving in S w/o cruise-Driving Time Sporty,0, %
IDE03174-ENG100072,Driving strategy driving portions in Tiptronic-Driving Time Manual,0, %
IDE03180-ENG103176,Number of standard trips-General Denominator,1311,
IDE03181-ENG102823,Number of ignition cycles-Ignition Cycle Counter,3664,
IDE03212-ENG100620,Start/stop conditions-Start_/_Stop_conditions,Stop release,
IDE03361-ENG130487,Driver intention torque-Driver Requested Torque,FF FF,
IDE03404-ENG130574,AUTOSAR Standard application software identification-software ID,20 00,
IDE03404-ENG104191,AUTOSAR Standard application software identification-Vendor ID,00 01,
IDE03404-ENG99019,AUTOSAR Standard application software identification-Version number,01 01 00,
IDE05398-ENG130490,Transmission output speed: uncond voltage-Automatic transmission output speed raw voltage,1.4, V
IDE05400-ENG102986,Hill factor driving strategy-DSP Mountain Index,0.0, %
IDE05401-ENG130491,Transmission input speed: uncond voltage-Automatic transmission input speed raw voltage,0.6, V
IDE05403-ENG130492,Accelerator pedal idling-Accelerator Idle signal,Not operated,
IDE05668-ENG101751,Transmission control module torque request-TCM Requested Torque,initialized,
IDE06323-ENG102841,Status: switch valve S1/S2-S2,Open,
IDE06323-ENG55631,Status: switch valve S1/S2-S3,Open,
IDE06323-ENG56246,Status: switch valve S1/S2-S4,Open,
IDE06323-ENG55712,Status: switch valve S1/S2-S5,Open,
IDE06323-ENG55997,Status: switch valve S1/S2-SL,closed,
IDE06323-ENG55341,Status: switch valve S1/S2-sr,closed,
IDE06658-ENG99605,Pressure control valve 2: act. current-Actual current SLB1,0.10, A
IDE06659-ENG101258,Pressure control valve 3: act. current-Actual current SLC1,0.10, A
IDE06660-ENG101181,Pressure control valve 3: spec. current-Order current SLC1,0.10, A
IDE06661-ENG100294,Pressure control valve 2: spec. current-Order current SLB1,0.10, A
IDE06662-ENG100356,Pressure control valve 4: spec. current-Order current SLC2,0.10, A
IDE06663-ENG99880,Pressure control valve 4: act. current-Actual current SLC2,0.10, A
IDE06664-ENG99347,Pressure control valve 5: act. current-Actual current SLC3,0.09, A
IDE06665-ENG101266,Pressure control valve 5: spec. current-Order current SLC3,0.10, A
IDE06666-ENG101252,Pressure control valve 6: act. current-Actual current SLC4,0.10, A
IDE06667-ENG103324,Pressure control valve 6: spec. current-Order current SLC4,0.10, A
IDE06668-ENG103285,Pressure control valve 1: act. current-Actual current SLT,0.40, A
IDE06669-ENG103245,Pressure control valve 1: spec. current-Order current SLT,0.40, A
IDE06670-ENG55516,Pressure control valve 7: act. current-Actual current SLB2,0.32, A
IDE06671-ENG55517,Pressure control valve 7: spec. current-Order current SLB2,0.32, A
IDE06672-ENG130501,Current gear/clutch status-Actual Gear And LU Mode,0 ,
IDE06674-ENG102023,Driving strategy: rolling resistance-DSP Road Resistance,-0.3, %
IDE06675-ENG100839,Driving strategy: Sport Index-DSP Sport Index,0, %
IDE06676-ENG130488,Driving strategy: driving mode-DSP Driving Mode,DS,
IDE06677-ENG100939,Driving strategy: Sport Index Hybrid-DSP Sport Index Hybrid,Not supported,
IDE06875-ENG101762,Height-Altitude,0.97625, mbar
IDE06879-ENG103976,Software level supplier-ATCU software level,3,
IDE06880-ENG06100,Calc. transmission fluid temp.-Temp TC Lifetime Max Value,114, °C
IDE06881-ENG130493,Max. transmission fluid temperature over lifetime-ATF Temperature Lifetime Max Value,105, °C
IDE06882-ENG102253,Trans. fluid temp. model value-Transmission fluid temperature (Model),14, °C
IDE06883-ENG130500,Max. transmission fluid temp. model value over lifetime-ATF Temperature Model Lifetime Max Value,100, °C
IDE06884-ENG99385,Trans. fluid temp. sensor: voltage-ATF-Temperature Voltage,3.3, V
IDE06885-ENG102696,Torque converter: torque loss-Converter Loss Torque,0, Nm
IDE06887-ENG130498,Driver for electric oil pump: max. temperature-DrivingRecorder - highest temperature of the choke coil estimate temperature,200, °C
IDE06888-ENG130499,battery voltage: distribution-DrivingRecorder - distribution of Battery voltage,N/A---,
IDE06889-ENG130497,Driver for electric oil pump: temperature distribution-DrivingRecorder - distribution of choke coil estimate temperature,N/A---,
IDE06893-ENG130489,Trans. thermal management request-DSP Fan control,heating,
IDE06894-ENG130495,Hot running progr. status-DSP Hotmode Status,normal,
IDE06895-ENG130502,Level/hill recognition-DSP Plain/Mountains,Ebene (Plain),
IDE06896-ENG103489,Driving strategy: software version-DSP software level,3,
IDE06897-ENG99419,Engine torque loss-Engine Loss Torque,Not supported,
