Engine Malfunction codes.
mark07eur
DE, USA
C?ID=420545
Hello, Am looking for some advice. I just receieved the VCDS tool and able to scan my new to me D4 A8. I see quite a few engine codes that alarm me. The misfires code on Cylinder 4 stands out to me the most. Wanted to ask some of your experpt opinions before taking her into the mechanic. I can't tell any difference on performance when driving. Of course the car is new to me so nothing to compare to. I did previously own a D3 4.2, my new one feels very similar.
Here is my Scan. Thank you so much in advance
Wednesday,21,October,2020,15:39:56:56688
VCDS Version: 20.4.2.0  HEX-V2 CB: 0.4513.4
VIN: WAURVAFD8CN020736   License Plate:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 28 34 36 3B 3C 42
          46 47 48 52 53 56 5B 5F 62 6C 6D 6F 72 7F 81 84 85 88 89 8A
          8B 8D 8E 8F 90
VIN: WAURVAFD8CN020736   Mileage: 129458km-80441miles
0E-Media Player 1 -- Status: Malfunction 0010
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
7F-Inform. Electr. II -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
Address 01: Engine (------CDRA)       Labels:| 079-907-560-CFS.clb
   Part No SW: 4H0 907 560 C    HW: 4H0 907 560
   Component: 4.2l V8/4V    H07 0005
   Revision: N5H07---
   Coding: 0106000A290F0268
   Shop #: WSC 27585 001 1048576
   ASAM Dataset: EV_ECM42FSI0114H0907560C 001006
   ROD: EV_ECM42FSI011_AU64.rod
   VCID: 2A0D064C4C72FE5B2C7-807E
11 Faults Found:
4588 - Knock Sensor 2 (G66)
          P0332 00 [101] - Signal too Low
                    Mileage: 129450 km
                    Date: 2020.10.19
                    Time: 15:31:15
                    Engine speed: 1007.50 /min
                    Normed load value: 25.5 %
                    Vehicle speed: 22 km/h
                    Coolant temperature: 49 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 13.688 V
                    AFS dm: 35.0 kg/h
                    Median injection timing: 0.909 ms
                    Engine operating condition: Idling
4590 - Knock Sensor 2 (G66)
                    Mileage: 129450 km
                    Date: 2020.10.19
                    Time: 15:30:44
                    Engine speed: 1891.00 /min
                    Normed load value: 46.3 %
                    Vehicle speed: 23 km/h
                    Coolant temperature: 45 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 13.900 V
                    AFS dm: 115.8 kg/h
                    Median injection timing: 1.625 ms
                    Engine operating condition: Part. load
                    Engine operating condition-Test_Program_Channel 87: 6
10333 - Thermostat for Transmission
          P19A2 00 [047] - Open Circuit
                    Mileage: 117872 km
                    Date: 2020.06.25
                    Time: 08:40:28
                    Engine speed: 0.00 /min
                    Coolant temperature: 60 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 12.203 V
                    AFS dm: 0.0 kg/h
                    Median injection timing: 0.000 ms
4661 - Relay for Aux Coolant Pump (J496)
          P1927 00 [047] - Open Circuit
                    Mileage: 117872 km
                    Date: 2020.06.25
                    Time: 08:41:08
                    Engine speed: 962.50 /min
                    Normed load value: 23.1 %
                    Coolant temperature: 59 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 14.065 V
                    AFS dm: 28.4 kg/h
                    Median injection timing: 1.267 ms
5608 - No Communications with Steering Angle Sender (G85)
          U0126 00 [032] - -
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [032] - -
4714 - Steering Column Control Module
          U0212 00 [032] - No Communications
4715 - No Communication with Instrument Cluster
          U0155 00 [032] - -
          [Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [032] - -
                    Mileage: 128559 km
                    Date: 2020.09.30
                    Time: 08:29:53
                    Engine speed: 1143.00 /min
                    Normed load value: 40.0 %
                    Coolant temperature: 16 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 13.782 V
                    Unlearning counter according OBD: 13
                    AFS dm: 62.3 kg/h
                    Median injection timing: 2.128 ms
10594 - Cylinder 4
          P0304 00 [032] - Misfire Detected
                    Mileage: 128559 km
                    Date: 2020.09.30
                    Time: 08:29:56
                    Engine speed: 1113.50 /min
                    Normed load value: 45.9 %
                    Voltage terminal 30: 13.523 V
                    AFS dm: 64.8 kg/h
                    Median injection timing: 2.270 ms
7780 - Engine Off Timer Performance
          P150A 00 [032] - -
   Part No SW: 4H1 927 158 BR    HW: 0BK 927 156 K
   Component: 0BK 42 FSIUSA H08 1001
   Revision: --H08---
   Coding: 000002
   ASAM Dataset: EV_TCMALX51011 002018
   VCID: 015F81E09184DD035DD-8054
8724 - Park-Lock
          P17F9 00 [032] - Mechanical Malfunction
                    Mileage: 128676 km
                    Date: 2020.10.01
                    Time: 12:30:41
                    Unlearning counter according OBD: 15
                    Voltage terminal 30: 13.115 V
                    Engine speed: 0 /min
                    Transmission input speed: 0.00 /min
                    Transmission fluid temperature: 47 °C
                    Transmission output speed: 0.00 /min
