Long coding ABS MK60EC1
Mario8080
Poland
C?ID=355715
The pump has lost the coding, please help
Tuesday,27,October,2020,15:50:41:51259
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
Dealer/Shop Name: ELMAR
VIN: WVWZZZ13ZDV003467   License Plate:
Chassis Type: 13-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 55 56
VIN: WVWZZZ13ZDV003467   Mileage: 136090km-84562miles
Address 01: Engine (J623-CFHC)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 AN    HW: 03L 907 309 R
   Component: R4 2,0L EDC   H25 9015
   Revision: 42H25---    Serial number:
   Coding: 00190012042400080000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM20TDI01103L906018AN 003008
   ROD: EV_ECM20TDI01103L906018AM_003_VW36.rod
   VCID: 76A0E721C90F063639-8022
   Revision: 00H31001
   Shop #: WSC 33361 790 00053
   VCID: 7DB2F80DE439556E78-8028
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 113
                    Mileage: 136093 km
                    Date: 2015.03.20
                    Time: 16:42:04
                    Count: 7
                    Count: 2
                    Count: 20480
                    Count: 288
                    Count: 41728
                    Count: 256
                    Count: 65024
                    Reset counter: 113
                    Mileage: 136093 km
                    Date: 2015.03.20
                    Time: 16:42:04
                    Count: 7
                    Count: 2
                    Count: 20480
                    Count: 195
                    Count: 41728
                    Count: 256
                    Count: 65024
                    Fault Status: 01100101
                    Reset counter: 113
                    Mileage: 136093 km
                    Date: 2015.03.20
                    Time: 16:42:03
                    Count: 2
                    Count: 2
                    Count: 20480
                    Count: 279
                    Count: 41728
                    Count: 256
                    Count: 65024
                    Reset counter: 113
                    Mileage: 136093 km
                    Date: 2015.03.20
                    Time: 16:42:03
                    Count: 2
                    Count: 2
                    Count: 20480
                    Count: 295
                    Count: 41728
                    Count: 256
                    Count: 65024
                    Reset counter: 113
                    Mileage: 136093 km
                    Date: 2015.03.20
                    Time: 16:42:03
                    Count: 2
                    Count: 2
                    Count: 20480
                    Count: 270
                    Count: 41728
                    Count: 256
                    Count: 65024
   Part No SW: 3AA 907 044 AF    HW: 3AA 907 044 AF
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0010004002
   VCID: 74A4DD29DF73142607-8020
          B10AB F0 [009] - Too Low
                    Reset counter: 113
                    Mileage: 136093 km
                    Date: 2020.10.27
                    Time: 16:42:03
   Part No SW: 5K0 937 087 R    HW: 5K0 937 087 R
   Component: BCM PQ35 H    021 0068
   Revision: BE021001
   Coding: 40180A3888250A00400800C0340049E44BD50A88736D8120648000000040
   Shop #: WSC 00020 790 00000
   VCID: 44C44DE9C753E4A677-8010
   Subsystem 1 - Part No SW: 1K8 955 119 F    HW: 1K8 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 21051  10  0603
   Coding: 009795
   Component: RLS 090612 05  54  0403
   Coding: 0230ED
                    Reset counter: 113
                    Mileage: 136093 km
                    Date: 2015.03.20
                    Time: 16:42:48
                    Voltage: 11.55 V
Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
   Part No SW: 1K0 919 475 L    HW: 1K0 919 475 L
   Component: PARKHILFE     006 1806
   Revision: 00006000    Serial number: 0 263 004 450
   Coding: 108001
   VCID: 3B363615BAAD9B5E06-806E
   Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
   Component: 0G AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 003D1D04ZLVZ
   Coding: 0012359
   VCID: 6FAED2457E5537FEFA-803A
   Subsystem 1 - Serial number: 6332MSME6C421477E
   Subsystem 2 - Serial number: 6342MSME6C5142079
   Subsystem 3 - Serial number: 6352QSME0C15237EL
   Subsystem 4 - Serial number: 6362QSME23175672B
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: 20120609300506
   Coding: 1082140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79BAEC1DF811694E54-802C
   Component: E221__MFL-TAS  H31 0033
   Coding: 820000
   Part No SW: 1K8 920 874 A    HW: 1K8 920 874 A
   Component: KOMBI         H05 0705
   Coding: 170F01
   VCID: 33261E359AFD531EDE-8066
   Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
   Component: J533  Gateway H42 1632
   Revision:   H42       Serial number: 050612F2000307
   Coding: 354000
   VCID: 3FCE4205AEB5877E2A-806A
   Component: IMMO          H05 0705
   VCID: 6A98C3518DB7D2D6AD-803E
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662772002
   Coding: 020100
   VCID: 2A180351453712D66D-807E
   Part No SW: 3C0 035 279 N    HW: 3C0 035 279 N
   Component: RNS315-EU   H52 0319
   Serial number: VWZAZ2M5919411
   Coding: 04000411040004000000900C
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 2E100F4171DF7EF6B1-807A
   Component: EUR_W_0038  0038
   Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
   Component: Tuer-SG         009 2129
   Coding: 0020535
   VCID: 393A2C1D7091A94E14-806C
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
   VCID: 373E2A254685BF3EE2-8062
   Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
   Coding: 0020790
   VCID: 3A3833117597A2561D-806E
   Part No: 8P0 907 357 K
   Coding: 0000015
   VCID: 42C84BF11D47EA9645-8016
End----(Elapsed Time: 01:00, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
How did it lose its coding? What parts have been replaced? Is the VIN shown in the scan the correct one for the car?
Mario8080
Poland
C?ID=355715
The pump has been changed
Yes vin is valid
Bump on behalf of the OP...
iichel
Eindhoven, NB, NL
C?ID=284912
Gone But Not Forgotten
For Uwe and Iichel,
Vehicle Identification No.WVWZZZ13ZDV003467
ModelScirocco 2.0
SCI
Date of production27.06.2012
Model year2013
Sales type137262
Engine CodeCFHC
Transmission CodeNFP
Hill hold.
ABS module correct application.
Mario8080
Poland
C?ID=355715
Well done iichel coding matched