IDE06898-ENG101044,Engine torque with external intervention-Engine Torque With External Engagement,FF FE,
IDE06899-ENG99632,Engine torque without external intervention-Engine Torque Without External Engagement,FF FE,
IDE06913-ENG102247,Trans. pilot control torque-Idle Speed Loss Torque,5, Nm
IDE06914-ENG99114,Unfiltered transmission input speed-Turbine Speed Signal Current Value,810, /min
IDE06915-ENG98331,Trans. position switch: raw signal-a,closed,
IDE06915-ENG98436,Trans. position switch: raw signal-B,closed,
IDE06915-ENG98435,Trans. position switch: raw signal-C,closed,
IDE06915-ENG98824,Trans. position switch: raw signal-Pa,closed,
IDE06916-ENG101593,Software_ID-Mot-File,JL209B35.MOT ,
IDE06917-ENG100970,Software enable status-Software Level,3,
IDE06919-ENG102285,Torque converter clutch: status-Lock Up Clutch Status,Open,
IDE06920-MAS00115,Tiptronic: raw signal-Tiptronic gate,OFF,
IDE06920-MAS00116,Tiptronic: raw signal-Tiptronic +,OFF,
IDE06920-MAS00117,Tiptronic: raw signal-Tiptronic -,OFF,
IDE06920-MAS00118,Tiptronic: raw signal-Tiptronic steering wheel +,OFF,
IDE06920-MAS00119,Tiptronic: raw signal-Tiptronic steering wheel -,OFF,
IDE06921-ENG100848,Calculated vehicle speed-Vehicle Speed Sensor (Dev),0.0, km/h
IDE07159-ENG28759,Control module switch-off: counter-Knockout_counter,0,
IDE13953-ENG56038,Error code of the main and monitoring processors-Maximum of consecutively error counter in this IG cycle.(BIST error),0,
IDE13953-ENG55833,Error code of the main and monitoring processors-Maximum of consecutively error counter in this IG cycle.(Clock check),0,
IDE13953-ENG56042,Error code of the main and monitoring processors-Maximum of consecutively error counter in this IG cycle.(Communication check for between CPU and PCU),0,
IDE13953-ENG56620,Error code of the main and monitoring processors-Maximum of consecutively error counter in this IG cycle.(core check),0,
IDE13953-ENG56660,Error code of the main and monitoring processors-Maximum of consecutively error counter in this IG cycle.(Power Supply check),0,
IDE13953-ENG55853,Error code of the main and monitoring processors-Maximum of consecutively error counter in this IG cycle.(Program flow check),0,
IDE13953-ENG55954,Error code of the main and monitoring processors-Maximum of consecutively error counter in this IG cycle.(RAM check),0,
IDE13953-ENG55730,Error code of the main and monitoring processors-Maximum of consecutively error counter in this IG cycle.(ROM check),0,
IDE13953-ENG56641,Error code of the main and monitoring processors-Maximum of consecutively error counter in this IG cycle.(Self test result),0,
IDE13953-ENG56382,Error code of the main and monitoring processors-Total of error counter in the total lifetime.(BIST error),0,
IDE13953-ENG55852,Error code of the main and monitoring processors-Total of error counter in the total lifetime.(Clock check),0,
IDE13953-ENG55967,Error code of the main and monitoring processors-Total of error counter in the total lifetime.(Communication check for between CPU and PCU),0,
IDE13953-ENG55918,Error code of the main and monitoring processors-Total of error counter in the total lifetime.(core check),0,
IDE13953-ENG55856,Error code of the main and monitoring processors-Total of error counter in the total lifetime.(Power Supply check),0,
IDE13953-ENG56139,Error code of the main and monitoring processors-Total of error counter in the total lifetime.(Program flow check),0,
IDE13953-ENG56707,Error code of the main and monitoring processors-Total of error counter in the total lifetime.(RAM check),0,
IDE13953-ENG55621,Error code of the main and monitoring processors-Total of error counter in the total lifetime.(ROM check),0,
IDE13953-ENG55902,Error code of the main and monitoring processors-Total of error counter in the total lifetime.(Self test result),0,
IDE13953-ENG56109,Error code of the main and monitoring processors-Total of error counter in this IG cycle.(BIST error),0,
IDE13953-ENG56466,Error code of the main and monitoring processors-Total of error counter in this IG cycle.(Clock check),0,
IDE13953-ENG56170,Error code of the main and monitoring processors-Total of error counter in this IG cycle.(Communication check for between CPU and PCU),0,
IDE13953-ENG56430,Error code of the main and monitoring processors-Total of error counter in this IG cycle.(core check),0,
IDE13953-ENG56404,Error code of the main and monitoring processors-Total of error counter in this IG cycle.(Power Supply check),0,
IDE13953-ENG55926,Error code of the main and monitoring processors-Total of error counter in this IG cycle.(Program flow check),0,