                    Transfer speed from ESP: valid
                    Transfer speed from ESP: 0.00 km/h
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 E    HW: 4H0 907 379 E
   Component: ESP PREMIUM   H10 0352
   Coding: 44E6F20022674F00E200
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ESPPremi 005013
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 343118349EB6B8AB86B-8060
   Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 BD
   Component: BCM2 2.0      H31 0510
   Coding: 0D872006000000000000
   Shop #: WSC 25863 001 1048576
   VCID: 6E85CA5CB09AD27BB0F-803A
   Component: J764 ELV MLB  H39 0046
   Serial number: 2311000258252005
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00000018398557
   Coding: C018B60085043201010001010101112131313333283333
   Shop #: WSC 02313 785 00200
   VCID: 35372530954CA1A3B15-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 H    HW: 4H0 820 043 H
   Component: Klima 4 Zonen H20 0072
   Coding: 488122BECC
   ASAM Dataset: EV_AirCondiFront 001050
   ROD: EV_AirCondiFront_001_AU64.rod
   VCID: 2517F570256CD123015-8070
0137 - Motor for  Right Side Window Defrost Flap
          B10D8 22 [008] - Signal Amplitude Too High
                    Reset counter: 147
                    Mileage: 117872 km
                    Date: 2020.06.25
                    Time: 08:40:56
   Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0100
   Revision: 11012002    Serial number: 00000001142422
   Coding: 09072091073C9FE18B000804A0003800009CD308820001218001085C3B00
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 111021  H35 0040
   Serial number:         111107190154
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10162962
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531 C    HW: 4H0 941 531 C
   Component: E1 - LDS  H07 0044
   Serial number: 02 11 2011  00001014
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R0X1702
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000010111100010141
   Coding: 100000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000009111100010603
   Coding: 100000
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA103084000000622367
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: A11848D5000000000001
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 E    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0190
   Revision: AA001001
   Coding: 020000
   VCID: 221DEE6C34C2261B647-8076
02261 - Data Medium
            014 - Defective
                    Fault Status: 01101110
                    Fault Frequency: 94
                    Reset counter: 122
                    Mileage: 128978 km
                    Date: 2020.10.04
                    Time: 12:02:40
                    Text: 00000000
   Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0043
   Revision: 11001001    Serial number: 55901132500204
   Coding: 280902
   ASAM Dataset: EV_EPHVA18AU57X0000 002005
   ROD: EV_EPHVA18AU57X0000_002_AU64.rod
   VCID: 3B233308B3E877D3471-806E
   Part No SW: 4H0 907 561 A    HW: 4H0 907 561
   Component: ACC3          H17 0160
   Coding: 3601020201
   ASAM Dataset: EV_AdaptCruisContrAU64X 001012
   ROD: EV_AdaptCruisContrAU64X_001.rod
   VCID: 290FF9404974F54325D-807C
10 Faults Found:
30720 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_KOMBI]
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.12
                    Time: 06:53:05
                    Control Module temperature: 18 °C
                    Voltage terminal 15: 13.335 V
32256 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_LS_01]
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
                    Control Module temperature: 21 °C
                    Voltage terminal 15: 13.929 V
36608 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIS_TIMEOUT_GW_SMLS_01]
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
                    Voltage terminal 15: 14.137 V
95488 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_QDISACC_FAIL]
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
                    Control Module temperature: 22 °C
                    Voltage terminal 15: 11.979 V
38912 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_APS1]
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
                    Voltage terminal 15: 13.851 V
38656 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_APS2]
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
                    Voltage terminal 15: 13.882 V
21760 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_APSM]
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
105472 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_VDC_FAIL]
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
                    Voltage terminal 15: 13.980 V
82688 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_TSK_FAIL]
                    Fault Frequency: 8
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_VIDEO_FAIL]
                    Fault Frequency: 17
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
                    Voltage terminal 15: 12.046 V
   Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
   Component: Airbag10.43   H41 0041
   Revision: --------    Serial number: 003JS0017BSB
   Coding: 303143303230303030314A55304C34483053
   VCID: 372B2F388FC053B3A39-8062
   Subsystem 1 - Part No SW: 4H0 959 339 A    HW: 4H0 959 339 A
   Component: BF-Gewichtss.  H03 0040
   Serial number: 5850000R11A3102C7U
   Serial number: 3575HRB40510U20QA0D.
