Understanding battery check results.
Gooders
C?ID=259138
Hello
I have checked my battery using section 19 and wondered if any one could shed some light on my results? I have used the wiki and not found anything to explain them. I have had no faults related to the battery, I do have a glow plug code which I think requires plug replacement p0671 cyl 1 glow plug circuit. note I have just completed a 200mile drive so would expect the voltage to be higher, that said I have never been good with elects.
the battery says it’s a moll de mla 12v 520a 110Ah din 850a EN/SAE. Would the 44Ah result mean it’s going to need replacement soon?
logged results
018
11.800v battery voltage
-20,8 a battery current
10.0 deg c bat temp
8.0 deg c bat temp amb
019
81.0 % battery state of charge soc
100.% battery state as show on Mmi (can’t see on screen)
53.0% battery aging derived from load
75.0 % battery aging derived from output
020
4.4 Mohm internal battery resistance actual
3.8 Mohm internal battery resistance Stan
44Ah battery capacity actual available
12.60 v quiescent voltage
gooders
It might be useful if we knew more about the car. If you've posted an Auto-Scan from it, please link to it. If you haven't posted one, please do.
Gooders
C?ID=259138
I copied all from the logs, I will complete a engine running check and post results