IDE13953-ENG56338,Error code of the main and monitoring processors-Total of error counter in this IG cycle.(RAM check),0,
IDE13953-ENG56428,Error code of the main and monitoring processors-Total of error counter in this IG cycle.(ROM check),0,
IDE13953-ENG56394,Error code of the main and monitoring processors-Total of error counter in this IG cycle.(Self test result),0,
IDE14325-MAS00207,Oil pressure switch status-Oil pressure switch 2,Open,
IDE14325-MAS18242,Oil pressure switch status-Oil pressure switch 6,Open,
IDE14325-MAS18243,Oil pressure switch status-Oil pressure switch 8,Open,
IDE14703-ENG102978,Pressure control valve for torque converter lock-up clutch: actual flow-Actual current SLU,0.10, A
IDE14704-ENG101564,Pressure control valve for torque converter lock-up clutch: specified flow-Order current SLU,0.10, A
IDE80020,Analysis 20,0,
IDE80021,Analysis 21,0,
IDE80022,Analysis 22,100,
IDE80023,Analysis 23,100,
IDE80024,Analysis 24,100,
IDE80025,Analysis 25,100,
IDE80026,Analysis 26,100,
IDE80027,Analysis 27,100,
IDE80028,Analysis 28,100,
IDE80029,Analysis 29,100,
IDE80030,Analysis 30,100,
IDE80031,Analysis 31,100,
IDE80032,Analysis 32,100,
IDE80033,Analysis 33,100,
IDE80034,Analysis 34,61,
IDE80035,Analysis 35,265,
IDE80036,Analysis 36,199,
IDE80039,Analysis 39,4581603,
IDE80040,Analysis 40,N/A---,
IDE80041,Analysis 41,N/A---,
IDE80042,Analysis 42,N/A---,
IDE80043,Analysis 43,N/A---,
IDE80046,Analysis 46,N/A---,
IDE80049,Analysis 49,100,
ENG101413,Calibration Identification,9S927158R_ 3587,
ENG99697,Calibration Verification Number,B9 C8 0A 00,
ENG100152-ENG104003,ECUNAME-ECU,CM-,
ENG100152,ECUNAME,ransmisCtrl,
ENG125778,EMOP Demand Duty %,0, %
ENG125927-ENG125781,EMOP_Feedback_ON OFF-EMOP Feedback ON/OFF,OFF,
ENG02239,The counter and interval timer for Race up shifting,60000,
ENG02241-ENG02261,The status monitor for Free Wheel Function-110 <= Vehicle speed < 130 Counter,0,
ENG02241-ENG02262,The status monitor for Free Wheel Function-110 <= Vehicle speed < 130 Total distance,0, m
ENG02241-ENG02263,The status monitor for Free Wheel Function-130 <= Vehicle speed Counter,0,
ENG02241-ENG02264,The status monitor for Free Wheel Function-130 <= Vehicle speed Total distance,0, m
ENG02241-ENG02255,The status monitor for Free Wheel Function-50 <= Vehicle speed < 70 Counter,0,
ENG02241-ENG02256,The status monitor for Free Wheel Function-50 <= Vehicle speed < 70 Total distance,0, m
ENG02241-ENG02257,The status monitor for Free Wheel Function-70 <= Vehicle speed < 90 Counter,0,
ENG02241-ENG02258,The status monitor for Free Wheel Function-70 <= Vehicle speed < 90 Total distance,0, m
ENG02241-ENG02259,The status monitor for Free Wheel Function-90 <= Vehicle speed < 110 Counter,0,
ENG02241-ENG02260,The status monitor for Free Wheel Function-90 <= Vehicle speed < 110 Total distance,0, m
ENG02241-ENG02253,The status monitor for Free Wheel Function-Vehicle speed < 50 Counter,0,
ENG02241-ENG02254,The status monitor for Free Wheel Function-Vehicle speed < 50 Total distance,0, m
Elapsed Time: 00:19
blockmap-03-5Q0-614-517-DG_3VWC57BU2KM121617-20201017-1232.CSV
;Component:ESC           H62 0654, Coding:70FB6AA12422216DC57D0201A0CA250E562484A34005A4701041F058C282430B00000012121212B835351919323200
;EV_Brake1UDSContiMK100IPB,037009,EV_Brake1UDSContiMK100IPB_037_VW37.rod
;Saturday,17,October,2020,12:32:49:14741
;VCDS Version: Beta 20.9.1 (x64)  Data version: 20200919 DS322.0
;VCID: F9A406AEA95A4B93A05-80AC
Group,Description,Actual
IDE00609-MAS01155,Communication status of data bus 1-Control module,Engine Electronics,
IDE00609-MAS01156,Communication status of data bus 1-Communication status,active,
IDE00780,Mode,running_mode,
IDE02270-IDE00086,CAN input signal(s) status-Accelerator pedal position,0, %
IDE02270-IDE02049,CAN input signal(s) status-Trailer detected,Malfunction,
IDE02270-IDE02713,CAN input signal(s) status-Brake lamp switch,operated,
IDE02270-MAS00025,CAN input signal(s) status-Driver seat belt switch,not connected,
IDE02270-MAS00218,CAN input signal(s) status-Driver door,Open,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,operated,
IDE02270-MAS00364,CAN input signal(s) status-Shift lever / selector lever position,Neutral,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamp,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,BU21617,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,active,
IDE02271-IDE03311,CAN output signal(s) status-Emergency braking display,not active,
IDE02271-IDE03660,CAN output signal(s) status-Longitudinal acceleration,0.09375, m/s²
IDE02492,Start/Stop Function: coding information,Start-stop function in control module active,