   Serial number: 3585HRB405T0TGJE71H2
   Serial number: 3515JRB40690TGJI48FR
   Serial number: 3525JRB40650TGJI3H4L
   Serial number: 3554VRB405V0PMKO5O9/
   Serial number: 3564VRB40610PMKOHOL-
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90815KK90000A
   Coding: 0004BC
   VCID: 38292C04825E5CCBAA3-806C
   Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
   Component: E221 - MFL  H09 0009
   Serial number: 24 09 2011  33135252
   Part No SW: 4H0 920 880 E    HW: 4H0 920 880 E
   Component: TBenUSAACCNV- H71 0416
   Revision: 32081056    Serial number: 658181111593055
   Coding: 0B4608015700D705020000
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K_AU64.rod
   VCID: 2C0100544686E06BDEB-8078
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
   Component: Analoguhr D4  H05 0224
   Serial number: 1111114000307
   Part No SW: 4H0 907 468 G    HW: 4H0 907 468 C
   Component: J533--Gateway H08 0214
   Revision: --------    Serial number: 00000000312523
   Coding: 00C1034A00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 3537253095CCA1A3B15-8060
   Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650973673
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
   Component: Klima Fond    H16 0071
   Coding: 0000000000
   ASAM Dataset: EV_AirCondiHeck 001039
   ROD: EV_AirCondiHeck.rod
   VCID: 313F112061A48D83EDD-8064
   Part No SW: 4H0 907 553 C    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H17 0096
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003022
   ROD: EV_AirSuspe_VW51.rod
0264 - Data Set Implausible
          B2012 00 [008] - -
                    Reset counter: 147
          C10C8 00 [008] - -
                    Reset counter: 134
                    Mileage: 128559 km
                    Date: 2020.09.28
                    Time: 08:24:30
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000018398499
   Coding: C018BF8085853201030001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637     HW: 4H0 907 637
   Component: SARA 6D       H02 0015
   Revision: --------    Serial number: EJ1BPA31013V4.0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 6C81C0548606206B9EB-8038
   Part No SW: 4H0 907 566 A    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0030
   Revision: 00H02000    Serial number: 6PZ 010 287-07
   Coding: 0000002
   VCID: 2E050A5C7C1A927BF0F-807A
   Subsystem 1 - Part No: 4H0 907 568 A
   Component: J770  SWA Slave H02 0030
   Subsystem 2 - Serial number: 6PZ 010 287-27
   Subsystem 3 - Serial number: 5F12.11.1100H020003CX20648ÿ
   Subsystem 4 - Serial number: X20648ÿ
   Part No SW: 4H0 959 793 G    HW: 4H0 959 793 G
   Component: TSG FA        H06 0261
   Revision: --------    Serial number: 0000122254241
   Coding: 011F1F005E0062C202003017
   Shop #: WSC 02312 785 00200
   VCID: 3D273D10AD7C79E3795-8068
   Revision: 00002001    Serial number: 0163912770
   Coding: 0106023A00FA759FB0B0C780020301000000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0070
   Serial number: 00000000000000056948
   Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J245  007C  H06 0005
   Serial number: 144600009617
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 BR    HW: 4H0 947 135 BR
   Component: Dachelektroni  H11 0080
   Serial number: A2011000000000505955
   Coding: 070000
   Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J394  0014  H06 0005
   Serial number: 144500008734
   Coding: 020200
   Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J392  006A  H06 0005
   Serial number: 144600009608
   Coding: 020200
   Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J867  00E0  H06 0005
   Serial number: 144500008737
   Coding: 020200
   Subsystem 8 - Part No SW: 3AA 962 243     HW: 3AA 962 243
   Component: GEB.F.Heckoef  H12 0719
   Serial number: 84182754
   Part No SW: 4H0 035 465 A    HW: 4H0 035 465 A
   Component: BO G3 D4      H07 0150
   Revision: 05S00000    Serial number: 0016342
   VCID: 2411E8742ED6282B16B-8070
   Subsystem 1 - Part No SW: 4H0 035 466     HW: 4H0 035 466
   Component: BO D4 SLAVE  H51 0180
   Serial number: 00408110006300
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
                    Voltage: 12.00 V
