Polo 6r steering buttons coding
overpower
Greece
C?ID=24601
Good morning. I changed a steering wheel with buttons to without buttons steering wheel to a polo 6r. The cable is complet. I need to coding the buttons to control modul. Can you help me to this? I send you the links of the diagnostic protocol and a photo from new steering wheel.
Thanks.
https://files.fm/f/eu38hfsr
Wednesday,28,October,2020,12:59:05:52027
VCDS Version: 20.4.2.0
VIN: WVWZZZ6RZFY295976   License Plate: IPX6241
Mileage: 123869km-76968mi   Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZFY295976   Mileage: 123869km-76968miles
Address 01: Engine (J623-CUSA)       Labels:. 04B-907-445-V1.clb
   Part No SW: 04B 906 027 AJ    HW: 04B 907 445
   Component: R3 1.4l TDI   H07 5567
   Revision: 21003001
   Coding: 01114012420400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM14TDI03004B906027AJ 004005
   ROD: EV_ECM14TDI03004B997027F.rod
   VCID: 69E1AB1C88B2D9CEA4-803C
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0003
   Serial number: 08508722150311
   Coding: 21DD2485892C33C5091D00700057842491CC90000007C9098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 335D09749AFE531EDE-8066
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045     HW: 6C0 820 045
   Component: AC Manuell    H03 0108
   Serial number:  1503041B-1177
   Coding: 201000000000000200
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 5C8F82C857E0BC662F-8008
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 6C0 937 087 B    HW: 6C0 937 087
   Component: BCM PQ26 Me4R H07 0065
   Serial number: 001088027469
   Coding: 00000840401300534B844000400703000000580051010000000000000000
   ASAM Dataset: EV_BCMA0 004008
   ROD: EV_MQBA0.rod
   VCID: 2D691F0C7CDA05EE88-8078
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 6R0 959 801 AT    HW: 6R0 959 801 AT  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU025021550566291
   Coding: 0000A0
   Subsystem 2 - Part No SW: 6R0 959 802 BE    HW: 6R0 959 802 BE  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU019021550501716
   Coding: 1000A0
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 A    HW: 6C0 959 655 A
   Component: VW20Airbag00Z 001 0330
   Revision: --------    Serial number: 003LM009PPGZ
   Coding: 88C0C000000000005C000000000800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3151037C60E2610EAC-8064
   Subsystem 1 - Part No SW: -----------    HW: 410 821 103 15
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00AB19C7442E35X
   Subsystem 2 - Part No SW: -----------    HW: 410 821 103 15
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00AB19C7440E12R
   Subsystem 3 - Part No SW: -----------    HW: 442 150 803 15
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00A7196A0B472FM
   Subsystem 4 - Part No SW: -----------    HW: 442 150 803 15
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00A7196A0B3E3ET
   Part No SW: 6C0 920 731 B    HW: 6C0 920 731 B
   Component: KOMBI         110 0290
   Coding: 0720090021000008000808000000000000000000
   VCID: 2171F33C3002D18E3C-8074
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 087
   Component: GW MQB A0     H07 0065
   Revision: --------    Serial number: 001088027469
   Coding: 01000008180A590071000000000000000001010000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_001_VW26.rod
   VCID: 65F9A72C64AAFDAE80-8030
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 M    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3211
   Serial number: PF3O0653
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
   VCID: 32530C7065E45A16D5-8066
   Part No SW: 6C0 035 888 A    HW: 6C0 035 888 A
   Component: MU-E--ER      820 6230
   Serial number: 06121400011002
   Coding: 026200003C00000041110001010000001F0000840000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001017
   ROD: EV_MUEnt4CGen2LGE_VW26.rod
   VCID: 2A6314104D3412D66D-807E
End-------------------------(Elapsed Time: 01:48)--------------------------