IDE02986-IDE04431,Indicator lamps-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,Indicator lamps-Tire press monitoring display indictor lamp,OFF,
IDE02986-IDE04498,Indicator lamps--AUTO HOLD- Indicator Lamp,Not available due to specific system,
IDE02986-IDE04771,Indicator lamps-Indicator lamp for electro-mechanical parking brake malfunction,OFF,
IDE02986-MAS00253,Indicator lamps-ABS indicator lamp,OFF,
IDE02986-MAS00556,Indicator lamps-Electromechanical parking brake indicator lamp,On,
IDE02986-MAS01206,Indicator lamps-Hill descent control indicator lamp,Not available due to specific system,
IDE02986-MAS02925,Indicator lamps-Brake system indicator lamp,OFF,
IDE02986-MAS03234,Indicator lamps-ESP_off indicator lamp,OFF,
IDE03008-IDE05181,Stop process prevented-Emerg.brake,not active,
IDE03008-MAS04513,Stop process prevented-ABS control module pump running,not active,
IDE03008-MAS04515,Stop process prevented-Roll back detection,not active,
IDE03009-IDE04446,Start process requested-Hill descent control,not active,
IDE03009-IDE06139,Start process requested-AUTO HOLD slippage recognition,not active,
IDE03009-MAS02515,Start process requested-System malfunction,not active,
IDE03009-MAS04485,Start process requested-ESP function deactivation,not active,
IDE03009-MAS04515,Start process requested-Roll back detection,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,0,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.brake,0,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,37,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-ABS control module pump running,636,
IDE03010-MAS04515,Number of prevented stop processes-Roll back detection,0,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,1,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,748,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,7,
IDE03011-MAS02515,Number of requested start processes-System malfunction,0,
IDE03011-MAS04515,Number of requested start processes-Roll back detection,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2020,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,7,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,8,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,29,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,13,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,5,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,9,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,20,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,10,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,18,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,51,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,13,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,24,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,39,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,2,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,20,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,56,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,21,
IDE03127,Prevented stop processes (ring memory),Inclination limit,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2020,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,5,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,6,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,10,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,17,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,6,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,5,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,9,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,22,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,6,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,11,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,16,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,8,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,24,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,27,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,49,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,33,
IDE03128,Requested start processes (ring memory),AUTO HOLD slippage recognition,
IDE03207,Hardware version for suppliers,Texas_Instruments,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,No release by coordinator,
IDE03527-IDE02070,CAN signals-Wake-up cause,1,
IDE03527-IDE02445,CAN signals-Transmission type,26,
IDE03651,Bleed brake system (rework bleeding),0.00, s
IDE03680-IDE00018,Supply voltages-Voltage terminal 15,On,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,5.000, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,0.014, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,13.365, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,On,