                    Temperature: 39.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.00 V
                    Temperature: 37.0°C
                    Bin. Bits: 10000011
                    Bin. Bits: 00000000
Address 48: Seat, Rear, DS (J876)       Labels: None
   Part No SW: 4H0 959 860     HW: 4H0 959 860
   Component: MEM-FS-Fond   H06 0155
   Revision: AA000000    Serial number: 00000017259123
   Coding: 001892800000300D0A00392038193A2039203B3B202020
   VCID: 71BFD120A1A4CD83ADD-8024
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H06 0261
   Revision: --------    Serial number: 0000122055465
   Coding: 011F1F005E0062C202003007
   VCID: 3C213014B66670EB4EB-8068
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000196645
   ROD: EV_ParkiBrake_VW51.rod
331008 - Function Restricted due to Missing Message(s)
          U1111 00 [000] - -
          [FC_KOMBI_02_MESSAGE_TIMEOUT]
462848 - Function Restricted due to Missing Message(s)
          U1111 00 [000] - -
          [FC_SIGNAL_KOMBI_02_ALT_OUT_OF_DATE]
465152 - Function Restriction due to Faults in Other Modules
          U1113 00 [000] - -
          [FC_SIGNAL_DI_KL58D_ERROR_VALUE]
467456 - Function Restricted due to Missing Message(s)
          U1111 00 [000] - -
          [FC_SIGNAL_UHRZEIT_01_ALT_OUT_OF_DATE]
   Part No SW: 4H0 035 082 B    HW: 4H0 035 082
   Component: Radio U SIRIU H53 0076
   Revision: AB001007    Serial number: 155K%0B7516275
   Coding: 020007010003000001
   VCID: 2019E4643ACE340B723-8074
Address 5B: Seat,Rear,PS (J877)       Labels: None
   Component: MEM-BFS-Fond  H06 0155
   Revision: AA000000    Serial number: 00000017259136
   Coding: 001896800000300D0A00392038193A2039203B3B382020
   Part No SW: 4H0 035 746 K    HW: 4H0 035 746
   Component: H-BNT-NA      H48 0939
   Revision: --------    Serial number: 035KX0B7505163
   Coding: 020100000001F9EF7D168B1E00000003140001000000000000
   Shop #: WSC 25807 444 183079
   VCID: 303914246A2E848BE23-8064
   Subsystem 1 - Part No: 8R0 060 884 DF
   Component: EUR 2016  2204
   Subsystem 2 - Part No SW: 4H0 919 604 D    HW: 4H0 919 604 D
   Component: DU8 D4 SV NB  H47 0021
   Serial number: AUZ8ZDB6900HC7L
   Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000060170
   Component: CD-Database  3371
                    Reset counter: 121
                    Mileage: 129449 km
                    Date: 2020.10.19
                    Time: 13:12:13
                    Text: DU902A,,D,0,0,6
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H06 0262
   Revision: --------    Serial number: 0000122243418
   Coding: 010F1F00420062C202003007
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4H0 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H04---    Serial number: 525 PA8J1YD0II
   Coding: 1080003
   Shop #: WSC 02391 785 00200
   VCID: 2615F27C54EADA3B08F-8072
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 R    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0039
   Revision: 10011001    Serial number: 315100229
   Coding: 0210044100
   ASAM Dataset: EV_DeckLidContrUnit 001025
   ROD: EV_DeckLidContrUnit.rod
   VCID: 3D273D10ADFC79E3795-8068
0051 - Hall Sensors in Motor 1 for Rear Lid
          B1211 12 [008] - Short to Plus
                    Fault Frequency: 59
                    Reset counter: 161
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
                    Voltage terminal 30: 12.15 V
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000050969
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6393AB686BD86F132F1-8036
   Component: TSG HR        H06 0262
   Revision: --------    Serial number: 0000122243415
Address 7F: Inform. Electr. II (J829)       Labels: None
   Part No SW: 4H0 035 774 E    HW: 4H0 035 774
   Component: H-BN-NA       H48 0424
   Revision: --------    Serial number: 108JW0B7502642
   Coding: 02020000000100400100000400001300E00000000000000000
   VCID: 2B0303484308E753D71-807E
   Subsystem 1 - Part No SW: 4H0 919 607     HW: 4H0 919 607
   Component: DU10 RSE  H41 0021
   Serial number: AUZ8ZDB1200HSW7
   Subsystem 2 - Part No SW: 4H0 919 607     HW: 4H0 919 607
   Serial number: AUZ8ZDB1200HSY9
   Subsystem 3 - Part No SW: 4H0 919 709 C    HW: 4H0 919 709 C
   Component: E499 BDT 2  H07 0019