IDE04422-IDE04442,Brake system sensor-Vacuum sensor,-658, mbar
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,21.70, bar
IDE04422-IDE04494,Brake system sensor-Brake pressure sensor 1: uncond voltage 1,Not available due to specific system,
IDE04422-IDE04495,Brake system sensor-Brake pressure sensor 1: uncond voltage 2,Not available due to specific system,
IDE04422-MAS00179,Brake system sensor-Brake lamp switch,operated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,Not available due to specific system,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.0, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,65535, mm
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Wheel speed: right front,0.0, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,65535, mm
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.0, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,2, mm
IDE04427-IDE04440,Left rear ABS wheel speed sensor-Validity of direction of rotation,valid,
IDE04427-IDE04441,Left rear ABS wheel speed sensor-Validity of gap information,valid,
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.0, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,2, mm
IDE04428-IDE04440,Right rear ABS wheel speed sensor-Validity of direction of rotation,valid,
IDE04428-IDE04441,Right rear ABS wheel speed sensor-Validity of gap information,valid,
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,Reverse,
IDE04442-IDE00009,Vacuum sensor-Date of manufacture,KW 02 2018,
IDE04442-IDE00010,Vacuum sensor-Serial number,00 48 CC 7C 75,
IDE04442-IDE00104,Vacuum sensor-DTC,0,
IDE04442-IDE02955,Vacuum sensor-System status,available.,
IDE04442-IDE03205,Vacuum sensor-Manufacturer code,0,
IDE04442,Vacuum sensor,-658, mbar
IDE04442-MAS12759,Vacuum sensor-Type of individual vacuum sensor,2,
IDE04443-IDE02241,Slip control system sensor-Lateral acceleration sensor 1,-0.02943, m/s²
IDE04443-IDE02538,Slip control system sensor-Longitude Acceleration Sensor,0.14715, m/s²
IDE04443-IDE04429,Slip control system sensor-Lateral acceleration sensor 1: offset,-0.09810, m/s²
IDE04443-IDE04430,Slip control system sensor-Longitudinal acceleration sensor: offset,0.09375, m/s²
IDE04443-IDE04449,Slip control system sensor-Rotation rate sensor 1: Z-axis,-0.166, °/s
IDE04443-IDE04460,Slip control system sensor-Steering angle sensor: offset straight line running,-0.569, °
IDE04443-MAS00815,Slip control system sensor-Steering angle sensor,-0.569, °
IDE04446-IDE01599,Hill descent control-Incline,0, %
IDE04446-IDE03664,Hill descent control-Button for driving program,not activated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,Not operated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,Not available due to specific system,
IDE04452-IDE03664,Brake system button-Button for driving program,Not operated,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,Not operated,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,Not operated,
IDE04456-IDE02955,Brake disk drying-System status,available.,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,66785, km
IDE04461-IDE03208,Internal measured values-Software version for suppliers,MZERAD00028,
IDE04461-IDE03649,Internal measured values-Fill/bleed brake system,not completed successfully,
IDE04461-MAS01481,Internal measured values-Temperature in control module,16, °C
IDE04461-MAS04484,Internal measured values-Flashloader version, TSCBAB00008,
IDE04499-IDE02955,Sensor for roof rack recognition-System status,Not available due to specific system,
IDE04499-MAS03095,Sensor for roof rack recognition-Function status,not detected,
IDE04508-IDE02955,Hydraulic brake booster-System status,available.,
IDE04508-IDE04442,Hydraulic brake booster-Vacuum sensor,-658, mbar
IDE04508-IDE04450,Hydraulic brake booster-Brake pressure sensor 1,21.80, bar
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04508-MAS04002,Hydraulic brake booster-Low intake manifold pressure,648, mbar
IDE04644-IDE02955,Roll-over protection-System status,Not available due to specific system,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04645-IDE00003,Electromechanical parking brake-Coding,will be performed.,
IDE04645-IDE00902,Electromechanical parking brake-Automatic distance control: status,not activated,
IDE04645-IDE02652,Electromechanical parking brake-Start-stop status,activated,
IDE04645-IDE02955,Electromechanical parking brake-System status,available.,