   Serial number: 90238KK80002Q
   Subsystem 5 - Part No: 8R0 060 884 AD
   Component: NAR 2011  0505
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H08 0083
   Revision: 0L0D5013    Serial number: SN111019  0219
   ROD: EV_GSM2x3Mono_AU64.rod
   VCID: 2B0303484388E753D71-807E
Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
   Part No SW: 4H0 907 547 E    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H09 0028
   Serial number: 0K84AE40053965
   Coding: 1200
   ASAM Dataset: EV_NightVisioGen1 001002
   ROD: EV_NightVisioGen1.rod
   Night vision system camera:
   Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
   Component: NV-CAM-Gen1  H08 0007
   Serial number: 00000000001129200453
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H25 0036
   Coding: E9060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 6597B57065EC1123C15-8030
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00003629027601
   Coding: 764FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2F3B175877909B73FB9-807A
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00003629023301
   Coding: 364FF2
Address 8A: Multicont. Seat Rear,DS (J875)       Labels:* None
   Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
   Component: IVB           H08 0042
   Serial number: 00003626084202
   Coding: 200F00
   ASAM Dataset: EV_IVBDriveSideRear 001003
   VCID: 2E050A5C709A927BF0F-807A
   Part No SW: 4H0 907 541 A    HW: 4H0 907 541
   Component: ACC3          H15 0160
   Coding: 3601020201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
   ROD: EV_AdaptCruisContr2AU64X_001.rod
   VCID: 270BFF785F60C333339-8072
10 Faults Found:
          U1111 00 [008] - -
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.12
                    Time: 06:53:05
                    Control Module temperature: 16 °C
                    Voltage terminal 15: 13.357 V
                    Velocity_vehicle_reference: -0.00 m/s
          U1111 00 [008] - -
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
                    Control Module temperature: 20 °C
                    Voltage terminal 15: 13.897 V
          U1111 00 [008] - -
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
                    Voltage terminal 15: 14.203 V
          U1113 00 [008] - -
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
                    Voltage terminal 15: 11.993 V
          U1111 00 [008] - -
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
                    Voltage terminal 15: 13.938 V
          U1111 00 [008] - -
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
          U1111 00 [008] - -
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
          U1113 00 [008] - -
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
                    Voltage terminal 15: 14.094 V
144896 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_US_FAIL]
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
                    Voltage terminal 15: 13.956 V
          U1113 00 [008] - -
                    Fault Frequency: 8
                    Reset counter: 162
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
Address 8D: Multicont. Seat Rear,PS (J874)       Labels:* None
   Serial number: 00003626081902
   Coding: 200F00
   ASAM Dataset: EV_IVBPasseSideRear 001003
   Part No SW: 4G0 907 107 D    HW: 4H0 907 107
   Component: BV-SG         H30 0038
   Serial number: 005000051511117
   Coding: 02A19A000111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 0066F609031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   VCID: 323D1E2C64A2B69B947-8066
End----------(Elapsed Time: 03:37, VBatt start/end: 14.3V/14.6V)-----------
South Molton, UK
There are lots of Fault Frequency=1 and Not Confirmed faults with dates from several days ago, the first step is to clear all fault codes so you/we can see which ones are current.
mark07eur
DE, USA
C?ID=420545
Thanks for the advice, I was hesitant at first to clear everything. After the clearing the DTC's and scanning again. Only 2 faults showing as confirmed. When the car is cold, the transmission does seem to shift hard and late in my opinion. Once everything warms up that seems to go away. Would the Thermostat transmission fault code cause that?