IDE04645-IDE03493,Electromechanical parking brake-Driver's door status,activated,
IDE04645-IDE04871,Electromechanical parking brake-Dynamic starting assist,activated,
IDE04645-IDE04944,Electromechanical parking brake-Brake pedal evaluation,activated,
IDE04645-IDE04948,Electromechanical parking brake-Fall-back level,0,
IDE04645-IDE05711,Electromechanical parking brake-Automatic application during engine stalling,activated,
IDE04645-IDE06590,Electromechanical parking brake-Play protection counter: button for electromech. parking brake,0,
IDE04645-MAS02666,Electromechanical parking brake-Seat belt buckle scan,activated,
IDE04645-MAS03998,Electromechanical parking brake-Delay interface for electro-mechanical parking brake,6,
IDE04645-IDE02657,Electromechanical parking brake-Cut-off current: left: reached,11.90, A
IDE04645-IDE02658,Electromechanical parking brake-Cut-off current: right: reached,13.41, A
IDE04645-IDE04496,Electromechanical parking brake-Left parking brake motor: status,closed,
IDE04645-IDE04497,Electromechanical parking brake-Right parking brake motor: status,closed,
IDE04645-IDE04506,Electromechanical parking brake-Calculated left rear brake temperature,17.0, °C
IDE04645-IDE04507,Electromechanical parking brake-Calculated right rear brake temperature,17.0, °C
IDE04645-IDE04647,Electromechanical parking brake-Left parking brake motor: current,0.00, A
IDE04645-IDE04648,Electromechanical parking brake-Right parking brake motor: current,0.00, A
IDE04645-IDE05048,Electromechanical parking brake-Left parking brake motor: actuation counter,430,
IDE04645-IDE05049,Electromechanical parking brake-Right parking brake motor: actuation counter,430,
IDE04765-IDE02955,Counter steer support-System status,available.,
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,67807, km
IDE04772-IDE03530,Indicator light in the button for electromech. parking brake-Monitoring status,7,
IDE04772-MAS03745,Indicator light in the button for electromech. parking brake-Function light,On,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Not available due to specific system,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04871-IDE01599,Dynamic starting assist-Incline,1, %
IDE04871-IDE02445,Dynamic starting assist-Transmission type,automatic,
IDE04871-MAS01447,Dynamic starting assist-Act.val.,normal,
IDE04871-MAS03995,Dynamic starting assist-Clutch pedal threshold: initial value,60, %
IDE04871-MAS03996,Dynamic starting assist-Clutch pedal threshold: learned value,0, %
IDE04871-MAS04734,Dynamic starting assist-Required engine torques: current slope (TARGET),0, Nm
IDE04871-MAS04735,Dynamic starting assist-Current engine torques (ACTUAL),0, Nm
IDE04871-MAS04736,Dynamic starting assist-Expected achievable engine torques,0, Nm
IDE04939-IDE02955,Tire Pressure Monitoring System (TPMS)-System status,available.,
IDE04939-IDE04248,Tire Pressure Monitoring System (TPMS)-Left front tire pressure diffusion indicator,240,
IDE04939-IDE04249,Tire Pressure Monitoring System (TPMS)-Right front tire pressure diffusion indicator,240,
IDE04939-IDE04250,Tire Pressure Monitoring System (TPMS)-Left rear tire pressure diffusion indicator,240,
IDE04939-IDE04251,Tire Pressure Monitoring System (TPMS)-Right rear tire pressure diffusion indicator,240,
IDE04939-IDE04432,Tire Pressure Monitoring System (TPMS)-Tire Pressure Monitoring Display Button,Not operated,
IDE04939-IDE04946,Tire Pressure Monitoring System (TPMS)-Odometer reading at last adaptation,52162, km
IDE04939-IDE04947,Tire Pressure Monitoring System (TPMS)-Odometer reading of last warning,51313, km
IDE04939-MAS04538,Tire Pressure Monitoring System (TPMS)-Odometer reading two adaptations ago,30669, km
IDE04939-MAS04539,Tire Pressure Monitoring System (TPMS)-Odometer reading three adaptations ago,16693, km
IDE04939-MAS04540,Tire Pressure Monitoring System (TPMS)-Odometer reading four adaptations ago,28, km
IDE04939-MAS04541,Tire Pressure Monitoring System (TPMS)-Odometer reading of next-to-last warning,0, km
IDE04939-MAS04542,Tire Pressure Monitoring System (TPMS)-Odometer reading of third-to-last warning,0, km
IDE04939-MAS04543,Tire Pressure Monitoring System (TPMS)-Odometer reading of fourth-to-last warning,0, km
IDE04939-MAS04544,Tire Pressure Monitoring System (TPMS)-Left front flat tire indicator,248,
IDE04939-MAS04545,Tire Pressure Monitoring System (TPMS)-Right front flat tire indicator,248,
IDE04939-MAS04546,Tire Pressure Monitoring System (TPMS)-Left rear flat tire indicator,255,
IDE04939-MAS04547,Tire Pressure Monitoring System (TPMS)-Right rear flat tire indicator,255,
IDE05712-IDE02955,AUTO HOLD-System status,Not available due to specific system,
IDE05712-IDE03530,AUTO HOLD-Monitoring status,7,
IDE05712-IDE04498,AUTO HOLD--AUTO HOLD- Indicator Lamp,OFF,
IDE05712-IDE04561,AUTO HOLD-Switch-on and shut-off conditions,valid,
IDE05712-IDE05333,AUTO HOLD-Indicator light in AUTO HOLD button,OFF,
IDE05712-MAS00025,AUTO HOLD-Driver seat belt switch,not connected,
IDE05712-MAS03095,AUTO HOLD-Function status,not active,
IDE05712-MAS04006,AUTO HOLD-Operating mode,Last setting,
IDE05712-MAS04409,AUTO HOLD-Active hold,not active,
IDE05712-MAS04411,AUTO HOLD-Hydraulic pressure transfer to electro-mechanical parking brake,No,
IDE06591-ENG118150,Pump load counter-Comp_Rotatation_of_pump_motor,76988,
IDE06591-ENG118152,Pump load counter-Load_on_feeding_side_of_Pump,310333,
IDE06591-ENG118151,Pump load counter-Load_on_suction_side_of_Pump,8657,
IDE06591-ENG118153,Pump load counter-Pump_motor_start_counter,4355,
IDE07280-IDE04775,Multiple collision brake-Odometer reading of last activation,0, km
IDE07280-IDE06609,Multiple collision brake-Odometer reading of last deactivation,0, km
IDE07280-MAS00106,Multiple collision brake-Year,2126,
IDE07280-MAS00107,Multiple collision brake-Month,14,
IDE07280-MAS00108,Multiple collision brake-Day,0,
IDE07280-MAS00109,Multiple collision brake-Hours,30,
IDE07280-MAS00110,Multiple collision brake-Minutes,62,
IDE07280-MAS00111,Multiple collision brake-Seconds,62,
IDE07280-MAS07659,Multiple collision brake-Frequency counter for multi-collision brake active,0,
IDE07280-MAS07660,Multiple collision brake-Frequency counter for multi-collision brake deactivated,0,
IDE07280-MAS07661,Multiple collision brake-Frequency counter function deactivated by driver,0,
IDE07280-MAS07662,Multiple collision brake-Mileage reading of the last deactivation by driver,0, km
IDE80101,Analysis 101,A3 32 38 35 31 35 38 36 38 33 32 33 30 30 30 30 35 31 38 38 31 35 30 30 32 34 39 2F 02 14 1E 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80102-ENG122580,Analysis 102-value_1_percentaged,96.0876, %
IDE80102-ENG122579,Analysis 102-value_1_quantity,0,
IDE80102-ENG122582,Analysis 102-value_2_percentaged,99.2124, %
IDE80102-ENG122581,Analysis 102-value_2_quantity,0,
IDE80102-ENG122584,Analysis 102-value_3_percentaged,94.1346, %
IDE80102-ENG122583,Analysis 102-value_3_quantity,1563,
IDE80102-ENG122586,Analysis 102-value_4_percentaged,99.9936, %
IDE80102-ENG122585,Analysis 102-value_4_quantity,1510,
IDE80102-ENG122588,Analysis 102-value_5_percentaged,97.2594, %
IDE80102-ENG122587,Analysis 102-value_5_quantity,763,
IDE80102-ENG122590,Analysis 102-value_6_percentaged,103.118, %
IDE80102-ENG122589,Analysis 102-value_6_quantity,1137,
IDE80103-MAS00976,Analysis 103-Counter,0,
MAS00121-IDE02955,Electronic Differential Lock-System status,available.,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,17.0, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,17.0, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,17.0, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,17.0, °C
MAS00121-MAS00179,Electronic Differential Lock-Brake lamp switch,operated,
MAS00121-MAS01853,Electronic Differential Lock-Left front,available.,
MAS00121-MAS01854,Electronic Differential Lock-Right front,available.,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,available.,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,available.,
MAS00210-IDE80007,Parking Brake-Analysis 7,43608, km
MAS00210-IDE80008,Parking Brake-Analysis 8,67972, km
MAS00210-IDE80009,Parking Brake-Analysis 9,0, km
MAS00210-IDE80010,Parking Brake-Analysis 10,0, km
MAS00210-IDE80011,Parking Brake-Analysis 11,67972, km
MAS00210-IDE80012,Parking Brake-Analysis 12,8F 0A 11 10 02 0C,
MAS00210-ENG36680,Parking Brake-ActDbg_ECR_EvCnt,0,
MAS00210-ENG36681,Parking Brake-ActDbg_ESA_EvCnt,0,
MAS00210-ENG36682,Parking Brake-ActDbg_OTH_EvCnt,0,
MAS00210-ENG36683,Parking Brake-ActDbg_SAR_EvCnt,0,
MAS00210-ENG36684,Parking Brake-ActDbg_UV_EvCnt,0,
MAS00210-ENG36685,Parking Brake-ActDbg_UVE_EvCnt,0,
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,Not available due to specific system,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch: status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Fully open,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0.0, %
MAS02138-IDE02955,Hill-start assistant-System status,available.,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver door,Open,
MAS02138-MAS03095,Hill-start assistant-Function status,Condition not met,
MAS02426-MAS00580,Text display in instrument cluster-Electromechanical parking brake text 1,0,
MAS02426-MAS03359,Text display in instrument cluster-Text,0,