appreciate it
Thursday,05,November,2020,16:52:20:56688
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VirtualBox)
VCDS Version 20.4.2.0  HEX-V2 CB: 0.4513.4
          8B 8D 8E 8F 90
VIN: WAURVAFD8CN020736   Mileage: 129794km-80650miles
   Revision: N5H07---
   VCID: 2A0D064C4C72FE5B2C7-807F
                    Mileage: 129534 km
                    Date: 2020.10.30
                    Time: 18:20:58
                    Coolant temperature: 96 °C
                    Intake air temperature: 58 °C
                    Voltage terminal 30: 12.557 V
                    AFS dm: 0.0 kg/h
                    Mileage: 129534 km
                    Date: 2020.10.31
                    Time: 11:06:55
                    Engine speed: 1241.00 /min
                    Normed load value: 38.0 %
                    Coolant temperature: 15 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 12.981 V
                    AFS dm: 64.1 kg/h
                    Median injection timing: 1.848 ms
   Revision: --H08---
   Coding: 000002
   VCID: 015F81E09184DD035DD-8055
   VCID: 343118349EB6B8AB86B-8061
   VCID: 6E85CA5CB09AD27BB0F-803B
   VCID: 35372530954CA1A3B15-8061
   Coding: 488122BECC
   VCID: 2517F570256CD123015-8071
   Coding: 0045F7
   Coding: 025523
   Coding: 100000
   Coding: 100000
   Coding: 020300
   Revision: AA001001
   Coding: 020000
   VCID: 221DEE6C34C2261B647-8077
02261 - Data Medium
            014 - Defective
                    Fault Frequency: 23
                    Reset counter: 139
                    Mileage: 129534 km
                    Date: 2020.10.30
                    Time: 18:20:05
                    Text: 00000000
   Coding: 280902
   VCID: 3B233308B3E877D3471-806F
   Coding: 3601020201
   VCID: 290FF9404974F54325D-807D
   VCID: 372B2F388FC053B3A39-8063
   Coding: 0004BC
   VCID: 38292C04825E5CCBAA3-806D
   Coding: 034608015700D705020000
   VCID: 2C0100544686E06BDEB-8079
   Analog_clock:
   Coding: 00C1034A00
   VCID: 3537253095CCA1A3B15-8061
   Coding: 0000000000
   VCID: 313F112061A48D83EDD-8065
   Coding: 008002
   VCID: 6C81C0548606206B9EB-8039
   Coding: 0000002
   VCID: 2E050A5C7C1A927BF0F-807B
   VCID: 3D273D10AD7C79E3795-8069
   Coding: 020200
   Coding: 070000
   Coding: 020200
   Coding: 020200
   Coding: 020200
   VCID: 2411E8742ED6282B16B-8071
                    Reset counter: 179
                    Mileage: 122626 km
                    Date: 2020.08.11
                    Time: 19:19:07
                    Voltage: 12.00 V
                    Temperature: 39.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.00 V
                    Temperature: 37.0°C
                    Bin. Bits: 10000011
                    Bin. Bits: 00000000
   VCID: 71BFD120A1A4CD83ADD-8025
   VCID: 3C213014B66670EB4EB-8069
   VCID: 2019E4643ACE340B723-8075
   VCID: 303914246A2E848BE23-8065
                    Reset counter: 132
                    Mileage: 129534 km
                    Date: 2020.10.30
                    Time: 18:19:18
                    Text: DU902A,Front,M,0,0,6
   Coding: 1080003
   VCID: 2615F27C54EADA3B08F-8073
   Revision: 10011001    Serial number: 171100149
   Coding: 0210044000
   VCID: 3D273D10ADFC79E3795-8069
0014 - Supply voltage
          [Versorgungsspannung dauerhaft zu niedrig]
                    Reset counter: 135
                    Mileage: 4770 km
                    Date: 2016.07.20
                    Time: 16:56:32
                    Voltage terminal 30: 6.32 V
   ROD: EV_Ambie.rod
   VCID: 6393AB686BD86F132F1-8037
   VCID: 2B0303484308E753D71-807F
   VCID: 2B0303484388E753D71-807F
   Coding: 1200
   Coding: E9060000
   VCID: 6597B57065EC1123C15-8031
   Coding: 764FF2
   VCID: 2F3B175877909B73FB9-807B
   Coding: 364FF2
   Coding: 200F00
   VCID: 2E050A5C709A927BF0F-807B
   Coding: 3601020201
   VCID: 270BFF785F60C333339-8073
   Coding: 200F00
   ROD: EV_BC7.rod
   VCID: 323D1E2C64A2B69B947-8067
End----------(Elapsed Time: 03:39, VBatt start/end: 14.7V/14.8V)-----------
Two actuators, both showing "Open Circuit". Get out your wiring diagram and see if they have anything in common, for example a ground or a source of power.