MAS02672-IDE02955,Start-stop-System status,available.,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE03215,Start-stop-Engine start using start-stop function,not active,
MAS02672-MAS00025,Start-stop-Driver seat belt switch,not connected,
MAS08072-MAS13685,Driving profile selection-Actual value of downhill driving assistant,0,
MAS08072-MAS13686,Driving profile selection-Actual value uphill driving assistant,0,
MAS08072-MAS13687,Driving profile selection-Actual value of differential lock,0,
MAS08072-MAS13688,Driving profile selection-ESC actual value,0,
MAS08072-MAS13689,Driving profile selection-Compatibility of downhill driving assistant,Yes,
MAS08072-MAS13690,Driving profile selection-Compatibility of uphill driving assistant,Yes,
MAS08072-MAS13691,Driving profile selection-Compatibility of differential lock,Yes,
MAS08072-MAS13692,Driving profile selection-ESC compatibility,Yes,
MAS08072-MAS13693,Driving profile selection-Spec. value of downhill driving assistant,0,
MAS08072-MAS13694,Driving profile selection-Spec. value of uphill driving assistant,0,
MAS08072-MAS13695,Driving profile selection-Spec. value of differential lock,0,
MAS08072-MAS13696,Driving profile selection-ESC spec. value,0,
MAS08072-MAS13697,Driving profile selection-System status of downhill driving assistant,available.,
MAS08072-MAS13698,Driving profile selection-System status uphill driving assistant,Not available,
MAS08072-MAS13699,Driving profile selection-System status of differential lock,Not available,
MAS08072-MAS13700,Driving profile selection-ESC system status,available.,
MAS08072-MAS13701,Driving profile selection-Switchover status of downhill driving assistant,Shifting carried out,
MAS08072-MAS13702,Driving profile selection-Switchover status of uphill driving assistant,Shifting carried out,
MAS08072-MAS13703,Driving profile selection-ESC switchover status,Shifting carried out,
MAS08072-MAS13704,Driving profile selection-Switchover status_differential lock,Shifting carried out,
ENG26281-IDE01011,HBV_Event_Counter-Data record,0,
Elapsed Time: 00:14
blockmap-OBD_3VWC57BU2KM121617-20201017-1235.CSV
;Saturday,17,October,2020,12:35:35:14741
;VCID: E78050D6CFEECD63461-80B2
03,Fuel system 1/2 status,Closed loop,,using O2 sensors,Engine off
04,Calculated load value,21.2 %,21.2 %
05,Engine coolant temperature,55 °C,55 °C
06,Short Term Trim - Bank 1,3.1 %
07,Long Term Trim - Bank 1,-2.3 %
0B,Intake Manifold Absolute Pressure,33 kPa abs
0C,Engine RPM,877 /min,872 /min
0D,Vehicle speed,0 km/h,0 km/h
0E,Ignition timing advance for cyl #1,3.5 Degrees
0F,Intake air temperature,21 °C
11,Throttle position sensor,12.9 %,12.9 %
12,Secondary Air Status,Atmosphere/off
13,Location of O2 sensors,B1S1 B1S2
15,Bank 1 Sensor 2 Status,0.745 V
1C,OBD Requirements Met,OBD + OBD II
1F,Time since engine start,319 s
21,Distance travelled with MIL on,0 km
2E,Commanded Evaporative Purge,0.0 %
2F,Fuel Level Input,90.6 %
30,Warm-ups since DTC cleared,255
31,Distance since DTC cleared,65535 km
33,Barometric pressure,99 kPa abs
34,Bank 1 Sensor 1 Status,1.001 Lambda,-0.020 mA
3C,B1S1 Cat. Temp.,387.2 °C
42,Control module voltage,13.260 V,13.338 V
43,Absolute Load Value,25 %,25 %
44,Commanded Equivalence Ratio,1.000 Lambda
45,Relative Throttle Position,3 %
46,Ambient Air Temp,18 °C
47,Absolute Throttle Position B,13 %
49,Accelerator Pedal Position D,15 %,15 %
4A,Accelerator Pedal Position E,15 %
4C,Commanded Throttle Actuator Control,4 %
51,Fuel type,Gasoline
56,Long term sec. O2 trim bank 1/3,0.0 %
62,Torque actual,10 %
63,Torque Reference,280 Nm
65,Auxiliary Input/Output,
67,Engine Coolant Temp,ECT 1:56 °C,ECT 2:16 °C
6D,Fuel Press. Control A/B,FRP CMD:---/--- kPa,FRP ACT:9900/--- kPa,FRTemp:---/--- °C
70,Boost Press Ctrl A/B,BP_A act:99 kPa
75,Turbo A Temp.,Compr. in/out---/23 °C,Compr. in/out---/--- °C
77,Charge Air Temp.,B1S1:21 °C, °C
Type 02 - VIN : 3VWC57BU2KM121617 (Address E8)
Type 04 - Calibration ID : 04E024AF6809DXAA (Address E8)
Type 04 - Calibration ID : 09S927158R_ 3587 (Address E9)
Type 06 - Calibration Verification Number : D4B4D5D3 (Address E8)
Type 06 - Calibration Verification Number : 0EB9C80A (Address E9)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 1325
    Ignition cycle count : 3837
         Catalyst monitor bank 1 : 2017 / 1324
         Catalyst monitor bank 2 : 0 / 0
         O2 Sensor monitor bank 1 : 1567 / 1324
         O2 Sensor monitor bank 2 : 0 / 0
         EGR-VVT monitor : 3016 / 1325
         AIR monitor : 855 / 402
         EVAP monitor : 260 / 184
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
